[Plugin] TopoShaper - v2.5c - 29 Oct 19 - IsoContour & Cloud
Re: [Plugin] TopoShaper - v1.0b - 26 Apr 13 -Terrain & Conto
Postby panixia » Tue Apr 30, 2013 9:21 am
this is fantastic! thank you one more time!!
a question about your tool interface: is there a way to avoid the text in tool panel being same color of the sketchup line style? i realized this looking at your screenshot.. if i turn on a style with black lines, i can see the text, but i'm used to work with a dark style + white edges and this make the text over yellow or other very light-coloured buttons almost unreadable.. is there a way to set this or some workaround to this? thank you!
panixia
Postby fredo6 » Tue Apr 30, 2013 9:48 am
panixia wrote:this is fantastic! thank you one more time!!
Unfortunately, I have no control on the text color with the current Ruby API. I think that the text color is inherited from the line color.
I will see if I can make a palette style.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby panixia » Tue Apr 30, 2013 10:12 am
Fredo6 wrote:I will see if I can make a palette style.
thank you a lot!
:idea: maybe if you already got control over the label's color it could also be easier to change them with some colors which can work good with both light or dark line style, pheraps using colors wich ar not much light or much dark..
panixia
Postby Hieru » Tue Apr 30, 2013 11:57 am
When working on architectural models, generating good topo for a hillside plot can be an absolute pain.
I just tried this on a project that previously took me the best part of a day to deal with the landscaping. A few clicks with this plugin and job done - simply amazing :sketchstatic:
Hieru
Premium Member
Premium Member
Postby matt.gordon320 » Tue Apr 30, 2013 4:42 pm
Absolutely astounding work as always sir. A donation will be on it's way soon :)
matt.gordon320
Premium Member
Premium Member
Postby EscapeArtist » Wed May 01, 2013 2:05 pm
This is AWESOME. I've been fighting with trying to smooth out some not-so-detailed contours from a USGS map for a while, this ruby did it in a snap with perfect detail. Thank you! :thumb: :thumb:
EscapeArtist
Top SketchUcator
Postby olishea » Wed May 01, 2013 3:01 pm
HUGE time saver!!
Normally i'd have to make construction point grids and then triangulate the points. This is so much more streamlined.
:thumb: :thumb: :thumb: :D
oli
olishea
Premium Member
Premium Member
SketchUp crashes generating terrain?
Postby gundamzd » Wed May 01, 2013 9:36 pm
Thanks so much for sharing this great plugin. However everytime I click "Calculate Terrain" SketchUp just crashes....and I tried the old sandbox tool it worked OK...can anyone tell me how to resolve this? Thanks so much!
gundamzd
Re: SketchUp crashes generating terrain?
Postby Krisidious » Wed May 01, 2013 11:44 pm
gundamzd wrote:Hi,
do you have any of these conflicting plugins? and have you downloaded the new libfredo library?
IMPORTANT: Requires to download LibFredo6 4.8 or higher if not already installed
CONFLICTING PLUGINS: some plugins conflicts with some of my scripts
Some versions of Podium
SunPosition
Matchbox
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby fredo6 » Thu May 02, 2013 12:16 am
gundamzd wrote:Hi,
Could you post or PM me the contours model so that I have a look.
Does it happen on all models you test (for instance on the sample models which are attached to the first post of this thread)?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby gundamzd » Thu May 02, 2013 2:45 pm
Fredo6 wrote:
gundamzd wrote:Hi,
Fredo
I reinstalled SketchUp and now it's working...must be some other conflicting plugins. Thanks again!
gundamzd
Postby gundamzd » Thu May 02, 2013 2:47 pm
Krisidious wrote:
gundamzd wrote:Hi,
SunPosition
Matchbox
You're right it was some other conflicting plugin but solved the problem by re-installing SketchUp. Thanks!
gundamzd
Postby Krisidious » Thu May 02, 2013 10:25 pm
No Problem... Enjoy Fredo's awesome plugin.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby plot-paris » Fri May 03, 2013 10:10 am
Hey Fredo,
pbacot's post made me thinking: One more nifty feature would be "Automatic Elevation".
Oftentimes one receives topographical data in 2D form (each line represents lets say 1 meter, but the actual model is just a 2D plan).
While your plugin does everything else perfectly, one still has to rely on manual labour (or another plugin) to move the contours up one by one.
Therefore this feature request for "Automatic Elevation". It would work as follows:
  • when analyzing the model, TopoShaper checks, if there is a third dimension to the geometry.
  • if all the contours reside on a planar surface, the plugin assumes a default step size (1 meter) and offsets each contour line by that distance in z-direction (or perpendicular to the planar surface of the contours).
  • TopoShaper chooses one boundary-contour as the "bottom" (usually the southern one I would presume) and displays a gizmo, sitting on that contour.
    • you can drag the gizmo to the other side of the terraint to reverse the direction of elevation
    • alternatively you get that little popup-window (that is already being used by the plugin) to choose the direction. The gizmo would then jump to the other side
    • the gizmo shows a vertical scaling-handle (like the green scale knob in the scale tool), which you can use to change the overall height of the terrain
    • alternatively you can type in a numerical height in the menu at the top of the screen
    • this "Elevation Gizmo" is deactivated by default, should the plugin find z-elevation already present in the model. It can be toggled on/off in the top menu though
In my opinion, this addition would perfect the plugin! Don't know, if it is possible. But considering what the plugin already does... ;)
Would love to hear your thoughts on this.
plot-paris
Postby pbacot » Fri May 03, 2013 3:46 pm
P-P
Contours, as you know can be convoluted. The tool I use in PowerCADD is more hands-on but goes pretty fast. You set the tool to the height of the contour you want to start with, set the increment and up-down direction. Then as you drag the cursor (in this case needle) it tells you what the contour under the cursor will be, then sets it when you let go. So you can do many contours in a sweep, all with a tag giving their elevation. You let go and they're set. Hovering with the cursor will give the contour's set elevation. And you can change it the same way.
PowerCADD is 2D but it will export such a set of contours in 3d dxf.
P
Top SketchUcator
Postby panixia » Fri May 03, 2013 7:54 pm
i'm not into this kind of modeling.. anyway i'm interested into trekking and mountan biking so i tried to have fun with this plugin it works hella fine even with massive geometry here is my test with one of my favourite mountains :)
panixia
Postby jolran » Fri May 03, 2013 8:00 pm
Fredo, you must be very rich giving a plugin like this away for free :shock:
Crazy amounts of code..
jolran
PluginStore Author
PluginStore Author
Postby Panga » Sat May 04, 2013 11:03 am
A really big thanks for this one Fredo, as always ! You don't imagine how many hours of my life you give me back with this ! I'll hit the donation button again, and hit it hard ! Now I have to learn this plugin, it seems that there's so many features in it !
Thinking of it, you just made what I was waiting from the SU dev team since I started using sketchup...
Panga
Premium Member
Premium Member
Postby thomthom » Sat May 04, 2013 11:59 am
panixia wrote:i'm not into this kind of modeling.. anyway i'm interested into trekking and mountan biking so i tried to have fun with this plugin it works hella fine even with massive geometry here is my test with one of my favourite mountains :)
That's some nice terrain graphics there. Did you make the earth section texture yourself?
PluginStore Author
PluginStore Author
Postby panixia » Sat May 04, 2013 8:47 pm
i don't deal with contour models, landscape and so on.. just wanted to play with this beauty of plugin.. so grabbed the mountain from google used contour maker by tig to cut the contours, used the cuntours to generate the mesh, did a bit of general cleanup and texturing with a mix of VT + QFT + trupaint, then copied and pasted in place into groups both the contours and the quad grid and converted them with "lines to tubes" plugin for vray to render them.
just to practice.. one never knows.. plus this is funny.
edit. i misunderstood the question.. my english is quite bad.. and i'm tired.. yeah i did the texture by myself.. here is the vismat if you like it..
panixia
Postby rv1974 » Sun May 05, 2013 8:53 am
Fantastic! thank you Fredo for sharing.
rv1974
Postby publied » Sun May 05, 2013 11:11 am
no words. one only: amazing!
+thank you
publied
Postby torring » Sun May 05, 2013 12:44 pm
thanks fredo... your the man
torring
Postby tspco » Sun May 05, 2013 2:55 pm
Very cool Fredo!. Since I used to grab terrains from within SU that were supposed to be geolocated and truthful...I grabbed one today, used the contour tool, to generate the iso-lines then deleted the terrain I grabbed. Used TopoShaper to redo the terrain. It worked well after a few attempts thank you very much!. All is not perfect however, I tried to project a gradient material to the terrain, and I ended up with a bunch of different colored triangles, not a smooth texture, I will see if I can figure out what I did wrong...
SU make 2017, /Twilight Render Hobby
Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
tspco
Postby pjkm21 » Mon May 06, 2013 11:36 am
Really Thank You!! A real Master!
pjkm21
Postby Whaat » Tue May 07, 2013 7:25 pm
Just seeing this now for the first time. Pure brilliance! :thumb: :thumb: Another incredible addition!
Whaat
PluginStore Author
PluginStore Author
Postby mitcorb » Tue May 07, 2013 7:31 pm
@Whaat:
see this example: viewtopic.php?f=81&t=52237
mitcorb
Top SketchUcator
Postby troyhome » Tue May 07, 2013 8:32 pm
Any ideas why I get this when starting SU after installing TopoShaper?
IOviz.com
SU Pro 2017 PC
Thea: latest
vray4SU latest
troyhome
Postby massimo » Tue May 07, 2013 8:44 pm
Have you observed the correct footprint? (See the first post of the thread)
massimo
Postby troyhome » Tue May 07, 2013 9:12 pm
massimo wrote:Have you observed the correct footprint? (See the first post of the thread)
Ha! Silly mistake. Thanks!! works fine. :oops:
IOviz.com
SU Pro 2017 PC
Thea: latest
vray4SU latest
troyhome
PreviousNext
Return to Plugins
Users browsing this forum: No registered users and 18 guests
