[Plugin] TopoShaper - v2.5c - 29 Oct 19 - IsoContour & Cloud
Re: [Plugin] TopoShaper - v1.0b - 26 Apr 13 -Terrain & Conto
Postby massimo » Tue May 07, 2013 9:12 pm
:thumb:
massimo
Postby **Ewie** » Wed May 08, 2013 1:16 am
Love the idea of this plugin but I'm having no success in getting it to work at all. I've followed the instruction to the letter, checked directories, updated the lib file.. but can't get it to work even with the sample files.
The error message window does not appear, is there a log file located somewhere that I could send in hope of finding the problem??
Cheers
**Ewie**
Premium Member
Premium Member
Postby TIG » Wed May 08, 2013 11:05 am
Ewan
Open the Ruby Console.
Then try running the tool.
Report any error messages.
Also check your Plugins folder's Properties > Security permissions are set to FULL for everyone in the list [Edit + Apply/OK]
If not this might stop some log file etc getting written if you have limited rights...
Global Moderator
Postby tspco » Thu May 09, 2013 1:31 am
Fredo, works like a champ here, installation was a tad tricky (no I don't remember what I did to make it work). After p[laying with this a few days, I ran across a issue. The terrain I have is a lake with several high hills around it, I would like to make the water one material and the hills another material, I tried a few gradients, found one close enough to work, but when rendering I cannot make the water reflective and the hills not. The system recognizes the material as one material. I tried freehanding the water areas, but who would of thought water wasn't level?. I know this is not really about this great plugin, but related. If anyone has any ideas please share them.
SU make 2017, /Twilight Render Hobby
Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
tspco
Postby Mistro11 » Sun May 12, 2013 6:52 pm
I'm having a problem downloading. I'm using Internet Download Manager. I never had this problem downloading plugins before. Any Ideas?
i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
Structural Integrity is Not Just Physical...It's in the Design and Purpose
Mistro11
Postby Elibjr » Tue May 14, 2013 7:31 am
Thanks. This is simply amazing. Fredo6 you are too kind!
Elibjr
Premium Member
Premium Member
Postby TeKnoel » Wed May 15, 2013 4:47 pm
This is Amazing!!!! There have been tools that let you get to something approaching this result in the past but they have never been this streamlined and powerful. Thank you very much.
TeKnoel
Postby rv1974 » Thu May 16, 2013 8:08 am
Hi Fredo, I have a couple questions\requests(?), may be you could kindly help:
How would I:
1.precisely respect given contours (see the red clouds in attachment)
2.predictably set the grid direction (could toposhaper respect the current UCS, including grid origin point would start at current x=0,y=0,z=0?)
3.is there specific reason for minimum number of 20 cells? Setting (alternatively) the grid's physical dimentions would be nice too).
Thank you in advance.
rv1974
Postby fredo6 » Thu May 16, 2013 7:24 pm
rv1974 wrote:Hi Fredo, I have a couple questions\requests(?), may be you could kindly help:
How would I:
On 1), respecting contours, this is difficult and would not give smooth results. What I can maybe do is 'almost' respect 'some' contours.
On 2), it would be fairly possible to set the origin and orientation of the grid. This is just GUI to add.
on 3), you can already enter the cell dimensions. just type them as float (for current unit) or float + unit. architectural unique are accepted. This works in the VCB and in the dialog boxes. Otherwise, there is a minimum limit to the grid size, because otherwise you would not see anything.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Fri May 17, 2013 6:10 am
Fredo, thank you for clarification :thumb:
and hoping for p.2 will come true in some up-coming point update.
rv1974
Postby sridhar » Sun May 19, 2013 10:21 am
Hi Fredo,
Tried using the plugin, it allows me to select and then quickly flashes the cleansing screen and generates a flat rectangular surface and contours as guidelines.
I have installed as instructed.
Am i missing something
Regards
Sridhar
sridhar
Postby fredo6 » Sun May 19, 2013 2:27 pm
sridhar wrote:Hi Fredo,
Regards
Sridhar
The default view for the Cleansing is the map view. Are your original contours given an elevation?
The best would be to post your model
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby sridhar » Sun May 19, 2013 3:48 pm
Regards
Sridhar
Fredo
Hi sending the screenshot
thanks
sridhar
Postby fredo6 » Sun May 19, 2013 6:10 pm
@Sridhar
It seems you miss the button palette
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby sridhar » Tue May 21, 2013 3:21 pm
Fredo6 wrote:@Sridhar
Fredo
The button comes briefly and then exits out of the plugin with an output shown above,
Regards
Sridhar
sridhar
Postby fredo6 » Tue May 21, 2013 6:49 pm
sridhar wrote:Hi
Regards
Sridhar
Could you open the Ruby console and report of the error message you see.
Your model seems complex and there may be some issues
Thanks very much
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby chris87 » Tue May 21, 2013 8:08 pm
Fredo6 wrote:
sridhar wrote:Hi
Regards
Sridhar
Thanks very much
Fredo
I have the same problem.
The rod of Topshaper tools also disappears to this level.
No message of mistake in the Ruby console.
This problem even occurs with the well stocked examples.
chris87
Postby fredo6 » Tue May 21, 2013 10:55 pm
@chris87, @sridhar
Could check that if you type Return, you go to the next step (preview). You can also check the contextual menu.
By the way, which OS are you on?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby chris87 » Wed May 22, 2013 8:38 am
fredo6 wrote:@chris87, @sridhar
Fredo
OS :
PC windows 7 - sketchup 8 pro last version-
No action occurs with the key return
the contextual menu "toposhaper --- > generate land (square maillage)" makes the previous operation throw back only.
the toposhaper toolbar doesn't reappear.
excuse me for the bad english language (french user....)
best regards and thank you for your superb plugins...
chris87
Postby thirty6 » Wed May 22, 2013 10:10 am
Great plugin love it!
thirty6
Postby **Ewie** » Thu May 23, 2013 5:08 am
TIG wrote:Ewan
Hi TIG, sorry for the tardy reply, I didn't get a notification of the replies on this thread..
I checked permissions on the plugin folder; all full control so no issues there.
Re-ran the plugin with the ruby script window open.. Same issue as before, this time using one of the sample files
Screen shot attached to explain.
**Ewie**
Premium Member
Premium Member
Postby TIG » Thu May 23, 2013 8:50 am
@Ewan
Have you tried reinstalling the whole Topo'toolset AND the latest LibFredo again.
That might jolt it into submission...
First, if you did a manual install check for misplaced files in the Plugins folder.
Then reinstall the Lib, then Topo'toolset - I recommend you get/use the "SketchUcation Plugin Store" and use its 'AutoInstall' feature, this will ensure that everything is always put into the right places...
Global Moderator
Postby chris87 » Thu May 23, 2013 9:59 am
TIG wrote:@Ewan
I have exactly the same problem.
All is installed correctly with the good rights and with the last libraries.
No error in the ruby console !!!!
chris87
Postby TIG » Thu May 23, 2013 5:15 pm
Can you post screenshots for Fredo to check...
Of the Plugins folder showing the installed files/subfolder and the contents of the subfolder itself...
Global Moderator
Postby fredo6 » Thu May 23, 2013 6:51 pm
@chris87, @ewan
It may simply be a bug.
I'll come back with some instructions in order to figure out what it could be.
What would help me is that you tell me what you see in the contextual menu when you are in this screen (a screenshot is OK).
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby chris87 » Thu May 23, 2013 8:17 pm
fredo6 wrote:@chris87, @ewan
Fredo
chris87
Postby fredo6 » Thu May 23, 2013 9:14 pm
Chris,
I mean when you are within TopoShaper and have the display of your screenshot, right click and tell me what is the contextual menu.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby chris87 » Thu May 23, 2013 9:40 pm
fredo6 wrote:Chris,
Fredo
Visible on my screenshot :
right click
toposhaper ---- > générer terrain (maillage carré)
best regards
chris87
Postby solo » Thu May 23, 2013 10:08 pm
I'm getting a warning when starting SU 2013
Code: Select all
Error loading File bootstrap_TopoShaper.rb
uninitialized constant bTopoShaper::T6
I have tried reinstalling and even checked that bootstrap_TopoShaper is present in plugin folder.
Still get the error.
http://www.solos-art.com
solo
Global Moderator
Postby Rich O Brien » Thu May 23, 2013 10:10 pm
Is this the path?
C:\Program Files (x86)\SketchUp\SketchUp 2013\Plugins\TOPOSHAPER_Dir_10
Rich O Brien
Administrator
PreviousNext
Return to Plugins
Users browsing this forum: buiminh0402, jonorman, Josh16, juju, nima78 and 10 guests
