[Plugin] 3D Text Editor
Re: [Plugin] 3D Text Editor (1.0.0) — 19 February 2013
Postby rv1974 » Wed Jun 05, 2013 9:42 am
:? (SU2013 win7 x64, latest TT_lib (v.7.1)))
there's nothing in combo-box, height parameter is down.
Any hints?
rv1974
Postby TIG » Wed Jun 05, 2013 9:55 am
rv1974 wrote::? (SU2013 win7 x64, latest TT_lib (v.7.1)))
Any hints?
Are you doubly sure that this Lib is 'latest' and properly installed ?
Screen-shot of Plugins WE window ?
What can you do after closing that error-message ?
Global Moderator
Postby thomthom » Wed Jun 05, 2013 10:16 am
Any hints?
Try these possible solutions - in order.
#1: Check that you don't have an old version of TT_Lib in the VirtualStore: viewtopic.php?t=48399
#2: Manually reinstall TT_Lib - by closing all SketchUp windows and removing the TT_Lib2 lib files before reinstalling.
(BTW: What is your Internet Explorer version? )
(P.S. The latest version of TT_Lib is 2.8.2 - currently only available on the Extension Warehouse. Ditto for an updated version of 3D Text Editor - though the very latest revision is still in moderation. I'm still in the process in updating my plugins to comply with the EW requirements - and I'm currently awaiting some changes to the SCF PluginStore before I start updating my plugin threads here.)
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Jun 05, 2013 11:41 am
Good news:
I managed to make tt_text work properly.
Bad news: now I've got 2 the same "editable 3d text" lines in Draw menu. the same happens in the Context menu.
I guess I should purge something i plugins folder. Could you look at the attached search filter (by 'tt')?
BTW#1 I've got IE 9.0.8112
BTW#2 I have vertigo with all those 'shops' (SU Ext wharehouse, virtualstore, sketchucation forum threads, sketchucation plugin store :shock: ). Where from I should get your goodies?
Thank you for trying to sort it out.
rv1974
Postby thomthom » Wed Jun 05, 2013 11:50 am
VirtualStore is not a plugin repository. It's a security feature in Windows that will place files in a "virtual" ghost folder mirroring the original one. Please check out the link in #1 of my previous post - install the utility and use it to check of you have files trapped in Virtual Store.
(alternatively: when you look at your Plugins folder with Explorer, do you see a Compatibility Files button?)
PluginStore Author
PluginStore Author
Postby thomthom » Wed Jun 05, 2013 11:51 am
rv1974 wrote:BTW#2 I have vertigo with all those 'shops' (SU Ext wharehouse, virtualstore, sketchucation forum threads, sketchucation plugin store :shock: ). Where from I should get your goodies?
Currently the very latest versions of my plugins are at Extension Warehouse. I will migrate the forum posts at SCF to point to the PluginStore and update these as well. But there are some things that needs to be done to the PluginStore first.
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Jun 05, 2013 12:03 pm
thomthom wrote:VirtualStore is not a plugin repository. It's a security feature in Windows that will place files in a "virtual" ghost folder mirroring the original one. Please check out the link in #1 of my previous post - install the utility and use it to check of you have files trapped in Virtual Store.
I run the 'virtualstore' and the report says there are no files in it.
I see no 'Compatibility Files' button in Plugins folder. Where it should be located?
rv1974
Postby thomthom » Wed Jun 05, 2013 12:17 pm
It's only visible if there are files in VirtualStore. Since that isn't the case I'm not sure what is going on here. It's not something I've seen.
Can you post a screenshot of your Plugins folder in Explorer?
...you don't have anything like Organizer installed, have you?
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Jun 05, 2013 1:31 pm
After some manual deleting\reinstalling I set the things right. No worries.
P.S. Here are some points that could make this tool more efficient:
1. make it non-modal (like windowizer 4 or profile builder), it'd speed up the editing of large number of components drastically.
2. height and extrude values come true only after some editing.
3. in complex models (with lot of nesting) the tool's snapping does not work correctly.
Had no problems with native 3d text.
4. After running TIG's 'uniquify' script some 3d text component look unchanged, but
when one would try to edit the text it get mirrored (see attached). Donno where your this bug come from.
rv1974
Postby thomthom » Wed Jun 05, 2013 1:44 pm
rv1974 wrote:1. make it non-modal (like windowizer 4 or profile builder), it'd speed up the editing of large number of components drastically.
But, it's not modal... and whether it would be modal or not - how would that improve performance?
rv1974 wrote:2. height and extrude values come true only after some editing.
This is fixed in the version that is plaiting moderation in EW.
rv1974 wrote:3. in complex models (with lot of nesting) the tool's snapping does not work correctly.
Can you explain further to what isn't working correctly? What am I looking for to reproduce this?
rv1974 wrote:4. After running TIG's 'uniquify' script some 3d text component look unchanged, but
I don't know what his uniquify script does... but if it doesn't preserve the transformation and orientation of the original component then it'll mess things up. When third party tools modify the text group it's hard to predict what will happen.
PluginStore Author
PluginStore Author
Postby JuanV.Soler » Wed Jun 19, 2013 1:02 pm
Hi thomthom
I think this is a great plugin that you could keep improving . There is trouble when changing heights that I workaround by clicking and unclicking the extrude buttom . My question is can it be possible to update a bunch of texts to a chosen one ? Sort of Matching Properties ?
thankyou
_,_)))_,_
JuanV.Soler
Postby thomthom » Wed Jun 19, 2013 1:25 pm
JuanV.Soler wrote:There is trouble when changing heights that I workaround by clicking and unclicking the extrude buttom .
This bug has been fixed - but only released on Extension Warehouse. I've not gotten around to update my plugins to SCF's new PluginStore. For the time being - check EW for latest versions of my scripts.
JuanV.Soler wrote:My question is can it be possible to update a bunch of texts to a chosen one ? Sort of Matching Properties ?
It's technically possible. But I cannot promise when/if. It's very busy at the moment.
PluginStore Author
PluginStore Author
Postby JuanV.Soler » Wed Jun 19, 2013 3:25 pm
hi thomthom ,
there is something wrong when downloading TT_Lib² from Extension Warehouse , it does install but then in SketchUp it shows
_,_)))_,_
JuanV.Soler
Postby thomthom » Wed Jun 19, 2013 3:44 pm
Perhaps you've got some files in Virtual Store? If you go to your Plugins folder - is there in Explorer a button that says "Compatibility Files"? (or similar in whatever language you might use)
PluginStore Author
PluginStore Author
Postby JuanV.Soler » Wed Jun 19, 2013 4:35 pm
no , I haven´t . Nevermind , I managed to get it work again . Thanks
_,_)))_,_
JuanV.Soler
Postby thomthom » Wed Jun 19, 2013 7:06 pm
How? What fixed it?
PluginStore Author
PluginStore Author
Postby JuanV.Soler » Wed Jun 19, 2013 11:10 pm
I avoided the message of the need to install the 2.8.3 version and just closed that window .
But where is that version ?
I tend to think that it is not in the Extension Warehouse for the moment .
The one to download must be a previous one or something .
Thus the message of updating and thus that the Editable 3D Text still works the same for me .
thanks
_,_)))_,_
JuanV.Soler
Postby thomthom » Thu Jun 20, 2013 10:40 am
The version is there - and it has some important fixes for 3d text editor.
You might have to remove TT_Lib2 before reinstalling. There could be some files that are in use when SU tries to update.
PluginStore Author
PluginStore Author
Postby JuanV.Soler » Thu Jun 20, 2013 10:47 am
thomthom I have done it several times to no avail .
It remains a mystery to me .
_,_)))_,_
JuanV.Soler
Postby thomthom » Thu Jun 20, 2013 10:50 am
Just to be sure - if you try this utility: viewtopic.php?f=180&t=48399
And use "Check Virtual Store" - what happens then?
Also, what is the output of TT::Lib::VERSION if you type it into the Ruby Console?
PluginStore Author
PluginStore Author
Postby JuanV.Soler » Thu Jun 20, 2013 11:19 am
now that´s funny , it says :
so I do have installed the latest version after all
I have the virtualstore plugin installed in the folder but it does not show in Plugins SketchUp aplication so I cannot run it
_,_)))_,_
JuanV.Soler
Postby thomthom » Thu Jun 20, 2013 11:24 am
But you still get the warning? Did you use the VirtualStore check utility?
PluginStore Author
PluginStore Author
Postby JuanV.Soler » Thu Jun 20, 2013 11:27 am
no more warnings no . I think that the trick was to ignore the first warning after installed
As I edited my latest post : I have the virtualstore plugin installed in the folder but it does not show in Plugins SketchUp aplication so I cannot run it
_,_)))_,_
JuanV.Soler
Postby thomthom » Thu Jun 20, 2013 12:17 pm
? Really? No menu under the Plugins menu?
PluginStore Author
PluginStore Author
Postby JuanV.Soler » Thu Jun 20, 2013 12:33 pm
no , no menu under the Plugins menu
_,_)))_,_
JuanV.Soler
Postby thomthom » Thu Jun 20, 2013 12:54 pm
what happens if you type this into the ruby console: TT::Plugins::VirtualStore.check_virtualstore
PluginStore Author
PluginStore Author
Postby JuanV.Soler » Thu Jun 20, 2013 1:55 pm
The Text Editor still works with the same workaround of unticking the extrude function to get the heights modified
_,_)))_,_
JuanV.Soler
Postby thomthom » Thu Jun 20, 2013 3:19 pm
What does TT::Plugins::Editor3dText::PLUGIN_VERSION report.
And what version of Internet Explorer do you have installed?
(Lots of questions here - but I'm baffled by what is going on here. It should be working... :s )
PluginStore Author
PluginStore Author
Postby JuanV.Soler » Thu Jun 20, 2013 5:11 pm
it reports :
about Internet Explorer :
______________________________________
now those are all my credentials :D
_,_)))_,_
JuanV.Soler
Postby thomthom » Fri Jun 21, 2013 8:37 am
Your 3d Text Editor is out of date. It should be 1.1.3 - if you install the version from EW.
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: colenzo, Dave R, phantan, Roberto193, sfortunos and 16 guests
