[Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
Re: [Plugin] ToolbarEditor (1.0.6) – updated 15.05.2013
Postby Box » Sat Apr 05, 2014 5:39 pm
It throws a load error in SU2014
Postby Aerilius » Sat Apr 05, 2014 7:04 pm
Thanks, I fixed the load error.
Aerilius
PluginStore Author
PluginStore Author
Postby TIG » Sat Apr 05, 2014 11:41 pm
Aerilius wrote:Thanks, I fixed the load error.
BUT you haven't published it :roll:
Global Moderator
Postby Box » Sun Apr 06, 2014 1:02 am
It's on the previous page Tig, not the first post. It's a teaser/beta and the fix worked for me.
Postby TIG » Sun Apr 06, 2014 11:04 am
So the version in that mid-thread post has been updated - it was not clear... :?
Global Moderator
Postby function » Sun Apr 06, 2014 8:34 pm
I've noticed that this plugin takes a fairly long time to load all the icons at startup. Is there any other negative affects to performance?
function
Postby Aerilius » Mon Apr 07, 2014 11:44 pm
It has an arbitrary timeout of five seconds. It's not doing much processing, it just needs to be sure that SketchUp has finished loading all other plugins. I wish SketchUp had (or will have) a proper API method for that. When I come back I'll see if it still works reliably wirh a shorter timeout.
Aerilius
PluginStore Author
PluginStore Author
Postby function » Tue Apr 08, 2014 4:48 pm
its kind of strange for me. i have something like 4 tool bars, they load one icon at a time, and then on the 5th toolbar i made it loads all 6 instantly .. ::shrug::
function
Re: [Plugin] ToolbarEditor (1.1.1) – updated 07.05.2014
Postby Aerilius » Thu May 08, 2014 1:48 pm
I updated the plugin. It now includes custom buttons.
Aerilius
PluginStore Author
PluginStore Author
Postby Rich O Brien » Thu May 08, 2014 1:50 pm
Incredible.
Rich O Brien
Administrator
Postby Krisidious » Thu May 08, 2014 5:11 pm
I can haz all thomthoms in a toolbar?
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Ben Ritter » Thu May 08, 2014 8:15 pm
Thank you for sharing this with us.
Ben Ritter
Postby Krisidious » Thu May 08, 2014 11:07 pm
does this mean it's time for the Icon Making Challenge?
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby LewisEE » Sat May 10, 2014 8:32 am
I can't enter code for custom (new) buttons using SketchUp Make 2014. Other wise this is a great extension. Thanks
LewisEE
Postby driven » Sat May 10, 2014 8:53 pm
how did miss this one, very nice...
just pondering some additional behaviour...
I regularly 'bury' plugins that I use infrequently, but add the tools main icon to a toolbar and use that to 'load' the plugin only when I need it, I tend to do it for plugins that add observers, skp's or materials to my model.
I try to do it on my own plugins as well so the 'command' is the loader...
example
Code: Select all
      command2 = UI::Command.new("Add mac batch Icons"){ load( File.join(File.dirname(__FILE__), "Add_icon_logic_batch_skps.rb") ) }
could the 'burying' be an option for this plugin?
so if I add a complex plugin to a toolbar it is moved into a 'Toolbar 1' folder and only a single icon is added to the 'Toolbar 1' toolbar, but if I click on that 'Icon' 'Toolbar 1' is replace by a second 'Toolbar1' that includes any additional toolset buttons at exactly the same position...
I'll see if I can find my simple 2 tool test file, that may clarify what I mean...
john
driven
PluginStore Author
PluginStore Author
Postby alsomar » Fri May 16, 2014 9:02 am
Thank you so much Aerilius!
It could be nice to export custom toolbars to a *.dat file to get the same toolbars in other computers. Is there any way to do anything like that?
Greetings!
alsomar
Premium Member
Premium Member
Postby Aerilius » Fri May 16, 2014 11:05 am
The toolbars are stored in the registry
HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2014\Plugins_ae\ToolbarEditor.
You can copy and paste it in the same key on another SketchUp installation or version. You can also use the File → Export functionality of the registry. I'm not sure whether I should add an export button to each of my plugins, I hope SketchUp will provide an efficient and central place to migrate settings.
From a developer side, I want to emphasis again that most of us want plugin settings to be namespaced and bundled in one sub-key, and not mixed within SketchUp's internal keys.
Aerilius
PluginStore Author
PluginStore Author
Postby alsomar » Fri May 16, 2014 12:06 pm
Aerilius wrote:The toolbars are stored in the registry
Thank you for your response! Greetings! :)
alsomar
Premium Member
Premium Member
Postby Lushi » Sun May 18, 2014 8:56 pm
i would love this tool could create groups of nested buttons, like those in the bar "getting started"
Lushi
Postby Aerilius » Mon May 19, 2014 8:58 am
I would love this too!
But they are neither user-editable nor available for plugins.
Aerilius
PluginStore Author
PluginStore Author
Postby glro » Tue May 20, 2014 12:15 pm
LewisEE wrote:I can't enter code for custom (new) buttons using SketchUp Make 2014. Other wise this is a great extension. Thanks
i can't enter snippets either
su8, win7
glro
Postby Aerilius » Tue May 20, 2014 2:09 pm
What happens when you can't enter snippets? What do you do and what does not happen?
Aerilius
PluginStore Author
PluginStore Author
Postby glro » Tue May 20, 2014 7:40 pm
Aerilius wrote:What happens when you can't enter snippets? What do you do and what does not happen?
nothing happens...
after i fill in the form (name, category, ...), and i choose a file for the icon, it is then impossible for me to type anything in the area below the icon file address
glro
Postby Aerilius » Wed May 21, 2014 10:28 am
I cannot reproduce this. For me the webdialog accepts input in all input fields in SU 2014, SU 2013, SU8, WinXP, Win7.
• What version of Internet Explorer do you have installed?
• Does the text area for Ruby code never accept input or only after you selected an icon?
• Can you see that it is a text area (or is it possible that it just has a zero size)?
Aerilius
PluginStore Author
PluginStore Author
Postby glro » Wed May 21, 2014 12:09 pm
Aerilius wrote:I cannot reproduce this. For me the webdialog accepts input in all input fields in SU 2014, SU 2013, SU8, WinXP, Win7.
internet explorer 11
never accepts input
cannot see that it is a text area (screen copy added)
hope it helps
glro
Postby Jim » Sat Jun 07, 2014 9:14 am
Same here - no input area for code.
Win 8.1, SU-2014 Pro, IE 11 (never used outside of SketchUp.)
Jim
Global Moderator
Postby titou » Sun Jun 08, 2014 9:45 am
me too, same problem, cannot whrite anything in the text zone
titou
Postby Jim » Sun Jun 08, 2014 2:31 pm
I know it has probably already been thought about, but it would be incredible to have a command repository where we can browse, install, and share commands...
Maybe a dvcs repo (github) could be used as the repo. What format would be good for command files - json or yaml maybe?
Jim
Global Moderator
Postby Aerilius » Sun Jun 08, 2014 5:19 pm
I uploaded a workaround for IE 11's bug (ToolbarEditor 1.1.2).
Currently the plugin writes each snippet to a ruby file (in %APPDATA%) and stores the metadata with the plugin's preferences in the registry.
A json or yaml format would also not be a bad idea. I chose rb because it contains runnable code and I don't need to extract the code from a part of the file (or deal with escaping etc.). The metadata is also written in the comment of the ruby file, but I haven't decided yet to parse it out of the comment again, because there would be many sources of error (or the comment would have to strictly follow a specific syntax.
Aerilius
PluginStore Author
PluginStore Author
Re: [Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
Postby Jim » Sat Jun 14, 2014 9:31 am
Is the numeric part of the filename unique for each user? If so, that makes it difficult to have a way to share commands.
Jim
Global Moderator
PreviousNext
Return to Plugins
Users browsing this forum: oscardelavega, topcon and 9 guests
