by TIG » Sun Oct 20, 2013 3:28 pm
How have you 'installed it' ? What are the errors? I suspect they relate to missing files ?? This plugin's archive [ZIP file] looks like the attached image. Copy those two items into the Plugins folder, keeping the contents in the same relationship. That is one .rb file and the plugins's subfolder [containing other code files, images etc]. You need FULL read/write security permissions to the main Plugins folder... ['Compatibility Files' issues and the 'VirtualStore' beckon otherwise  ] Also set SketchUp.exe to 'Always Runs as Administrator'... There are may posts covering these aspects in great detail...
- Global Moderator
- Name: TIG
- Operating system: Windows
- SketchUp version: 2021
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by Cerboney » Sun Oct 20, 2013 10:08 pm
Hi thank you TIG for your help, it works thanks to your explanations. I think I copied only the .rb file in the folder "Plugins" of Sketchup.
Bye
Cerboney
- Name: Cerboney
- SketchUp version: 8
- License type: Free/Make
- SketchUp use: historical reconstruction
- Level of SketchUp: Beginner
by dacastror » Thu Nov 07, 2013 1:38 am
dacastror
- Name: Diego Castro
by dacastror » Thu Nov 07, 2013 1:52 am
the helix is closed properly!
dacastror
by fcohen » Mon Nov 25, 2013 2:30 am
Thank you for this plug-in. Very useful! I am looking to hire a contractor to take my hand-drawn sketches of a mens watch project (details at http://www.votsh.com) and create SketchUp files. Please email me fcohen at votsh.com for details on the contract. Thanks! -Frank
fcohen
- Name: Frank Cohen
- Operating system: Mac
- SketchUp use: product design
by 3dalbertsoft » Thu Mar 27, 2014 12:48 am
I have verified that helix along curve works in sketchup 2014, you can install and use without problems
3dalbertsoft
- PluginStore Author
- Name: 3dalbertsoft
- SketchUp version: 2014
- SketchUp use: hobby
by Harry K » Sat Aug 02, 2014 9:30 pm
I don't seem to be able to get it to install properly. Running OSX 10.8.5. Am placing files in Library/Application Support/Sketchup 2014/Sketchup/Plugins.
Any ideas?
Harry K
- Name: Harry K
by Dave R » Sat Aug 02, 2014 10:34 pm
Harry K wrote:Am placing files in Library/Application Support/Sketchup 2014/Sketchup/Plugins What does this mean specifically? Did you just drop the downloaded ZIP file into the Plugins folder? If so, that won't work indeed because you didn't actually install the plugin. If you did that, move the zip file back out of the Plugins folder to somewhere else. Maybe Downloads. Then right click on the zip file and choose Get Info. There change the extension from .zip to .rbz. In SketchUp click on the SketchUp menu and choose Preference>Extensions. Click on Install Extension. Navigate to the file and click Open. Click Yes and OK as they show. The plugin should now be installed correctly. If you did anything else, go to the Plugins folder and delete any and all related files before making the .rbz file and installing it. Most plugins are available through the Sketchucation Plugin Store--link at the top of the page or the Extension Warehouse. You don't have to do all these gymnastics to install plugins with them but you should at least install the SCF Plugin Store.
- Global Moderator
- Name: Dave R
- License type: Pro
- SketchUp use: woodworking
by Harry K » Sun Aug 03, 2014 12:33 am
Dave R wrote:Harry K wrote:Am placing files in Library/Application Support/Sketchup 2014/Sketchup/Plugins What does this mean specifically? Did you just drop the downloaded ZIP file into the Plugins folder? If so, that won't work indeed because you didn't actually install the plugin. If you did that, move the zip file back out of the Plugins folder to somewhere else. Maybe Downloads. Then right click on the zip file and choose Get Info. There change the extension from .zip to .rbz. In SketchUp click on the SketchUp menu and choose Preference>Extensions. Click on Install Extension. Navigate to the file and click Open. Click Yes and OK as they show. The plugin should now be installed correctly. If you did anything else, go to the Plugins folder and delete any and all related files before making the .rbz file and installing it. Most plugins are available through the Sketchucation Plugin Store--link at the top of the page or the Extension Warehouse. You don't have to do all these gymnastics to install plugins with them but you should at least install the SCF Plugin Store.
Mac OSX automatically unzips, but the extension was wrong (tbs, rb), so I added the "z" AND the system also hides the library so you can't navigate to it via preferences > extensions.... But I found a way to "unhide" the Library. I was then able to choose the extension...only to be greeted with "unable to open..." Is there a Plan B?
Harry K
- Name: Harry K
by Dave R » Sun Aug 03, 2014 9:37 am
You don't need a plan B. You need to follow plan A.
AGAIN: -Remove the files you inserted into the Plugins folder because you've done it wrong. -Make sure you have permissions set to Read and Write for the Plugins folder. -Find the ZIP file and rename it from .zip to .rbz. DO NOT OPEN THE ZIP FILE. DO NOT TOUCH ANYTHING INSIDE IT. -Open SketchUp. -Go to the SketchUp menu--left of File and click on Preferences. -Select Extensions from the list in the Preferences window. -Click on Install Extension. -Navigate to where you downloaded and saved the zip file (which is now a .rbz file). -Select it. -Click Open -Click Yes and OK as they present themselves. -Close the Preferences box.
The plugin should now be installed.
- Global Moderator
- Name: Dave R
- License type: Pro
by Harry K » Sun Aug 03, 2014 12:52 pm
Ahhh. My browser was auto-unzipping the download. Changed that and it worked like a charm.
Many thanks for your patience.
Harry K
- Name: Harry K
by hgdn » Sun Oct 05, 2014 4:47 pm
Oh, what a fun/amazing plugin ever, works and so much creative outcomes with quick changes, thanks so much to 3dalbertsoft!!!!
hgdn
- Name: hgdn
by GregorS » Sun Feb 01, 2015 2:12 pm
My suggestions for the English text describing the plugin options:
These are the Helix along curve plugin options: You can set a value for the radius of the helix start and another for the end (these values can be positive or negative) You can set the number of turns of the helix (this value can be a positive integer or a positive decimal) Specify the number of line segments that make up each turn of the helix (this value can be a positive integer decimal) Modify the start angle of the helix (the angle value should be given in degrees as an integer or decimal) Set the level of "noise" (the value entered must be between 0 and 1), this will add a different random value to each turn radius of the helix. This random noise will be greater when the input value is closer to 1 You can choose from five different options for a parameter called "adherence to the curve", which defines whether the helical curve will strictly or smoothly. (smooth is recommended for best results). The "Calculation mode" simply summarizes multiple internal parameters that would not be easily understood by users. Sometimes very steep curves can cause unwanted results, in these cases smoother curves or slightly different tests can be performed by varying the "calculation method" to find out which will give the best results for that particular curve. If you are not having problems, it is advisable to leave this value in recommended mode (C) You can set the direction of rotation of the helix, i.e. rotation in the clockwise or counterclockwise direction Helicoid will create with a curve or a circular tube. If you choose to create a tube, you can set your ratio (the value entered must be a positive integer or a positive decimal). You can specify the number of sides of the tube (which can be a minimum of 3 sides, this value must be a positive integer).
Now I will try to design a lamp with the plugin! If I can install it! there were no installation instructions so I do not know where to put the files extracted from the .zip...
GregorS
- Name: Gregor Shapiro
- SketchUp version: 2015
by Dave R » Mon Feb 02, 2015 1:11 pm
GregorS wrote:Now I will try to design a lamp with the plugin! If I can install it! there were no installation instructions so I do not know where to put the files extracted from the .zip...
Knock, knock. viewtopic.php?f=323&t=51770&p=555970#p534207
- Global Moderator
- Name: Dave R
- License type: Pro
by 3dalbertsoft » Tue Feb 10, 2015 7:14 pm
GregorS thank you very much  , I updated the description of plugin options using your suggestions. Dave Thanks for responding to the subject of the installation (google translator)
3dalbertsoft
by HikerDave » Sun Aug 23, 2015 11:19 pm
Hi 3dalbertsoft - having lots of fun with this plugin! Is there a way to rotate the extruded shape on its own axis as it follows the curve? That is to say, in your video at 5:00 you extrude a triangle along the curve. What I would like to do is rotate the triangle on its center, perpendicular to the curve, so that I may have a twisting triangular tube. Thanks for the work on this!  Dave
HikerDave
- Name: Dave Misner
by 3dalbertsoft » Wed Sep 02, 2015 1:25 pm
Hello Dave, now that option is not implemented. It seems a good idea for future versions
3dalbertsoft
by wimve » Fri Jan 29, 2016 7:59 pm
THANK YOU VERY MUCH !
Very nice and simple to use plugin.
I have a question too: how can I create flat start and ends ? Real spings have a "flat" end. So the last coil bends inwards and flattends out. (I hope I write something that makes sense)
wimve
- Name: wimve
by Dave R » Fri Jan 29, 2016 8:08 pm
When I need to draw a compression spring or a spring with a hook or eye on the end, I draw the flattened helices for the ends separate from the middle section. adding a hook would be a matter of continuing the paths. See this for ideas. The same basic workflow can also be used for springs with changing radii.
- Global Moderator
- Name: Dave R
- License type: Pro
by MCVet » Fri Jul 15, 2016 1:43 am
Great Plugin, I was able to replicate a Torque (a celtic jewel) and then 3dprint the result.
MCVet
- Name: Mario Crespo
- SketchUp version: 2018
by Rozina » Sat Sep 17, 2016 2:51 am
Does anyone know hot to install it?
Rozina
- Name: Rozina
- SketchUp version: 2016
by TIG » Sun Sep 18, 2016 7:52 pm
Rozina wrote:Does anyone know hot to install it?
Swapping the word 'hot' for 'how'... I assume you mean this: viewtopic.php?p=467840#p467840The first post in the thread... There are two links. One to the author's own site and the other to the PluginStore's RBZ... http://sketchucation.com/pluginstore?pl ... long_curvePlease learn to use the links, search-tools and so on...
- Global Moderator
- Name: TIG
- License type: Pro
by jack_sprat » Sat Oct 01, 2016 12:15 am
Great plug-in - a really handy tool. Thank you.
jack_sprat
by uxamakhan21 » Mon Sep 25, 2017 6:16 pm
how to download this plugin please letme know ..
uxamakhan21
- Name: Usama
by TIG » Mon Sep 25, 2017 6:59 pm
uxamakhan21 wrote:how to download this plugin please letme know ..
Most plugin threads have download links in their first post. This is no exception. The PluginStore entry is also easily found using helix + curve as the search... https://sketchucation.com/pluginstore?pln=helix_along_curve Download its RBZ and install that using the native Extension Manager installer... Or of course, the SketchUcation ExtensionStore's similar tool...
- Global Moderator
- Name: TIG
- License type: Pro
by Ahmed0007 » Mon Oct 30, 2017 7:12 pm
This plugin initially emerged in order to meet design needs some personal projects. I've decided to add some additional details and publish this work. I plan to make more plugins when I have free time.
Ahmed0007
- Name: Ahmed
- License type: Pro
- SketchUp use: other
by kapstuff » Mon Feb 19, 2018 8:45 pm
A great tool. Tried a number of different helix plug-ins. This one best satisfied my needs, and much easier than many others. Would be handy if I could load the variables from a text file (or XLS). Have multiple helixes to create.
kapstuff
- Name: Ken Penske
- SketchUp version: 2017
by chaster » Wed Mar 21, 2018 11:42 pm
3dAlbertsoft, this is one of my FAVORITE plugins. Thank you so much for making and publishing it! By chance, would it be possible to modify the plugin so that it takes a second curve to define the radius of the helix? This feature would help me on a project greatly.  Regardless, WONDERFUL work! Thanks again for making it available to everyone! Eric
chaster
- Name: chaster
by gripple » Thu May 03, 2018 3:07 pm
This is a great plugin, I have been using it in Sketchup 2017, however it doesn't seem to work/install in Sketchup 2018! Anyone else got it to work in Sketchup 2018? Thanks, Jez.
gripple
- Name: Jez
- License type: Pro
by gripple » Thu May 03, 2018 3:37 pm
UPDATE! This does work in Sketchup 2018. Cheers, Jez.
gripple
- Name: Jez
- License type: Pro
- Robot
Return to Plugins
