[Plugin] Animatex v1.0.6
Postby renderiza » Tue May 07, 2013 4:08 am
Author:: Renderiza
Plugin Name:: Animatex
Version:: 1.0.6
Date:: 5/24/2013
Cost:: Free
Animatex
Animatex allows you to animate multiple textured faces by assigning them to any of the three Animatex layers which have their own x,y,z parameters to set speed. You can also set the FPS (frames per second) of the animation but make sure to use a speed that your machine can handle.
To solve the problem of the plugin not working properly while transitioning camera though your scenes a "Fix" check box is provided to address that specific issue.
Available at
sketchUcation
plugin Store
click here
______________________________________________________________________
Extension Warehouse
click here
Note: If the latest version is not yet available at Extension Warehouse that means it is still awaiting to be approved by the quality assurance team to make sure extension meets the technical and security requirements.
Web-Dialog :
renderiza
Premium Member
Premium Member
Re: [Plugin] Animatex :: v1.0.0 :: 5/6/2013 ::
Postby pilou » Tue May 07, 2013 11:22 am
Waiting the video :)
Speedy Galerie
Top SketchUcator
Postby renderiza » Tue May 07, 2013 5:59 pm
Pilou wrote:Waiting the video :)
Video is up! :bounce:
renderiza
Premium Member
Premium Member
Postby pilou » Tue May 07, 2013 6:41 pm
Seems very cool indeed! :enlight:
Does the animated textures are living scenes to scenes ?
say I have 3 scenes : does an animated texture will work on each scene without new regulates ?
PS does the plug works on any version of SU ? (6,7,8)
Speedy Galerie
Top SketchUcator
Postby raineysky » Tue May 07, 2013 6:45 pm
Very nice Renderiza!!!
raineysky
Postby urgen » Tue May 07, 2013 7:28 pm
:thumb: :thumb: :thumb:
--pupil forever...------
urgen
Postby renderiza » Tue May 07, 2013 11:17 pm
Pilou wrote:Seems very cool indeed! :enlight:
Just read questions again and this are the answers...
Does the animated textures are living scenes to scenes ? Yes
does an animated texture will work on each scene without new regulates ? Yes
I thought you were asking about animating cameras using scene transitions while having animated textures running...my bad but below is the answer to that just in case. :oops:
Short answer - Not at the moment since page transition will lag if the web-dialog is frames per second is set too high.
Long answer - If you access 'rnd_animatex.html' you will notice a line that says this "var delay = 1000/15 ;" which indicates the 'frames per second' that the web-dialog will update to refresh its values, in this case 15 frames a second.
Since the SketchUp view-port can't be unfocused while scene/page is being transitioned its creating a problem with the web-dialog since every 15 frames per second the focus is going back and forward between dialog & view-port.
The higher the FPS the worst but if you use 5fps for example the the scene transition speed will be fine. In the future having the user set the frames per second will be a very good idea but I will still be searching for a better way to go around this issue.
For the plugin being compatible with other versions I am not sure. :oops:
Anyways thanks everyone for reply! :thumb:
renderiza
Premium Member
Premium Member
Postby pilou » Wed May 08, 2013 12:27 am
THX for precisions! :thumb:
Speedy Galerie
Top SketchUcator
Postby Krisidious » Wed May 08, 2013 1:46 am
koool....
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Re: [Plugin] Animatex :: v1.0.1 :: 5/9/2013 ::
Postby renderiza » Thu May 09, 2013 11:26 pm
Animatex v1.0.1 Released!
Now with v1.0.1 you can set the frames per second (fps).
renderiza
Premium Member
Premium Member
Postby Elibjr » Fri May 10, 2013 1:27 am
Nice!
Elibjr
Premium Member
Premium Member
Postby pilou » Fri May 10, 2013 10:17 am
Can you input a GIF animated as texture ?
Speedy Galerie
Top SketchUcator
Postby renderiza » Fri May 10, 2013 5:22 pm
Pilou wrote:Can you input a GIF animated as texture ?
Not at the moment but maybe in the future something like that can be implemented.
Here are some plugins that can play a sequence of images much like a gif;
[Plugin][Code]SKMtools,MaterialTools,ImageTools110225:
viewtopic.php?p=293677#p293677
[Plugin] jpg_gif (Updated 22/12/2010):
viewtopic.php?t=33054
Again thanks everyone for the questions & comments! :thumb:
renderiza
Premium Member
Premium Member
Postby renderiza » Thu May 16, 2013 1:18 am
Animatex v1.0.2 Released!
Now with v1.0.2 you can animate multiple faces on each of the three separate layers that can control different x,y,z speeds.
Will make quick video soon explaining the new features so expect that soon.
renderiza
Premium Member
Premium Member
Re: [Plugin] Animatex :: v1.0.2 :: 5/15/2013 ::
Postby renderiza » Thu May 16, 2013 3:35 am
Animatex v1.0.3 Released!
Now with v1.0.3 you can animate multiple faces on each of the three separate layers that can control different x,y,z speeds. Animatex now works while transitioning between scene camera animation without lag. Will make quick video soon explaining the new features so expect that soon.
renderiza
Premium Member
Premium Member
Re: [Plugin] Animatex :: v1.0.3 :: 5/15/2013 ::
Postby renderiza » Thu May 16, 2013 4:26 am
Just realized texture don't animate if face is inside a group or component so will be try to solve that in the future.
renderiza
Premium Member
Premium Member
Re: [Plugin] Animatex :: v1.0.4 :: 5/16/2013 ::
Postby renderiza » Thu May 16, 2013 11:45 am
Animatex v1.0.4 Released!
Animatex works with groups now!
Note: Thanks to TIG and Thomthom for helping me solve the issue on the development forum!
renderiza
Premium Member
Premium Member
Postby CadFather » Thu May 16, 2013 12:32 pm
Thanks Rafael - from strength to strength. :thumb:
CadFather
PluginStore Author
PluginStore Author
Postby raineysky » Fri May 17, 2013 6:05 pm
Renderiza,
First off this is a very nice plugin. Question: Will it work with round objects like pipes? I would like to simulate water flowing through a pipe. Also, can I make the water flow to the left instead of the right? Probably a dumb question but I can't change the direction.
Thank You,
Paul
Edit: Figured out the second question. Make it a negative number :D
raineysky
Postby renderiza » Fri May 17, 2013 10:21 pm
raineysky :: Will it work with round objects like pipes?
The plugin will animate any face with a texture that is inside or outside of a group but it can't be nested in a group withing another group and also it is not working with face inside Component Instances at the moment. :?
With this in mind you can have animated textures on round objects but since the texture x,y,z coordinate are set by face and not globally like for example projected faces, it will mess the uvs coordinates if you used projected texture if that make any sense.
Now you pointed out that you are using water so it may still look decent...I might include an example of this on my upcoming video. :thumb:
raineysky :: Also, can I make the water flow to the left instead of the right?
You can use negative sign to specify x,y,z to move in opposite direction. For example;
x= -1 , y= -6 , z= -10
Hope this helped...Cheers!
renderiza
Premium Member
Premium Member
Postby raineysky » Sat May 18, 2013 1:30 am
Thank You!!!
raineysky
Postby renderiza » Sat May 18, 2013 2:55 am
I corrected the message since 2nd time I read it wasn't what I wanted to mean so here is another try on that sentence...
Cheers!
renderiza
Premium Member
Premium Member
Postby renderiza » Sat May 18, 2013 3:53 pm
When I was using Animatex inside SketchUp there was no lag but I guess 'ActivePresenter' screen capturing software produced some lag in the video output. If you want to screen capture without lag output then I recommend using 'Fraps'.
renderiza
Premium Member
Premium Member
Postby renderiza » Sun May 19, 2013 1:30 pm
New Video:: (Part 2)
renderiza
Premium Member
Premium Member
Postby raineysky » Sun May 19, 2013 4:35 pm
Thank You for the videos. This plugin is awesome!!! I finally got water flowing through the pipes :o
raineysky
Postby lovesket » Sun May 19, 2013 9:29 pm
A very good plugin RESPECT ....! Now together with mover2 are two my lovely plugins ever for sketchup...The only think on Animatex is the large page during the work.. is not practic, if is possible to change page, like mover2 for example...is better..thnx
lovesket
Re: [Plugin] Animatex :: v1.0.5 :: 5/21/2013 ::
Postby renderiza » Tue May 21, 2013 10:09 pm
Animatex v1.0.5 Released!
Hi, this is a small update for Animatex.
Now Animatex is an extension that you can see under Window > Preferences > Extensions. With a quick click, you can learn some info about plugin and can even turn it on and off.
Also this update attempts to fix some buttons that were not showing on some web-dialogs and also removed some that were not needed.
renderiza
Premium Member
Premium Member
Re: [Plugin] Animatex :: v1.0.6 :: 5/24/2013 ::
Postby renderiza » Fri May 24, 2013 8:26 pm
Animatex v1.0.6 Released!
Hi, this update was all about to make Animatex follow the requirements to be posted on Extension Warehouse. The plugin is still in revision but hopefully you will see it soon but why wait go ahead an download it now from SketchUcation. :thumb:
Cheers!
renderiza
Premium Member
Premium Member
Postby pilou » Sat May 25, 2013 12:38 am
What screen recorder are you used for the videos?
Speedy Galerie
Top SketchUcator
Postby renderiza » Sat May 25, 2013 12:46 am
I used Active Presenter which is free.
http://atomisystems.com/activepresenter/free-edition/
I also use Fraps which only captures viewport and ignores things like cursor, toolbars and so on. This screen capturing software reduce lag and preserve frame rate really well but its not free.
http://www.fraps.com/
Cheers!
renderiza
Premium Member
Premium Member
Next
Return to Plugins
Users browsing this forum: chandat, nozzle and 10 guests
