[Plugin] FloorGenerator ( Updated 6-Apr-2017)
Floor Generator Gap in one/two directions?
Postby deaneau » Sat Oct 04, 2014 5:18 am
Hallo is this possible?
green arrows mean only this direction(s) i want
selected multiple face doing this in one step
here what i have choose in preferences
the wall in the backbround is a curved object.
the result is this
reason could be that a curved face is splitted in smaller face like this
the wall part i want produce have an exact width of 1200mm (3' 11")
or have anybody an other solution?
download this file here
https://drive.google.com/file/d/0B9ET1G ... sp=sharing
the curved face havn´t the exaxt width :-/
thank you
MADE, BORN AND LIVING IN BERLIN
Big Thank You to all Programmers
Some German words are so long that they have a perspective. M.Twain
deaneau
Re: [Plugin] FloorGenerator (Updated 21-Sep-2014)
Postby sdmitch » Sat Oct 04, 2014 2:35 pm
Sorry but FloorGenerator only works on faces not surfaces. Even if hidden geometry is not displayed, when you pick a point on the surface you select just one of the faces that make up the surface.
You could create a face with the overall dimensions of the surface. Then use Shape Bender to produce the curved surface after applying the tile pattern. A bit of work but all I can offer at this time.
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby deaneau » Sat Oct 04, 2014 4:21 pm
sdmitch wrote:Sorry but FloorGenerator only works on faces not surfaces. Even if hidden geometry is not displayed, when you pick a point on the surface you select just one of the faces that make up the surface.
yes this i have try before i asking here, with Fredo Scale ( Radial Bending)
what you mean is Chris Fullmer Shape Bender.
i have never tried it before.
ok, this work.
now i have a problem. the segments have not the exact lenght.
your plugin AddPts2Curve was my help, to see where on the curve is the 1,2m point and the next etc.
I will try step by step all your plugins.
Helper like plugins will every time be welcome.
thank you
deaneau
Postby tomot » Sun Oct 05, 2014 6:41 pm
@sdmitch Its the first time I see HTML code embedded in a Ruby script. Thanks for not using .rbs
It gives me some confidence and a template to redo some of my scripts incorporating HTML. :bounce:
Finally I have an example & see how with HTML I can place pictures next to my drop-down boxes.
cheers!
tomot
PluginStore Author
PluginStore Author
Postby sdmitch » Mon Oct 06, 2014 12:51 am
That's the way I learned what little I know.
sdmitch
PluginStore Author
PluginStore Author
Postby deaneau » Tue Oct 07, 2014 9:40 pm
Hello Sam,
is it possible to insert the feature that tiles is grouped?
actually if i generate a floor i have only a main group.
when tiles is grouped i can do random rotate with mover2.
this will look a little bit more inperfect.
in mover i can use random rotation in x,y or z axis and can insert the degree by value.
thank you
Dean
deaneau
Postby sdmitch » Wed Oct 08, 2014 2:57 pm
deaneau wrote:Hello Sam,
Do you mean each individual brick is a group?
That is what the "Random Imperfections" option is for. That feature was fixed and enhanced in the last update on 21-Sep
thank you
Dean
sdmitch
PluginStore Author
PluginStore Author
Postby deaneau » Wed Oct 08, 2014 4:27 pm
the random inperfection rotate in all axis.. some times i would have only a rotation in z-axis. a value in degree is helpful.
when all tiles would be in own group..so i could work with mover2 and in the last step ungroup this tiles.
ungrouping go faster than grouping if i have tiles more than 1000+ .
thank you
deaneau
Random Rotation
Postby deaneau » Thu Oct 09, 2014 6:50 am
i have seen your plugin "Random Rotation".
in this plugin you could insert 3 checkmarks for x y z-axis.
so i have the control for axis. actually looks that the rotation work in all axis.
like this
deaneau
Re: Random Rotation
Postby sdmitch » Thu Oct 09, 2014 4:23 pm
deaneau wrote:i have seen your plugin "Random Rotation".
like this
That plugin is for rotating whole components or groups not individual entities within the component or group.
sdmitch
PluginStore Author
PluginStore Author
Re: Random Rotation
Postby deaneau » Thu Oct 09, 2014 7:43 pm
yes ..ok no problem
deaneau
[REQ]Prefix for Random Textures in Floor Generator
Postby deaneau » Tue Oct 14, 2014 9:44 am
Hello Sam,
i have a project for this i would use your FloorGenerator.
i know that you have a random textur feature in this plugin.
what do you think about to integrate a feature that doing follow:
i have 10 different pattern and i would use 10 different texture packs.
a approach to solving this problem could be that all textures have a prefix.
for example.
A_Texture1,A_Texture2,A_Texture3 etc
B_Texture1,B_Texture2,B_Texture3 etc.
A_ B_ C_ etc is the prefix.
Texture1, Texture2 is a placeholder for my own given name.
when i use in the first step the Tile Pattern and i will use a texture pack A_
dropdown menue let me choose the Prefix A_
in the next step i would use Brick Pattern with TexturePack B_
i choose only in the dropdown the Prefix B_
this textures with a given Prefix i want use for your Random texture feature.
actually i must change the textures in the texture folder when i want have different textures in the next step.
if the floor is generated i would have all parts in own groups.
actually the floors is only in one main group.
why i would have this features.
the workflow after integrating this feature would be more faster and when the objects is in own groups i can animate this in other programs.
download here
thank you
p.s.component is better than groups i think
deaneau
Postby deaneau » Sat Oct 18, 2014 9:25 am
Hello,
i have had a problem with random texture.
my result was this:
after renaming all textures with a prefix i have solve this problem
result:
here a example for file renaming:
and here a freeware to remame files with your favorit prefix etc.
http://www.advancedrenamer.com/download
:thumb: :thumb: many thanks at Sam for the hard work for the Floor Generator :thumb: :thumb:
deaneau
Postby deadakos » Tue Nov 04, 2014 7:42 pm
I was looking for such a tool for SketchUp so long! Thanks for it!
I'm playing with the plugin now, and I have a questions:
- is there a way to limit the used quantity of the colors in "Rand_clr" mode?
deadakos
Postby sdmitch » Wed Nov 05, 2014 3:10 pm
Sorry but no.
sdmitch
PluginStore Author
PluginStore Author
Postby logan683 » Wed Feb 11, 2015 2:59 am
What is the latest version of this plugin? This is different than the one downloaded straight from the SketchUcation store in SU.
Also, you can't change the size of the pattern?? I want to set a 10' long wood board pattern, but it's stuck on 10" and won't accept any changes.
Does this work correctly at all?
logan683
Postby sdmitch » Thu Feb 12, 2015 5:08 pm
logan683 wrote:What is the latest version of this plugin? This is different than the one downloaded straight from the SketchUcation store in SU.
21-Sep-2014 is the latest version. The plugin is setup for inches or millimeters so 10' is not valid, enter 120 instead.
sdmitch
PluginStore Author
PluginStore Author
Postby lothian » Fri Mar 06, 2015 6:55 pm
This tool has the potential to be an indispensable time-saving utility for visualizing tile layout. For example, the capability to use the actual images of tile to visualize their position within a layout is absolutely wonderful. As one who sees the prospect of this utility, I offer the following feature suggestions to extend its usefulness even further:
1) Add a 'Pattern Reset' button.
Move pattern reset from its present location under the pattern drop menu to its own dedicated button on the main options palette.
2) Save current settings when the plugin closes.
Presently, settings reset to default when the FloorGenerator plugin closes.
3) Add the option to prevent "texture adjacency".
This suggestion requires some explanation. Applies to tile with images/patterns/designs, where 1) images/patterns/designs are randomly distributed within a grid BUT, 2) images/patterns/designs must not be adjacent. Presently, the FloorGenerator plugin's randomization permits instances where two identical textures are adjacent. Allow the option to prevent any instance from occurring where the same tile is adjacent along horizontal, vertical or diagonal axes. This option would only be relevant above a certain min. threshold of unique tiles. This ability is, in my opinion, the most important potential feature of the plugin.
4) Add a "1:1 Texture Scale" button.
A button that instantly matches tile size values to tile image at 1:1 would be a valuable convenience.
5) Add a material selection browser box.
Replace the current requirement of coping tile texture images to a specific location (within the plugin folder) with the ability to browse and select any custom location. That location is saved when the plugin is closed.
lothian
Postby sdmitch » Sat Mar 07, 2015 5:06 pm
lothian wrote:This tool has the potential to be an indispensable time-saving utility for visualizing tile layout. For example, the capability to use the actual images of tile to visualize their position within a layout is absolutely wonderful. As one who sees the prospect of this utility, I offer the following feature suggestions to extend its usefulness even further:
1. The current "Reset" option, returns all patterns to there default settings and was something I assumed would be rarely used. I guess that's not the case for you?
2. The individual "Pattern" settings are maintained from session to session. The only thing not currently retained is the Pattern Option itself which defaults to Tile. If this is not the case for you, perhaps you have an old version? I will add code to save last Pattern selected.
3. An easy thing to see visually but would be a major task to code I think.
4. Could be applicable to some Patterns but not all. I will give it some thought.
5. This is something I did sometime ago. Guess I forgot to post that version.
sdmitch
PluginStore Author
PluginStore Author
Re: [Plugin] FloorGenerator (Updated 7-Mar-2015)
Postby rhinoferoce » Tue Apr 14, 2015 10:10 am
Hello ! I would love to try this plugin that seems very helpful, but I'm unable to find it within the pluginstore (toolbar or website).
Can you help me to find it ?
Thank you very much...
rhinoferoce
Postby driven » Tue Apr 14, 2015 1:03 pm
did you try Sam's website?
john
driven
PluginStore Author
PluginStore Author
Postby arqjonatan » Mon Apr 27, 2015 1:03 am
Hello, i want to ask, is this plugin already avalible for sketchup 2015?
arqjonatan
Postby TIG » Tue Apr 28, 2015 12:05 pm
arqjonatan wrote:Hello, i want to ask, is this plugin already avalible for sketchup 2015?
In its PluginStore listing 'More Info' it says,
Compatibility: Pre-8, v2013, >=v2014
Since 2015 is > 2014 seems to me it will be !
Global Moderator
Postby sepo » Fri May 01, 2015 10:04 am
Maybe stupid but how do you rotate direction of the floorboards. However I try I get same direction.
sepo
Postby sdmitch » Fri May 01, 2015 3:09 pm
sepo wrote:Maybe stupid but how do you rotate direction of the floorboards. However I try I get same direction.
By using the Grid Rotation option of 0,45,90. 0 and 90 usually work without a problem, but for some reason yet to be determined, 45 often fails. The 0 option always causes the pattern to be aligned with the longest side of the face.
sdmitch
PluginStore Author
PluginStore Author
Postby sepo » Fri May 01, 2015 8:26 pm
OK, tried it and did not work for me. O makes it on the short side....will try to redraw the geometry and see what comes out of it. thanks
sepo
Postby sdmitch » Fri May 01, 2015 8:59 pm
sepo wrote:OK, tried it and did not work for me. O makes it on the short side....will try to redraw the geometry and see what comes out of it. thanks
If you are unable to achieve the results you want, please post or PM the file to me. Please save as version <=2014.
sdmitch
PluginStore Author
PluginStore Author
Postby sepo » Sun May 03, 2015 12:30 pm
Today I tried again the same geometry and it worked...joys of computing..
How do you go about texturing individual boards without going into each board? Is this actually possible? What I have done so far applied texture to whole face and than executed plugin. BTW great plugin. Much nicer than working with displacement in render time.
sepo
Postby sdmitch » Sun May 03, 2015 1:58 pm
sepo wrote:Today I tried again the same geometry and it worked...joys of computing..
Something I have experienced many times.
The original face is sub-divided by a grid and new faces created to create the width and depth of the gaps. These new faces don't automatically inherit the material of original face so it is necessary to apply the desired material to each new face. Applying the material to the original face only defines that material as the current material.
sdmitch
PluginStore Author
PluginStore Author
Postby thirdleft » Wed May 06, 2015 12:56 pm
Sdmitch This plugin is AMAZING! I am surprised it is free! the more i use it the more powerful i find it.
One thing that would be really great to see is a randomflip to the textures option. This would increase the quality of rendering substantially.
Great job again!
thirdleft
PreviousNext
Return to Plugins
Users browsing this forum: emirsaritas and 12 guests
