[Plugin] 3D Tree Maker - New version 1.10.14
Re: [Plugin] 3D Tree Maker - New version 1.10.11
Postby pilou » Sat Feb 11, 2017 2:41 am
Works fine for me inside Su2017 Make ! :enlight:
Make your change(s) then Right Click on the selection / Context Menu 3D Arc Studio Tree/ Redraw.
Free version
3DArcStudio Tree Maker Sketchup Plugin can be downloaded for free from this site. The free version gives you access to all features, except you are not granted the right to sell or distribute trees created with the plugin, you will get one message each time you change configuration and little time to wait before the tree starts drawing, and you will not get access to all the tree templates included in the full version. If you like this plugin, you can get a licence for 10 euros that will remove those limits.Possible with the free version
Time was 5 s ;)
Rendered with the free SimLab Composer Light! maxi 1920 * 1080 ;) (a KeyShot like)
Can reload quasi any format of files! :thumb:
Speedy Galerie
Top SketchUcator
Postby pilou » Sat Feb 11, 2017 3:40 am
PS But you right : Configuration Menu works not like inside Su2016! :o
Seems some parameters are not responsive like "Number of truncs"...
and more curious the 2 buttons Redraw and Draw Proxy!
So it's a very good habit to keep old versions of SU! :mrgreen:
Speedy Galerie
Top SketchUcator
Postby mwm5053 » Tue Feb 21, 2017 3:45 pm
I downloaded the plugin from Sketchucation store within SU just the other day and read the post about the difference between free and paid so I don't think that's the issue I'm having. The drop down list of templates shows none either for the trees or grass. May be some knows something I don't (which is entirely possible).
2011 iMac
SU 2015 Pro, 2017 Make
V2 Twilight
macOS Sierra 10.12.5
mwm5053
Premium Member
Premium Member
Postby Oxer » Tue Feb 21, 2017 7:11 pm
The plugin does not work on SU 2017, try with SU 2016 or 2015.
http://www.oxervision.blogspot.com/
Oxer
Postby Dave R » Tue Feb 21, 2017 7:16 pm
Oxer wrote:The plugin does not work on SU 2017, try with SU 2016 or 2015.
If it doesn't work in SU2017, why did I get trees from it in SU2017?
viewtopic.php?f=323&t=52540&start=240#p613826
It worked for Pilou with no problem either. Maybe we're doing it wrong.
Global Moderator
Postby Oxer » Tue Feb 21, 2017 7:35 pm
Perhaps because you use Windows, mwm5053 & me work on Mac, the plugin works fine in SU2016 on Mac but in SU2017 it appears the issue that mwm5053 describes.
Oxer
Postby mwm5053 » Tue Feb 21, 2017 8:24 pm
I just removed all website data in Safari and Google Chrome ( some plugins I remembered use web dialogue something or other ) like the Fur plugin that I had problems with on Mac but still no choice for choosing type of tree.
Edit the Fur plugin does work in SU 2017 and OS X 10.10.5 Yosemite
2011 iMac
V2 Twilight
mwm5053
Premium Member
Premium Member
Postby lgrahm » Mon Mar 27, 2017 7:22 am
I guess it's a Mac-related problem. I've tried to install it on both an iMac and a Macbook pro with SU2017 pro.
Problem 1 is (as other have noted) that the menu is blank - you can't choose any tree type.
Problem 2 is that the plugin dissapears when you quit and restart SketchUp! Yes, it's not disabled - it's not there!
lgrahm
Postby karllarsen » Wed Mar 29, 2017 4:08 am
Dave R wrote:
karllarsen wrote:It sure would be nice to know if this will ever work or its just a lost-cause?
I don't really have a need for it but I just installed it now because of your post. It seems to work fine for me. It makes trees like it says on the box.
Great! Now try to EDIT the tree and tell me if you can ADD branches.
Then, make sure you read the entire description of what is NOT working ;)
Less is more.
karllarsen
Postby mwm5053 » Wed Mar 29, 2017 5:44 pm
Still having the same problem as lgrahm on my Mac with SU 2017 seems to work fine in SU 2015 however.
2011 iMac
V2 Twilight
mwm5053
Premium Member
Premium Member
Postby LOAM » Wed Apr 05, 2017 10:33 am
Hi Dave R, can you explain the process of how you are editing already created trees please? This is a plugin that we have paid for and whilst it wasn't expensive we would like to continue to use it in 2017 Pro. As you discovered It makes trees fine, they all generate originally but you can not edit them once created as a large percentage of the sliders are listed as "NaN" and the redraw button does nothing and the ruby console throws an error.
Works ok though in 2016 pro.
Would really appreciate a description of how you got it working so we can try the same thing.
This post describes the issue we are running into;
viewtopic.php?f=323&t=52540&start=240#p608575
LOAM
Postby jdcamc » Fri Jun 23, 2017 6:27 pm
The plugin works fine in the Windows version of SketchUp 2017 but it doesn't work for the MAC version of SketchUp 2017. I have both and the drop-down menus in both the trees and grass dialog boxes are empty in the MAC version. I can import a tree that I made with the Windows version into the MAC Version of SketchUp but when I select the tree, then right click to bring up the context menu, the context menu is empty, too. I am, however, able to turn on and off the proxy of the tree that I've imported into the MAC version of SketchUp.
jdcamc
Re: [Plugin] 3D Tree Maker - New version 1.10.14
Postby ppoublan » Thu Aug 17, 2017 11:34 am
I uploaded in sketchucation plugin store a new version that is working with SU2016 and SU2017.
4
ppoublan
Premium Member
Premium Member
Postby juju » Fri Aug 18, 2017 8:43 am
ppoublan wrote:I uploaded in sketchucation plugin store a new version that is working with SU2016 and SU2017.
Thank you, good sir!
juju
Premium Member
Premium Member
Postby TIG » Fri Aug 18, 2017 12:44 pm
How did you do it ?
I can't see an updated version ?
Global Moderator
Postby Oxer » Tue Sep 05, 2017 7:43 pm
The last version 1.10.14 doesn't work on Mac OS X 10.11.6 & SU2017, I can't select the trees in the list, this is empty. See the image.
EDIT: In SU2016 works fine.
Oxer
Postby garystan » Fri Sep 08, 2017 1:12 am
Hi everybody :
Too bad there wasn't a version for Sketchup 8. I would upgrade.....but Sketchup Pro is $700. Right now, money is tight.
garystan
garystan
Postby jdcamc » Sat Sep 16, 2017 12:19 am
Yep, does't work with Mac OS X 10.12.6 & SU2017 but does work with SU2016.
jdcamc
Postby genesissaul » Tue Oct 03, 2017 11:35 am
thanks
genesissaul
Postby CassieFlo » Sun Dec 03, 2017 2:38 am
I am have the free version of this, I have both 2017/2018 versions of Sketchup for Mac. I can draw trees and change them from proxies to full render just fine, but I can't change the configuration of them. It takes me to the full configure screen but when I press the redraw button it doesn't do anything? Is this a mistake I am making or does it deal with compatibility issues? Any suggestion is appreciated!
Thanks!
CassieFlo
Postby choppir » Fri Dec 08, 2017 1:36 pm
Thank you, just bought it!
Will you send us the plugin? Havent received anything on our email...Still just the free version on my sketchup
choppir
Postby pexin82 » Mon Feb 19, 2018 11:14 am
I still waiting my 3DTree plugins License information to SketchUp.
pexin82
Postby juju » Mon Feb 19, 2018 12:17 pm
pexin82 wrote:I still waiting my 3DTree plugins License information to SketchUp.
Through which channel did you purchase it?
juju
Premium Member
Premium Member
Postby pexin82 » Mon Feb 19, 2018 7:54 pm
I buy it from: http://www.3darcstudio.com/downloads-fi ... lugin.html
Here's Buy Now link (right, down) and i paid it in PayPal.
pexin82
Postby Dave R » Mon Feb 19, 2018 7:57 pm
You should be contacting the people you got it from. It's their responsibility to make sure you get the license.
Global Moderator
Postby pexin82 » Mon Feb 19, 2018 8:04 pm
I have contacted several times already. It looks like I do not get my own license and someone taking my money. :(
pexin82
Postby pexin82 » Mon Feb 19, 2018 8:10 pm
...And my payment 10€ is to PASCAL POUBLAN from PayPal. Where he is?
Item number 100.
pexin82
Postby Dave R » Mon Feb 19, 2018 8:18 pm
You purchased it from the author's website. It's going to be the best way to get in touch with him. His last visit to Sketchucation was in August of last year.
Unfortunately there's nothing we can do about getting you the license. It's up to the author to supply it.
Global Moderator
Postby pexin82 » Mon Feb 19, 2018 8:21 pm
Dave R wrote:You purchased it from the author's website. It's going to be the best way to get in touch with him. His last visit to Sketchucation was in August of last year.
Thank you! It was very kind to answer my messages. :thumb:
pexin82
Postby Dave R » Mon Feb 19, 2018 8:25 pm
Good luck getting in touch with Mssr Poublan.
Global Moderator
PreviousNext
Return to Plugins
Users browsing this forum: AlphaZer0, caermalo and 9 guests
