[Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19
Re: [Plugin] JointPushPull Interactive - v3.1a - 27 Nov 13
Postby fredo6 » Wed Nov 27, 2013 9:38 pm
NEW RELEASE: JointPush Pull Interactive v3.1a - 27 Nov 13
JointPushPull Interactive 3.1a is a release for future Sketchup compatibility.
See main post of this thread for Download.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] JointPushPull Interactive - v3.0h - 29 Oct 13
Postby blackquod » Fri Dec 06, 2013 3:16 am
BruceG wrote:Doesn't seem to work in my Windows 8.1 machine. Previous push/pull still works fine. It will highlight sections but not select more than one or if one is selected it will not extrude. Anyone else with this problem?
Try running sketchup.exe in compatibility mode for Windows 7/8. It worked for me.
blackquod
Postby kaas » Wed Dec 11, 2013 3:07 pm
any chance you know whats causing this error?
Date: 11-Dec-13 15:01:48
An error occured in Joint Push Pull
Error in Analysis of model
undefined method `entityID' for nil:NilClass
JointPushPullAlgo.rb: 377 -- algo_analyze_groupings
JointPushPullAlgo.rb: 489 -- algo_prepare_calculation_exec
JointPushPullAlgo.rb: 476 -- algo_prepare_calculation
JointPushPullTool.rb: 892 -- modify_preparation
JointPushPullTool.rb: 910 -- modify_execute
JointPushPullTool.rb: 931 -- modify_offset
JointPushPullTool.rb: 1128 -- execute_validate
JointPushPullTool.rb: 1327 -- onReturn
kaas
Postby fredo6 » Wed Dec 11, 2013 5:05 pm
It's a small bug when
- you do a first Push pull
- then you press Return, whereas there is no face selected
I'll fix it in a next release
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby pilou » Mon Dec 30, 2013 3:33 am
does this is possible or I miss something ?
(i have not tested with the new version)
Speedy Galerie
Top SketchUcator
Postby Dave R » Mon Dec 30, 2013 3:59 am
It worked for me, Pilou. You should try it.
Global Moderator
Postby pilou » Mon Dec 30, 2013 5:06 pm
With the old version the best was that! :shock:
Cool now with this new version that is working as wished! :thumb:
Speedy Galerie
Top SketchUcator
Postby rekin0 » Tue Dec 31, 2013 9:27 am
Thanks a lot!
rekin0
Postby Elmer BeFuddled » Sat Jan 18, 2014 3:28 pm
Greetings!
I'm having a problem with trying to use this tool. When I open SU I get an error msg regarding LibFredo as below:
Code: Select all
Error Loading File C:/Program Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_!LibFredo6/__loader.rb
(eval):1:in `effective_load_part2': compile error
(eval):1: syntax error, unexpected tINTEGER, expecting ')'
...Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_!LibFredo6', '...
(eval):1: syntax error, unexpected tCONSTANT, expecting kDO or '{' or '('
... '13/Plugins/Fredo6_!LibFredo6', 'LibFredo6') ; MYDEFPARAM =...
(eval):1: syntax error, unexpected tCONSTANT, expecting kEND
...Fredo6_!LibFredo6', 'LibFredo6') ; MYDEFPARAM = MYPLUGIN.cre...
..._PLATFORM =~ /darwin/i) ? 'MAC' : 'PC' ;RUN_ON_MAC = false ;...
...RM =~ /darwin/i) ? 'MAC' : 'PC' ;RUN_ON_MAC = false ;end
(eval):1: unterminated string meets end of file
(eval):1: syntax error, unexpected $end, expecting kEND
... 'PC' ;RUN_ON_MAC = false ;end
Error Loading File C:/Program Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_ToolsOnSurface/__loader.rb
...Files (x86)/DESIGN/SketchUp '13/Plugins/Fredo6_ToolsOnSurface...
(eval):1: syntax error, unexpected tSTRING_BEG, expecting kDO or '{' or '('
...Plugins/Fredo6_ToolsOnSurface', 'ToolsOnSurface') ; MYDEFPAR...
...olsOnSurface', 'ToolsOnSurface') ; MYDEFPARAM = MYPLUGIN.cre...
I've just installed Ruby, as well, although not where it wants to go (in the root of C:\. Nothing goes there unless Security logs!) Its been installed to the same sub-folder in Program Files as SketchUp.
Any hints or tips to help me?
On a good note (always leave 'em happy Elmer!!) I've just installed the bezier curve tool. What a little beauty!!
Elmer BeFuddled
Postby cotty » Sat Jan 18, 2014 6:44 pm
You should never use special characters in path names!
in your case: '13...
cotty
Top SketchUcator
Postby TIG » Sat Jan 18, 2014 8:01 pm
Certainly special characters like é or ö will break the current version of Ruby that ships with SketchUp.
The ' is a special case, because it breaks some Ruby and js when passed in a string that is 'raw'.
The author can use " " to encapsulate Ruby string parts so the included ' is preserved.
Or if the encapsulation is ' ' it must then be escaped - tr("'","\'") for js use it's best perhaps as say tr("'","\\\\'") ...
But for now please leave ' out of your path-names - there are many alternatives... :roll:
Global Moderator
Postby numerobis » Sat Jan 18, 2014 8:30 pm
Almost two months online already... How could i miss this one?!? :o
Unbelievable! You've done it again... Great improvement! 8-)
I'm not sure if the sketchup "developers" are still following what's going on with their software on plugin level... If i would be in their position i would really be ashamed...
numerobis
Postby Elmer BeFuddled » Sun Jan 19, 2014 1:52 am
cotty wrote:You should never use special characters in path names!
TIG wrote:Certainly special characters like é or ö will break the current version of Ruby that ships with SketchUp.
Right, I shall remove the offending "happy oz trophy" (which is a straight one, nothing oblique or fancy) from the SU file path.
Its never affected any thing else when I abb. (tee hee!! ;) ) the date in the path name but I'll be honest, up until ten days ago I'd never heard of Ruby, heathen that I am!!
A thought. A.N.Other plug-in, the SVG importer that required rexml (from Ruby) to be added into the plug-ins folder didn't work either, though I can't remember the error msg. I received.
It may also be why I can't import *.dxf files from Inkscape that were made from a *.pdf files that were made in Photoshop from *.psd files that were made from thoughts in my single malt, whisky hazed mind!
Back to the point, I'll update you with as to how things went.
!!! HOT OFF THE PRESSES !!!
An Update.
Well, I re-installed SU to C:\Program Files (x86)\DEVELOP\SketchUp 13 and Ruby to C:\Program Files (x86)\DEVELOP\Ruby193 and voila!! Joint Push Pull and Tools on Surface both popped up their toolbars when I opened up SU.
Who'd have thunked a little apostrophe could cause so much hassle!
That would never of crossed my mind as I've been 'apostrophising' install paths and file names since Jesus left Kilmarnock (a.k.a a very long time) with no issues. Strange how the parenthesis as in (x86) get ignored!
Still having problems with the svg importer (the error message shows one oblique and one straight comma) but I'll post about that in the correct place.
Many many thanks to you cotty and TIG for your help. I'd have got nowhere without it.
:ecstatic: :ecstatic: :ecstatic:
Elmer
Elmer BeFuddled
Re: [Plugin] JointPushPull Interactive - v3.2a - 25 Jan 14
Postby fredo6 » Sat Jan 25, 2014 11:02 am
NEW RELEASE: JointPush Pull Interactive v3.2a - 25 Jan 14
JointPushPull Interactive 3.2a includes a Projected mode for Vector Push-Pull (see video).
Fredo
3
fredo6
PluginStore Author
PluginStore Author
Postby cotty » Sat Jan 25, 2014 11:13 am
One WOW! per day, a good average ;-)
:thumb:
cotty
Top SketchUcator
Postby CadFather » Sat Jan 25, 2014 11:23 am
wow indeed, here's a scary thought... ..imagine life without Fredo6..... :shock: :lol:
CadFather
PluginStore Author
PluginStore Author
Postby babak » Sun Jan 26, 2014 12:35 pm
Happy new year and thank you very much !
babak
Postby pilou » Sun Jan 26, 2014 5:25 pm
Hello Fredo
Does it possible to keep a multiple selection result of a JPP for another "Joint Push Pull" ?
CTRL seems don't working! :?
If not does exist a plugin for a "circular selection" ?
Will be cool in this case (for select all vertical faces) and many other cases! :)
A general circular selection will be sufficient with the help of the Inverse Selection existing! ;)
On the right one result wanted...sor many other JPP are missing! :)
Speedy Galerie
Top SketchUcator
Postby numerobis » Mon Jan 27, 2014 1:16 am
did you try to recall the last selection?
http://sketchucation.com/pluginstore?pl ... ion_memory
numerobis
Postby pilou » Mon Jan 27, 2014 11:44 am
No! I will try that! :)
But Circular selection wiil be also a cool thing for another thing if possible! :)
Speedy Galerie
Top SketchUcator
Postby pilou » Tue Jan 28, 2014 10:45 am
@numerobis
I have used the Thomthom Recall last selection but alas that can't work in this case because of course it's a new selection never yet selected! :o
Speedy Galerie
Top SketchUcator
Postby Ben Ritter » Wed Jan 29, 2014 2:57 pm
Fredo, thank you!!!!
Ben Ritter
Postby tetrochuan » Sat Feb 01, 2014 12:17 pm
hi there,
thanks for you awesoem plugin...
may i report a something strange on the joint push pull tool
i have made 2 circles and extruded them up as wall and then drew with tools on surface an arc on it - i tried to do everything as simple and geomeetrically correct as possible - then i wanted to push the arc inwards (the goal would be the inward operation with respect to the circle curvature...)
but joint push pull gives ackward results which are not expected from me..
would love if anyone could give an alternate solution =)
i also tried to construct and draw the arc on the inside but then i have to draw the intermediate wall features all manually... and since there are 12 arcs.. hm.
see the second pic .. it shows what i want.. accomplished via manual arcs drewn on both sides and then curvilofted the inbetween...
would be nice if joint push pull would handle cuved sufaces well
tetrochuan
Postby pilou » Sat Feb 01, 2014 12:29 pm
Seems you can make something with the Taper function inside the plugin?
But seems you don't escape to make an intersection and some delete! :shock:
if you have the Pro seems boolean solids Difference will be fine ?
Speedy Galerie
Top SketchUcator
Postby pilou » Sat Feb 01, 2014 2:37 pm
And it's maybe more tricky to make a thickness with The JPP ! ;)
You will obtain more easily that you want! :)
Speedy Galerie
Top SketchUcator
Postby Dave R » Sat Feb 01, 2014 3:08 pm
Another thing to consider is that changing the order in which you do things might change the outcome. Pilou's second example shows that with his opening drawn before the wall is given thickness. An alternative might be as shown below.
Or maybe you break the thing down into a single copy of the repeating element and, once you've drawn it, copy that as needed.
Global Moderator
Postby tetrochuan » Sat Feb 01, 2014 3:19 pm
hi there, thanks for all your replies - i will give it a try and give you some feedback...
its nice if a problem gets proper response=)
tetrochuan
Postby TechnoGuru » Mon Feb 03, 2014 4:28 pm
Hello Fredo, You mention the need of LibFredo6 5.4 (the most recent available as of now) for JointPshPull, but I get the message ''need library 55 or higher'' on startup, and the plugin will not work. Where can we get LibFredo6 5.5 ?
Thanks CC
TechnoGuru
Postby Dave R » Mon Feb 03, 2014 7:13 pm
TechnoGuru wrote:Hello Fredo, You mention the need of LibFredo6 5.4 (the most recent available as of now) for JointPshPull, but I get the message ''need library 55 or higher'' on startup, and the plugin will not work. Where can we get LibFredo6 5.5 ?
Thanks CC
You could try this thread: viewtopic.php?f=323&t=17947 but you should really install the Sketchucation Plugin Store and auto-install plugins.
Global Moderator
Postby BruceG » Tue Feb 04, 2014 2:59 pm
I've installed the latest version and still have no luck with the new joint push pull in Windows 8.1. The old joint push pull still functions. I have a similar problem with AMD 7700 video card with latest updated driver and the following installed
extensions:SketchUcation
3DxSketchUp
BezierSpline
Dialog
Bulge
Push
Smooth
Smudge
Grab
Planar Lock
Arcs Circles
Fredo6 LibFredo6
Fredo6 Curviloft
Fredo6 Curvizard
Fredo6 FredoScale
Fredo6 Fredo Tools
Fredo6 JointPushPull
Fredo6 Round Corner
Fredo6 Tools on Surface
JointPushPull
quarr_jsalign
s4u-AlignTool
STL Import & Export
CleanUp³
TT_Lib²
Edge Tools²
Solid Inspector
Any suggestions?
BruceG
PreviousNext
Return to Plugins
Users browsing this forum: ainakn, diethereotype23, Mrglrts and 12 guests
