[Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19
Re: [Plugin] JointPushPull Interactive - v3.3b - 09 Jan 15
Postby Dave R » Thu Apr 30, 2015 10:56 am
It's poorly drawn at the end near the red axis. If you did a better job of drawing it, Joint Push/Pull wouldn't fail.
Global Moderator
Postby littleche » Thu Apr 30, 2015 6:07 pm
HI Dave
I had not checked the lines For this reason,The main tool push&pull was not any problem.
I did not know that fredo plugin is more sensitive.
thank you ...
littleche
Postby Dave R » Thu Apr 30, 2015 6:26 pm
I don't know that it's more sensitive but since you have that little triangular loop with no face in it, i'd guess that causes problems. Try this: Scale the entire geometry up by a factor of 1000. make a face on that triangle by tracing one edge of it with the Line tool. Then trying running Joint Push/Pull on the result.
Global Moderator
Postby derei » Fri Jul 10, 2015 3:03 pm
Hy, I am a bit confused on how to PROPERLY use this plugin... Ok, I understood that I should keep the mouse button pressed while pulling the face, because click will only select/deselect (which is a bit annoying, honestly). But there is a funny behavior AFTER I do the push pull... sometimes (couldn't figure out in which conditions), when I press ENTER it actually CANCEL my pushpull.
Until now, every successful pushpull i did was out of luck... I have no idea how I confirmed the operation, because apparently I do the same thing like when it's canceled.
In my opinion it should do better use of ESC and ENTER keys (first to cancel, second to confirm). Also, selection of faces would be best to be key-assisted, as in regular SU behavior.
Is very confusing when plugins ask for different commands to do similar SU actions... is like two different programs. Select should be performed the same in native Su and under plugins (same key+mouse combinations), other operations should be similar.
Wish you best.
DESIGNER AND ARTIST DEREI.UK
derei
Postby fredo6 » Fri Jul 10, 2015 4:03 pm
I know it is a change of habit, but JPP is not designed to replace the native SU Pushpull either.
SU PushPull only acts on a single face. So when you click, the next action is PushPull.
In multiface seelction, you cannot do the same, because when you click on the first face, then this face would move / pushpull with the mouse when you will try to select a second face.
The only possibility remain is to select with NO click:
- if the mouse if over a face and you click, this face is PushPulled
- if you press CTRL why hovering over faces (.ie. no click), then these faces are added to the selection. If you then click, the Push Pull applies to all faces selected.
This method is also different from Sketchup, which does not have a multi-element selection capability in implicit selection (i.e. just hovering the mouse).
Note that I use this method in FredoScale, but I am pretty sure few users noticed or use it.
I'll have anyway another look and reflection to see if I can improve the face selection process (the best, when applicable, is to select the faces and then just type the offset, if you don't need a placement by target).
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby derei » Fri Jul 10, 2015 7:38 pm
I completely understand that this tool is not meant to replace a native SU tool. I was merely talking about the way of use of the similar commands (eg. selecting faces).
But this is not the biggest problem I got into. I could accommodate to it. The problem is that ENTER cancels the push-pull. I do it, i set custom value in VCB, then i press ENTER. And voila: no pushhpull. :? And I get confused: did I pressed ESC?
Unless there is any reason to assign a canceling to ENTER key.
By the way... "before" JPP wasn't behaving like this. It's like this change was introduced recently...couldn't tell which release.
Thank you very much, Fredo
derei
Postby fredo6 » Fri Jul 10, 2015 11:10 pm
I will have a look.
The latest version of JPP is dated 9 Jan 15, so it's not recent, unless there is a side effect from LibFredo6.
Did the problem happens when you are extruding a few faces or a lot of faces (with many faces, you have a preview mode)?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Dave R » Fri Jul 10, 2015 11:17 pm
I just did some quick testing and I'm not seeing any weird behavior with the Enter key. When I type a JPP distance and hit Enter, it makes the adjustment just like the native Push/Pull tool does. Maybe there's something else causing a conflict?
FWIW, I updated LibFredo and the other extensions that got recent updates and according to the Plugin Store and LibFredo, everything is up to date.
Global Moderator
Postby derei » Fri Jul 10, 2015 11:19 pm
I tried to reproduce it now, Couldn't. Will keep an eye on it, as it happened many times while working.
derei
Postby derei » Mon Jul 13, 2015 11:14 pm
UNDO issue ...
sometimes when I cancel JPP it lets the geometry with missing faces. Then I undo to get it back to its previous state...the problem is that i have to hit A LOT of UNDOs.
Maybe the undo function should be reviewed and pack multiple phases in a single undo command.
derei
Postby Ciacnorris » Thu Aug 06, 2015 10:41 am
Hi, I tried to install it on my PC, and I think it doesn't work on Windows 8.1.
Are you gonna make it work on Windows 8.1 too?
Really wanna try your plugin! :)
Ciacnorris
Postby peterromao » Fri Aug 07, 2015 7:46 pm
Hail to a very reliable extension which I have used countless times so far to give thickness to my sheets! Good Job!
Today is the first time that I found an error with it.
For some reason I cannot give this form a thickness.
The ruby error I get is the following:
Date: 07-Aug-15 19:49:31
An error occurred in Joint Push Pull
Error in generation of the geometry
reference to deleted Entity
JointPushPullGeometry.rb: 1027 -- entityID
JointPushPullGeometry.rb: 1027 -- block in geometry_coplanar_edges_overhang
JointPushPullGeometry.rb: 1025 -- each
JointPushPullGeometry.rb: 1025 -- geometry_coplanar_edges_overhang
JointPushPullGeometry.rb: 354 -- block in geometry_robot_erase_coplanar_edges
JointPushPullGeometry.rb: 352 -- each
JointPushPullGeometry.rb: 352 -- geometry_robot_erase_coplanar_edges
JointPushPullGeometry.rb: 214 -- robot_call_action
JointPushPullGeometry.rb: 177 -- geometry_robot_exec
JointPushPullGeometry.rb: 160 -- geometry_robot
JointPushPullGeometry.rb: 75 -- block in geometry_execute
Lib6Operation.rb: 325 -- call
Lib6Operation.rb: 325 -- step_geometry
Lib6Operation.rb: 367 -- start_execution
JointPushPullGeometry.rb: 75 -- geometry_execute
JointPushPullTool.rb: 891 -- go_preview_or_geom
JointPushPullTool.rb: 697 -- dragging_stop
JointPushPullTool.rb: 1319 -- onLButtonUp
I have attached the object.
peterromao
Postby TIG » Tue Aug 11, 2015 2:46 pm
If you JPP OUTWARDS it works OK.
Extruding INWARDS will fail.
This is because you have some tiny geometry in the surface - e.g. the segmented edges around the slotted holes semi-circular ends.
When extruding 'inwards', SketchUp's tolerance of 1/1000" can cause some tiny edges to be omitted - their start/end points are deemed coincident - then the faces relying on those also fail to be created.
But all is not lost...
You can JPP INWARDS if you do the following...
Make your group into a component.
Make a copy of it and Scale that x100.
Edit that instance and Preselect its surface.
Activate JPP - making x100 allowance in the offset value.
It will now extrude successfully.
Exit the edit and delete the scaled version.
The real size version will also show the JPP changes.
Tiny geometry can exist but it cannot be created directly in SketchUp.
The "Scale up a copy of a component" trick is a well known workaround for these kinds of issues...
Global Moderator
Postby peterromao » Wed Aug 12, 2015 3:56 pm
Hello TIG,
Awesome!!!!
That was an excellent reply. It worked. Thanks for the heads up. I recall doing something of the sort in the very distant past but if it weren't for your reminder I would have never gotten there!
Thanks again!
Peter
peterromao
Postby JQL » Tue Oct 20, 2015 12:47 pm
Fredo,
We are able to push pull by vector keeping original face orientation or by creating the ending faces as normal to the push pull vector. This is great!
Do you think it would be possible to pick any face in the project as the ending faces plane?
Thanks and best regards,
João
JQL
Premium Member
Premium Member
Postby fredo6 » Wed Oct 21, 2015 12:56 pm
Joao,
This is technically feasible, but more a matter of UI, which is already complex for users, as you know.
I'll see what I can do when I refresh the plugin.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby JQL » Wed Oct 21, 2015 3:34 pm
fredo6 wrote:Joao,
Fredo
I understand perfectly.
It's also something that would be good to have but that can be achieved manually. I hope you find the time to include it someday.
Thanks again,
João
JQL
Premium Member
Premium Member
Re: [Plugin] JointPushPull Interactive - v3.5a - 13 Nov 15
Postby derei » Wed Dec 02, 2015 3:41 pm
Two changes would be great for this plugin, as it works somehow against "intuition":
-first would be Press RETURN to exit (that's the ENTER key, and usually is used to CONFIRM a action, not to cancel it) - best would be to use ESC Key
-second would be the obligation of inserting push value with (-) AFTER the push action was initialized. It is great to let the option there, in case the user really needs to revert the direction, but it would be better that once a number was introduced, to take "by default" the pushing direction already initialized by the user.
Another thing is that AFTER doing a JPP operation, I must be very careful what tool or key I press, or I risk to have my operation canceled... this is extremely frustrating, as there is no intuitive action. As I said before, I am tempted to press ENTER - but guess what? I cancel my work. If I press Space Bar (to go to select tool) it happens the same, if I click on screen I also cancel the operation... every time is "lucky guess". In my opinion should be clear: ESC= Abort, ENTER=Commit. Nothing around. To not exit from operation until ESC or ENTER was pressed. This way there is no chance of mistake.
I hope this suggestions make sense.
Thank you.
derei
Postby fredo6 » Wed Dec 02, 2015 4:14 pm
Do you have a model where this happens? It must be related to the Preview mode, when you have a lot of faces.
- Enter / Return is used to perform the Push Pull, so that you don't even need to drag the faces. The cursor must be still on one face, since when the cursor is in the empty space, it is used to exit the tool.
- Escape does Abort when in interactive mode
- Spacebar functions as in any Sketchup tool. If you did not commit beforehands, it simply exits with doing nothing.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby derei » Thu Dec 03, 2015 3:56 am
yes, I had many faces in the model (organic modelling)...
But why there are 2 different uses for ENTER (when cursor on face, or not on face?) Is possible that is why I miss it many times... because i move the cursor around. I am not used to pay attention to it when i don't actively use it to manipulate geometry. Do you think this behavior is actually useful?
Thanks for all explanations ;)
derei
Postby JQL » Fri Feb 12, 2016 1:39 pm
Fredo,
Would it be easy to have normal push pull Taper with an angle or a offset distance instead of exclusivelly by ratio? It would be a nice feature to have for chanfering faces outside their plane with a double click. (I love this double click through groups/components)
JQL
Premium Member
Premium Member
Postby bapito » Tue Apr 19, 2016 9:57 pm
Where do i download it!!!???!!!
bapito
Postby Dave R » Wed Apr 20, 2016 10:19 am
bapito wrote:Where do i download it!!!???!!!
See the first post of this thread. It is clearly spelled out with bold type and links.
Global Moderator
Postby Arctura » Sat Jul 30, 2016 8:44 am
Hi I'm having a small issue that I can't for the life of me understand.
I'm extruding the wall of a truncated cone, or more like a rounded plate that along with 11 other identical plates will make up the cone. I'm trying to make flanges around the sides of one plate to then instance it, but the sides keep intersecting and I can't seem to control them! :(
I did manage to get it right at first, but there were some other issues with the model so I have restarted and this time around I can't get it to work.
I'm using Joint Push Pull and Round Push Pull.
Arctura
Postby Pixero » Wed Sep 21, 2016 9:24 am
I'm getting this error message when trying to Joint Push pull:
[/Date: 21-Sep-16 09:11:28
undefined method `smooth?' for nil:NilClass
JointPushPullGeometry.rb: 1107 -- block in geometry_coplanar_edges_overhang
JointPushPullGeometry.rb: 1105 -- each
JointPushPullGeometry.rb: 1105 -- each_with_index
JointPushPullGeometry.rb: 1105 -- geometry_coplanar_edges_overhang
Lib6Operation.rb: 332 -- call
Lib6Operation.rb: 332 -- step_geometry
Lib6Operation.rb: 374 -- start_execution
JointPushPullTool.rb: 892 -- go_preview_or_geom
JointPushPullTool.rb: 698 -- dragging_stop
JointPushPullTool.rb: 1320 -- onLButtonUp
Pixero
Postby fredo6 » Wed Sep 21, 2016 11:42 am
@pixero
Thanks for signaling. This seems to be an unusual case.
Anyway, I have fixed the problem and will re-release soon.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby surfmike » Sat Nov 26, 2016 11:35 am
Hi. I'm having a problem with the plugin gui showing up really small in SU. See attached picture.
I'm on SU2016, OS X 10.9.5.
How can I make it bigger?
//Mike
surfmike
Postby fredo6 » Sat Nov 26, 2016 8:51 pm
surfmike wrote:Hi. I'm having a problem with the plugin gui showing up really small in SU. See attached picture.
//Mike
Mike,
If you go to Windows > libFredo6 Settings... > Default Parameters..., you will find an option "Retina Screen" in the section "Palette Configuration".
If you check the option, you should get the palette buttons bigger (x 2). However, the text may remain small.
If you are OK, and since you are on SU2016, you can help me to see if we can resolve the issue, if you are OK to test some changes in the LibFredo6 library. I was hoping that it would be solved by Sketchup 2017, but that's not the case!
Otherwise, other high-dpi screen users have discussed some ways to avoid the issue by system set up. See discussion here.
Fredo6
fredo6
PluginStore Author
PluginStore Author
Postby pbacot » Wed Nov 30, 2016 5:58 pm
What may I be doing wrong. Trying to pull up three surfaces sharing three edges.
ate: 30-Nov-16 08:55:30
Could not compute valid matrix from points
JointPushPullGeometry.rb:: 1169 -- position_material
JointPushPullGeometry.rb:: 1169 -- block in geometry_transfer_material_top
JointPushPullGeometry.rb:: 1145 -- each
JointPushPullGeometry.rb:: 1145 -- geometry_transfer_material_top
JointPushPullGeometry.rb:: 337 -- block in geometry_robot_transfer_material
JointPushPullGeometry.rb:: 337 -- each
JointPushPullGeometry.rb:: 337 -- geometry_robot_transfer_material
JointPushPullGeometry.rb:: 212 -- robot_call_action
JointPushPullGeometry.rb:: 177 -- geometry_robot_exec
JointPushPullGeometry.rb:: 160 -- geometry_robot
JointPushPullGeometry.rb:: 75 -- block in geometry_execute
Lib6Operation.rb:: 332 -- call
Lib6Operation.rb:: 332 -- step_geometry
Lib6Operation.rb:: 374 -- start_execution
JointPushPullGeometry.rb:: 75 -- geometry_execute
JointPushPullTool.rb:: 890 -- go_preview_or_geom
JointPushPullTool.rb:: 696 -- dragging_stop
JointPushPullTool.rb:: 1318 -- onLButtonUp
Top SketchUcator
Postby pbacot » Wed Nov 30, 2016 6:04 pm
I guessed that although it looked simple, there might be some errant geometry from making the faces. I grouped the faces and ran TT Cleanup3 and that fixed it.
Top SketchUcator
PreviousNext
Return to Plugins
Users browsing this forum: agme, RUbank4136 and 9 guests
