CadFather wrote:just when i drag - typing a negative/positive value works as expected
Not clear
- one particular tool or all tools?
- if you drag, how does this happen exactly?
Fredo
[Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19Re: [Plugin] JointPushPull Interactive - v4.3b - 25 Feb 18
Not clear - one particular tool or all tools? - if you drag, how does this happen exactly? Fredo
Re: [Plugin] JointPushPull Interactive - v4.3c - 27 Feb 18NEW RELEASE: JointPushPull Interactive v4.3c - 27 Feb 18
JointPushPull Interactive 4.3c fixes bugs in the Vector tool, as signaled by Einstein (see this post). You also need to upgrade LibFredo6 to v8.1c. JointPushPull 4.3c requires LibFredo6 8.1c or above ---------------------------------------------------------------------------- See plugin home page of JointPushPull for Download of JointPushPull. Main Post of the JointPushPull thread on this forum Fredo
Impressive, clearly a bug or a mystery. Could you post the model, so that I try to understand what happens. Thanks Fredo EDIT: I could reproduce the problem (when the group is upside down). Fixing it. Thanks for signaling.
Re: [Plugin] JointPushPull Interactive - v4.3d - 28 Feb 18NEW RELEASE: JointPushPull Interactive v4.3d - 27 Feb 18
JointPushPull Interactive 4.3d fixes bugs preventing to have a correct orientation of the pushpull direction when used on groups and components, as signaled by Cadather (see this post). You also need to upgrade LibFredo6 to v8.1c. JointPushPull 4.3d requires LibFredo6 8.1c or above ---------------------------------------------------------------------------- See plugin home page of JointPushPull for Download of JointPushPull. Main Post of the JointPushPull thread on this forum Fredo
Re: [Plugin] JointPushPull Interactive - v4.3e - 28 Feb 18NEW RELEASE: JointPushPull Interactive v4.3e - 28 Feb 18
JointPushPull Interactive 4.3e fixes remaining bugs preventing to have a correct orientation of the pushpull direction when used on groups and components, as signaled by CadFather (see this post). You also need to upgrade LibFredo6 to v8.1c. JointPushPull 4.3e requires LibFredo6 8.1c or above ---------------------------------------------------------------------------- See plugin home page of JointPushPull for Download of JointPushPull. Main Post of the JointPushPull thread on this forum Fredo
Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18NEW RELEASE: JointPushPull Interactive v4.3f - 02 Mar 18
JointPushPull Interactive 4.3f fixes a major bug introduced in v4.3e. Thanks for upgrading and sorry for inconvenience[/b]. JointPushPull 4.3f requires LibFredo6 8.1c or above ---------------------------------------------------------------------------- See plugin home page of JointPushPull for Download of JointPushPull. Main Post of the JointPushPull thread on this forum Fredo
Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18I tried a few times to install 4.3f and get this error each time.
I have LibFredo6 8.1c installed.
Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18... if interested and not yet known or seen so far, TheSketchUpEssentials has recently posted a pretty good and worth seeing video about this tool with the mysterious title "8 SECRET FUNCTIONS of the SketchUp Joint Push Pull Extension"
![]() https://www.youtube.com/watch?v=wOl9qQXwwbw&t=210s never trust a skinny cook
Very strange! How do you install it - from the Sketchup RBZ installer - from the Sketchucation PluginStore? Fredo
I downloaded it from here: https://sketchucation.com/plugin/715-jointpushpull I try installing through the Extension Manager Click image to see the gif.
Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18FYI
I have successfully installed this version's using the PluginStore's downloaded RBZ, using the native Extension Manager's red-button, in both v2017 & v2018, on both PC & MAC. I have also successfully installed it using the SketchUcation ExtensionStore³ dialog's 'AutoInstall' red-button, again in both of those SketchUp versions and OSs. I also pre-installed the latest LibFredo6 in those 4 permutations... TIG
Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18Hm, odd.
I have not had this issue before. I installed each update you have put up the past week as well. I get the same error trying to install in 2017 through the Extension Manager also. Must be something on my end although I don't know what. Restarting my computer did not solve it. I have never tried the installing through the Sketchucation PluginStore.
Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18-Solved-
Well this is even more strange. It was definitely an issue on my end. I went to try it again just now, after about a half hour of trying it last time, and the extension was not in the folder I saved it in. It was just gone. I am assuming it is an issue with our server profile here at work as we have seen files disappear before. I also assume on my previous attempts to install this plugin that the server was showing the file but it was not actually there. Not sure. Anyway, I downloaded a fresh .rbz and it installed just fine. Sorry for the uproar.
Good for you. It's anyway good to know this case, as it may happen to someone else, including when try to open a skp file. Fredo
Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18Thanks for creating these awesome tools! i just tried the JPP "project on a plane" trick on some topo i created and I'm getting a Ruby Error. it says "Error in generation of the geometry" and "Not enough points - at least 3 required". Any Idea what is going on?
-thanks Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18
I would need to get the model, and also have the full text of the error message. Fredo
Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18I used to use this tool extensively to create curbs from complicated terrain, and it worked almost perfectly. The new version, however, with all it's options, no longer has a tool for extruding in z axis, which baffles me. Does anyone know if there's a variable that can be changed in settings to fix this, or know of another tool to achieve the same effect?
Thanks Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18
Could you show a sample of model to illustrate your problem. Fredo
Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18Hi FREDO,
This plugin is sooo good. Thankyou. Donation on its way. There is one quirk that i dont understand and makes the plugin unuseful when dealing with 'group copies' If editing a group of which copies have been made, all group copies are also affected. I'd expect this behaviour only for components not groups. The behaviour id expect is that if i joint push pull a face of a group, that only that group is modified, not every other instance. Have I overlooked some setting to turn this behaviour off ? Cheers John Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18
I'll probably have to fix this general issue, not just for JPP, which comes from a side effect of Sketchup (freshly copied groups behave as components until they are edited, for optimization). In the meantime, I would suggest that you go inside the group to do the Joint Push Pull, as you would do for the native Push Pull. The capability to operate across boundaries of group and components is just a convenience. Fredo
Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18Ok that makes sense, i was aware of that optimisation of the group definition.
I'll happily edit from within the group for now, but definitely look forward to an option to treat group copies as individual groups when using joint push pull when you get time to implement it. Thanks ![]() Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18Hi!
I caught a bug. Here it is: I extruded several connected faces with JPP and choose the option which removes source faces, leaving only extrusion. I confirmed the extrusion and then did UNDO. Unfortunately undoing can't be done in one go. Instead, it's "broken" into small steps and it brings back my source geometry edge by edge so I have to press UNDO many times. It happens with every sub-tool of JPP. I'm using SU17 with newest JPP and newest LibFredo. Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18You would make it easier to sort out if you share the SKP file that exhibits this behavior. I just tried it and found Undo still works in a single step.
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18It's OK when I use THICKEN option. But UNDO breaks when using PUSH-PULL option (source faces get erased).
Here's my file: Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18
There could be an error. Could you open the Ruby console while doing the JPP operation. Also, does it happen with any shape or model, or specifically for one? Fredo
Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18There's an error related to layers. Any time your plugins are used, there's a new layer created "LIBFREDO6_TEMP_LAYER", the geometry-to-remove is moved to that layer and it immediately gets turned off, probably due to another plugin that I use - LAYERS PANEL. As long as I remember to turn on this layer, everything goes fine and UNDO doesn't break anymore.
The bug/error is not related to any particular model or shape. Re: [Plugin] JointPushPull Interactive - v4.3f - 02 Mar 18
This seems definitely to be related the another plugin, jbb_layer_panels, which has an observer and does not cover cases when layers are deleted. Who is the author? I use the TEMP layer to simply hide faces temporarily, but JPP (as FredoCorner) deletes the layer afterwards. Fredo
I'm used to have this layer turned on by default for a long long time. Layer's panel is a fundamental tool.
But the small bug can be fixed by in Layer Panels...
