[Plugin]T2H_Stretch_By_Area v1.2.3(Aug 25,2013)
Postby tak2hata » Sun Jul 07, 2013 2:33 pm
Hi,Everyone.
I upload new plugin here.
Tool for Stretching by Area through Group/Component.
General disclaimer:
I MAKES NO GUARANTEE OF VALIDITY about this script.
Please use this script at your own risk.
Notice:The modified component will be made unique from others
DONWLOAD:
Get the latest version from the PluginStore:
http://sketchucation.com/resources/plug ... ch_by_area
or AutoInstall from within SketchUp using the SketchUcation Tools
Update in Aug15,2013.Only Modify the entities in active editting group/components.and Improves.
Update in Aug25,2013.BugFix about selecting vertices in curve.
Watch Video.
Enjoy.
6
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin]T2H_Stretch_By_Area v1.2.1(Jul 07,2013)
Postby srx » Sun Jul 07, 2013 4:17 pm
Very useful plugin! Thank you! :D
I'd like to have it in Autocad.
www.saurus.rs
srx
Postby pilou » Mon Jul 08, 2013 2:52 am
Seems a very cool one! :enlight:
Speedy Galerie
Top SketchUcator
Postby a4chitect » Tue Jul 09, 2013 11:11 am
very nice, would be perfect if it only scaled/rotated linear components and keep the original component definition
thank you for sharing!!
a4chitect
PluginStore Author
PluginStore Author
Postby JQL » Thu Jul 11, 2013 2:00 pm
Amazing plugin tak2hata! Thanks,
I noticed that if I use you plugin in a group with some components where I pick a selection where some are stretched but some are just moved along the vector, the plugin creates unique components for all selected instances.
Is it possible to make the plugin behave as it does if the components are not grouped?
Best regards and thank you again!
JQL
Premium Member
Premium Member
Postby Box » Thu Jul 11, 2013 2:20 pm
Yet another outstanding plugin.
Postby Vicspa » Thu Jul 11, 2013 2:58 pm
Very useful, thank you. :thumb:
Vicspa
Postby treviso » Thu Jul 11, 2013 3:37 pm
Great!!!
Will be perfect if sensitive with osnap geometry when clicking move direction
treviso
Postby Elibjr » Wed Jul 17, 2013 7:56 pm
Thank you so much! This is better than the AutoCAD stretch. Can't wait to really get into using it.
Elibjr
Premium Member
Premium Member
Postby tawny » Thu Jul 18, 2013 2:26 pm
Thanks you, like the demonstration.
tawny
Postby JQL » Tue Jul 30, 2013 5:54 pm
Tak2Hata,
When working inside a component/group if we use your plugin to stretch a small portion of the group, it selects everything inside the group but also outside it. This makes it very prone to create unexpected results. Is it somehow possible to affect only that wich is within the active context?
Thank you very much and best regards,
JQL
JQL
Premium Member
Premium Member
Postby tak2hata » Wed Jul 31, 2013 4:26 am
JQL wrote:Tak2Hata,
JQL
Hi,JQL.
It is possible.
But now my right hand does not work fine for two weeks.
Please wait.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby JQL » Tue Aug 06, 2013 11:17 pm
Hi Tak2Hata,
Thanks for your generous reply. Please have no rush as it was just a suggestion for improvement on an already very useful plugin.
I hope you get well soon and best regards,
JQL
JQL
Premium Member
Premium Member
Re: [Plugin]T2H_Stretch_By_Area v1.2.2(Aug 15,2013)
Postby tak2hata » Thu Aug 15, 2013 4:27 am
Hi,All.
I update this version to 1.2.2.
ArcCurve modify as curve.
Draw Snap points.
And BugFix.
My right hand is not completely fixed,yet.
So,I edited small changes of this script.
Thanks!
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby rv1974 » Thu Aug 15, 2013 9:22 am
I'll be damned! This is amazing (and seems to be stable)tool! :o
At last, after long dead period we've got something estimable in the Plugins forum.
Many thanks tak2hata!
rv1974
Postby rv1974 » Thu Aug 15, 2013 9:35 am
some minor bug: stretch doesn't work in this case.
P.S. My humble request: multiple stretch a-la Acad's one (with Shift key).
rv1974
Postby lmfboy » Fri Aug 23, 2013 9:53 am
why i can't upload this plugin after i put it in the plugin folder?
lmfboy
Postby Dave R » Fri Aug 23, 2013 1:33 pm
How did you go about putting it in the Plugins folder? Did you just paste the .rbz file into Plugins? If so, that the wrong way to do it. You need to use Install Extension under Preferences>Extensions.
Complete your profile with your SketchUp and operating system versions.
Global Moderator
Postby Ben Ritter » Fri Aug 23, 2013 4:11 pm
Thank you for your generosity
Ben Ritter
Postby tak2hata » Sat Aug 24, 2013 8:14 am
Hi,rv1974.
I will correct this bug.
I think that adding function multiple stretch is difficult.
So it takes long time.Please wait.
Hi,lmfboy.
I agree with Dave.
Thanks Dave.
Hi,Ben.
Enjoy it.
Thanks!
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin]T2H_Stretch_By_Area v1.2.3(Aug 25,2013)
Postby tak2hata » Sun Aug 25, 2013 9:53 am
Hi,everyone.
I update this version to 1.2.3 in Aug25,2013.
Bugfix abot selecting vertices in curve.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby rv1974 » Sun Aug 25, 2013 12:52 pm
Tak2hata, thank you for refinements!
Somehow you tool manage to temporarily 'disable' the skp file hierarchy (you know all those group\components relationships) and work on the primitive vertex level. Have you thought about some kind of 'tak2hata line tool' that would draw directly on the faces (and splitting them of course) regardless the hierarchy?
rv1974
Postby pgarmyn » Fri Dec 20, 2013 11:02 pm
Extremely usefull :!:
Thanks Tak2hata :!:
pgarmyn
PluginStore Author
PluginStore Author
Postby kimi kimi » Tue Sep 22, 2015 6:24 pm
Man, if I knew this existed... ;( This is so awesome. I had to change the height of some building once, stretch all the windows, doors, with this thing I just cross it all, move it up and it's done. Previously, I had to open each window, each door, each column, each wall, ohhh maaan... It was such a frustration. Thank you!
kimi kimi
Premium Member
Premium Member
Postby ronhiatt » Sat Nov 21, 2015 1:32 am
Thank you VERY MUCH for making this tool. I would pay good money for this. I am only buying Sketchup Pro because of this tool.
How can I make sure I don't loose it? I'm worried Sketchup might mess it up.
Thanks,
Ron
ronhiatt
Premium Member
Premium Member
Postby benpaq » Tue Feb 23, 2016 11:25 pm
This is a very useful plug-in. I did not have any problem until I tried to use component attributes. The problem is not for the stretch by plug-in but what comes after it.
For my component, I added an attribute "DoorSide" with value Left/Right. I would like to choose which group to display depending on DoorSide value. So I use hidden attribute for the group based on DoorSide value. Once the function is defined in hidden parameter, I can do a stretch by for an area of my component and it works fine. But when I change the value inside component option (Left/Right), the stretch is done another time! Do you have any idea what is happening? It looks like the ruby code is executed again.
Thank you,
Benoit Paquette
benpaq
Donation
Postby ronhiatt » Wed Jul 27, 2016 5:26 pm
Hi, I clicked on the "Donate" Button next to "Stretch by Area", but it doesn't work.
Stretch by Area is a VERY important tool for me. I don't know if Sketchup would work for me without it. I would like to donate $50 to you. I also would be very happy if you would improve "Stretch by Area" if you have time.
Thanks,
Ron
ronhiatt
Premium Member
Premium Member
Postby petersaal » Sat Jan 28, 2017 3:09 pm
Thank you for sharing this plugin. Super helpful.
petersaal
Postby bsfranza » Fri Jun 09, 2017 1:29 pm
wow :)
i dont know how it could happen to me just NOT to know and use this FREAKING AWESOME plugin :)
damn... sometimes stuff is slipping by...
super product, but allow me to make a humble request or wish for making it even more better :) ->
give the user the option to "complete" selection with shift strg modifications just like with regular su activation tool... that helps to only select whats really of interest!
would be cool if the t2h could implement this in a convinient way like a two step process 1. selecting the verts with the help of the modifier keys and then 2. right click to finish selection and start moving :)
thanks for this awesome plugin!!! thumbs up
bsfranza
Postby andsgf » Thu Aug 17, 2017 12:28 pm
Спасибо
andsgf
Return to Plugins
Users browsing this forum: lukycat77, sajeel, sarah sayed and 8 guests
