[Plugin] TopoShaper - v2.5c - 29 Oct 19 - IsoContour & Cloud
Re: [Plugin] TopoShaper - v2.3b - 06 Dec 17 - IsoContour & C
Postby fredo6 » Wed Apr 11, 2018 11:13 am
clement duvoux wrote:Bonjour Fredo,
Après installation de la dernière version de Toposhaper (2.3b) et de LibFredo6 v8.1h, Toposhaper ne s'execute pas à l'ouverture de Sketchup, renvoyant un message d'erreur qui est le suivant : "you must install LibFredo6 to run Toposhaper
Open the download page of LibFredo6 at https....".
Après vérification dans l'extension manager, LibFredo est pourtant bien installé. Une idée sur l'origine du bug ?
Il faut verifier que LibFredo6 est bien chargé. Est ce qu'il y a un menu Window > LibFredo6 Settings.... ?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby gio » Fri May 04, 2018 11:43 pm
Pixero wrote:I was wondering if there is a limit to how detailed a ISO lines terrain can be to work with Toposhaper?
As you can see in the attached image only a part of the terrain is created. If I try with a less dense contour file of the same area it works but I need the detail as high as possible.
Maybe you can make just smaller portions and join them in the end?
Gio
gio
Postby dlannetts » Mon May 07, 2018 11:38 am
Hello,
Great plugin, however I am having an issue, after generating the terrain from guide points, using the toolbar, and clicking off elsewhere, the toolbar disappears and I can't seem to get it back to modify the terrain. How can I get the toolbar back after it has disappeared?
David.
dlannetts
Postby fredo6 » Mon May 07, 2018 1:06 pm
dlannetts wrote:Hello,
David.
Can you open the Ruby console, as there may be an error.
Did the terrain generate correctly by the way?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby simonhaufe » Wed Jun 13, 2018 10:52 am
I just try TopoShaper with a point cloud with more than 130.000 points out of a ASCII-File. How I can import it in SU and make any kind of terrain model?
Any ideas and suggestions are most welcome!! :fro: :enlight:
Best Regards Simon
simonhaufe
Postby fredo6 » Wed Jun 13, 2018 3:00 pm
simonhaufe wrote:I just try TopoShaper with a point cloud with more than 130.000 points out of a ASCII-File. How I can import it in SU and make any kind of terrain model?
Best Regards Simon
I don't think TopoShaper can handle 130,000 points; and I don't think either that Sketchup will not scream with a mesh of 130,000 vertices.
So you'll probably have to find a way, with other tools to simplify the input points or raw mesh, either simplifying, or cutting in pieces if the cloud covers a very large area. I don't know if there are Ruby scripts in Sketchup to do that, but I know there are specialized terrain software that can do it. There are several discussion threads in Sketchucation and Sketchup forums about terrains.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rspierenburg » Wed Jul 11, 2018 2:04 pm
I'm trying to use Toposhaper to create a topo from points. I have points selected and when I run the plugin all I get is a blank error.
rspierenburg
Postby fredo6 » Thu Jul 12, 2018 12:20 am
rspierenburg wrote:I'm trying to use Toposhaper to create a topo from points. I have points selected and when I run the plugin all I get is a blank error.
It would be helpful that you attach your model so that I can investigate. Thanks.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rspierenburg » Thu Jul 12, 2018 2:53 pm
Thanks, Here is the model.
rspierenburg
Postby fredo6 » Thu Jul 12, 2018 4:40 pm
@Rspierenburg
You just need to put all contruction points and the contour within a Group, then select the group and run TopoShaper Cloud.
Note that your model seems to have some points which create peaks.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Anastasia_0111 » Sat Jul 14, 2018 8:41 am
What can be the reason of such error of TopoShaper?
It appears on SketchUp17 and 18, if I try very simple terrain, just of 2 or 3 curves.
Anastasia_0111
Postby pilou » Sat Jul 14, 2018 9:19 am
Put your SKP, that can be helping! ;)
Save as V6 for a more large audience! ;)
Speedy Galerie
Top SketchUcator
Postby Anastasia_0111 » Sun Jul 15, 2018 7:49 pm
As I said it happens in any file, just if I try to create a terrain from 2 simple curves drawn by "freehand".
This is a full text of the error:
body_lib6g6.rbe
2254
block in proximity_point_curve_by_circle
body_lib6g6.rbe
2249
each
body_lib6g6.rbe
2249
toposhaperalgo.rbe
2419
block in altitude_at_point
toposhaperalgo.rbe
2417
each
toposhaperalgo.rbe
2417
altitude_at_point
toposhaperalgo.rbe
2390
altitude_multi
toposhaperalgo.rbe
427
block in top_processing
toposhaperalgo.rbe
425
each
toposhaperalgo.rbe
425
each_with_index
toposhaperalgo.rbe
425
top_processing
toposhapertool.rbe
574
algo_processing
toposhapertool.rbe
666
execute_validate
toposhaperpalette.rbe
130
execute_from_palette
76
notify_from_palette
518
call
518
block (2 levels) in palette_validate
body_lib6palette.rbe
3596
call
3596
execute_button
3401
onLButtonUp
lib6palette.rbe
91
onLButtonUp
toposhapertool.rbe
984
onLButtonUp
Anastasia_0111
Postby fredo6 » Sun Jul 15, 2018 8:35 pm
@Anastasia_0111
Could you indicate the text of the error (just just give the files and line numbers), as well as post one of this simple model with free-hand drawn curve.
Many thanks
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby peggy1124 » Sat Aug 11, 2018 3:13 pm
Thank you Fredo
amazing plugin
peggy1124
Postby Keniff » Fri Sep 14, 2018 12:00 pm
Hi, Can't get this to work on my Mac. Using the supplied 'test' SKP file I either get a full on program bug splat! a non contoured output, just the shape of the face or the attached useless error message:
Any help appreciated
Keniff
Postby Keniff » Fri Sep 14, 2018 4:28 pm
Hi, Finally got this working on my mac after I realised that it worked on a group rather than selecting points (contrary to some vids I've watched) However, now I've got it working the results I've got are not using all the cloud points in the group. Therefore the result is very "pointy" Any help appreciated
Keniff
Postby fredo6 » Mon Sep 17, 2018 12:36 pm
Very difficult to help if you do not post the model
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby akaraphon » Mon Nov 05, 2018 5:00 am
hi fredo btw this plugin is very useful but i have some question . i want to create full area terrain but this is what i got . could you help me what i have to do
ps. thank you
akaraphon
Postby akaraphon » Tue Nov 06, 2018 3:34 am
hi fredo ,i got some problem . i want to create terrain in full area but this is what i got . how can i do for expand the extent of terrain
thank you
akaraphon
Postby fredo6 » Tue Nov 06, 2018 9:40 pm
akaraphon wrote:hi fredo ,i got some problem . i want to create terrain in full area but this is what i got . how can i do for expand the extent of terrain
If you include a face (or several) in the group where you have the Guide points, TopoShaper will use them for the contour of the terrain.
Anyway, the best is that you post your model so that I can have a look.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby alpro » Sat Nov 10, 2018 12:35 am
Fredo, first off let me thank you for all of your amazing plugins. I have a request for toposhaper. I don't know anything about coding and/or how difficult this would be. But in surface modeling programs you have the ability to add breaklines which make a more accurate surface. Do you think this can be added?
A Breakline is a line used to connect data representing a distinct surface feature, like a ridge line, edge of pavement, toe of a slope, centreline of a road, or flowline of a ditch or stream. When a breakline is defined, the surface triangulation must first follow the breakline, by placing triangle edges coincident with the breakline segments. This ensures the feature in the model is accurately depicted. Then, the rest of the interpolation is performed based on proximity. Breaklines are typically critical to creating an accurate surface model. It is the interpolation of the data, not just the data itself that determines the shape of the model.
alpro
Premium Member
Premium Member
Postby fredo6 » Sat Nov 10, 2018 7:18 am
alpro wrote:Fredo, first off let me thank you for all of your amazing plugins. I have a request for toposhaper. I don't know anything about coding and/or how difficult this would be. But in surface modeling programs you have the ability to add breaklines which make a more accurate surface. Do you think this can be added?
It is complex (it involves constrained Delaunay triangulation), but I finally built an algorithm (I use it already in FredoCorner). I will integrate it in TopoShaper when I can, along with a GUI refresh. This would look like a "from Contour", where you can also influence the terrain with additional guide points.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby alpro » Sat Nov 10, 2018 10:45 am
That's great Fredo, look forward to it.
alpro
Premium Member
Premium Member
Postby pbacot » Sat Nov 10, 2018 7:34 pm
What I wonder how this could be input to the plugin. I'd like to see an example and how it might be implemented on UI level. I suppose edges that are horizontal can be introduced which are defined as firm intersections with the surface and not interpolated with the rest of the terrain. Working-in grades along retaining walls or building walls (rarely level) might be done be definition of point elevations.
My approach is usually working with existing terrain so after TopoShaper I massage it to new work as needed, sometimes cutting the surface where needed, sometimes moving points of the cut portions to fit to new walls or edges of pavement (e.g.). I see that where a vertical face is actually included in the original contours, weird results happen, but I generally rebuild that part or cover it in other geometry (like a model of the retaining wall it represents).
Top SketchUcator
Postby fredo6 » Sun Nov 11, 2018 11:13 pm
In general, it is better to conceive the terrain before adding decoration, houses, fences, etc...
But I'll think about what can be done, especially for roads.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby KrisM » Sun Nov 11, 2018 11:51 pm
This would be GREAT addition to this plugin. I do this work manually at present and it is tedious to say the least. This would be a great time saver.
KrisM
KrisM
Premium Member
Premium Member
Postby Pixero » Mon Nov 12, 2018 9:56 am
Something interactive like this for roads would be superb.
https://www.youtube.com/embed/APuVx7Wdvk4?ecver=1
And here is a open source road editor solution: https://gupea.ub.gu.se/bitstream/2077/2 ... 3047_1.pdf
Pixero
Postby fredo6 » Mon Nov 12, 2018 11:07 am
I think there is already a Plugin, InstantRoad by ValiArchitect.
Anyway, building such a plugin is independent from TopoShaper, as it should apply to any terrain, whatever method has been used to generate it.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Pixero » Mon Nov 12, 2018 11:54 am
But Instant road isn't interactive like in the link.
Pixero
PreviousNext
Return to Plugins
Users browsing this forum: ALPKFTC, chriseckelkamp, degele, Google Bot, joseluis778, jstock327 and 20 guests
