[Plugin] RichSection V0.5.8 UPDATED march 2015  Topic is solved
Re: [Plugin] RichSection V0.5.8 UPDATED march 2015
Postby pgarmyn » Wed Apr 22, 2015 6:53 am
bik wrote:1. I have a problem with the setting panel.
When I click on the button to call the setting panel, nothing happens.
2. And most of time I encounter a bug splat windows when I just click on "create" for a first Rich Section. The section become grey, and everything close.
3. When I succeed to create one, I don't have a lot of color section choice, only wide stripes by default and Black (plain color)...
1. You have to select a section plan or section group. The instructions are in the text field below, or read the pdf file in the first post.
2. How big is your mode? Start without projection. For big projects, it is better to limit projection : with layers from scene, limited by distance... . Do not select any command after selecting the ´creaté button, until the Section panel is updated.
3. Only one default material will be created and aplied after creation with the default settings. Please Read the instructions : pdf file included in the first post: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072#p499865
pgarmyn
PluginStore Author
PluginStore Author
Postby shake1 » Sun May 03, 2015 7:19 am
Hi, this is a little bug
win7/64
Su 2015 3.331 x64
shake1
Postby srx » Fri Jul 17, 2015 10:49 am
Today I found out that plugin has time limit. How to continue using it?
www.saurus.rs
srx
Postby agmgpro » Fri Jul 17, 2015 2:37 pm
The same thing is happening with me... please help!
agmgpro
Postby Petrroo » Fri Jul 17, 2015 3:45 pm
Hi! Thank you so much for your work on this plugin. A very useful program.
But at the moment really need Your help!
Already addressed, but the message remained unanswered! Suddenly stopped working plugin RichSection. As I understand the network is a demo version that stops working after a certain period. Work on the Mac. Previously had no problems. And all of a sudden stopped working. Tried to reinstall - no help. The most interesting thing that is worth Parallels with the sketch for the Windows. Put the plugin in there - the same nonsense - lets not create a section. Open the file with a previously created sections RichSection - they are edited, but all are not created equal! Really need Your help, because the whole model was done with the expectation of making further using this plugin!!! Thank you!
Petrroo
Postby Gliph » Sun Aug 09, 2015 4:54 pm
Le plug-in ne fonctionne plus, apparement la version demo s'arrête au 2 juillet 2015. On paye où pour la "full version" ? :o
Gliph
Postby rombout » Thu Sep 03, 2015 7:54 pm
Im trying this again on mac su make 2015, but nothing happens? is this a know issue, i did a quick search here but coulnt find any mac users...
i think i found the issue, its a license thing. Thought this one was for free :)
RichSection: Time-limited FULL WORKING license
Expired at 2015-07-01 20:00:00 -0400 : [nil]
rombout
Postby cucsat2003 » Mon Sep 07, 2015 4:47 am
@ pgarmyn:Sorry for a dumb question.
But I've installed RS plugin,and it's icons appeared,but I can't add rich section(first icon) anymore.When I hit the icon,there's no section appears like in your video.
I've read all comments in this topic but can't find solution.
Should you help me please?
This plugin seems so great and I can't wait to try it.
3
cucsat2003
Postby Dimitri972 » Tue Sep 22, 2015 5:31 pm
I fixed time expired problem. Here it is:
http://www.mediafire.com/download/brjzm ... imitri.zip
Author was't answering question for months. I tried to fixing expired issue and fixed. If this isn't wanting thing in this forum, you can delete my post. I don't know forum rules.
Dimitri972
Postby bimbachi » Tue Sep 29, 2015 1:18 pm
@Dimitri972
I did try on my macbookpro skp 2015 , unfortunately it crached skp
bimbachi
Postby jim smith » Tue Sep 29, 2015 7:22 pm
I loaded Dimitri's fix to replace the expired files, re-booted SU opened a model, selected create section and got the section box to appear on the model. I haven't time to experiment with it but apparently it will at least open on a PC (I am running an ASUS pc with i7, 16GB).
I hope pgarmyn has not lost interest because of "skalp". I am sure many people would like the option to use this free plugin.
"Out of clutter find simplicity,
from discord find harmony,
In the middle of difficulty lies opportunity"
Albert Einstein
jim smith
Premium Member
Premium Member
Postby Dimitri972 » Sat Oct 03, 2015 11:12 pm
Most of Skalp section materials are free on 3d warehouse. You can combine them with this plugin for amazing result. And don't forget to make group or component before taking section.
Actually this plugin is crashing in many situation but it is still usefull plugin.
Dimitri972
Postby piyanan » Wed Oct 14, 2015 1:43 pm
Hello any one
I install plugin for sketchup 2015-64 bit for windows and saw tool in sketchup is OK
then I click 1st tool is (Create RechSection)and I did my model it is notthing to happen.
and same other tool
piyanan
Postby lippo » Sat Nov 28, 2015 7:05 pm
Hi, I have unloaded the plugin, but I don't succeed in making him/it work... I make click on the icon it creates richsection and it doesn't happen anything. I use SUpro2015 64bit :oops: :oops:
lippo
Postby Mike8P » Sun Dec 06, 2015 7:57 pm
It doesn´t seem to work on SketchUp 2015...
Any issue?
Mike8P
Postby Skalp » Fri Dec 18, 2015 7:58 am
Dimitri972 wrote:Most of Skalp section materials are free on 3d warehouse. You can combine them with this plugin for amazing result. And don't forget to make group or component before taking section.
Skalp section materials are intended to be used with Skalp. Skalp materials are much more then just textures.
The Skalp team
-2
Skalp
PluginStore Author
PluginStore Author
Postby pilou » Fri Dec 18, 2015 11:24 am
@Skalp
2 trivial questions :)
Does the Skalp material can be used as normal material for any facades surfaces ?
Does SKalp is existing in French ?
Speedy Galerie
Top SketchUcator
Postby Skalp » Fri Dec 18, 2015 12:23 pm
pilou wrote:@Skalp
Yes Skalp materials can be used like normal SketchUp materials.
At this moment there isn't a French version. But we are working on translations at this moment.
The Skalp Team
Skalp
PluginStore Author
PluginStore Author
Postby antoinelepoutre » Tue Dec 29, 2015 3:38 pm
does not work in SU2016 on WIN7
antoinelepoutre
Postby Ader89 » Tue Mar 08, 2016 3:07 pm
Hi, I put this aap on my sketchup 2015, every bottom is working including the menus, but when i tried to use create richsection its don´t work, the section plane just don´t appear on screen, what can i do to solve it? the app ins´t compatible with sketchup 2015? Thanks
Ader89
Postby rombout » Tue Mar 15, 2016 11:16 pm
Dimitri972 wrote:I fixed time expired problem. Here it is:
It sort of works when im doing a single group, crashes when there is more than 1 though.
osx 10.11.2
su2015
rombout
Postby Ekon » Sun Aug 14, 2016 1:35 am
I don´t get it to work properly on Win 10 and SU 2016 64bit pro. I get a simple section but no materials, no options dialog and if I do a second section it does it like native SU.
None of the other buttons work. It says select Rich Section first, but my section is already selected.
Some help would be appreciated.
thanks
Ekon
Postby RBCADDSVCS » Mon Sep 26, 2016 5:08 am
I've tried and tried to get this to work.
I've installed, uninstalled, and reinstalled, and nothing works.
I'm running Sketchup Pro 2014.
The toolbars shows up, and the drop-down menu shows up, but when I click on them nothing happens at all.
The log file says my license is expired.
I didn't think it needed a license.
What's up with that?
RBCADDSVCS
Postby Haddal88 » Wed Mar 08, 2017 4:26 pm
Hello!
I am trying this plugin after I saw the amazing videos.
When I press the button to create the section, nothing happens.
Running Pro trial on Sketchup 2017 Make.
Any reasons?
Running Windows 7, Intel i7.
Thanks in advance!
Haddal88
Postby TIG » Fri Mar 10, 2017 1:41 pm
Run it with the Ruby Console open.
There might be incompatibilities with v2017 ?
It is two years without an update...
Global Moderator
Postby juju » Fri Mar 10, 2017 1:55 pm
TIG wrote:Run it with the Ruby Console open.
IIRC this has been turned into a commercial plugin, namely SKALP, support / updates to this will then have ceased.
21 Sept. 2020. Please support this thread on the SketchUp forum to resolve Extension Warehouse problems. Faults being ignored is not an option.
juju
Premium Member
Premium Member
Postby ahdims » Wed Jun 21, 2017 5:54 am
Just wondering if this extension is supported in sketchup 2017 or it will be supported for sketchup 2017
ahdims
Postby juju » Wed Jun 21, 2017 8:26 am
ahdims wrote:Just wondering if this extension is supported in sketchup 2017 or it will be supported for sketchup 2017
please read the two posts directly above yours
juju
Premium Member
Premium Member
Postby zooen » Sun Jun 10, 2018 7:48 am
December : 2015
Skalp wrote:
pilou wrote:@Skalp
The Skalp Team
June 2018 : Does Skalp is existing in French ?
zooen
Postby Bandika » Sun Aug 05, 2018 9:53 pm
It is not working in 2015, when I click on the icon,nothing happens. V0.5.8
Any idea?
Bandika
PreviousNext
Return to Plugins
Users browsing this forum: irfan01 and 19 guests
