[Plugin] LSS Toolbar 2.0 Beta
Re: [Plugin] LSS Toolbar 2.0 Beta
Postby SUFractal2 » Thu Dec 20, 2012 6:29 am
kirill2008 wrote:
Note
- current version runs under Windows only
- some certain tools conflict with SketchyPhysics plugin
Do you have plans to make this available for Mac? If so, any idea as to how soon?
Thanks!
SUFractal2
Postby boilingsnow » Sat Jan 26, 2013 11:35 pm
great tools, thank you so much.
boilingsnow
Postby matt.gordon320 » Thu May 30, 2013 12:30 am
These are some pretty amazing tools!
I'm getting an error that I'm not sure is just me. Once I start the process of Voxelizing a model, if I don't choose the voxel size first, and then the group, I get locked into a pop-up dialog that won't go away. It simply warns me how many copies of the voxel there will be, and there is no way to exit aside from killing SketchUp in the task manager.
Any thoughts on what I'm doing wrong? Thanks!
Matt
matt.gordon320
Premium Member
Premium Member
Postby PabloNCS » Sun Jun 09, 2013 3:56 am
I am not sure if LSS tool bar does not work for mac plattaform or I am just missing some steps during the installation but it doesn't work properly. The tool bar is displayed and everything seems ok, but it doesn't let me pick neither the forms nor the path, If I selected the two forms and the path at the same time and then I pick the tool, it kind of works because the program displays the forms that are supposed to form the model, but I am not able to apply the transformation correctly because nothing happens... An none of the other tools work also. Am I missing something here? I follow the video tutorials but nothing. I have installed the beta version, the light version, and nothing... Someone knows what to do or what's happening?
Thanks.
Pablo
PabloNCS
Postby ATI_SOLAPA » Wed Jun 19, 2013 1:45 pm
I'd like to know if this plugins works on Sketchup Pro 2013
ATI_SOLAPA
Postby boilingsnow » Fri Dec 06, 2013 12:59 am
great! thanks a lot.
boilingsnow
Postby pep75 » Mon Jan 13, 2014 9:42 am
Will there be still any updates on this plugins? This is actually one of the best plugins ever made for SU...
pep75
Postby DOD3R » Tue Jan 14, 2014 11:12 am
pep75 wrote:Will there be still any updates on this plugins? This is actually one of the best plugins ever made for SU...
true to that.
It rivals Fredo6s collection for the first place
DOD3R
Postby escufi » Thu Feb 27, 2014 7:26 pm
Hello All,
I tried several times to run this plugin ( or toolbar) but doesn't work for me.
I have SK 2008 and I follow the installation instructions. It could be a problem about language ? ( mine SK is in spanish). I say that about the "en-US" folder that must bé extracted on "sources" SK folder.
Thanks in advance
Kind Regards
escufi
Postby function » Wed Apr 09, 2014 4:23 am
would love to have the lss toolbar and matrix in 2014!~
function
Postby boilingsnow » Fri Aug 29, 2014 10:39 pm
Is there a new version of this plugin for sketchup 2014?
boilingsnow
Postby boilingsnow » Sun Sep 07, 2014 10:35 am
I ve already tested it. LSS toolbar also works in sketchup 2014. Thank you so much.
The follow edges tool is brilliant.
boilingsnow
Postby Bob James » Mon Sep 22, 2014 8:15 pm
I get the attached error (and similar other errors with other buttons) when trying to use the Toolbar
Bob James
Premium Member
Premium Member
Postby TIG » Tue Sep 23, 2014 4:30 pm
This tool has an overly complex installation requirement. :roll:
Some files go in the Plugins folder but some others go in the Resources folder.
It's explained in the tool's installation guide.
It must find some files in the Resources folder because in several places like this:
Plugins\lss_toolbar\lss_crvsmth.rb
The tool has code:
resource_dir = File.dirname(Sketchup.get_resource_path("lss_toolbar.strings"))
html_path = "#{resource_dir}/lss_toolbar/crvsmth.html"
If 'resouce_dir' is not found, then the empty folder path used for the html file will mean it's broken !
Use this in the Ruby Console to find your Resources folder:
File.dirname(Sketchup.get_resource_path("."))
>>> C:/Program Files (x86)/SketchUp/SketchUp 2014/Resources/en-US)
If you have this tool's files in the right places the strings file should be found too, when using.
If you don't get a 'path' some files are mis-filed...
The returned paths will vary depending on your setup and SketchUp version etc...
Global Moderator
Postby mtr » Wed Dec 24, 2014 7:27 am
For the correct path, you must extract Plugin content into Sketchup/plugin and Resources content into Sketchup/Resources.
See below:
See install guide here:
https://sites.google.com/site/lssoft201 ... ss-toolbar
mtr
Postby jandizondesign » Thu Feb 26, 2015 4:09 am
I get this error when I try to use the stick group tool.
All other tools work fine.
If possible, how do I fix this?
Thanks!
Error: #<NoMethodError: undefined method `to_a' for "":String>
C:/Users/INDIGO SOLUTIONS/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1078:in `settings2hash'
C:/Users/INDIGO SOLUTIONS/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1073:in `read_defaults'
C:/Users/INDIGO SOLUTIONS/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1153:in `create_web_dial'
C:/Users/INDIGO SOLUTIONS/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1282:in `activate'
C:/Users/INDIGO SOLUTIONS/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:23:in `select_tool'
C:/Users/INDIGO SOLUTIONS/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:23:in `block in initialize'
SketchUp:1:in `call'
jandizondesign
Postby AcesHigh » Wed Aug 05, 2015 2:41 pm
mtr wrote:For the correct path, you must extract Plugin content into Sketchup/plugin and Resources content into Sketchup/Resources.
See below:
problem is that we are told all the time here at Sketchucation we should in no way do manual installations of plugins like it was done in old Sketchup 8 times...
AcesHigh
Postby DreamPsi » Mon Nov 30, 2015 9:50 pm
First and Foremost I would like to say this plugin is amazing and thank you for you time and effort. for it makes my life easier,
now with that said I seem to have run into a problem with the stick group tool on your lss toolbar for sketchup 2016 when I click on it nothing happens, it doesn't bring up the html page for editing, but all the other tools work just fine.
i use windows 10 os
i was thinking it just might be a file pathing problem seeing how sketchup 2016 uses two different directories for plugins and resources.
I.E for the resources folder is located in C:\Program Files\SketchUp\SketchUp 2016\Resources\en-US
meanwhile for the plugins them selves is located in C:\Users\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
but if all the other tools work i don't think its a pathing problem. i tried looking at your code to see if there was a discrepancy but i couldn't find anything wrong with it logic wise although I'm not too good with programming :roll:
i saw on one of your youtube posts that it might be six months before you get around to updating lss toolbar :?
please help i installed the plugin to the correct folders and unistalled then reinstalled and nothing seems to work.
oh and by the way your lss_arch is also pretty amazing. which i like a lot reminds me of the functionality of the good ol halflife 2/ source level editor i started using when when i got into modeling and level design. :fro:
DreamPsi
Postby DreamPsi » Tue Dec 01, 2015 1:45 am
Hi first of all i think your plugins are amazing, thank you for your time and effort on them
but with your lss toolbar plugin in sketchup 2016 most of them work but the stick group plugin
doesn't for some reason i get this in the ruby console window whenever i click on it in the tool bar
C:/Users/RedBeaner/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1078:in `settings2hash'
C:/Users/RedBeaner/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1073:in `read_defaults'
C:/Users/RedBeaner/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1153:in `create_web_dial'
C:/Users/RedBeaner/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:1282:in `activate'
C:/Users/RedBeaner/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:23:in `select_tool'
C:/Users/RedBeaner/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/lss_toolbar/lss_mshstick.rb:23:in `block in initialize'
it doesn't even load up the dialog html command window for this specific function
everything is installed in there right places please help
ok I have seemed to have found a solution for the stickgroup function in sketchup 2016.
sketchup 2016 uses the newer version of ruby code. which makes the method to_a function not work unless you put it as lines.t_a first.
so in the lss_mshstick.rb
the problematic code is this
line1078 @settings_hash["stick_vec"]=[@stick_vec.to_a.join(";"), "vector_str"]
line1082 @settings_hash["bounce_vec"]=[@bounce_vec.to_a.join(";"), "vector_str"]
the new fixed code is this
line1078 @settings_hash["stick_vec"]=[@stick_vec.lines.to_a.join(";"), "vector_str"]
line1082 @settings_hash["bounce_vec"]=[@bounce_vec.lines.to_a.join(";"), "vector_str"]
so that fixed it for me though I'm still getting error msgs in the ruby console but its not affecting the function as far as I can tell.
so hope this helps you guys
DreamPsi
Postby driven » Sun Dec 27, 2015 2:29 am
@DreamPSI,
I imagine you are now getting a 'less fatal' No Method error for 'lines'...
but you could try to fix it properly...
the to_a method used to take a String and 'split' it into an array...
as it's no longer available you need to 'split' any String yourself...
so to find what we need to 'split' we first need to know what @stick_vec is...
on line 108 @stick_vec=Geom::Vector3d.new(0,0,-1), but if you do a test in 'Ruby Console' it's not a String and @stick_vec.to_a will work, so we keep digging...
on line 1063 @stick_vec=Sketchup.read_default("LSS_Mshstick", "stick_vec", nil), will return a String and
on line 1073 we see it's being passed to the method that's failing using self.settings2hash...
so now we have a String and we know it was once in the format of (n,n,n) we can try splitting it using ','...
@stick_vec.to_a.join(";") >> @stick_vec.split(',').join(";")
but, there is another place as well, so use search and replace for @stick_vec.to_a to find it...
@bounce_vec.to_a possibly has the same solution...
john
driven
PluginStore Author
PluginStore Author
Postby DreamPsi » Sun Dec 27, 2015 2:55 am
thanks I will try my hand... but seing how I'm rusty at programing that hand will probably find my face several times before finding the other hand lol.
DreamPsi
Postby elizabeth001au » Sun Jan 17, 2016 1:37 pm
Please excuse me if I have missed something. I am excited about this plugin. Downloaded it today and went to use it. Can not
use any tool. Each tool give me the message " Cannot find file LSS_toolbar/pathface.html" I have read the installation instructions and have checked that everything is in correct folder. The same message repeats for each different tool. Thanks.
elizabeth001au
Postby DreamPsi » Tue Jan 19, 2016 1:37 pm
open ruby script console, copy and then post the results here, when you try to click on the tool bar buttons
idk maybe you dled a baddy
DreamPsi
Postby elizabeth001au » Tue Jan 19, 2016 2:18 pm
Thankyou DreamPSI. Yes, I was able to make the toolbar appear to be active. However, unfortunately this tool is not working with Sketchup Pro 2016. The last version it is compatible with is Sketchup 2013. This is due to some changes in API. Shame really...I was very keen to play with this, as it appears to be just what I need.
elizabeth001au
Postby pilou » Tue Jan 19, 2016 5:36 pm
What tool exactly?
Seems Lss works fine in 2016!
Ah Yes The Stick tool : curious I have seen the Stick Dialog Box one time but then after to close it impossible to re-appear! :(
Someone can post the file lss_mshstick.rb modified for 2016 ?
Speedy Galerie
Top SketchUcator
Postby DreamPsi » Mon Feb 08, 2016 9:14 pm
I would but unfortunately I had to reinstall windows ten due to a virus but if you look at the post by driven a few posts up you would see exactly where in the rb file you need to change the code to the corrected code. it can be edited in any text editor, I find notepad++ to be an excellent fast and easy app that's free for editing minor script changes
ill will reinstall sketchup and re dl the lss tool bar and post the updated rb for mshstick.rb in lss tool bar plugin at a later date.
DreamPsi
Postby frankleng » Fri Jun 17, 2016 11:17 am
pilou wrote:What tool exactly?
I had the same problem. NOw it works.
frankleng
Postby pilou » Fri Jun 17, 2016 1:28 pm
NOw it works.
Not yet! Even more it's bugsplat and crashes! ;)
Speedy Galerie
Top SketchUcator
Postby haydenr » Mon Jul 18, 2016 6:11 am
I am also having the issue where it cant find the support html files. Every tool replies with the same pathing issue.
haydenr
Postby Bob James » Mon Jul 18, 2016 7:29 pm
haydenr wrote:I am also having the issue where it cant find the support html files. Every tool replies with the same pathing issue.
This problem has existed for almost two years!! :|
See earlier post in this thread dated..Mon Sep 22, 2014 12:15 pm
Bob James
Premium Member
Premium Member
PreviousNext
Return to Plugins
Users browsing this forum: GigParallele and 16 guests
