MSPhysics 1.0.3 (16 October 2017)
Re: MSPhysics 0.9.5 (31 October 2016)
Postby TIG » Tue Nov 01, 2016 11:53 pm
You have an accent in your Windows user-name 'Lémony'.
This has long been taboo !
It breaks older versions of SketchUp's Ruby completely !!
However, it should be possible to encode such a string when defining the file-path to avoid these issues - somewhat straightforward with newer Ruby versions - such as yours 'v2016'...
Perhaps the author needs to reconsider the paths' encoding...
Global Moderator
Postby Anton_S » Wed Nov 02, 2016 1:10 am
What? I thought I fixed that bug... :?
Anton_S
PluginStore Author
PluginStore Author
Postby Anton_S » Wed Nov 02, 2016 2:16 am
Unfortunately I didn't fix the encoding issue. I thought I did but I didn't. I will work on it soon.
Thanks for the report, SynSuka3d.
TIG, thank you for remarking on the issue.
Anton_S
PluginStore Author
PluginStore Author
Postby cristyan » Wed Nov 02, 2016 7:36 am
Hello Anton ! It give me an error on Sketchup 2013 when presing PLAY.On Sketchup 2016 is runing ok.Thank you !
cristyan
Postby Oxer » Wed Nov 02, 2016 9:07 pm
With the last version MSPhysics 0.9.5 & AMS Library 3.4.0 it appears an error message in Ruby Console:
Code: Select all
Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
Error: #<Exception: An exception occurred while loading MSPhysics library. The exception occurred due to one or more of the following reasons:
- LoadError: dlopen(/Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle, 9): Library not loaded: @loader_path/../libSDL2-2.0.0.dylib
  Referenced from: /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
  Reason: image not found - /Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle
- LoadError: MSPhysics library file, "/Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib_no_sdl.bundle", is missing!
/Applications/SketchUp 2016/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `require'
/Applications/SketchUp 2016/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `load'
/Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in `register_extension'
/Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in `<module:MSPhysics>'
/Users/Oxer/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
OSX 10.11.6
SU 2016
http://www.oxervision.blogspot.com/
Oxer
Re: MSPhysics 0.9.6 (4 November 2016)
Postby Anton_S » Sat Nov 05, 2016 12:06 am
SynSuka3d, I fixed the encoding error with non-ascii user names.
Download version 0.9.6 to get it working.
Cristian, Oscar you might be getting these errors because you overwritten original versions rather than deleting them.
It is important that you delete original AMS Library and MSPhysics versions from the plugins folder prior to installing the new ones; otherwise, you'll get nonsense errors. The extension signature tool is not working right. I could not sign my extensions. That's why overwriting original versions will result with errors when using MSPhysics and AMS Library.
Anton_S
PluginStore Author
PluginStore Author
Postby cristyan » Tue Nov 08, 2016 12:38 am
Hello to everyone out there ! and Hello Anton ! It give me an error after program is launched... 2013 and 2016... And on version ...
I manually install all the new plugins and I always delete the old ones ...
Thank you !
cristyan
Postby Oxer » Tue Nov 08, 2016 7:59 pm
I obtain similar message:
Code: Select all
Error al cargar archivo /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
- LoadError: dlopen(/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle, 9): Library not loaded: @loader_path/../libSDL2-2.0.0.dylib
  Referenced from: /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
  Reason: image not found - /Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib.bundle
- LoadError: MSPhysics library file, "/Library/Application Support/SketchUp 2016/SketchUp/Plugins/MSPhysics/osx64/2.0/msp_lib_no_sdl.bundle", is missing!
OSX 10.11.6 SU2016
Oxer
Postby Anton_S » Wed Nov 09, 2016 12:23 am
Alright, I'll look into this.
Anton_S
PluginStore Author
PluginStore Author
Postby vico44 » Wed Nov 09, 2016 8:36 am
The 0.9.4 still working well on OS 10.11.6 SU2016
vico44
Postby JEER » Wed Nov 09, 2016 12:45 pm
Hello Anton!
I have installed this plug-in and when started a SU , came a window:
Error Loading File C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics/main.rb
- Encoding::CompatibilityError: incompatible character encodings: Windows-1250 and UTF-8
C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2016/Tools/extensions.rb:197:in `load'
C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in `register_extension'
C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:90:in `<module:MSPhysics>'
C:/Users/Jenő/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
My SU is 2016 64 bit (16.1.2104)
My wsystem WIN10
JEER
Postby TIG » Wed Nov 09, 2016 2:59 pm
C:/Users/Jenő/...
Contains an accented character.
The extension's coding was updated to fix the user-path encoding to UTF-8, so do you have the latest version installed ?
If so then perhaps Anton needs to make his re-encoding more robust ?
Global Moderator
Postby khturnings » Wed Nov 09, 2016 9:49 pm
Just installed Sketchup Make 2017 and tried to install MSPhysics 0.9.6 and AMS 3.4.0 and got this error ---
Error Loading File C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/main.rb
- LoadError: 126: The specified module could not be found. - C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/win64/2.2/msp_lib.so
- LoadError: 126: The specified module could not be found. - C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics/win64/2.2/msp_lib_no_sdl.so
C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `load'
C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:90:in `register_extension'
C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:90:in `<module:MSPhysics>'
C:/Users/anykh/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
khturnings
Postby Anton_S » Thu Nov 10, 2016 4:26 am
That's unfortunate. Looks like I will need to create another account to ensure that the encoding error is actually not fixed.
Anton_S
PluginStore Author
PluginStore Author
Postby M3one » Thu Nov 10, 2016 11:25 pm
I'm want to do a path following object, but I don't really know how. I found on this thread that it's done with curvy joints, but I'm lost. Please, can you explain how or do you have kind of example?
Thanks!
M3one
Re: MSPhysics 0.9.7 (10 November 2016)
Postby Anton_S » Fri Nov 11, 2016 6:48 am
Okay, those loading and encoding issues should be fixed now. Upgrade to 0.9.7.
Anton_S
PluginStore Author
PluginStore Author
Postby Anton_S » Fri Nov 11, 2016 10:27 am
Hi M3one,
At the moment, you can refer to this tutorial on curvy joints.
https://www.youtube.com/watch?v=dU-KgxKc0ds
You can also check out this example model at 3Dwarehouse.
https://3dwarehouse.sketchup.com/model. ... 91ae85afe4
Anton
Anton_S
PluginStore Author
PluginStore Author
Postby M3one » Fri Nov 11, 2016 10:32 am
Anton_S wrote:Hi M3one,
Anton
Thanks Anton, I'll check it later
M3one
Postby khturnings » Fri Nov 11, 2016 6:29 pm
Anton_S wrote:Okay, those loading and encoding issues should be fixed now. Upgrade to 0.9.7.
Thanks Anton that has sorted the loading issue with Sketchup 2017.
Regards
khturnings
Postby Taner Batu » Fri Nov 11, 2016 6:31 pm
Hello, I can't download MSPhysics 0.9.7 plugin from your link!
Taner Batu
Postby Emersonvip » Fri Nov 11, 2016 9:20 pm
First of all thanks for sharing this great plugin
Please I need help. with chains.
Emersonvip
Postby Oxer » Sat Nov 12, 2016 2:18 pm
I installed the last version 0.9.7 and it appears this message:
Code: Select all
Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/main.rb
Error: #<Exception: An exception occurred while loading MSPhysics 0.9.7! The exception occurred due to one or more of the following reasons:
- LoadError: dlopen(/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib.bundle, 9): Library not loaded: @loader_path/../libSDL2-2.0.0.dylib
  Referenced from: /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/libSDL2_mixer-2.0.0.dylib
  Reason: image not found - /Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib.bundle
- LoadError: MSPhysics library file, "/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics/osx64/2.2/msp_lib_no_sdl.bundle", is missing!
/Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `require'
/Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `load'
/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:90:in `register_extension'
/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:90:in `<module:MSPhysics>'
/Users/Oxer/Library/Application Support/SketchUp 2017/SketchUp/Plugins/MSPhysics.rb:72:in `<top (required)>'
SU2017 & OSX 10.11.6
Oxer
Postby cristyan » Sun Nov 13, 2016 9:24 am
Hello !!!
I think most stable version is MSPhysics_0.9.4 for now ... in MSPhysics_0.9.7 "Drag to orbit" does not work when the simulation is runing...
Emersonvip - you can browse through this forum about chains ( search.php?keywords=chain&t=56852&sf=msgonly ). Here you have a file, see how it was done this chain piece by piece and you will understand how MSPhysics it works with chains.
as Anton wrote in a reply "You can adjust Update Timestep, Solver Model, and Update Rate for the desired speed, performance, and stability."
cristyan
Postby faust07 » Sun Nov 13, 2016 12:18 pm
The same here - Orbit doesn't work during simulation. Zooming in and out works.
faust07
Postby SketchyPhysicsNutt » Sun Nov 13, 2016 1:49 pm
Hi Anton and thanks for MSPhysics your done a great job so far congratulations.
only problem for me is new MS scripts are confusing....old sketcky user
waiting on more models with script examples in them.
Scaled down my j-pod/cable car model from Eneroth Railroad plugin
Curvy piston joint testing
thx again
3
SketchyPhysicsNutt
Postby PituPhysics » Mon Nov 14, 2016 12:06 am
faust07 wrote:The same here - Orbit doesn't work during simulation. Zooming in and out works.
Yes, For me also don't works the Middle click in 0.9.5+
PituPhysics
Re: MSPhysics 0.9.8 (13 November 2016)
Postby Anton_S » Mon Nov 14, 2016 5:13 am
Oxer, I fixed the loading issue on Mac OS X.
Cristyan, Faust07, PituPhysics the orbiting issue should be fixed new.
Please upgrade to 0.9.8.
Thanks y'all for reporting!
Anton
Anton_S
PluginStore Author
PluginStore Author
Postby Oxer » Mon Nov 14, 2016 9:28 pm
Thanks!! :thumb:
All works fine right now on Mac.
Oxer
Postby Anton_S » Mon Nov 14, 2016 11:16 pm
Oxer wrote:Thanks!! :thumb:
Phew :)
Anton_S
PluginStore Author
PluginStore Author
Postby DonDeEs » Thu Nov 17, 2016 2:00 am
Hi Anton
Please, please could you help me.
Firstly thanks for making it possible for us all to have this plugin. I really appreciate your work.
I have one little problem which I am sure is easily remedied. In my models the groups or components are falling through each (like in the following post) a lot of the time.
viewtopic.php?f=61&t=64189
I need to change a setting somewhere I guess but I have no idea which. I hope I haven't missed something obvious, I have tried looking for the solution online without success and I have tried systematically changing setting also without success.
Many thanks once again.
DonDeEs
PreviousNext
Return to Plugins
Users browsing this forum: Arzaga, Bing [Bot], Dave R, JakobsenChri, jessica ubatuba, matthewmildon, reynoldparada, rushimamarde, sumey, thaibuilders and 12 guests
