[Plugin] EdgeInspector - v1.2a - 12 Oct 14
Re: [Plugin] EdgeInspector - v1.2a - 12 Oct 14
Postby pipinek » Fri Apr 29, 2016 5:11 pm
Huge thanks.
It does work as you have described.
But you have to admit that its a too tricky for an everyman user. The tool name is DrawAlong (no space).
I will be aware such possibilities in the future.
Best regards with my gratitude for your responses.
pipinek
Premium Member
Premium Member
Postby fredo6 » Fri Apr 29, 2016 6:55 pm
Glad it works now.
Actually, the best is to look first at the menu text and apply the filter accordingly.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby pipinek » Fri Apr 29, 2016 8:07 pm
Indeed this is the best way.
Alas, I am not the one.
Thank you once more for your assistance and your marvellous works.
pipinek
Premium Member
Premium Member
Postby karasupike » Thu Apr 27, 2017 12:34 pm
thank youu!!
karasupike
Postby bharralure » Sun Mar 24, 2019 7:15 pm
Bonjour,
Edge Inspector v3.3b semble ne pas fonctionner correctement sur SU 2019 (Installé depuis SketchUcation).
Au lancement de l'outil, la fenêtre affichée est incomplète, tel que le montre la capture d'écran jointe.
J'ai désinstallé FredoTools, puis réinstallé sans succès.
Je joins également le rapport de la console Rubis, en espérant que cela aide.
D'avance merci pour toute aide.
EdgeInspector_ErreurInstallation.txt
bharralure
Postby fredo6 » Sun Mar 24, 2019 10:25 pm
Thanks for advising. I fixed it in FredoTools v3.3c. This is actually an incompatibility introduced with the new version of Ruby that is shipped with SU2019.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby bharralure » Sun Mar 24, 2019 10:40 pm
Effectivement, la version 3.3b fonctionne parfaitement dans SU 2018, mais je viens d'installer la version 3.3c dans SU 2019, et tout est rentré dans l'ordre.
Encore un grand MERCI pour la rapidité de cette mise à jour, et pour l'ensemble de votre travail.
bharralure
Postby ct103stu0 » Fri Jun 12, 2020 3:32 pm
Could not detect and/or fix these tiny gaps in diagonal lines. See attached file (screen shot). What am I doing wrong?
ct103stu0
Postby fredo6 » Fri Jun 12, 2020 6:10 pm
ct103stu0 wrote:Could not detect and/or fix these tiny gaps in diagonal lines. See attached file (screen shot). What am I doing wrong?
Could you post or send me the model.
May be normal, or maybe not....
fredo6
PluginStore Author
PluginStore Author
Postby ct103stu0 » Fri Jun 12, 2020 8:06 pm
I posted the model in the SU Forum. The model is located here:
https://forums.sketchup.com/t/edge-gaps ... azy/127787
This is a 2019 SU model. Tried to send you the 2017 SU model via the board but the file size is too large.
Thanks ,,,
ct103stu0
Postby ct103stu0 » Fri Jun 12, 2020 8:13 pm
In the screenshot and SU model, in terms of EdgeInspector defects, what are these "spaces" in the diagonal lines called (tiny gaps, lost junctions, etc.)?
ct103stu0
Postby fredo6 » Fri Jun 12, 2020 8:47 pm
I posted my answer in the Sketchup Forum too.
fredo6
PluginStore Author
PluginStore Author
Previous
Return to Plugins
Users browsing this forum: Jean Louis Fibonacci and 12 guests
