by Anton_S » Mon Mar 20, 2017 2:53 am
Pilou, do you mean, how to set the box static when the other box hits it? If so, attach this script to the little box: - Code: Select all
onTouch { |toucher, point, normal, force, speed| this.static = true this.set_velocity(0,0,0) this.set_omega(0,0,0) }
This should set the little box static whenever the falling box over it catches up.
Anton_S
- PluginStore Author
- Name: Anton
- Operating system: Windows
- SketchUp version: 2018
- License type: Pro
- SketchUp use: hobby
- Level of SketchUp: Advanced
by pilou » Mon Mar 20, 2017 10:05 am
For avoid this artificial bowling's corridors!
Objective is make a stone wall : so a general vertical fall Rotation 90° Then another download/file.php?id=146225
- Top SketchUcator
- Name: Pilou
- SketchUp version: 2017
- License type: Free/Make
by delchrys » Mon Mar 20, 2017 10:21 am
Anton_S wrote:Hello, Bert Broek, Here is the hydraulic torque wrench with MSPhysics: delchrys - hydraulic torque wrench.skp The center of rotation might need some adjusting but it works as good as the model is. Regards, Anton
It's getting there but now i only need to get it to rotate around the small hole's center. i've made another one with a dynamic component for you to see what i mean. Hope you can help me with it. regads, Bert
delchrys
- Name: bert broek
- SketchUp version: 2016
- SketchUp use: product design
by pilou » Mon Mar 20, 2017 3:53 pm
@ Anton yes that works fine but I have hundred of objects! I can't put one by one the script!  (multiple selection don't work for this case) GIF_touch2.gif and little problem!  stop_at5.jpg
- Top SketchUcator
- Name: Pilou
by Anton_S » Mon Mar 20, 2017 4:46 pm
Hello, Bert, Could you be more clear about, which small hole's center it should rotate about? Is that what it should do now? PROBEER NIEUWE ATORATOR.skp I will soon make a video on how I am adding MSPhysics to it, so you know how it is done. Regards, Anton
Anton_S
- Name: Anton
- License type: Pro
by Anton_S » Mon Mar 20, 2017 5:12 pm
Hi, Pilou,
To assign same script to multiple objects, give them all the same name, assign script to one of them, and in the Properties tab of the UI click on the Assign Script to All with Same Name button.
One way to reduce the offset, is by enabling the Continuous Collision in Simulation tab.
Regards, Anton
Anton_S
- Name: Anton
- License type: Pro
by delchrys » Mon Mar 20, 2017 9:23 pm
Sorry for not being very clear. The whole circular wrench part should rotate around the hole's center. I'll post a update tomorrow where I have added the hydraulic cylinder so you can see what I mean. Now I'm on my phone so can't post it now. I want the cylinder to push out and push the lever so that the wrench part rotates a bit. So from a linear motion to a rotating one. I'll update tomorrow, thanks for now.
delchrys
- Name: bert broek
by Anton_S » Mon Mar 20, 2017 11:03 pm
Bert, you can alternatively add labels to hole centers and then indicate which hole you're referring to by its name.
Anton_S
- Name: Anton
- License type: Pro
by pilou » Tue Mar 21, 2017 3:09 am
@Anton Not so bad!
and after Eclate Deplace
PS Have you something for "untouch" some objects with a measure given inside mS Physics? Sure I have yet Eclate-deplace ...
- Top SketchUcator
- Name: Pilou
by Anton_S » Tue Mar 21, 2017 5:58 am
faust07 wrote:Hallo Anton. Thanks for your explanation. Here is a picture sequence with the problem. It usually happens in fast motion sequences, as if MSPhysics tries to run the simulation in real time. For games and the like it is certainly useful, but for a video recording are missing some phases of some objects. Unfortunately the model is currently under construction. I am trying to optimize and combine motion sequences and motion modes. If it works again, I can send it to you.
Hello, Faust, I sent you a private message on this. Please check your inbox. Thanks, Anton
Anton_S
- Name: Anton
- License type: Pro
by pilou » Tue Mar 21, 2017 6:29 pm
@Anton By Chri : tricky use of MS Physics!  dameuse2.gif dameuse21.gif PS Have you something for "Untouch" objects selected in Ms Physics ?
- Top SketchUcator
- Name: Pilou
by delchrys » Tue Mar 21, 2017 8:37 pm
So I made my model a bit more complete. So the red cylinder pushes out and pushes the yellow block. the yellow block makes the green part rotates around origin point. I have made a dynamic component that when you click on the yellow part it show the rotation and added a piston controlley for the cylinder. Hope someone can show me how you make it moving and maybe a step by step guide with it.
delchrys
- Name: bert broek
by faust07 » Tue Mar 21, 2017 9:56 pm
First impressions of MSPv1.0.0_WIP6: Great new features and improvements!: Particle recording and export, Escape to stop exporting, Magnets, Joystick, OnTouch functions ... I've got my walker model to run. Although I thought first, I can not do it. The main problem was my inaccurate definition of "Material" in conjunction with "Mass Control". For example: rubber with a mass of 3 kg, wood with a mass of 10 kg etc. This worked in version 0.9.9 but after opening with v1.0.0 all former mass values were displayed in density and the bodies then behaved strangely... I have now changed all the MSP materials with deviating mass to "Custom" and reset the display of "by Density" to "by Mass". It would be good to know the dependence of the strength of the joints on the density / mass of the connected body parts. For the walking person, I have to adjust the triple weight for all parts of the body in order to reduce the wobbling and trembling to a tolerable level. An oscillation of previously 60 frames now appears to correspond to a value of 1.0. Does the oscillation refer to real time or simulation time? The start rotation direction of the joints changes sometimes? I guess the cause is at the oscillators starting point at -1.0. But that's ok. The improper phasing till persists: The elimination of movement phases of individual bodies is still present. This, however, seems to be due to the amount of transformed emitters (drops, splashes, etc.). Without the many emitters, the body movements of my "Little Richie Gear" (I as a boy with a lantern...) are smooth. What is the influence of setting "Kinematic" or "Dynamic" to the simulation? Where can I find the script overview? Right now, I'm just trying to figure out what the simplest method is to copy a complex MSPhysics conglomerate like a person (with Curvy Piston and scripts) and let them act independently.
faust07
- Name: Faust07
by Anton_S » Tue Mar 21, 2017 9:57 pm
Hello, Bert, That's indeed a better model! I made a YouTube video on how to add MSPhysics to it: Here is the model: delchrys - gatorator.skp Regards, Anton
Anton_S
- Name: Anton
- License type: Pro
by Anton_S » Tue Mar 21, 2017 11:07 pm
Hello, Pilou, There is an onUntouch {|toucher| ...} event for that. Basically when squeezing wall stops touching the stones, you want them to become static, right? To do that, you have to assign this script to the wall(s): - Code: Select all
# Triggered when the wall stops touching a body. onUntouch { |toucher| # Ensure that only touchers named, 'stone', are set static. next if toucher.group.name != 'stone' # Set static toucher.static = true toucher.set_velocity(0,0,0) toucher.set_omega(0,0,0) } # Triggered when the wall starts touching a body. onTouch { |toucher| # Ensure that only touchers named, 'stone', are set movable. next if toucher.group.name != 'stone' # Set toucher toucher.static = false }
Make sure to name all stones, stone. However, I think that for cluttering a lot of stones it would be better to manually set them static, say after pressing key, S. Assign this script to the wall: - Code: Select all
onStart { @set = false } onTick { if key('s') == 1 && !@set @set = true simulation.world.bodies.each { |body| if body.group.name == 'stone' body.static = true body.set_velocity(0,0,0) body.set_omega(0,0,0) end } end }
This, too, requires that all stone objects are assigned a name, stone. FYI, it's not "Ms Physics" it's "MSPhysics", standing for Math Science and Physics. Regards, Anton
Anton_S
- Name: Anton
- License type: Pro
by Anton_S » Tue Mar 21, 2017 11:33 pm
Hello, Faust, faust07 wrote:This worked in version 0.9.9 but after opening with v1.0.0 all former mass values were displayed in density and the bodies then behaved strangely...
Yes, that was another change I made. I basically renamed the attribute, so it describes the Control by Mass/Density property more accurately. After version 1.0.0, new releases will usually include backup compatibility, but while MSPhysics is still in 0.x.x stage, I don't make changes compatible. faust07 wrote:It would be good to know the dependence of the strength of the joints on the density / mass of the connected body parts. For the walking person, I have to adjust the triple weight for all parts of the body in order to reduce the wobbling and trembling to a tolerable level.
In the current versions, joints are the most robust when two linked objects have identical masses. But since linked objects usually don't have identical masses, simply assign realistic mass ratios to objects, and that will usually, too, guarantee strong joint connections. For example, the torso of your robot could have a mass of 1.0 kg, the arm of 0.2 kg, the hand of 0.05 kg, and etc... faust07 wrote:An oscillation of previously 60 frames now appears to correspond to a value of 1.0. Does the oscillation refer to real time or simulation time?
Yes, that was changed too. Now the oscillator accepts frequency in seconds of simulation time - number of times to oscillate per simulation second; no longer depends on frame. This change was made to keep the oscillation value persistent when changing the simulation timestep. faust07 wrote:The start rotation direction of the joints changes sometimes? I guess the cause is at the oscillators starting point at -1.0.
I added another function, called oscillator2, which starts at 0.0 and oscillates from 0.0 to 1.0. See the documentation for details. Also, since 1.0.0 isn't released yet, the documentation is local. To open it, select some group, open MSPhysics UI, activate the Script tab, and select MSPhysics link. From there, click on CommonContext too see all functions you could use as controllers. faust07 wrote:What is the influence of setting "Kinematic" or "Dynamic" to the simulation? Where can I find the script overview?
After opening the local documentation, click on Overview tab. There should be a small topic on that. faust07 wrote:Right now, I'm just trying to figure out what the simplest method is to copy a complex MSPhysics conglomerate like a person (with Curvy Piston and scripts) and let them act independently.
This can be done by selecting the entire robot, and enabling the Connect Closest Joints state. Then you can copy it, along with the curvy joint, as many times as you want. faust07 wrote:The improper phasing till persists: The elimination of movement phases of individual bodies is still present. This, however, seems to be due to the amount of transformed emitters (drops, splashes, etc.). Without the many emitters, the body movements of my "Little Richie Gear" (I as a boy with a lantern...) are smooth.
Send me a private message with the model so I can see what could be done to improve MSPhysics and/or the model. Regards, Anton
Anton_S
- Name: Anton
- License type: Pro
by pilou » Tue Mar 21, 2017 11:46 pm
@Anton! Thx i will test all that! Can you see the 2 gif animations above? (because they are on the Su French forum section) PS Sorry for the MS "Untouching" Physics! I will remember that for the next time!
- Top SketchUcator
- Name: Pilou
by Anton_S » Wed Mar 22, 2017 12:00 am
pilou wrote:Can you see the 2 gif animations above? (because they are on the Su French forum section)
Nope, I don't see them. It says I'm unauthorized to view them... pilou wrote:PS Sorry for the MS "Untouching" Physics! I will remember that for the next time!
I'm not offended by that in any way. Neither is Ms Physics
Anton_S
- Name: Anton
- License type: Pro
by pilou » Wed Mar 22, 2017 2:19 am
Gif animations repaired! viewtopic.php?f=323&t=56852&start=600#p616669Sorry for the inconvenience!
- Top SketchUcator
- Name: Pilou
by faust07 » Wed Mar 22, 2017 11:27 am
Hi Anton, thank you for the detailed explanations. Much confirms my assumptions. Can not wait for the final version. From the v1.0.0 onwards, it also makes more sense to put models in 3D-Warehouse. I've sent you a PM with the test model. Perhaps you can find the causes for the jerky movements in complex MSP calculations and give ideas for the improvement of the scripts.
faust07
- Name: Faust07
by delchrys » Wed Mar 22, 2017 1:38 pm
Almost ready Anton, now i only need to get it moving a bit further. If the two green half circles meet each other and the cyclinder moves further, the whole green circle part should rotate a bit around the origin point. If you know what i mean. If you look at the following youtube video you should understand what i mean. The first couple of centimeters is needed for closing the green grip halves, the next centimeters are needed to rotate. regards, Bert PS Hope i'm not asking too much https://www.youtube.com/watch?v=MO2Dy7PM7Gs
delchrys
- Name: bert broek
by Anton_S » Thu Mar 23, 2017 11:11 am
Hi, Bert Here it is: delchrys - gatorator.skp Now it rotates along the pipe, like desired. I also made it compatible with MSPhysics 0.9.9. I assigned all bodies a mass of 1.0 so that the joints are robust. This won't be necessary in the final MSPhysics, version 1.0.0, but that's what required in the current version. I also added grippers to the clutches. The clutches themselves are ignored, but the grippers are collidable. If you enable the MSPhysics Joints layer, you will see the grippers. I also changed the solver model to iterative 64 passes, once again, for a more stable behavior of joints in the current versions of MSPhysics. Regards, Anton
Anton_S
- Name: Anton
- License type: Pro
by delchrys » Thu Mar 23, 2017 12:50 pm
Hi Anton,
thanks you are the greatest. Now i'm going to figure out all the joints and combinations of groups so i can figure how you do it. Also i'm adding a other wrench that is holdng the other end of the pipe. Then i hope it will loosen like i need it to. Keep you update!!!
delchrys
- Name: bert broek
by delchrys » Thu Mar 23, 2017 7:22 pm
Anton? How do you make the guide points?
delchrys
- Name: bert broek
by Anton_S » Thu Mar 23, 2017 8:33 pm
So, for a circle/arcs, you right click on them and select "Find Center".
Anton_S
- Name: Anton
- License type: Pro
by delchrys » Fri Mar 24, 2017 4:16 pm
Ah thanks you didn't know that option. Also downloaded pointtool plugin. Tonight in my nightshift I'm going to draw some more of the model to make a nice overview to show at work. Really loving this msphysics plugin. Possibilities are almost endless
delchrys
- Name: bert broek
by delchrys » Fri Mar 24, 2017 7:38 pm
Does someone have any advise in rendering for sketchup? Preferably free?? Like to render some things when i'm done, needs to look good
delchrys
- Name: bert broek
by delchrys » Fri Mar 24, 2017 8:49 pm
Anton_S wrote:So, for a circle/arcs, you right click on them and select "Find Center".
So i kind of remodelled a bit, but can't seem to understand why the pipe continues to rotate even when the grippers are open. It kind of get momentum because of the rotation, how can i stop that. So when the cylinder moves back, the grippers open and let go of the pipe and it stands still. Made the body static because it will be connected with the other wrench, so that only the gripper head rotates. Did i do the pipe right by giving him a plane joint and only allow it to rotate??? I don't want it to move in any other direction then rotating caused by the grippers. Should i accomplish this all by adding friction or is there a simple workaround? I doesn't have to be Physics Law proof but only look right. A lot of questions but getting there PS is ther a plugin for SU2016 to import 2017 files or a simple converter??? I cannot install 2017 at work due to lack of administrative rights
delchrys
- Name: bert broek
by Anton_S » Sat Mar 25, 2017 12:48 am
Hello, Bert, delchrys wrote:So i kind of remodelled a bit, but can't seem to understand why the pipe continues to rotate even when the grippers are open. It kind of get momentum because of the rotation, how can i stop that. So when the cylinder moves back, the grippers open and let go of the pipe and it stands still.
To fix this, you need reduce linear friction of the Plane joint from 100 to 1. This will the pipe to require less force to move along the plane. Also, setting the angular friction of the Plane joint to 0.01 should prevent the backward rotation of the pipe. delchrys wrote:Did i do the pipe right by giving him a plane joint and only allow it to rotate???
Either the tool should move or the pipe should move for the grippers to work properly, presumably even in real case scenario. Above, reducing plane linear friction, allows the pipe to move. delchrys wrote:PS is ther a plugin for SU2016 to import 2017 files or a simple converter??? I cannot install 2017 at work due to lack of administrative rights
Click on File->Save As and in the Save As Type, choose the desired SU version. Regards, Anton
Anton_S
- Name: Anton
- License type: Pro
by delchrys » Sat Mar 25, 2017 1:05 pm
Little update
delchrys
- Name: bert broek
- Robot
Return to Plugins
