[Plugin] 3D Text EditorRe: [Plugin] 3D Text EditorDid you look in the Draw menu? Make sure you have installed the most recent version and also the latest TT_Lib2 installed.
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] 3D Text Editorok that was it !!
the draw menue ist the thing to look for, thanks for your advice Uli Re: [Plugin] 3D Text Editor
Happy that took care of it. ![]() Etaoin Shrdlu
Re: [Plugin] 3D Text Editorhello ThomThom,
I'm trying to use the plugin to import Sketchup dimensions lines into Sketchfab which is a well known big problem (if you don't use a picture for it)... I use the plugin to create the 2d dimension line value ... but i need the line ... maybe a possible improvement of the 3d text editor plugin ? Thank you. Sketchfab discussion : https://forum.sketchfab.com/t/dimension ... model/5480 Re: [Plugin] 3D Text Editor
What version of SketchUp are you using? Please complete your profile as that information helps us help you. If you are going to the trouble of adding dimensions as 3D text, why not make a dimension line component that you can insert? Personally if I'm going to download a 3D model to use as a plan, I wouldn't want all the dimensions as 3D geometry. That would just bloat the file without providing much benefit. Etaoin Shrdlu
Re: [Plugin] 3D Text EditorI noticed that SketchUp creates 3D text with very low precision. I mean, letters' curvature are made up with very low number of segments, and they look quite jaggy when you zoom in.
I guess Editable 3D Text uses the same methods for text generation so it also looks jagged but I thought: maybe it would be possible to generate text with more precision? |
