[Plugin] SketchUcation Tools
Postby Rich O Brien » Fri Oct 04, 2013 6:01 pm
New look, new tools, social sharing and more...
If you don't have it already grab the .rbz file here
If you are using version 1.2 just update by Autoinstalling 2.0, and restart SketchUp to effect all of the changes...
How to install the SketchUcation toolset....
Installing Plugins and updating Plugins....
Using Sets....
Rich O Brien
Administrator
Re: [Plugin] SketchUcation Tools 2.0
Postby tt_su » Fri Oct 04, 2013 7:00 pm
Shiny! :)
tt_su
SketchUp Team
SketchUp Team
Postby Rich O Brien » Fri Oct 04, 2013 7:03 pm
Mucho gracias
Rich O Brien
Administrator
Postby jiminy-billy-bob » Fri Oct 04, 2013 7:06 pm
:thumb:
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Anton_S » Fri Oct 04, 2013 11:13 pm
Thank you Rich!
This tool is essential :thumb:
Anton_S
PluginStore Author
PluginStore Author
Postby frlic » Sat Oct 05, 2013 4:04 pm
Dear Mr. Rich O'Brien,
I installed [Plugin] SketchUcation Tools 2.0. I have the SU2013 Pro, Windows XP,
The problem occurs on the card SketchUcation Plugin v.2.0.0 Store.
Rows with the letters overlap. Please see attached picture.
The same error occurs and the SketchUp 8 Pro. In versions SketchUcation Tools 1.2.0 everything was fine.
Sorry for the bad English, I can communicate with google translator.
Nice greetings from Croatian
Kresimir
frlic
Postby TIG » Sat Oct 05, 2013 5:39 pm
Please empty your 'Internet Explorer' cache and restart the tool...
In Internet Options set IE NOT to remember your history and clear the cache as it closes.
You are seeing older css files etc clashing with the newest versions...
Global Moderator
Postby frlic » Sat Oct 05, 2013 6:09 pm
TIG wrote:Please empty your 'Internet Explorer' cache and restart the tool...
I deleted the complete history in internet explorer, and Chrome. The result is the same as before.The other two cards, you can see well.
Kreso
frlic
Postby TIG » Sat Oct 05, 2013 6:22 pm
SketchUp uses IE on PC and Safari on MAC - so you don't have to worry about Chrome, Firefox etc...
Are your sure you have completely emptied the cache?
What version of Windows and IE do you have running ?
Global Moderator
Postby frlic » Sat Oct 05, 2013 6:46 pm
TIG wrote:SketchUp uses IE on PC and Safari on MAC - so you don't have to worry about Chrome, Firefox etc...
I once deleted a complete history in Internet Explorer, but without result. On the pictures you can see versions of Explorer and Windows.
Kresimir
frlic
Postby TIG » Sat Oct 05, 2013 6:48 pm
So XP Pro with IE 8 ?
Any one with that config having similar issues ?
Global Moderator
Postby frlic » Sat Oct 05, 2013 7:05 pm
TIG wrote:So XP Pro with IE 8 ?
Excuse me, but I did not really understand the problem?
Thank you for your patience.
Kreso
frlic
Postby TIG » Sat Oct 05, 2013 9:53 pm
It appears to be a css [cascading style sheet] issue.
It IE is indeed purging properly then perhaps it's an issue with the OS and/or the version of IE.
Could you consider an upgrade your version of IE ?
Global Moderator
Postby irwanwr » Sat Oct 05, 2013 10:18 pm
I thought IE 8 is the highest WinXP could use.
irwanwr
Postby TIG » Sat Oct 05, 2013 10:42 pm
I know the minions in the SCF back-room will be beavering away right now to fix the css/html so it'll be supportive of these older browsers like IE 8 - please wait till the start of next week... :D
It'll be server-side fixes, so what you currently have installed should work, but then load the fixed html/css once it's sorted...
Global Moderator
Postby g_wilson » Sat Oct 05, 2013 10:46 pm
Same Problem - XP HOME - IE8.
Internet Options: delete history on exit.
CCcleaner checked to analyze=>Temp Internet Files/History/Cookies/Recently typed URLs/Index.dat files/Last Download Loc'n./Autocomplete Form History.
Close Chrome - Close IE8 - Running SU8(last rev) + CCcleaner only.
Run CCcleaner=> clean history => CCcleaner re-analyze = 0 bytes.
Open Store => problem exists as per described => run CCcleaner (Store still open)=> IE - Temp files 126 KB 33 files and IE - Cookies 1 KB 1 files.
(DO NOT clean)=>Close Store => run CCcleaner=> analyze => IE - Temp files 235 KB 33 files and IE - Cookies 1 KB 1 files.
Repeatedly opening store+closing store + CCcleaner analyze without cleaning = IE - Temp files 235 KB 33 files and IE - Cookies 1 KB 1 files.
Hope this gives a hint as to what is problem.
g_wilson
Premium Member
Premium Member
Postby irwanwr » Sat Oct 05, 2013 10:50 pm
TIG wrote:I know the minions in the SCF back-room will be beavering away right now to fix the css/html so it'll be supportive of these older browsers like IE 8 - please wait till the start of next week... :D
Thank you very very much :D
irwanwr
Postby Rich O Brien » Sat Oct 05, 2013 10:50 pm
Problem possibly identified....
Fix will happen without needing to update tool
Rich O Brien
Administrator
Postby Rich O Brien » Sun Oct 06, 2013 8:44 pm
Someone on IE8 please test pluginstore 2 for me?
Clear cache beforehand to force new css update
Rich O Brien
Administrator
Postby irwanwr » Sun Oct 06, 2013 9:09 pm
Rich O Brien wrote:Someone on IE8 please test pluginstore 2 for me?
It produced "Bugsplat"
Sketchucation Tool 1.1.3 still works fine though.
irwanwr
Postby Rich O Brien » Sun Oct 06, 2013 9:12 pm
More info please....
Clicking the toolbar? Clicking the menu entry? What caused the splat?
Rich O Brien
Administrator
Postby irwanwr » Sun Oct 06, 2013 9:13 pm
It just crashed SketchUp.
Ed: Restarted SketchUp 8 and it works just fine now :D
irwanwr
Postby Rich O Brien » Sun Oct 06, 2013 9:15 pm
When you're ready to tell us what you did prior to the splat let us know...
Rich O Brien
Administrator
Postby irwanwr » Sun Oct 06, 2013 9:20 pm
Rich O Brien wrote:When you're ready to tell us what you did prior to the splat let us know...
Restarted SketchUp 8, with IE 8; all three Sketchucation Tool buttons works just fine.
Thank you very much, Rich :thumb: :D
Does it really have anything to do with the tool? Or, the html page?
irwanwr
Postby g_wilson » Sun Oct 06, 2013 9:20 pm
For me - a Eureka moment - works repeatedly open/close Store. Also works after opening IE8 again elsewhere. Also works after closing SU and restarting SU. Thank You for your efforts - This community never ceases to impress.
g_wilson
Premium Member
Premium Member
Postby Rich O Brien » Sun Oct 06, 2013 9:22 pm
Can either of your gents please take a screenshot of the PluginStore on your system?
Rich O Brien
Administrator
Postby g_wilson » Sun Oct 06, 2013 9:27 pm
Yor wish is my command.
g_wilson
Premium Member
Premium Member
Postby irwanwr » Sun Oct 06, 2013 9:30 pm
Rich O Brien wrote:Can either of your gents please take a screenshot of the PluginStore on your system?
irwanwr
Postby Rich O Brien » Sun Oct 06, 2013 9:40 pm
Ok, thank you. I see an issue with the icons. Wrongly postioned...
Tomorrow. Thanks for taking the time to help
Rich O Brien
Administrator
Postby halroach » Mon Oct 07, 2013 8:06 am
I back button and a forward button would be nice to have -
After doing a search, for instance, and then wanting to go back to the previous results...
halroach
Next
Return to Plugins
Users browsing this forum: gaaf99, Slon22 and 18 guests
