[Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19
Re: [Plugin] JointPushPull Interactive - v4.4d - 20 Feb 19
Postby SpookyChick1013 » Tue Mar 19, 2019 5:47 pm
Massively useful plugins as always Fredo. Had the following error found when attempting round pushpull. Here's the log dump.
Thanks in advance!
Date: 19-Mar-19 09:41:55
An error occurred in Round Push Pull
Error in generation of the geometry
undefined method `collect' for nil:NilClass
jointpushpull4geometry.rbe: 1450 -- geometry_rounding_mesh
jointpushpull4geometry.rbe: 1283 -- block in geometry_create_roundings
jointpushpull4geometry.rbe: 1282 -- each
jointpushpull4geometry.rbe: 1282 -- geometry_create_roundings
jointpushpull4geometry.rbe: 267 -- geometry_robot_prepare_mesh
jointpushpull4geometry.rbe: 211 -- robot_call_action
jointpushpull4geometry.rbe: 182 -- geometry_robot_exec
jointpushpull4geometry.rbe: 165 -- geometry_robot
jointpushpull4geometry.rbe: 80 -- block in geometry_execute
lib6operation.rbe: 365 -- call
lib6operation.rbe: 365 -- step_geometry
lib6operation.rbe: 413 -- start_execution
jointpushpull4geometry.rbe: 80 -- geometry_execute
jointpushpull4tool.rbe: 1034 -- go_preview_or_geom
jointpushpull4tool.rbe: 812 -- dragging_stop
https://kuromatsudriveyards.com
Fo-su to tomo ni aran koto o...
SpookyChick1013
Postby fredo6 » Tue Mar 19, 2019 6:52 pm
SpookyChick1013 wrote:Massively useful plugins as always Fredo. Had the following error found when attempting round pushpull. Here's the log dump.
You don't seem to have the latest version of JPP (it should be v4.4d).
Could you update it and advise. Thanks.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby SpookyChick1013 » Wed Mar 20, 2019 12:07 am
What? Wooops! You're right. I try to keep things updated, but somehow that one slipped past me.
I'll let you know once I've had a chance to test things. Thanks Fredo!
Update" Installed teh new version, made sure everything was updated, no conflicting versions, and presto, the same error.
Date: 22-Mar-19 11:54:25
jointpushpullgeometry.rbe: 1529 -- geometry_rounding_mesh
jointpushpullgeometry.rbe: 1362 -- block in geometry_create_roundings
jointpushpullgeometry.rbe: 1361 -- each
jointpushpullgeometry.rbe: 1361 -- geometry_create_roundings
jointpushpullgeometry.rbe: 269 -- geometry_robot_prepare_mesh
jointpushpullgeometry.rbe: 212 -- robot_call_action
jointpushpullgeometry.rbe: 183 -- geometry_robot_exec
jointpushpullgeometry.rbe: 166 -- geometry_robot
jointpushpullgeometry.rbe: 81 -- block in geometry_execute
jointpushpullgeometry.rbe: 81 -- geometry_execute
jointpushpulltool.rbe: 1119 -- go_preview_or_geom
jointpushpulltool.rbe: 845 -- dragging_stop
It happens whether I use the VCB or not. What I'm trying to do is Round PushPull the faces highlighted in the enclosed sreeen snip
If you need the model, let me know where to send it and I will do so.
Cathryn
SpookyChick1013
Postby HeyJujube » Fri Apr 05, 2019 8:33 am
J'ai de gros problèmes avec ce plugin (mode vecteur) sous SketchUp Pro 2019 (Mac 10.14). Problème connu ?
Merci
HeyJujube
Postby fredo6 » Fri Apr 05, 2019 11:51 am
HeyJujube wrote:J'ai de gros problèmes avec ce plugin (mode vecteur) sous SketchUp Pro 2019 (Mac 10.14). Problème connu ?
Merci
Difficile de juger sans le modele. Et, franchement, l'image ne me permet de savoir de quoi il s'agit.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby HeyJujube » Fri Apr 05, 2019 2:19 pm
N'importe quel modèle, ici une simple colonne inclinée pour l'exemple.
La face part dans tous les sens, se déforme, "explose".
J'ai toujours utilisé le plugin, mais récemment passage à SU 2019 sous Mac.
Merci
HeyJujube
Postby fredo6 » Fri Apr 05, 2019 4:52 pm
HeyJujube wrote:N'importe quel modèle, ici une simple colonne inclinée pour l'exemple.
Merci
it looks like the Vector direction is on the plane of the face.
Could you either lock an axis direction with the arrows, or find a proper direction and lock it (Shift).
fredo6
PluginStore Author
PluginStore Author
Postby theVonZipper » Mon Apr 22, 2019 11:16 pm
Thanks Fredo for the fantastic plugins. I use 'Divide faces' often and of course Joint Push Pull. Just wondering, is there a way for Push Pull Interactive to inherit layers from the faces they are affecting as the Classic version did?
theVonZipper
Postby Dave R » Mon Apr 22, 2019 11:39 pm
Faces and edges should always be created on and remain on Layer 0. See Controlling Visibility with Layers.
Global Moderator
Postby Einstein » Thu May 02, 2019 9:41 am
Hi!
I have an idea for a small feature upgrade.
Actually, two ideas ^^
1. Possibility to apply positive + negative offset in one go, so you can thicken a surface on both sides immediately
2. Extrude faces to point, like in Rhino. It would be almost analogic operation to scaling about a point which can be performed via ThomThom's Rotate and Scale. However, you'd then have to manually connect border edges of source and result meshes. Rhino has a tool which does everything in one step. I attach an illustration for it.
What do you think about it?
Einstein
Postby fredo6 » Thu May 02, 2019 10:00 am
Einstein wrote:1. Possibility to apply positive + negative offset in one go, so you can thicken a surface on both sides immediately
This is doable, though not trivial, because I have two generate two faces for each original face. It would also require an additional option, maybe triggered by a modifier; the only left is ALT (on Windows)
Einstein wrote:2. Extrude faces to point, like in Rhino. It would be almost analogic operation to scaling about a point which can be performed via ThomThom's Rotate and Scale. However, you'd then have to manually connect border edges of source and result meshes. Rhino has a tool which does everything in one step. I attach an illustration for it.
This would be a new tool actually. I need to think about it, but a priori an interesting idea.
fredo6
PluginStore Author
PluginStore Author
Postby Einstein » Sat May 25, 2019 4:09 pm
Could you please increase extreme angle values for Molding in the next release? Now it's +- 60, which is a serious limitation in some cases. I'd suggest 89 or even 90 - this would practically create a flat offset (nice!). Certainly, faces would overlap but that could be fixed manually.
Einstein
Postby fredo6 » Sun May 26, 2019 12:02 am
Einstein wrote:Could you please increase extreme angle values for Molding in the next release? Now it's +- 60, which is a serious limitation in some cases. I'd suggest 89 or even 90 - this would practically create a flat offset (nice!). Certainly, faces would overlap but that could be fixed manually.
If the angle is too large, then you are almost sure to get overlaps and mess up the extrusion.
Here is what I get with the set of letters, each one of width roughly 0.5 m. I had to reduce the offset of extrusion to 0.001 m (that is, 1mm) to get a molding at 85 deg. without overlap.
With an offset of 1cm, the extrusion gets seriously messy
I can increase it to 89 degrees. At 90, you reach math limit, since there is NO extrusion, and JPP does not like it. So, I'll probably pick 85 degrees, to make it a multiple of the 5 deg increment in a next release.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Einstein » Sun May 26, 2019 1:15 pm
Thank you :D
Einstein
Re: [Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19
Postby fredo6 » Sun Jun 02, 2019 9:28 am
NEW RELEASE: JointPushPull Interactive v4.4e - 02 Jun 19
JointPushPull Interactive 4.4e is a minor release including an increase of the maximum angle for Molding (now 85 degrees).
JointPushPull 4.4e requires LibFredo6 8.7m or above
See plugin home page of JointPushPull for Download of JointPushPull.
Main Post of the JointPushPull thread on this forum
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Einstein » Mon Jun 03, 2019 7:13 am
Thank you, for me it's a major release :D
Einstein
Postby jonnys777 » Thu Jun 20, 2019 8:40 am
Morning all,
I'm getting the follow error trying to thicken some terrain on the z-axis;
Date: 20-Jun-19 08:06:15
An error occurred in Vector Push Pull
Could not compute valid matrix from points
body_lib6g6.rbe: 4568 -- position_material
body_lib6g6.rbe: 4568 -- reverse_face_with_uv
jointpushpullgeometry.rbe: 556 -- block in geometry_handle_finishing
jointpushpullgeometry.rbe: 556 -- each
jointpushpullgeometry.rbe: 556 -- geometry_handle_finishing
jointpushpullgeometry.rbe: 376 -- geometry_robot_handle_finishing
jointpushpullgeometry.rbe: 222 -- robot_call_action
lib6operation.rbe: 370 -- call
lib6operation.rbe: 370 -- step_geometry
lib6operation.rbe: 305 -- block in yield?
SketchUp: 1 -- call
jonnys777
Postby jonnys777 » Mon Jun 24, 2019 5:06 pm
jonnys777 wrote:Morning all,
SketchUp: 1 -- call
I'm not having much luck resolving this. I've tried scaling up and inspecting the surface to see if there's anything obviously wrong. It allows Normal Push Pull, but Vector, Joint etc. all fail.
Any ideas as to what might be wrong?
It's a fairly complex surface - a piece of terrain that is a hill with sections cut out of it (I draped a road onto the surface so that counts as a separate surface, for example). The surface I want to extrude is vegetation and I need it locked to the z-axis otherwise the software I intend to import it into won't work properly.
Many thanks
jonnys777
Postby fredo6 » Tue Jun 25, 2019 6:53 am
jonnys777 wrote:I'm not having much luck resolving this. I've tried scaling up and inspecting the surface to see if there's anything obviously wrong. It allows Normal Push Pull, but Vector, Joint etc. all fail. Any ideas as to what might be wrong?
I included a fix in LibFredo6 9.0a
jonnys777 wrote:It's a fairly complex surface - a piece of terrain that is a hill with sections cut out of it (I draped a road onto the surface so that counts as a separate surface, for example). The surface I want to extrude is vegetation and I need it locked to the z-axis otherwise the software I intend to import it into won't work properly.
If you post or PM me the model, I can have a look and advise.
fredo6
PluginStore Author
PluginStore Author
Postby jonnys777 » Tue Jun 25, 2019 8:53 pm
Hi Fredo, I can confirm the updated version of LibFredo has solved my issues. Many thanks, and keep up the good work.
jonnys777
Postby DigitalArena » Thu Jun 27, 2019 4:21 pm
Have a problem with one installation of this set of tools on Pro 2019. We have the latest Fredo6Lib. We have installed the latest JointPushPull plugin. The tools appear in the toolbar. But when you select the surface and then the tool, the tool doesn't become active. You remain with the mouse pointer and it doesn't change to the selected JointPushPull tool.
Any idea why this would be happening?
We installed the same setup on another computer and everything is fine. Thoughts?
DigitalArena
Postby Dave R » Thu Jun 27, 2019 4:27 pm
When SketchUp 2019 was installed, did you right click on the installer and choose Run as administrator?
Global Moderator
Postby deaneau » Thu Aug 22, 2019 12:54 am
Feature Request in this Plugin
Hi Fredo is this possible to have an offset of faces with the same material?
I need this for a game.
The windows in the night will be the only face that has an offset. this face will save as a separate file (night mesh).
big thank you
MADE, BORN AND LIVING IN BERLIN
Big Thank You to all Programmers
Some German words are so long that they have a perspective. M.Twain
deaneau
Postby Ahmed0007 » Sat Oct 05, 2019 9:09 pm
Getting a bugsplat when trying to change the random push pull values. in sketchup 2019 and 18
any solution?
Ahmed0007
Postby Dave R » Sat Oct 05, 2019 10:38 pm
Ahmed0007 wrote:Getting a bugsplat... any solution?
You'd need to provide some useful information to be able to diagnose the problem and find a solution. Share the SKP file and the values you are trying to use.
Global Moderator
Postby Ahmed0007 » Sun Oct 06, 2019 12:13 am
here are:
Ahmed0007
Postby Dave R » Sun Oct 06, 2019 1:14 am
I don't have any problems with your file in SU2019.
Click on the picture to see it move.
Make sure have the current version installed along with the current version of LibFredo6 and make sure you installed SketchUp correctly. That is, you right clicked on the installer and selected Run as administrator from the context menu.
Global Moderator
Postby Ahmed0007 » Sun Oct 06, 2019 1:49 am
Dave R wrote:I don't have any problems with your file in SU2019.
yesterday i installed both JPP and Fredo6lib
everything is up to date
watch this https://streamable.com/oqz8g
Ahmed0007
Postby fredo6 » Sun Oct 06, 2019 11:56 am
I am unable to reproduce the problem either....
Do you get it always?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Ahmed0007 » Sun Oct 06, 2019 4:51 pm
fredo6 wrote:I am unable to reproduce the problem either....
Fredo
Thanks for reply
i haven't used random push pull a lot.
i found an old version of JPP (v3.6a) this also give me bugsplat screen. in su19
watch here : http://bit.ly/31SyEk5
Edit ; and latest version of JPP is working fine with SU2017
Ahmed0007
PreviousNext
Return to Plugins
Users browsing this forum: Camilahl22, jediferraz and 13 guests
