[Plugin] RichSection V0.5.8 UPDATED march 2015  Topic is solved
Re: [Plugin] RichSection [Demo] UPDATED 4 dec 2013
Postby pgarmyn » Fri Dec 27, 2013 10:17 pm
fionmacool wrote:Awesome plugin pgarmin. It is exactly what i've been looking for as an automated approach to the methodology in my book "Construction Documents Using SketchUp Pro & LayOut". There are one or two small refinements I would like to see ..... interested in co-authoring a publication. Thanks.
I'm still working on the 'refinements' but i don't have much time.
Co-authoring... : As you may have noticed, English is not my native language. Making a good tutoral is not evident. A small video can be very efficient .... .
I must say that there are some very good tutolals on this forum.
Good luck with your book. :D
pgarmyn
PluginStore Author
PluginStore Author
Postby Clayton49 » Tue Dec 31, 2013 1:27 pm
To all,
Having some problems installing this extension & getting it to work for some reason, any assistance would be greatly appreciated.
Question, as I'm using SU Pro 2013, I see the Plugin rbz file seems to be a non zipped file. Is it a case of just downloading this file to your PC to a folder of choice & then use the SU pull down menu "window" then "preferences" then install extension..??
I also see the zipped SU file 2008 version has another folder inside called recourses & two other files, .rbs & .rb. I assume these are the hatch pattern fills..?? So are there any fills for the SU Pro 2013 .rbz file..??
Over & out,
Clayton
Clayton49
Postby Clayton49 » Wed Jan 01, 2014 11:17 am
Clayton49 wrote:To all,
.............Having some problems installing this extension & getting it to work for some reason, any assistance would be greatly appreciated..............
Panic over, all now installed & working o.k. :ecstatic:
Most of the first set of settings on the menu with regards to hatch/fill types can be figured out. However the fill names won't mean anything until a few experiments & perhaps re-name to ones own personal library, although all can be seen in the materials SU menu & edited/renamed from this location.
I'll have to have another look a the vid's for other menu settings....I'll have to also look out for a help file, I'm sure there's one somewhere..!!!
In conclusion, this extension is great & will help me ton's with building plans & sections. :thumb: Another obvious missing tool that SU HQ should have in the box. :!:
Over & out,
Clayton
Over & out,
Clayton.
Trotman & Taylor
Architectural Consultants
Clayton49
Postby pgarmyn » Thu Jan 02, 2014 3:20 pm
Clayton49 wrote:...
...... the fill names won't mean anything until a few experiments & perhaps re-name ..... own personal library, although all can be seen in the materials SU menu & edited/renamed from this location. I'll have to have another look a the vid's for other menu settings....I'll have to also look out for a help file, I'm sure there's one somewhere..!!! In conclusion, this extension is great & will help me ton'..... Over & out,
Clayton
The most practical way to install and update plugins is the Sketchucation pluginstore (also called 'Sketchucation Tools') from Rich O Brien. Just one click to install or update any plugin ( for SU-2013 and the last versions of SU-8)
About all the options: i will make more videos. All the existing videos are in this post. You can alse read the posts above (27 nov 2013 ...).
I'm glad my plugin is usefull. I'm still working on it. So keep an eye on this post. :D
pgarmyn
PluginStore Author
PluginStore Author
Postby garyion » Mon Jan 06, 2014 5:13 pm
mladen90 wrote:This is unbelivable! Thank you soo much pgarmyn for sharing this.
It is just what i have been searching for for years. Now sketchup could be finally used as a proper drawing tool, without worrying are cetions up to date, visible to other scenes etc.
I downloaded it yesterday via sketchucation plugin manager and it says it's expired back in march 2014?.
https://dl.dropboxusercontent.com/u/350 ... xpired.jpg
I thought i should report this.
Thank you again pgarmyn!
I am having the same problem - "This plug in has expired"
I am using Sketchup Pro 2013 on Mac OSX, I haven't changed the date or any settings
http://www.flickr.com/photos/garymcginty/11800940273
any help would great,
this is a great plugin - should be a paid plugin
thanks,
Gary
garyion
Premium Member
Premium Member
Postby pgarmyn » Mon Jan 06, 2014 6:25 pm
@garyion
There have been 2 updates since mladen90 reported that bug?
Are you using the latest version : V0.0.3. ?
It will mark “Version: V00.03-2013.12.04-20:00 DEMO” in menu>Plugins>RichSection>About RichSection.
I suggest to install with PluginStore.with PluginStore.
http://sketchucation.com/pluginstore?pln=SketchUcationTools
Before installing plugins, you will need full access to the plugins folder.
Select 'pgarmyn' for 'Authors' in the pluginstore and you will find the latest update.
Let me know if this lost your problem :?: :D
pgarmyn
PluginStore Author
PluginStore Author
Postby fionmacool » Fri Jan 10, 2014 7:28 pm
Hey sorry for the long delay and thanks for the response- I would be delighted to show off your plugin in a free video here as well as including it in the book.
One big wish I would have for the plugin is to enable the 2D information to "float" above the model. This requires the section cut to be grouped with the building while the 2D info is outside this group. Please see the examples attached where the section info is floating one inch above the model.
Note also:
The line colours are set to "by material" so all groups that require definition are coloured black or dark while their internal surfaces are textured individually.
The colour of the section cut is set to a light hue and a thickness of 1 unit.
Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
fionmacool
Premium Member
Premium Member
Postby pgarmyn » Sun Jan 19, 2014 3:10 pm
@fionmacool
Hi fionmacool.
I guess you want to hide section-lines between different elements?
There is a beter way to controle that. I will make (soon) some "how to" videos. I will post them with the next update.
I want to keep the nesting & layer structure of the section-group identical to the model. To syncronize visibility and invisibility if certain layers are switched off.
It can become an option if you can really convince me of the advantage in a standard workflow to produce several sections of one model.
pgarmyn
PluginStore Author
PluginStore Author
Postby jeff hammond » Sun Jan 19, 2014 4:51 pm
solo wrote:
Rich O Brien wrote:Indigo respect Section Cuts
Rich, can you confirm that Indigo works with this plugin?
not sure if there's a way to make the cut color the same as the object? haven't really messed around with the settings too much in richSection.
Then I guess I'd like to know how Indigo can do it and other cannot.
maybe because whaat wrote skindigo? ;)
dotdotdot
jeff hammond
Global Moderator
Postby pgarmyn » Sun Jan 19, 2014 6:26 pm
jeff hammond wrote:not sure if there's a way to make the cut color the same as the object? haven't really messed around with the settings too much in richSection.
YES :D
Parameters for "cut color the same as the object" :
- Set 'RichSection material name' to "prefix+materialname, default"
- Set 'RichSection materials, prefix' to "" (empty)
pgarmyn
PluginStore Author
PluginStore Author
Postby fionmacool » Sun Jan 19, 2014 6:59 pm
pgarmyn wrote:@fionmacool
Thanks for your reply. OK so I'm not sure I understand you entirely... but to answer your last point- definitely multiple sections are desirable for each model- all technical drawings require one plan and one vertical section at least. The problem at the moment is that the 2D section info is "behind" the section cut so that it interferes with visibility. Does that make sense?
fionmacool
Premium Member
Premium Member
Postby pgarmyn » Sun Jan 19, 2014 7:45 pm
fionmacool wrote: .....that it interferes with visibility. Does that make sense?
What do you mean by interfere...
In this model floorslabs, stairs, walls etc. are separated groups. But i can control visibility of the faces separating those elements.... Zere are still some .... ?
pgarmyn
PluginStore Author
PluginStore Author
Postby jeff hammond » Mon Jan 20, 2014 12:25 am
pgarmyn wrote:YES :D
neat.
i tried a quick one in indigo with glass, metal, and wood..
i didn't let it render as long as it would need but it shows that it would work in an actual render..
glass- one solid sphere (rendered as a solid piece of glass)
metal- sphere inside a sphere (rendered as if it were a bowl)
wood- i resized the texture on the facing side.. the cut shows the original size.. probably not good to use this technique on renders requiring high quality texturing/mapping (as in- that block would require end grain etc.)
dotdotdot
jeff hammond
Global Moderator
Postby pgarmyn » Mon Jan 20, 2014 7:27 am
@jeff :thumb: :thumb:
pgarmyn
PluginStore Author
PluginStore Author
Postby kylintz » Tue Feb 11, 2014 7:37 am
I think it's perfect already. The last puzzle to this plugin, as suggestion would be :
1. How could the section manage not only material per group, but also the section line thickness for each group ?
2. And suppose we would like to create a furniture layout plan, how could we let furniture layer not afected by the section plane while at the same time letting the wall layer, column layer, windows and door cut by section plane in easy way? A different hierarchy in grouping works well, leaving the furniture group outside the parrent group of wall, door, window, floor, structure, but that would mean a special group just for the sake of displaying unsliced furniture on the floor plan.
kylintz
Postby pgarmyn » Thu Feb 13, 2014 8:05 pm
@kylintz
1. The sectionlines are produced by Sketchup. There is no way to control thickness. An option could be to ad sectionlines with TIG's linestyle (2D Tool). I plan to add dxf export with that capability: Sectionline by layer.
2. A special group is the only solution. The Sketchup Ruby API (programmer interface) doesn't let you controle what to cut.
:D Thanks for your interest. :D
pgarmyn
PluginStore Author
PluginStore Author
[Plugin] RichSection [Demo] UPDATED (feb-2014)
Postby pgarmyn » Sun Feb 23, 2014 10:52 pm
RichSection plugin UPDATED : download from the Plugin Store
http://sketchucation.com/pluginstore?pauthor=pgarmyn
pgarmyn
PluginStore Author
PluginStore Author
Re: [Plugin] RichSection [Demo] V00.01 UPDATED feb 2014
Postby diegob » Tue Feb 25, 2014 4:07 pm
I've just intsalled your updated plug-in
but apparently is not working
once Sketchup is started, a window is telling me that:
Error loading files PiGa_Richsection.rb
can not convert nil into String
ca you please help me?
diegob
Postby bimbachi » Tue Feb 25, 2014 5:27 pm
hello,
after install via skechucation plugin store on mac sketchup
- when starting skp. i'm geting this rubby error messge
"Error Loading File PiGa_RichSection.rb
can't convert nil into String"
can you advice?
bimbachi
Postby pgarmyn » Tue Feb 25, 2014 8:46 pm
@bimbachi @diegob
It must be a MAC related problem, you are both running on MAC ?
Any other Mac users with problems :?: :?: :?: :?: :?:
I have no explanation. For me it works on SU8 and SU2013. But i can't test it on mac.
Can you test the following : disable all the other plugins :?:
If this doesn't help, can you test the following file : replace PiGa_RichSection.rb (in directory ..SketchUp..\Plugins) by the file below, and tell me if it works :?:
Thanks in advance.
file deleted
pgarmyn
PluginStore Author
PluginStore Author
Postby bimbachi » Tue Feb 25, 2014 11:00 pm
pgarmyn wrote:@bimbachi @diegob
Thanks in advance.
@pgarmyn
done what you adviced
& no more error on app startup
but ...
at short test looks like that it is not working (add new section result nothing)
bimbachi
Postby pgarmyn » Tue Feb 25, 2014 11:09 pm
@Bimbach
Done as advised? What did you do : Uninstalled plugins, other file installed, or both?
RichSection only creats sectionfaces for groups that produce a closed section.
Did you activate the extension in 'preferences' ?
Is there a menu in plugins/RichSection?
Open the ruby panel : what is printed in the ruby-panel?
pgarmyn
PluginStore Author
PluginStore Author
Postby floffy1983 » Wed Feb 26, 2014 10:28 am
It looks like my wish-list plugin, but i cannot get it to load.
If it helps, i am stuck with the Italian SU8 on a partially locked down office pc, partially as i can install plugins but can't update.
floffy1983
Postby factopedia » Wed Feb 26, 2014 10:59 am
Thanks so much.
factopedia
Postby pgarmyn » Wed Feb 26, 2014 12:58 pm
@floffy1983
What system (mac/windows) ? what version ?
Please complete your profile. This can help me to find a solution for you?
pgarmyn
PluginStore Author
PluginStore Author
Postby pgarmyn » Wed Feb 26, 2014 1:00 pm
factopedia wrote:Thanks so much.
Glad you like it :D
pgarmyn
PluginStore Author
PluginStore Author
Postby floffy1983 » Wed Feb 26, 2014 2:32 pm
pgarmyn wrote:What system (mac/windows) ? what version ?
Sorry, you are perfectly right.
I am working on a windows xp machine, pentium 4, 2gb.
I weep daily for its lack of power, but alas, my place of work will not let me bring my own laptop.
floffy1983
Postby cilemomax » Wed Feb 26, 2014 2:59 pm
Can you help me with something? how do I uninstall it. I deleted it but every time I start up the program it gets an error saying it's trying loading the file. Thanks in advance
cilemomax
Postby bimbachi » Wed Feb 26, 2014 3:27 pm
pgarmyn wrote:@Bimbach
ok (following on mac issue)
1./ as adviced I replaced only the file you forwarded "PiGa_RichSection.rb"
2./ then no more loading error on startup
3./ than RichSection is in the palet and plugins menu
4./ than when clicking or choosing from menu - "create richsection" in rubby panel there is:
"Error: #<TypeError: can't convert nil into String>
(eval):917:in `+'
(eval):917:in `l_ctrl'
(eval):1466:in `createRichSectionTool'
(eval):4353:in `require'
(eval):917:in `call'
(eval):917"
bimbachi
Postby lcarlin247 » Wed Feb 26, 2014 6:42 pm
It just does not work to me, i create the section but the paremeters do not appear, not even by using the paremeters icon
any advice? i use skp 2013
lcarlin247
PreviousNext
Return to Plugins
Users browsing this forum: Bioarqman, gunawanlien, pharezscruggs, wasi and 10 guests
