[Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19
Re: [Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19
Postby rv1974 » Wed May 06, 2020 7:58 pm
something like this
rv1974
Postby rv1974 » Wed May 06, 2020 8:28 pm
>>Many things can be done, but it would make the UI more complex...
Ok, I'm just suggesting to tweak the plugin's behavior without UI changing:
If face selection = surface,
molding not equal 0,
borders = grid,
Then
'moldings' to be created between surfaces (and not along contour only)?
rv1974
Postby a_pusen » Sat Jun 27, 2020 1:07 pm
This does not work in Sketchup 2020 after installing the latest Fredotools. When will this be fixed?
a_pusen
Postby TIG » Mon Jun 29, 2020 10:22 am
It should work OK.
You need the latest RBZs installing for the Fredo Extensions and his LibFredo.
Note that the JPP Extension is separate from FredoTools Extension ???
After installing them you'll also need to restart SketchUp to sync everything.
When you say, "it doesn't work", what is the problem ? what are the error messages ? etc - providing those [if any] would help us to help you...
Global Moderator
Postby Tymnastik » Tue Jul 21, 2020 6:47 am
Please I have installed fredo jpits shows on the tool bar but it won't work
Tymnastik
Postby Dave R » Wed Jul 22, 2020 12:57 am
Tymnastik wrote:its shows on the tool bar but it won't work
Did you also install LibFredo6?
What version of SketchUp are you actually using? Your profile says 2018 Free/Make but there is no such version. Knowing the right version could help us help you.
Global Moderator
Postby AISmebel » Thu Sep 03, 2020 10:33 am
hi Fredo.
I ran into such a problem, I cannot make a uniform indentation around the entire perimeter on a model with an irregular shape. I couldn't find any plugin that could do this.
I have a big request to you to consider this improvement in the next versions of your excellent plugin. Thank you so much for your work!
https://youtu.be/wCsli3Ps7xc
AISmebel
Postby slb_jwm » Thu Nov 12, 2020 5:00 pm
Joint push pull Joint and Thickener both fail with errors when I try to make this skin (part of a geodesic dome of frequency 3) thicker (by 3/4"). But they only do it when the component is part of a larger model.
In a separate model, both those forms work, but only extrude normal to the faces (as designed).
Extrude works, but takes only an average direction, presumably along the radius to the centre of the hexagon.
Feature request: could there be an option in the existing plugin to enlarge radially from a given centre? Either the origin of a component opened for editing, or perhaps picked by the user?
Icosahedral skin.skp
I've managed to do it approximately with the Scale tool, but can't get it to scale to an exact thickness of 3/4"
slb_jwm
PluginStore Author
PluginStore Author
Postby Dave R » Thu Nov 12, 2020 5:32 pm
Is this what you're trying to do?
Global Moderator
Postby fredo6 » Fri Nov 13, 2020 8:41 pm
JPP Thickening is done along the normal of faces. If it happens that all faces are perpendicular to the the radial dierction, then it is OK.
fredo6
PluginStore Author
PluginStore Author
Postby Raimondo_Vincenti » Mon Dec 14, 2020 4:02 pm
Installed libfredo6 11.4f -> JointPushPull is not awailable and cannot be installed anymore.
Message(german): "JointPushPull_v4.4e.rbz konnte nicht installiert werden."
Raimondo_Vincenti
Postby Dave R » Mon Dec 14, 2020 5:21 pm
Where are you looking for it?
https://sketchucation.com/pluginstore?pln=JointPushPull
Global Moderator
Postby TIG » Mon Dec 14, 2020 8:12 pm
If you have successfully downloaded Fredo's extension as an RBZ file, then you still need to 'Install' it... using the appropriate button on SketchUp's 'Extension Manager' dialog...
But note that, as explained in the extension's notes, it also requires you to download and install a suitable version of the Libfredo... RBZ... [>=8.7]
After that you will need to restart SketchUp to 'sync' the loading files...
Global Moderator
Postby Raimondo_Vincenti » Tue Dec 22, 2020 5:52 pm
Fredo6 Libfredo6 is installed (Version11.4f) is installed
Still cannot install JointPushPull - a Sketchup 2021 problem?
I could use JountPushPull in Sketchup 2020.
Raimondo_Vincenti
Postby Einstein » Sun Jan 10, 2021 4:06 pm
Hello,
I got an error with joint push pull extrusion in SketchUp 2020.
Date: 10-Jan-21 15:59:27
An error occurred in Joint Push Pull
Error in generation of the geometry
undefined method `target' for nil:NilClass
jointpushpullgeometry.rbe: 447 -- block in geometry_create_top_face
jointpushpullgeometry.rbe: 445 -- collect
jointpushpullgeometry.rbe: 445 -- geometry_create_top_face
jointpushpullgeometry.rbe: 258 -- block in geometry_robot_prepare_mesh
jointpushpullgeometry.rbe: 257 -- each
jointpushpullgeometry.rbe: 257 -- each_with_index
jointpushpullgeometry.rbe: 257 -- geometry_robot_prepare_mesh
jointpushpullgeometry.rbe: 212 -- robot_call_action
jointpushpullgeometry.rbe: 183 -- geometry_robot_exec
jointpushpullgeometry.rbe: 166 -- geometry_robot
jointpushpullgeometry.rbe: 81 -- block in geometry_execute
lib6operation.rbe: 369 -- step_geometry
lib6operation.rbe: 304 -- block in yield?
Einstein
Postby fredo6 » Sun Jan 10, 2021 4:55 pm
I guess you wish to push-pull all faces.
Then, you have a number of them which are ill-formed and there is nothing JPP can do about it. For instance, these group of buildings:
fredo6
PluginStore Author
PluginStore Author
Postby Einstein » Sun Jan 10, 2021 5:32 pm
Then would it be possible for the plugin to skip the ill-formed faces, leave them unextruded and proceed?
Ok, some of the faces are broken but most of them are OK. Why break entire operation due to a few wicked faces?
Einstein
Postby Dave R » Sun Jan 10, 2021 5:55 pm
Why not clean up the model before you add more geometry and potentially make more problems for yourself?
Global Moderator
Postby fredo6 » Sun Jan 10, 2021 6:38 pm
Einstein wrote:Then would it be possible for the plugin to skip the ill-formed faces, leave them unextruded and proceed?
I concur with Dave. Better clean up the model if you wish to do something with it.
Detecting and cleaning the problem is a whole big task in itself. It could deserve a plugin. This is not like Sketchup tells you the face is ill-formed or not. Actually, these faces are toplogically valid for Sketchup but they won't work with many transformations and operations.
So, using a detection and fixing before operating JPP would be counterproductive and a big hit to performance in 99.9% of cases where the geometry is OK.
fredo6
PluginStore Author
PluginStore Author
Postby Dave R » Sun Jan 10, 2021 7:09 pm
Thom Thom's CleanUp3 could remove coplanar edges to merge faces although it may not remove the correct edges. In this particular model it would be difficult for an extension to identify which edges should be removed.
Global Moderator
Postby Einstein » Sun Jan 10, 2021 10:22 pm
That's weird. I actually did a cleanup using ThomThom's plugin and JPP first threw an error. Then did a cleanup again and JPP worked fine.
I don't know why it happened but sorry for bothering you.
Einstein
Re: Project shape on a plane for Mac
Postby jpaine » Mon Jan 18, 2021 5:38 pm
Hi everyone,
Is project shape on a plane possible on a Mac? I can't seem to find this option.
jpaine
Previous
Return to Plugins
Users browsing this forum: astronat, karakasmimarlikmuhendislik, maxtar65 and 15 guests
