[Plugin] S4U ScaleTool
• Page 1 of 1
[Plugin] S4U ScaleToolS4u_ScaleTool:
Current version: v3.0.0 http://sketchucation.com/pluginstore?pln=s4u_scaletool http://extensions.sketchup.com/en/content/s4u_scaletool Tutorial video: https://www.youtube.com/watch?v=ofgDbH8 ... lQktNvlhUW Update v3.0.0 -Display units -Optimize code -Save input user Update v2.0.2 : Decimal symbol "." or "," is OK now. -Select groups or components for scale or push/pull distance(x,y,z axis). -Scale Fix length(x,y,z axis). -Reset scale. Last edited by hdpv on Wed Sep 17, 2014 2:59 am, edited 5 times in total.
Suforyou
http://www.sketchupforyou.com
Re: [Plugin] S4U ScaleToolnice, but how about scaling in other directions, x & y, and scaling from corner
Re: [Plugin] S4U ScaleToolIn other directions wait next version,scaling corner is too detail , i think no need
Suforyou
Re: [Plugin] S4U ScaleToolVery handy for changing the multiple levels. very nice.
Re: [Plugin] S4U ScaleToolI am interested to see how this develops. Good work
![]() I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] S4U ScaleToolThanks all!
![]() Update S4U ScaleTool v2.0.0 scale x,y,z axis. Suforyou
Re: [Plugin] S4U ScaleToolIs it possible to implement "flip along" functions similar to the way scale works in this tool? I love how it scales multiple components at its own origin rather than as a whole.
I have tried giving -1 values to scale to produce "flipped along effect", but it isn't the same result as native tool's function. Re: [Plugin] S4U ScaleTool"flip along" for multiple components use s4u-Transformer : set base center and scale ratio -1
http://extensions.sketchup.com/en/conte ... ransformer but it must purchase ![]() Suforyou
okay, thank you. Re: [Plugin] S4U ScaleToolIs it possible to add following mode:
1. on preselected geometry, run the script. 2. select edge (if it was clicked in upper area (A) it will scale 'upward', if in lower (B) it will scale 'downward' 3. click desirable level. 4. preselected geometry get scaled up to the 'C' level. Re: [Plugin] S4U ScaleTool
What is the difference with use of the normal native Scale Tool of SU ? ![]() Or even FredoScale ? ![]() It's less simple! ![]()
Re: [Plugin] S4U ScaleToolscale the all cubes (by Z axis) at once to the top of cylinder
Re: [Plugin] S4U ScaleToolSorry I don't see the problem!
![]() That will be the same if I select all the cubes! And it's not a good idea to make groups! ![]() As soon as you have 2 similar objects make a component! ![]() See here you have a file of 1,6 megas The same with component is 28O kB so quasi X/6 ! ![]()
Re: [Plugin] S4U ScaleToolWhy don't you publish the gif with standard scale acting? Lately you tried to covince me how splendid standard scale tool is.
Look I know how standard\fredo scale work and find it inappropriate in many cases (mainly because it demands too much stupid navigation efforts to find the right grip\ target point (and in many cases it tend to disappear completely). My ideal workflow eliminates the successive zooming in\out altogether. Re: [Plugin] S4U ScaleToolYes but in this case you don't use correctly the objects!
It's not the normal way to use mutiple copy of a same group! Even it's working with 780 entities but not 1070 with your curious config that don't work ? Ask Tig, Thomthom, Fredo... And with a component you have just to resize one component! So i suppose the developpers don't imagine your case! Multi numbers of tinies groups! ![]()
Re: [Plugin] S4U ScaleToolI don't get it,why keep on cheating non-stop. There's indeed a bug in scale behavior- grips tend to disappear plus it's hard to navigate while scaling distantly scattered objects. Why keep on denying the obvious?
P.S. Please scale 2! (just 2) cubes in Z dir up to the big prism top with standard scale tool.
• Page 1 of 1
Users browsing this forum: salman1618, yoshi_5e8ccds5 and 13 guests
