[Plugin] 3D Tree Maker - New version 1.10.14
Re: [Plugin] Tree Maker
Postby Krisidious » Wed May 29, 2013 9:51 am
path='C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs'
File.exist?(path)
true
Load Path
Error: #<NameError: (eval):155: uninitialized constant Path>
(eval):155
load path
Error: #<SyntaxError: (eval):155:in `load': C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: no .<digit> floating literal anymore; put 0 before dot
RBS1.0...
C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: syntax error, unexpected tINTEGER
RBS1.0...
C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: Invalid char `\010' in expression>
(eval):155
(eval):155
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Krisidious » Wed May 29, 2013 9:53 am
yes... have it at the same.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Alan Fraser » Wed May 29, 2013 10:00 am
That looks similar to my Plugins properties...except I have "CREATOR OWNER" on top of SYSTEM; and "Administrators(Alan-PC/Administrators)" underneath it.
FormFonts
Alan Fraser
Top SketchUcator
Postby TIG » Wed May 29, 2013 11:51 am
Remove 'Trusted Installer'.
The 'CREATOR OWNER' is optional - but if it inherits permissions from its container, then it might screw up things...
Use the minimum number of 'users/groups' that you can get away with...
Ensure that they ALL have FULL permissions.
Do no 'inherit' any permissions...
Global Moderator
Postby Krisidious » Wed May 29, 2013 12:03 pm
Done... Still problem persists...
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby TIG » Wed May 29, 2013 12:07 pm
What's under the 'Owner' tab ?
Global Moderator
Postby Krisidious » Wed May 29, 2013 12:19 pm
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby TIG » Wed May 29, 2013 12:29 pm
Then you are screwed :shock:
I'm out of ideas... :roll:
Global Moderator
Postby Krisidious » Wed May 29, 2013 12:41 pm
:roflmao:
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
:cry: :cry: :cry:
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Krisidious » Wed May 29, 2013 12:43 pm
:idea:
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Krisidious » Wed May 29, 2013 12:44 pm
Yes!
It's a conflict.
Removing all plugins from the plugins folder and it works.
Now how can I figure out which one it is...
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Box » Wed May 29, 2013 12:48 pm
Do the old half half trick, add half of them back, if they work try the other half, when you get a half that doesn't work halve it and repeat until you have the one precious.
Postby Krisidious » Wed May 29, 2013 12:55 pm
I have something running that none of you do... and David does.
David? What do you draw?
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Krisidious » Wed May 29, 2013 1:07 pm
extensions.rb...
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Krisidious » Wed May 29, 2013 1:10 pm
Tig says...
As a 'health-check' can I suggest that anyone who thinks they have a mess up looks in their ../Plugins folder for the following .rb files that ought to appear only in their ../Tools folder.
If they are in the wrong folder move them [back] into ../Tools; if they are duplicated then remove the Plugins folder's version.
Depending on your SUp version, and what optional tools you might have, you could have these .rb files...
Which should be in ../Tools if you have them at all...
The bold ones are the base-set for most setups and have been around for several versions...
advancedcameratools
date
dynamiccomponents
extensions
filmandstage
langhandler
make_pano_pm
rational
sandboxtools
shadowstringsfix
SolarNorth
webtextures
Several of these have matching subfolders - e.g. 'Sandbox' within ../Tools too...
If you are in any doubt ask.
Don't delete any duplicated files you find but rather move them into a [new name='disabled'] subfolder so they don't auto-load - then you can always restore them when you've gone wrong :roll:
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby TIG » Wed May 29, 2013 1:29 pm
Note that with the advent of v2013 the files:
su_advancedcameratools.rb
su_dynamiccomponents.rb
su_sandbox.rb
su_webtextures.rb
and their matching-named folders should now be in the 'Plugin' folder.
As installed by SketchUp 2013's installer
These files replace the earlier SketchUp version's similar files [named without the 'su_' prefix] which belonged in the 'Tools' folder [<=v8], BUT which sometimes got misplaced in the Plugins folder...
The other 'system' .rb files still reside in the 'Tools' folder in v2013 as before [i.e. sketchup.rb, extensions.rb and langhandler.rb].
Global Moderator
Postby Krisidious » Wed May 29, 2013 1:34 pm
hooray...
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Box » Wed May 29, 2013 1:36 pm
Just curious Kristoff, did you copy plugins over from SU8 or did you clean install them all?
Postby Krisidious » Wed May 29, 2013 1:38 pm
What do you think... :roflmao:
You know how the sketchucation plugin store says 800 plugins? I tried each one...
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Box » Wed May 29, 2013 1:42 pm
Fair enough, but I have only installed what I needed as I wanted it, stopped me having loads of crap that I had tried in the past and didn't use now.
With the Sketucation plugin it makes it simple to start from scratch.
Postby TIG » Wed May 29, 2013 1:57 pm
And remember that if you AutoInstall a plugin from the "SketchUcation Plugin Store" and then find that you only want to use it occasionally, then you can use the Store's toolbar sibling 'SketchUcation Plugins Manager' to 'Disable' it, so then it doesn't auto-load when SketchUp starts.
Later when you need to use that particular Plugin you just 'Load' it [without Enabling]... so that it 'Loads' into SketchUp for just that one session, but it remains 'Disabled' when SketchUp is restarted.
If later you find that you want to use it more often, then you can 'Enable' it permanently, so it then auto-loads again whenever SketchUp starts...
If a Plugin is written as an 'Extension' then you can always use the 'SketchUcation Extension Manager' to 'Enable'/'Disable' it so it is only made active 'on demand'...
With v2013 the Extensions Manager's tool-details for a selected Extension show its 'Loader' file-path/name, so you can easily find that Plugin and 'Disable' it with the 'Plugin Manager', which will then stop the 'Extension' even being auto-loaded at startup - again that's tidier if it's rarely used...
Global Moderator
Postby Krisidious » Wed May 29, 2013 10:58 pm
Really great plugin Pascal... very powerful.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby peerman » Fri May 31, 2013 6:55 am
Great plugin!! I have a question though, is it possible to make the leaves and/or flowers have only one color instead of the random ones? I get a lot of different materials that I must change in order for Vray to render them in the correct color. Vray doesn't automatically apply the color to the greyscale image. Another advantage is that the materiallist keeps a bit more organized. For now I will ungroup the tree when it's in the shape I want and then change the material on the leaf component. And then to create some vray proxies!!
Thanks for this plugin!!
iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
peerman
Postby ppoublan » Fri May 31, 2013 8:05 am
peerman wrote:Great plugin!! I have a question though, is it possible to make the leaves and/or flowers have only one color instead of the random ones? I get a lot of different materials that I must change in order for Vray to render them in the correct color. Vray doesn't automatically apply the color to the greyscale image. Another advantage is that the materiallist keeps a bit more organized. For now I will ungroup the tree when it's in the shape I want and then change the material on the leaf component. And then to create some vray proxies!!
Yes I understand.
Currently I'm creating 8 small variations of the chosen color to make leaves/flowers each a little bit different. These materials are randomly applied to each component.
I will add in the futur the option to apply only one material.
Until this is implemented, you can edit the component, and appy your color/material directly to the faces, this will overwrite the color applied to the component. So this way you will not have to change each color.
Yours
Pascal
ppoublan
Premium Member
Premium Member
Postby peerman » Fri May 31, 2013 11:05 am
Pascal, Thanks for the quick reply!! I will try it out today.
peerman
Postby plot-paris » Fri May 31, 2013 4:06 pm
Looks very promising! I especially like the wind-force... Autumn is coming!
plot-paris
Postby majid » Sun Jun 02, 2013 12:19 pm
Great plugin, just to show my respect :thumb: :thumb: :thumb:
My V-Ray book for architects: https://goo.gl/cz1oRc
majid
Top SketchUcator
Postby Oxer » Sun Jun 02, 2013 6:59 pm
You can obtain very realistic trees, thanks again!! :thumb:
Playing with Vine Tree, I have changed the leafs for high details leafs with new texture and I add more details to the flowers, rendering with Thea.
Texture trunk changed.
http://www.oxervision.blogspot.com/
Oxer
Postby ppoublan » Sun Jun 02, 2013 11:51 pm
Oxer wrote:You can obtain very realistic trees, thanks again!! :thumb:
Waouah ! Thanks for sharing your results.
I'm working on the web UI interface. Just started so it will need some time, but will be easier to play with parameters. I will ask to those who created great trees to share them in order to include it into the next release (if volonteers of course).
Yours
ppoublan
Premium Member
Premium Member
PreviousNext
Return to Plugins
Users browsing this forum: 51areas and 26 guests
