[Plugin] TopoShaper - v2.5c - 29 Oct 19 - IsoContour & Cloud
Re: [Plugin] TopoShaper - v2.3a - 17 Jan 17 - IsoContour & C
Postby fredo6 » Tue Jan 17, 2017 11:16 pm
NEW RELEASE: TopoShaper v1.3a - 17 Jan 17
This is a minor release with SU2017 certification
See main post of this thread for Download.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby dvdstwrt » Thu Apr 13, 2017 3:53 am
I am having trouble installing the toposhaper extension in SUMaker2017 and get the following after restarting SU. Any suggestions would be appreciated
dvdstwrt
Postby TIG » Thu Apr 13, 2017 11:28 am
dvdstwrt wrote:I am having trouble installing the toposhaper extension in SUMaker2017 and get the following after restarting SU. Any suggestions would be appreciated
You seem to have missed off the error message ?
Have you also installed the needed LibFredo?
Also check that both Extensions are activated and restart SketchUp to ensure any changes/additions are fully integrated...
Global Moderator
Postby Einstein » Tue Apr 25, 2017 5:36 pm
Fredo, your plugins are mindblowing!
Einstein
Postby john2 » Tue May 30, 2017 3:57 pm
Every time I start sketchup I am receiving the following pop up.
All my fredo plugins are updated. I checked it with the feature of fredo tools itself.
What should I do to resolve this issue?
john2
Postby TIG » Tue May 30, 2017 4:04 pm
Have you also installed the very latest LibFredo ?
Global Moderator
Postby john2 » Wed May 31, 2017 5:24 am
TIG wrote:Have you also installed the very latest LibFredo ?
Yes
john2
Postby pilou » Wed May 31, 2017 10:57 am
Have you re-launched SketchUp ?
Speedy Galerie
Top SketchUcator
Postby john2 » Wed May 31, 2017 11:38 am
pilou wrote:Have you re-launched SketchUp ?
Yes. Every time I start sketchup, I am getting this dialogue box.
john2
Postby TIG » Wed May 31, 2017 1:59 pm
Is the LibFredo activated in the Extension Manager dialog ?
Global Moderator
Postby john2 » Wed May 31, 2017 3:36 pm
TIG wrote:Is the LibFredo activated in the Extension Manager dialog ?
I am using Sketchup 2016 version. The libfredo is activated and I see a tick mark right next to its name in the list which I accessed by going to System preferences>extensions
john2
Postby fredo6 » Wed May 31, 2017 7:34 pm
I think the best would be to have a snapshot of your Sketchup Plugins Directory. It looks like there is an old LibFredo6 somewhere.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Fri Sep 15, 2017 7:48 pm
WARNING: Potential issues in TopoShaper (IsoContour) with LibFredo6 7.7d.
I will publish a fix in LibFredo6 v7.7e as soon as the Extension Ware House site works again.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby hiryfi » Fri Sep 22, 2017 6:37 pm
Greetings,
I am a extreme beginner with SU and am trying to use toposhaper to generate a topo of a piece of land I recently purchased. Reading, researching, and a lot of trial and error!
I am using previous survey data and septic design plans to do this. I have a .txt file with 144 points of xyz data. I imported that into SU with point gadget in a .csv file and have all the points imported. My problem is getting toposhaper to accept the points. I either get a I have tried to install toposhaper with libfredo6_v7.7e prior multiple times with no luck. I could not find the auto-installer and have installed via the extension manager. I'm sure I am screwing something up, just can't pinpoint what I am doing wrong. Any tips are much appreciated. I will continue to search through the libfredo post as well. I have attached my data and some screen shots of the messages I am generating. I see others have had similar issues so I'm sure its some user issue on my end.
I am using SU Make 2017, Windows 7
Thanks,
hiryfi
SU17
Very Green
hiryfi
Postby fredo6 » Fri Sep 22, 2017 6:50 pm
@hiryfi
From the trace, it seems you have installed LibFredo6, TopoShaper (and FredoTools) correctly. Can you confirm?
For generating a terrain from the point cloud, Toposhaper requires that the points are
- Construction point (Guide Point in Sketchup), positioned at their altitude.
- all enclosed within a group
- If you add one or several faces within the group, they will delimit the boundary of the terrain by projection.
There are tools to import point clouds from CSV or TXT file (one by Didier Bur and one by TIG), I think.
Also, have a look at the videos in the first post of this thread for TopoShaper generation of terrain from point clouds.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby hiryfi » Thu Sep 28, 2017 4:19 am
@fredo
Thanks for the help, I used a different importer from TIG and yielded much better results. I made a small donation to your paypal on 9/22 for your time and wonderfully narrated videos on TopoShaper.
Cheers,
hiryfi
SU17
Very Green
hiryfi
Postby Slagothoric » Tue Dec 05, 2017 3:02 pm
Thank you for this wonderful plugin. I do have a question about the cell sizes. Is there a way to increase the cell size beyond 200? The current contour profiles that I'm using is set at 2 foot intervals. Unfortunately for the size of the profiles, the 200 limit on cell sizes is producing a less than desirable resolution for the entire map. I will gladly donate as this is an exceptional tool, but could you provide guidance or suggestions on any way to increase the cell size limit. Thank you in advance and kind regards.
Slagothoric
Postby fredo6 » Wed Dec 06, 2017 4:36 pm
@slagothoric
The purpose of TopShaper is to smooth the terrain to a grid. so this is why a too detailed grid is usually not necessary. In addition, the algorithm is quite greedy, so oversampling the grid may lead to very long computation times.
Anyway, I just published a new version, TopoShaper (v2.3b), where the default maximum value for the grid resolution an be increased up to 2000, by going to the Default Parameters box of TopoShaper (default is still 200). But be prepared to have a long coffee break...!
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] TopoShaper - v2.3b - 06 Dec 17 - IsoContour & C
Postby fredo6 » Wed Dec 06, 2017 4:41 pm
NEW RELEASE: TopoShaper v2.3b - 06 Dec 17
This is a minor release with an increase of the grid resolution for the Contour tool
- up to 200 by Default
- up to 2000, by changing in the Default Parameters dialog box
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby pbacot » Wed Dec 06, 2017 7:16 pm
Nice! Thanks Fredo!
Top SketchUcator
Postby Slagothoric » Wed Dec 06, 2017 10:05 pm
Fredo, thank you so much for addressing my issue. That is truly some amazing support. Please include your preferred link and I will gladly donate for your efforts!
Slagothoric
Postby TIG » Wed Dec 06, 2017 11:42 pm
Slagothoric wrote:...Please include your preferred link and I will gladly donate for your efforts!
Many authors provide a 'Donate' link-button [yellow] on their PluginStore entries listings...
Global Moderator
Postby edarchm2 » Wed Dec 13, 2017 12:14 am
where ccan i download it?#
edarchm2
Postby fredo6 » Wed Dec 13, 2017 4:51 am
edarchm2 wrote:where ccan i download it?#
You can download the RBZ at https://sketchucation.com/pluginstore?pln=TopoShaper
Note that you need to install also the companion library LibFredo6.
Otherwise, the best is to install the Sketchucation ExtensionStore plugin and then auto-install TopoShaper and any of the 800 plugins in the store in one click.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Mon Jan 29, 2018 9:23 am
Hi Fredo,
*) How do I solve 'needle eye' obstacle (see attached)? Plugin get stuck at this stage forever.
*) Second very primitive mesh crashes on generating. Could you take a look at this example?
P.S. I always had scruples to ask, What is purpose of this 2nd 'zoomed' mesh in beige square?
rv1974
Postby fredo6 » Mon Jan 29, 2018 2:51 pm
rv1974 wrote:Hi Fredo,
Your models seems 'unprepared' for TopoShaper. I don't see contour lines, but instead lot of edges with intersections and different altitudes.
The blocking on Needle Eye is actually just a Ruby error due to the convoluted configuration of contours, but even if I fixed it, I don't see how you can generate a terrain from your input data.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Mon Jan 29, 2018 5:16 pm
RTFM helped as usual, many thanks
rv1974
Postby Pixero » Mon Mar 19, 2018 9:03 am
I was wondering if there is a limit to how detailed a ISO lines terrain can be to work with Toposhaper?
As you can see in the attached image only a part of the terrain is created. If I try with a less dense contour file of the same area it works but I need the detail as high as possible.
Pixero
Postby fredo6 » Mon Mar 19, 2018 10:11 am
Pixero wrote:I was wondering if there is a limit to how detailed a ISO lines terrain can be to work with Toposhaper?
The typical usage of TopoShaper is to smooth out the terrain, using isocontours as guides for altitude. The precision of the contours is not necessary (i.e. does not need closely spaced contours, nor many points in the contour curves), and anyway in relation with the resolution of the mesh.
All this being said, I am impressed by the large model you have.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby clement duvoux » Wed Apr 11, 2018 12:45 am
Bonjour Fredo,
Après installation de la dernière version de Toposhaper (2.3b) et de LibFredo6 v8.1h, Toposhaper ne s'execute pas à l'ouverture de Sketchup, renvoyant un message d'erreur qui est le suivant : "you must install LibFredo6 to run Toposhaper
Open the download page of LibFredo6 at https....".
Après vérification dans l'extension manager, LibFredo est pourtant bien installé. Une idée sur l'origine du bug ?
clement duvoux
PreviousNext
Return to Plugins
Users browsing this forum: degele, Google Bot, lulilu2020, sreekanth reddy and 21 guests
