[Plugin]T2H_Annotator v1.2.0(20130915)
Postby tak2hata » Sat Aug 31, 2013 11:59 am
Hi,All.
This is tool for creating annotations easily.
#General disclaimer
#I MAKES NO GUARANTEE OF VALIDITY about this script.
#Please use this script at your own risk.
DONWLOAD:
Get the latest version from the PluginStore:
http://sketchucation.com/resources/plug ... tor_v1.1.0
or AutoInstall from within SketchUp using the SketchUcation Tools
Update::
v1.2.0(20130915):New Option for changing Sketchup Scene Page by clicking Annotater TAB.
Please watch viedo for more infomation.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin]T2H_Annotator v1.1.0(20130831)
Postby glro » Sat Aug 31, 2013 2:41 pm
nice idea
thank you
i am sure there are plenty of cases where it will be useful
association of tabs to scenes might enable to show a comment per scene
glro
Postby mitcorb » Sat Aug 31, 2013 2:50 pm
Hi, tak2hata:
A very handy innovation.
My question(s):
Is the text stationary or fixed in the scene? Or is it superimposed in the view and you can still navigate- orbit, pan, etc.?
Does this somehow utilize the same operations as the native annotation text labelling?
mitcorb
Top SketchUcator
Postby tak2hata » Mon Sep 02, 2013 2:19 am
Hi,mitcorb.
It is superimposed in the view and you can still navigate- orbit, pan, etc.
The purpose of this tool is for annotating about flow of the working.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby glro » Fri Sep 06, 2013 6:58 pm
i would like to use your plugin to add a comment on each scene of the model
now, it is not possible because you can show any tab (comment) on any scene
Would it be possible to link a tab to one scene, and one scene only?
And to edit the tab name, so it matches the scene name?
glro
Postby tak2hata » Sat Sep 07, 2013 9:35 am
glro wrote:i would like to use your plugin to add a comment on each scene of the model
Hi,glro.
That's a good idea.
I will update in few days.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby glro » Sat Sep 07, 2013 10:31 am
it would be great!
i know how to add a single line comment in the upper corner of the screen, but what you do, multilines comment in a html window, is much much better
i don't use the software that comes with sketchup, Layout, at all
i prefer writing directly down on the model space, more interactive
to add a multilines comment to a scene, i sometimes use gallery reference
https://sites.google.com/site/morisdov/
it only works if the plugin folder of the computer contains gallery_reference.rbs
glro
Re: [Plugin]T2H_Annotator v1.2.0(20130915)
Postby tak2hata » Sun Sep 15, 2013 3:15 pm
I update this to version 1.2.0
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby glro » Sun Sep 15, 2013 8:45 pm
tak2hata wrote:Hi,
Thanks.
you did what you said you did... :thumb:
i tried
i had problems until i understood that you are supposed to clic on the tab in the plugin html window to change scenes
because if i clic on the tabs in the sketchup windows, the text remains the same, it doesn't change
also, i understood later that the text tab is associated to the scene which is active when the text tab is created
if i close the sketchup window, and open it again with the same model, the text which was on the screen before is the one that appears again
Here are some comments:
> would it be possible to register the file with the text on each scene, so when the file is closed, and opened again, the right text goes to the right scene, even if the plugin annotator isn't switched on? use annotator as a word processor for sketchup?
> or at least make that no text appears until the text file is loaded through annotator
> would it be possible to change scene by clicking on the scene tab in the sketchup window, instead of clicking on the tab in annotator html window (i have to clic many times before it reacts)
> long texts don't fit to the screen; would it be possible to have a maximum number of characters per line, and then change line?
i am going to try your plugin in real situation this week
thank you
glro
Return to Plugins
Users browsing this forum: No registered users and 11 guests
