MSPhysics 1.0.3 (16 October 2017)Re: MSPhysics 0.9.8 (13 November 2016)The peaceful robots!
Re: MSPhysics 0.9.8 (13 November 2016)I had issues with MS UI: modifying values, sometimes works sometimes not.
![]() Then I notice this: typing a value +enter or tab does not work. ![]() Typing a value + click outside the input box works… ![]() Just for anybody else having the same troubles. Mac OSX 10.8.5, SU2015. " c'est curieux chez les marins ce besoin de faire des phrases "
Hi gilles I don't know if this is related but i noticed that when trying to alter friction, on cursor in window an X appears on the rhs and a new input will only be accepted after mouse over click X which blanks the window for a new entry kinda convoluted Robin As one door closes another one slams in your face
Re: MSPhysics 0.9.9 (22 December 2016)Announcing 0.9.9!
This version comes with mainly an improved dialog and joints. View changelog for details: http://www.rubydoc.info/github/AntonSyn ... ANGELOG.md Anton
Re: MSPhysics 0.9.9 (22 December 2016)Thanks Anton for fixing the full-screen issue my animations are back to normal
![]() MSPhysics 0.9.9 tested on win 8.1 and sketchup 2015/2016 working fine. the new plane joint works great on single or two different planes ![]() thx again and merry xmas Tez Re: MSPhysics 0.9.9 (22 December 2016)Hello, Tez,
Good to hear that it's working now. And merry Christmas to you too! Best regards, Anton
Re: MSPhysics 0.9.9 (22 December 2016)Sorry Anton forgot to ask u in my last post about simple OnTouch sound scripts
in Sketchyphysics i just tick the OnTouch panel and use playSound('Sound1') what's the MSphysics equivalent script for Ontouch sound .....i keep getting an error? its no bug ..just me don't understand MS scripts yet. Tez Re: MSPhysics 0.9.9 (22 December 2016)Hi Anton, installed 0.9.9 and restarted SU
but its screwed up my model? It falls downwards and I cant get the static floor to work as before, also the script stopped working Did I do a corrupt installation? Should I have deleted 0.9.8 first - you didnt say? I assumed it would overwrite and update itself Where to go? delete and start fresh installation or go back to 0.9.8? What to do? ![]() Robin As one door closes another one slams in your face
Re: MSPhysics 0.9.9 (22 December 2016)Tez,
In the Sound tab of the MSPhysics UI, whenever a sound is added, a piece of code for playing the sounds is displayed below. For your case, after you add the sound to the MSPhysics UI, the code for playing it would be:
You can also refer to this scripting documentation link for playing 3D sounds: http://www.rubydoc.info/github/AntonSyn ... ic___Sound Anton
Re: MSPhysics 0.9.9 (22 December 2016)Robin,
I assume the script you talk about is the controllable sphere thingy. There has been some scripting changes and the documentation for the controllable sphere is updated. For your case, you will have to replace the add_force2 function with the add_force function. Now, I don't know how the static floor behaved previously. Basing on the model you posted, everything is working fine. I don't see any issues. If you want to revert to on original version, you may always refer to the instructions on the homepage. Anton
Re: MSPhysics 0.9.9 (22 December 2016)Very strange Anton, I removed the sphere from the model to avaoid confusion , but on mine Falling block 7 the whole model falls. I must assume I got a corrupt installation, so will start again afresh back to 0.9.8 and fb 6
Cheers Robin As one door closes another one slams in your face
Re: MSPhysics 0.9.9 (22 December 2016)I am pleased to report, that after a tedious uninstall of msp and a clean instal of 0.9.9, everything now seems to work ok
Overwriting existing files looks unwise and it was severely screwed up I would advise users Cheers Robin PS I made the block and floor out of tungsten carbide, so the block didnt penetrate AKAIK, but bounces as expected As one door closes another one slams in your face
Re: MSPhysics 0.9.9 (22 December 2016)Thanks Anton for making MSPhysics better and better. First impression of running an old model with Curvy Pistons with version 0.9.9 - all moves but some objects move backwards... - I will test in the next days what I must change to get the desired results.
Merry Christmas to all friends of SketchUp, physics and animation. Re: MSPhysics 0.9.9 (22 December 2016)Hi MSP's
Herewith my mortar gun model, run and tap space bar, adjust azimuth with rotate tool on all the gun. Adjust charge by piston rate I thought I might add display of distance to first landing (just like a real gun spotter? As one door closes another one slams in your face
Re: MSPhysics 0.9.9 (22 December 2016)Hi robint your original model falling block8 and script anton
helped u with i found very interesting thx. I set block material to gold / elasticity to 2.00 and got a bouncing ball i like the affect max elasticity gives u. Gif starts on 2nd bounce then breaks free on 3rd and keeps bouncing Tez Re: MSPhysics 0.9.9 (22 December 2016)Indeed, it becomes quite addictive I found. I wish I knew more about ruby script
I want to xfer the script to my mortar gun, try to get muzzle velocity, distance to target and time of flight cheers, have fun Robin As one door closes another one slams in your face
Re: MSPhysics 0.9.9 (22 December 2016)Im no script monkey as well wish i was....but im experimenting connecting two servo's for swivel and tilt with your mortar gun model no luck yet
![]() Antons original script has come in handy with my trebuchet/catapult models and projectiles THX Robin happy new year Tez Re: MSPhysics 0.9.9 (22 December 2016)Yes I tried that, but the outer gun barrel has to be made up of 4 flat slabs grouped together and made static which is why it wont move, else the ball just falls through it
only way I found was to use the rotate tool before hitting go not very elegant perhaps someone else will pitch in Cheers Robin As one door closes another one slams in your face
Re: MSPhysics 0.9.9 (22 December 2016)Anyone know how to put sound into script eg a sound wav called "cannon" to be played when I press space bar (which also fires the cannon ball
I put the sound byte into the UI sound tab, but nothing happens? WOTODO? Robin As one door closes another one slams in your face
Hello Robin. I wrote a script to display the distance of bullet and target, the time of flight and play the sound. But the "Update Timestep" change it to Normal 1/60 on the Simulation tab. Try this: Re: MSPhysics 0.9.9 (22 December 2016)Great script inside PituPhysics 'Distance and time of flight' perfect for projectiles
thx Tez Re: MSPhysics 0.9.9 (22 December 2016)Hi PP
some good stuff there, doesnt make the sound? take a look at my falling block as it uses the ontouch procedure to capture the distance at the moment of first impact Another way might be to insert some magnetism into the ball, floor and target so that the missile sticks to its first landing place, as with a real mortar Have tried to use magnetism in UI but doesnt seem to have any effect? ![]() What am I doing wrong? Robin As one door closes another one slams in your face
Re: MSPhysics 0.9.9 (22 December 2016)I made more models to be more opportunities.
1.) Frozen: 2.) Hide: 3.) Simulation pause: And magnet test: Re: MSPhysics 0.9.9 (22 December 2016)Hi PP
tried your magnet and I am baffled as to why its so very slow, <2fps. tried everything to speed it up. Sketchy physic was much faster? I made ther executive balls desktop toy by putting all the balls as pendulums in a frame and colliding. It was fast and realistic? Robin As one door closes another one slams in your face
Re: MSPhysics 0.9.9 (22 December 2016)Even stranger, I managed to get my balls to clang together at 30 fps, but unable to simulate repulsion even with negative magnet values? I notice that perhaps magnet is a wrong term as it behave more like gravity between two masses (hence no repulsion effect)
Universal gravitation equation F = GMm/R2 where F is the force of attraction between two objects in newtons (N) G is the Universal Gravitational Constant = 6.674*10−11 N-m2/kg2 M and m are the masses of the two objects in kilograms (kg) R is the separation in meters (m) between the objects, as measured from their centers of mass notice how the ball is attracted to the target even though the target has no magnetic force for example Robin As one door closes another one slams in your face
Got as far as 4.3 and it certainly is the cats whiskers, like the disappering effect in 4.2, all we need is a little pop up explosion (still no sound on mine?) I dont understand what is affecting the fps so drastically? It goes from 30fps down to 4 or less Robin As one door closes another one slams in your face
Re: MSPhysics 0.9.9 (22 December 2016)Playing with real shells. Wonder how I can get the nose pointing along the path? hmmm
![]() As one door closes another one slams in your face
Re: MSPhysics 0.9.9 (22 December 2016)Wow PP that has blown me away, havent looked into detail yet, tomorrow am
Now could this be mounted on a tank? Forward, left, right track Then we could have two or more, multi players Tank battle, forests, obstacles, terrain, mines, smoke etc Pls assume all rights, I'll be your beta tester and write the manual Robin Ps I wrote a game like this in BASIC years ago, for four players, it was extemely addictive, hidng under tree cover trying to guess where you opponents were. Each tank had a home base corner and had to return for new ammo and fuel. we spent hours on it I turned this into a kids game sliding around on mats on a polished wood floor blindfold, getting coded instruction from their base commanders. They fired foam tennis balls at each other and only had three reserve tanks. Couldn't get them out of the classroom, oh and they had to give their instructions in a foreign language, French German, Italian and swedish - a summer uni job - but the kids loved it Robin As one door closes another one slams in your face
