Problem with Keyframe Animation plugin
Postby TheThirdPerson » Wed Dec 12, 2012 5:44 pm
Hello all. I am new to these forums and have been using sketchup here and there for about a year. I quite like the simplicity and versatility of the program and have recently been asked by my boss if I could do some animations.
So I've downloaded the trial version of keyframe animation and so far I'm loving the plugin and how easy and straightforward it is to use.
However, I have found that when I try to change the scene settings, the only thing that "sticks" is the delay number (which I set to 0)
I can't get the transition time or the framerate to change at all. I can change the number, but as soon as I run the animation they change themselves back. I can change the framerate, exit the scene settings dialog, and as soon as I go back into it it has reset itself to 10.
I am not sure what is causing this. Maybe it's because I've just got the trial version? I hope not. I would like to see that something works all the way before I pay for it. Any help would be greatly appreciated. I'm pretty much stymied on my animation job until I can get this resolved.
TheThirdPerson
Re: Problem with Keyframe Animation plugin
Postby iichiversii » Wed Dec 12, 2012 7:11 pm
Not sure if thats because its a Trial version, but i assure you its worth the full version and i never had that problem your having, but you can also contact Doug via his email on the keyframe plugin site, he normally replies in no time, but i recommend this plugin highly for animations :thumb:
Bring on the Rain...
iichiversii
Premium Member
Premium Member
Postby Bob James » Wed Dec 12, 2012 7:53 pm
@iichiversii
Do you export your animations to a rendering program? I have a strong need to create animations and use Thea as my rendering program.
Bob James
Premium Member
Premium Member
Postby iichiversii » Wed Dec 12, 2012 8:14 pm
I do yes,, i normally use Shaderlight to render my animations via keyframe but it does take quite sometime :)
iichiversii
Premium Member
Premium Member
Postby TheThirdPerson » Wed Dec 12, 2012 8:37 pm
So I guess I've solved the problem. All I did was uninstall the Keyframe Animations Plugin and reinstall. It seems to have fixed the issue.
Also, I use TwilightRender to render my animations, and while it is not free, it is also not that expensive and does a beautiful (and user-friendly) job.
TheThirdPerson
Postby Rich O Brien » Wed Dec 12, 2012 11:09 pm
Bob James wrote:@iichiversii
Bob,
TwiLight supports KeyFrame Animation. But why not use Thea's animation tools?
Rich O Brien
Administrator
Postby minhtp1209 » Sat Oct 24, 2020 5:59 pm
I can't use for version demo. I click at trial info, but can't. who is help me?
TKs all
minhtp1209
Postby Dave R » Sat Oct 24, 2020 10:14 pm
What version of SketchUp are you using? Your profile says 2020 Free/Make but there is no such version.
What exactly happens when you install it? Did you install the most recent version, V2.2.1?
Global Moderator
Return to Plugins
Users browsing this forum: kiki_biker, pedroalan11, petre76, Susudllo and 6 guests
