by TIG » Wed Sep 17, 2014 10:10 pm
Here's v2.3 which fixes the TAB bug on MACs... Download
- Global Moderator
- Name: TIG
- Operating system: Windows
- SketchUp version: 2021
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by Oxygen220 » Thu Sep 18, 2014 8:01 am
god damn, ok so i got the 2.3 version, and finally able to get the icons, but the problems still there, i can create points, i can triangulate but when i try the vonoroi tool, nothing happens D:, either its not working or im an idiot and forgot to do something, or both..
Oxygen220
- Name: Matt
- SketchUp version: 2014
- License type: Free/Make
- SketchUp use: hobby
- Level of SketchUp: Beginner
by CTX » Thu Sep 18, 2014 8:33 am
For Tig: Thank you very much, with the two updates (TIG: Triangulate Points v1.1 and MattC: VoronoiXY v2.3) now everything works great. Thanks again for the speed of response.
CTX
- Name: CTX
by CTX » Thu Sep 18, 2014 10:12 am
I would like to ask if anyone knows a plugin for SU able to draw points (maybe choosing how many and in what geometry) on a surface. Many thanks
CTX
- Name: CTX
by TIG » Thu Sep 18, 2014 12:35 pm
This is the staple 'PointTool'... http://sketchucation.com/pluginstore?pln=PointToolToolbar or menu item... It draws individual cpoints [guides] - but you can of course use Rotate OR Move +Ctrl to Copy and then type NNx +<enter> to array them by the number NN repeating the distance, or /NN to divide the original distance up with your copies...
- Global Moderator
- Name: TIG
- License type: Pro
by pilou » Thu Sep 18, 2014 12:37 pm
You have Raytracer by Thomthom who dropts Cpoints on Surfaces!
- Top SketchUcator
- Name: Pilou
- SketchUp version: 2017
by darkshadow47 » Sat Nov 29, 2014 4:56 am
OK, I feel like a complete idiot for not being able to make this work. I have the current plugin from MattC and TIGs separate triangulation plugin. After creating a polygon and selecting it, if I select Triangulate Points it will ask for a layer name, and then fail with the "No Guide Points in selection". How do I generate guide points?
The Conic curve in a face works fine...
darkshadow47
- Name: John Armbruster
- SketchUp version: 8
by ronel_12 » Sun Jan 03, 2016 5:19 pm
No Existe para Pc ? saludos y bendiciones
ronel_12
- Name: ronel ravarro
- SketchUp version: 2016
- License type: Pro
by TIG » Sun Jan 03, 2016 11:20 pm
ronel_12 wrote:No Existe para Pc ? saludos y bendiciones No entiendo lo que quieres decir. Esto funciona en la PC. ¿Por qué crees que no lo hace?I don't understand what you mean. This works on PC. Why do you think it does not?
- Global Moderator
- Name: TIG
- License type: Pro
by AUTER » Tue Jun 14, 2016 8:10 pm
i tried to install in my SketchUp but didnt work... anyone could help me with this?
AUTER
- Name: Pedro
by sdmitch » Sun Jun 19, 2016 2:03 am
AUTER wrote:i tried to install in my SketchUp but didnt work... anyone could help me with this?
What didn't work? Did not install? Installed but will not run? Runs but no results? Post the model or a screenshot. Open the Ruby Console and execute the plugin. Post any errors that are shown.
sdmitch
- PluginStore Author
- Name: sdmitch
by pilou » Sun Jun 19, 2016 3:05 am
You have Guide Points inside very practical Projection by Didier Bur conic.jpg
- Top SketchUcator
- Name: Pilou
by sarkarshomit » Sat Jul 23, 2016 7:44 am
Please can someone confirm that this works on Skup2016, as i cant seem to find the plugin after install.I have the conic curve in face working, but not the voronoi part...
sarkarshomit
- Name: sarkarshomit
- License type: Pro
by pilou » Sat Jul 23, 2016 10:38 am
Seems that works like a charm inside 2016 Make as shown on my previous post!  Quasi all is by hand "manual" ! GIF_voro0.gif GIF_voro.gif Last Icon GIF_voro1.gif
- Top SketchUcator
- Name: Pilou
by Lorand » Mon Dec 05, 2016 3:03 pm
Hello all:
The results look terrific but unfortunately it doesnt work for me neither in SU2017 nor in SU2016: both triangulation and conic curves work just fine but not the Voronoi XY. In 2017 it reports "Triangulation completed: xxx triangles created" without any other effect. In 2016 it does / reports nothing, just goes back to the SU selection tool.
All help would be highly appreciated, thank you, Lorand
Edited: Re-Hello:
All 3 component plugins work in both SU2016 and SU2017. I was trying to get Voronoi patterns inside a pre-established shape and I put constr. points on the edges of the shape and that kills Voronoi XY. Define your target shape (wasnt able to make triangles yet) by putting cps in the corners of it, BUT NOT ON THE EDGES, and it works nicely.
Hope this may help someone, Lorand
Lorand
- Name: Ladislau Randjak
by Einstein » Mon Jan 01, 2018 10:43 pm
Error loading file. The same issue in SU 2017, SU 8. The same with the version developed by the.pjt.
Einstein
- Name: Michal P
- SketchUp version: 2020
- License type: Pro
by TIG » Tue Jan 02, 2018 4:13 pm
Did you download the latest version's RBZ from the PluginStore ? https://sketchucation.com/pluginstore?pln=VoronoiXYThat RBZ contains the required file ' delauney3.rb' You error message is telling us it can't be found. If you install it from the RBZ the additional delauney3 RB should also be installed. If you have disabled it using the SCF PluginsManager tool, or the native Extension Manage tool in newer SketchUp versions you'll get that kind of error error... If you made the RBZ back into a .ZIP and took out only some files, then you haven't installed the required set of files !
- Global Moderator
- Name: TIG
- License type: Pro
by Einstein » Tue Jan 02, 2018 7:32 pm
I was trying to install manually. Now, with PluginStore package it works. Thank you again
Einstein
- Name: Michal P
- License type: Pro
by TIG » Tue Jan 02, 2018 8:45 pm
Einstein wrote:I was trying to install manually. Now, with PluginStore package it works. Thank you again
These days, you hardly ever need to do a manual installation - the RBZ installation does it for you automatically, and getting the latest version from our PluginStore [or the EWH when we don't host it], is always recommended... New versions throw up issues and the newest RBZ file are [re]written to get around these, and ensure continuing compatibility...
- Global Moderator
- Name: TIG
- License type: Pro
by wrensong » Mon Mar 26, 2018 2:01 pm
This plugin link does not work. The extension is a .rb not a .rbz
wrensong
- Premium Member
- Name: Michael Wren
- License type: Pro
- SketchUp use: interior design
by pilou » Mon Mar 26, 2018 2:20 pm
Zip the .rb file Rename .zip in .rbz and you can use it like any other file rbz!
- Top SketchUcator
- Name: Pilou
by TIG » Mon Mar 26, 2018 2:54 pm
Just download the later RBZ version from the PluginStore. Then install it. It includes the helper files needed too... Trying to load out-of-date RB files is a recipe for frustration... https://sketchucation.com/pluginstore?pln=VoronoiXY
- Global Moderator
- Name: TIG
- License type: Pro
by maoxx » Tue Nov 20, 2018 4:05 pm
nice
maoxx
- Name: Robert
- SketchUp version: 2015
by Pawatamit1994 » Thu Mar 28, 2019 6:33 pm
not getting the download link plss help
Pawatamit1994
- Name: AMIT KUMAR YADAV
- License type: Pro
by Gábor » Fri Mar 29, 2019 9:58 am
Pawatamit1994 wrote:not getting the download link plss help
Click the "Download" button at the first post of this topic. On the next page click "Download" near the description of the plugin.
Gábor
- SketchUcation IT
- Name: P.Gábor
- Operating system: Linux
by TIG » Fri Mar 29, 2019 1:27 pm
Or find in by searching the PluginStore... The first-post's 'Download' button is a direct link to that entry !
- Global Moderator
- Name: TIG
- License type: Pro
by HornOxx » Sat Mar 30, 2019 9:44 am
Hi All, I am also so dull and can't find your working download (I would like to use this tool on my private Make 2017 and, if possible, on Pro2019). So I´m looking forward to any patient help
never trust a skinny cook
HornOxx
- Name: HornOxx
- SketchUp version: 2019
- License type: Pro
by TIG » Sat Mar 30, 2019 2:12 pm
Try the Download button in this post: viewtopic.php?p=538039#p538039
- Global Moderator
- Name: TIG
- License type: Pro
by HornOxx » Sat Mar 30, 2019 3:15 pm
... thanks again TIG  your Link worked fine
HornOxx
- Name: HornOxx
- License type: Pro
by mackbrae » Tue Jun 11, 2019 6:27 pm
no puedo intalarlo..me pide el formato *.rbz ...!! ayudaa
mackbrae
- Name: mackbrae
- Robot
Return to Plugins
