by philhumphrey » Sun Oct 28, 2018 12:37 am
Hello I am looking to model buoyancy, is there a way to stop an object falling over only buoyancy straight up and down
philhumphrey
- Name: phil humphrey
- Operating system: Windows
- SketchUp version: 8
- License type: Free/Make
- SketchUp use: other
- Level of SketchUp: Beginner
by cristyan » Sun Nov 11, 2018 5:36 pm
Hello philhumphrey ! I have uploaded your file with some modifications. You have to play with density on the house and the buoyant material. and look how joint connection tool works or better you have to play a little with MSPhysics to understand how it works.For this you can download some file on 3dwarehouse searching "MSPhysics".
cristyan
- Name: Cristi Cristian
- SketchUp version: 2013
- SketchUp use: hobby
by pilou » Sun Nov 11, 2018 7:40 pm
A cool site for tuto about MS Physics!
- Top SketchUcator
- Name: Pilou
- SketchUp version: 2017
- Level of SketchUp: Advanced
by tayyab2224 » Fri Nov 16, 2018 6:25 pm
It's been so long when started using Ms physics tool and I have learned so many things from developers but the thing is found on YouTube or over here , is flying an object like helicopter and air plane, J have downloaded a model of an air plane, the plane can fly yeah, sketchyphysics is used in that model, the I want to ask is, how can do that in Ms physics?
M. Tayyab
tayyab2224
- Name: tayyab
- SketchUp version: 2020
- License type: Pro
- SketchUp use: architecture
by Oxer » Thu Feb 07, 2019 7:25 pm
Hi, I installed the new SketchUp 2019 (Trial) to test it and I have obtain one error message in Ruby Console: - Code: Select all
Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb Error: #<IOError: The required, staged c extension file, "/Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/osx64/2.5/msp_lib.bundle", is missing!> /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in `block in require_all' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in `each' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in `require_all' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in `<top (required)>' /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in `require' /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in `require' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in `<top (required)>' /Applications/SketchUp 2019/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `require' /Applications/SketchUp 2019/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `load' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in `register_extension' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in `<module:MSPhysics>' /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in `<top (required)>'
MSPhysics v1.0.3 & AMS Library v3.6.0h SU2019 (Trial) & macOS 10.13.6
Oxer
- Name: Oscar
- Operating system: Mac
- SketchUp use: illustration, cartoons
by Anton_S » Sun Feb 10, 2019 10:14 am
Thanks for letting me know. I sort of intend to rewrite MSPhysics over simply recompiling the libraries, which should take a while.
Anton_S
- PluginStore Author
- Name: Anton
- SketchUp version: 2018
- License type: Pro
by Oxer » Sun Feb 10, 2019 11:28 am
Thanks for the info.
Oxer
- Name: Oscar
by ashhenderson » Tue Apr 16, 2019 3:05 am
Hi there,
Im trying to apply breaking forces's to scaffold components to simulate when it will fail under a set load.
It looks to be possible by setting a breaking force to the fixed joint. the problem im having is the numbers are not making sense, e.g. when i rest a mass of 4kg on a joint with breaking force of 1962N (equal to 200kg of force) it breaks.
Am i messing up the settings?
ashhenderson
- Name: Ash Henderson
- License type: Pro
- SketchUp use: engineering and mechanical design
by Anton_S » Fri Apr 26, 2019 3:50 am
Hello Ash Henderson,
You are not messing anything up. Forces from the fixed joints are indeed incorrect. This is a bug in MSPhysics and I will fix it on the next release.
Thanks, Anton
Anton_S
- Name: Anton
- License type: Pro
by ashhenderson » Sun Apr 28, 2019 5:06 am
Thanks Anton, im looking forward to it!
MS Physics has been great in simulating the failure in overloading or over extending cantilever scaffolds.
Keep up the good work, You are doing a fantastic job!
ashhenderson
- License type: Pro
by alvin meza » Sat May 04, 2019 4:05 pm
este plugin me presenta error en skp ya cargue las librerias y todo pero no me arranca
alvin meza
- Name: educacion
- SketchUp use: education
by TIG » Sun May 05, 2019 1:49 pm
alvin meza wrote:este plugin me presenta error en skp ya cargue las librerias y todo pero no me arranca this plugin presents me with an error in skp and I load the libraries and everything but it does not startPlease post the error messages. Also ensure that your profile's details are up to date. Por favor, publique los mensajes de error. También asegúrese de que los detalles de su perfil están actualizados.
- Global Moderator
- Name: TIG
- SketchUp version: 2021
- License type: Pro
by RalfHannes » Sun May 26, 2019 8:43 pm
it's not working for SketchUp 2019 Error when loading file C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb Error: #<IOError: The required, staged c extension file, "C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!> C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in `block in require_all' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in `each' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in `require_all' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in `require' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in `require' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in `require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in `load' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in `register_extension' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in `<module:MSPhysics>' C:/Users/Username/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in `<top (required)>'
RalfHannes
- Name: Ralf
- License type: Pro
by TIG » Sun May 26, 2019 9:34 pm
If you look at the posts a few earlier you'll see that it's not compiled for the newer SketchUp version... Hence the error messages ?
- Global Moderator
- Name: TIG
- License type: Pro
by cristyan » Tue May 28, 2019 12:53 pm
Hello ! How can i connect these sliders ( or can be a piston joint )in a way that if I move one the other will move in the opposite direction or to affect its position (without connecting them directly). Thank you!
cristyan
by RalfHannes » Tue May 28, 2019 1:05 pm
TIG wrote:If you look at the posts a few earlier you'll see that it's not compiled for the newer SketchUp version... Hence the error messages ?
oh, i am sorry! thanks for your reply.
RalfHannes
- Name: Ralf
- License type: Pro
by ripvansparky » Thu May 30, 2019 8:35 am
Dang, just paid $300 so I could use this one extension, but it doesn't work with version 2019. Does anyone have any similar suggestions, or a way to create hinge points in a drawing? Thanks
ripvansparky
- Name: Kirtan Simon
- SketchUp version: 2019
- License type: Pro
by TIG » Thu May 30, 2019 3:05 pm
ripvansparky wrote:Dang, just paid $300 so I could use this one extension, but it doesn't work with version 2019. Does anyone have any similar suggestions, or a way to create hinge points in a drawing? Thanks
I'm sure a v2019 compatible version is under development... In the meanwhile you could get v2017 [Make?] and try using it with that for your hinging work... You can always use 'SaveAs' in a newer version model to get a v2017 SKP that's compatible... https://www.sketchup.com/download/all
- Global Moderator
- Name: TIG
- License type: Pro
by thedemoriliza » Mon Jun 24, 2019 8:47 pm
i'm trying to simulate gears and linkages and all my components just fall apart. it's like the joints are weak, and things gradually just start to wobble and fall apart. anyone know if there's a way to stop this? i dont want the joints to break. cheers =)
thedemoriliza
- Premium Member
- Name: jack walley
- SketchUp version: 2015
by ecati » Mon Jun 24, 2019 8:58 pm
If you share the .skp file, we may have better information about the problem you are talking about and we can help you.
ecati
- Name: Necati Abaylı
- License type: Pro
by Fokys » Mon Sep 02, 2019 11:56 am
Please tell me how to configure the plugin
Fokys
- Name: Fokys
by diogobr » Fri Sep 13, 2019 3:17 pm
My sketchup is hiding the objects, when I press start emulation (about 10 seconds). What is happening?
diogobr
- Name: Diogo Augusto Fernandes Vieira
- SketchUp use: game and/or sci-fi modelling
by Ahmed0007 » Thu Sep 19, 2019 2:48 am
please update for SU2019
Ahmed0007
- Name: Ahmed
- License type: Pro
by Anton_S » Mon Sep 23, 2019 7:30 pm
diogobr wrote:My sketchup is hiding the objects, when I press start emulation (about 10 seconds). What is happening?
This happens because some objects, like hidden objects fall too far down to the point where your view is clipped. Ensure to assign an Ignore state to the that objects that should not be a part of simulation.
Anton_S
- Name: Anton
- License type: Pro
by Anton_S » Mon Sep 23, 2019 7:31 pm
Fokys wrote:Please tell me how to configure the plugin
I will try to make the slider joint more useful by the next release. Thank you for your report!
Anton_S
- Name: Anton
- License type: Pro
by Anton_S » Mon Sep 23, 2019 7:32 pm
Ahmed0007 wrote:please update for SU2019
I am on it!
Anton_S
- Name: Anton
- License type: Pro
by Ahmed0007 » Mon Sep 23, 2019 9:32 pm
Anton_S wrote:Ahmed0007 wrote:please update for SU2019
I am on it!
Thank you so much
Ahmed0007
- Name: Ahmed
- License type: Pro
by faust07 » Mon Sep 23, 2019 11:20 pm
Sounds good. This could be a reason to purchase SketchUp 2019...
faust07
- Name: Faust07
by steambuf » Tue Oct 01, 2019 8:02 am
been looking for an animator for some time and have looked at this plugin with Sketchup 2017 Make to keep the costs down to zero. The new version of Free Sketchup is on line only so no use to me. I cannot get the joints to remain located exactly and the objects drift apart after a short period of time. I also downloaded a steam beam engine model with full animation. this worked fine for a couple of iterations and then proceeded to disintegrate due to drifting of the joints. Is this just me of is this an ongoing problem with this plug in?
If I could get it to work it would be a terrific program. everything seems to work except this drifting of the joints. pity I've spent quite a bit of time trying to make it work.
steambuf
- Name: Peter
by Anton_S » Tue Oct 01, 2019 7:47 pm
@steambuf Yes, joints are a problem. I wm hoping that an updated version of nrwton dynamics physics engine addresses the problem. In the meantime, joint stiffness is best, if all connected bodies are of the same mass and solver model is set to itetative 64 passes. To change the mass of a body, use the UI.
Anton_S
- Name: Anton
- License type: Pro
- Robot
Return to Plugins
