[Plugin] ToolbarEditor (1.1.2) – updated 08.06.2014
Postby Aerilius » Fri Apr 26, 2013 12:41 pm
A drag&drop editor for creating custom toolbars from plugin's buttons.
Download
Version: 1.1.2
Date: 08.06.2014
Requirements: SketchUp 8 M1+, IE8+
Usage:
  • Menu 'Window' → 'Toolbar Editor'
  • Click the "+" button on the left to create a new toolbar. You can rename toolbars or remove them ("-" button).
  • Click the "+" button on the right to create a new button. You can then write your own Ruby commands or paste a piece of Ruby code that you found on the forums.
  • Drag items from the list of available buttons to the left into a toolbar panel. You can rearrange the buttons, move them into other toolbars or remove them by dropping them out to the right.
  • The list can be filtered.
  • Don't forget to click the "Apply" button to save once you are happy with the changes. Not all changes can be applied immediately, some only on next start of SketchUp.
4
Aerilius
PluginStore Author
PluginStore Author
Re: [Plugin] ToolbarEditor (1.0.0) – 26.04.2013
Postby Dave R » Fri Apr 26, 2013 1:00 pm
This looks like a pretty cool plugin. Unfortunately on my MacBook, some of the icons won't stay on the left when I drag them. One in particular is the Fillet tool from TIG's 2D Tools. Is there something about some tools that will make this not work?
Edit: After inserting a tool from the BZ_Spline tools, I tried the 2D Fillet again and it went. Weird.
Global Moderator
Postby renderiza » Fri Apr 26, 2013 1:13 pm
Thanks for sharing this for free! Hope you get lots of donations...you deserve it! :thumb:
renderiza
Premium Member
Premium Member
Postby panixia » Fri Apr 26, 2013 1:18 pm
i don't know if i'm doing it right, but it refuses to add any tools i tried (i also tried with bezier toolbar tools ;) ) but unfortunately when i drag the icon from right to left and relase it, it comes back to the right and nothing happens.. am i missing something? :?
edit. it looks to work now.. maybe i was relasing the items the wrong way!
panixia
Postby Aerilius » Fri Apr 26, 2013 1:22 pm
The droppable area is only on the top.
Other weird behavior can be because it is not native drag&drop (but JavaScript/jQuery). Sometimes it's necessary to hover between two icons until jQuery finds the insertion point and opens a gap.
I'll add more visual feedback.
Aerilius
PluginStore Author
PluginStore Author
Postby panixia » Fri Apr 26, 2013 2:02 pm
:thumb: once used to it the dragging and dropping is OK!!
the major downside is that everytime you open/close sketchup the toolbars mess up!! :shock:
panixia
Postby panixia » Fri Apr 26, 2013 2:04 pm
great tool anyway, thank you! i will try to make only a couple of big toolbars so it's faster to rearrange them.. do you think this can be fixed in the future? or it's a sketchup limitation?
panixia
Postby CadFather » Fri Apr 26, 2013 2:51 pm
woooo... ..simply too stunned to comment.... :o :shock: :ecstatic:
PS
..Aerilius for President (of Italy please)!
CadFather
PluginStore Author
PluginStore Author
Postby panixia » Fri Apr 26, 2013 3:00 pm
CadFather wrote:..Aerilius for President (of Italy please)!
:roflmao:
panixia
Postby renderiza » Fri Apr 26, 2013 3:10 pm
CadFather wrote:woooo... ..simply too stunned to comment.... :o :shock: :ecstatic:
PS
CadFather you deserve some credit as well since you started this revolution of toolbar plugins...So you can be President of a country as well :lol:
renderiza
Premium Member
Premium Member
Postby CadFather » Fri Apr 26, 2013 3:21 pm
Renderiza wrote:CadFather you deserve some credit as well since you started this revolution of toolbar plugins...So you can be President of a country as well :lol:
well.. that's true... ok, i'll do the brain and Aerilius the arms.. ;) :lol:
actually this plugin has got to be the best of 2013....just too good...i can imagine a whole planet is going to redesign their toolbars layout in the next few days...incredible......
makes you wonder...if it takes Aerilius a week to create this beauty...what are Su developers doing in boulder colorado...skiing no doubt..! ;)
[removing by dropping the icon to the right doesn't seem to work on my machine - edit: working now that i restarted and re-edited the toolbar]
CadFather
PluginStore Author
PluginStore Author
Postby guanjin » Fri Apr 26, 2013 5:00 pm
Aprire lo strumento il seguente errore.
:berserk:
I come from China, is to learn
guanjin
Postby Aerilius » Fri Apr 26, 2013 5:25 pm
Oh, that could be difficult to find out ;-) The plugin sends all information about all your plugins into the dialog, and I don't have the same plugins as you. The error could be caused by something unknown.
Aerilius
PluginStore Author
PluginStore Author
Postby Rich O Brien » Fri Apr 26, 2013 5:30 pm
added to autoinstall
Rich O Brien
Administrator
Postby guanjin » Fri Apr 26, 2013 5:56 pm
Rich O Brien wrote:added to autoinstall
Have tried, useless, depressed.
You have the wrong?
guanjin
Postby Rich O Brien » Fri Apr 26, 2013 6:00 pm
You have the wrong?
Considering I installed it using autoinstall and it worked for me I think the problem maybe be at your end
Rich O Brien
Administrator
Postby CadFather » Fri Apr 26, 2013 6:34 pm
Guanjin, all works fine on my machine (win7 64 - english) - you need to find out whether it is the language settings (virtualbox in english?)
CadFather
PluginStore Author
PluginStore Author
Postby guanjin » Sat Apr 27, 2013 8:32 am
Aerilius wrote:Oh, that could be difficult to find out ;-) The plugin sends all information about all your plugins into the dialog, and I don't have the same plugins as you. The error could be caused by something unknown.
Hello:Aerilius
Reinstall SketchUp successful trial, the conflicted file can not be found.
guanjin
Postby lionk » Sat Apr 27, 2013 9:24 am
great work! :thumb:
here is the Chinese language file, translated by 麦兜(miduee)&双鱼(shuangyu)
lionk
Re: [Plugin] ToolbarEditor (1.0.1) – updated 27.04.2013
Postby danb » Tue Apr 30, 2013 10:12 am
Thankyou, I am on a mac and am sick of the toolbars floating all over the place and have been envious of Windows, this has instantly improved my workflow.
best
Dan
Sketchup Pro 2019/20
OSX 10.15.3
Macbook Pro
danb
Premium Member
Premium Member
Postby RickW » Thu May 02, 2013 12:25 am
Has anyone else had problems with not all commands being available? I'm also missing a lot of icons that exist on other toolbars.
RickW
Postby Dave R » Thu May 02, 2013 12:37 am
I haven't seen that. I maybe haven't looked very hard, though. I got the tools I wanted onto a toolbar without any problems.
Global Moderator
Postby zieios » Thu May 02, 2013 11:04 am
Nice one
zieios
Postby Aris » Thu May 02, 2013 12:09 pm
Great plugin! very nice interface and very useful!
I would suggest (don't know if it is doable) giving the option to create dialog boxes as well.
Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
Aris
Premium Member
Premium Member
Re: [Plugin] ToolbarEditor (1.0.2) – updated 03.05.2013
Postby kct3937 » Sun May 05, 2013 6:45 pm
I followed Dave's instructions and the toolbars are showing up fine in my Mac version. However they are vertical toolbars only. Can I get them to set out horizontally?
kct3937
Postby Dave R » Sun May 05, 2013 6:49 pm
It's a feature! :D
Move the toolbar up to the top or down to the bottom temporarily and it'll swing around to horizontal. Then you can place it wherever you want.
Global Moderator
Postby kct3937 » Sun May 05, 2013 7:46 pm
Thanks Dave…two thumbs up! :thumb: :thumb: :lol:
Have you met a new friend each morning in the mirror, yet? :?:
Ken T
kct3937
Postby lionk » Mon May 06, 2013 1:02 am
hi Aerilius,
some bugs:
1.there is a mismatch between toolbar name in the Editor and the real name.
2.when renaming the toolbar, ENTER will delete it instead of confirm the name...
3.i can't rename toolbars in double-byte characters.it will show like this.
the same problem happened to LaunchUp when i search DBCS strings.
4.if i close the toolbar and restart sketchup, i have to click 3 times in View menu to reopen it.
5.the position of the toolbar can't be saved.it troubled me so much...
lionk
Postby Aerilius » Mon May 06, 2013 9:09 am
Hi, thanks for the reports!
As for 2. it looks like the "-" button has focus and accepts enter. I think I can make sure that this doesn't happen.
4., 5. I have no control about that, I wished it worked in SketchUp as it should.
Aerilius
PluginStore Author
PluginStore Author
Postby Aerilius » Tue May 07, 2013 3:42 am
I could solve 1., 2. and 3., but I don't get an error when searching in LaunchUp for 面 or 测. Do you use the latest version of LaunchUp? Which version if Internet Explorer do you use?
Aerilius
PluginStore Author
PluginStore Author
Next
Return to Plugins
Users browsing this forum: Nguyen Duc Viet and 14 guests
