SketchUcation Premium Membership
[PLUGIN] Voronoi + Conic Curve
Re: [PLUGIN] Voronoi + Conic Curve
Postby MattC » Fri Jul 27, 2012 5:51 pm
sl!m wrote:Few comments :
1/ Could it be possible to undo the voronoi generation in one go ?(ctrl Z is going back through all the steps of the generation)
- added to the wish list - see some posts above
sl!m wrote: 2/ It does not generate the voronoi all the time. Sometimes nothing happens. Any idea ?
- if You can post Your .skp file then I can take a look at it.
Matt
MattC
Postby lapx » Fri Jul 27, 2012 10:01 pm
Great Plugin Matt,
However, some regions will not work for some strange reason. Snag in program somewhere.
Good start though. I wish the ruby God's will help complete this one. Its very useful for creating metal sheets with these patterns and much much more. I used the "conic curve on face" and pointed to each face.
Thanks!
Lapx
lapx
Postby nektares » Sat Jul 28, 2012 12:13 am
sorry for the late reply, it´s a new file, no other geometry in it. if i open the ruby console i get this:
Error: #<NoMethodError: undefined method `vector_to' for nil:NilClass>
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:258:in `voropoints'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:231:in `each'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:231:in `voropoints'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:128:in `voronoi'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:105:in `each'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:105:in `voronoi'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:36:in `initialize'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:384:in `new'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/VoronoiXY.rb:132:in `call'
voro-no-i.skp
i hope you know what it is matt i would love to do something cool with your plugin.
if i don´t open it i get this:
nektares
Postby sl!m » Sat Jul 28, 2012 4:21 am
MattC wrote:- added to the wish list - see some posts above
Thanks !
If I may add one wish : The tab options for the conics should remember the last options chosen.
MattC wrote:- if You can post Your .skp file then I can take a look at it.
Here it is.
By the way I'm using pjt's plugin. Thanks for looking at this!
Sl!m
sl!m
Premium Member
Premium Member
Postby the.pjt » Sat Jul 28, 2012 11:04 pm
Hi Matt :enlight: ... please post the toolbar (my work )to the first post ... copyrhight ? !! feel free .. it's our plugin .. not my" plugin . and I also posted PSD icons for you .. :P
ICON folder path ? .. I'm surry for this bug .... but I myself tested it on my 2 computers with windows 7 and 8 (SU8) .. and It was fine for me .. :| :| ... but if there is a problem please repair it and use my works in future versions ... ;)
good luck :)
the.pjt
Postby MattC » Sun Jul 29, 2012 8:55 am
I will do it as soon as I correct bug that nectares reported.
Also I already adressed some things from a wishlist.
So stay tune.
Also , evereyone that is using pjt's wrapped wersion with toolbar, please report if You can see icons, I don't know if it is only me that have this problem ??
I don't want to fix things that are ok.
In general Stat tuned. Version 1.1 is coming.
Matt
MattC
Postby gilles » Sun Jul 29, 2012 10:09 am
Same thing for me.
Also Tab key does not open dialog box (Macbook pro), for me.
gilles
Top SketchUcator
Operating system: Mac
SketchUp version: 8
License type: Free/Make
SketchUp use: other
Postby TIG » Sun Jul 29, 2012 10:23 am
On a MAC the TAB a onKeyDown method doesn't work [known bug!] - you need to use a onKeyUp method to spot the press of the TAB-key for MAC AND PC.
Also note that TAB key-mapping will differ between PC and MAC - if key==9 || key==15... DON'T use key 48 as that is only TAB on some Linux setups [I think] and causes issues with mainstream users [== 0 ?] - an error is some of my older code that should be fixed in MY scripts :?
The regional differences might be caused because there's a ',' as a decimal separator rather than a '.' ?
If dialog values are taken as 'float' or 'length' then this should be accounted for automatically by Sketchup ?
Use inputbox rather than UI.inputbox as it checks user inputs better...
[include a require 'sketchup.rb' in the first line of the script to ensure it's available to you]
Don't use @@dek.to_mm you've already predefined it as a 'length' as @@dek=25.mm - later you mess with it again .to_f.mm - because you first set it as a length then the user's current units will be used instead anyway - there's no need to restrict it to 'mm' at all - just use 'Offset:' as the prompt... similarly the other inputbox values can only be what you set them as so if it starts as a float the user's input must be a valid float so typing 3 returns 3.0 anyway...
Global Moderator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby ivreich » Mon Jul 30, 2012 1:54 am
Hi MattC
Still unable to use your plugin. Here's the error message and file...
Joel
ivreich
SketchUp version: 8
License type: Pro
Postby TIG » Mon Jul 30, 2012 8:58 am
It's possible to have two 'lines' that don't intersect and produce 'nil' as the result, so the code needs to trap for the existence of the point and only proceed with it if it's not nil...
That should be a relatively simple 'trap' to construct...
Global Moderator
License type: Pro
Postby MattC » Mon Jul 30, 2012 10:51 am
True TIG
I already implemented this trap, but also encountered another case that is a bit problematic.
It is geometry limitation of Sketchup.
I will update script when this will be solved, in a meantime if anyone also has non-working combination of points, post it here.
I will have more material to analyse.
Matt
MattC
Postby TIG » Mon Jul 30, 2012 11:06 am
Putting the code inside a begin...do_point...rescue...end structure will allow the code to fail on the point without a crash ?
But a simple intersect_lines...if point...do_stuff...else...next_point...end would suffice here...
Something like:
if int && (test[0]==0)&&(test[1]==0)&&(test[2]==0)
intprim=int+int.vector_to(pointstable[bpntindx])+int.vector_to(pointstable[bpntindx])
points<<intprim.project_to_line([midlines[0][0],midlines[0][1]])
points<<intprim
points<<intprim.project_to_line([midlines[1][0],midlines[1][1]])
elsif int
points<<int
and
if int && point_is_between(p1,p2,int)&&point_is_between(polygon[i],polygon[j],int)
point<<int
AND any other place where int is set as an 'intersection' that might fail - test for its existence before trying to use it.
Only uses int if it's not 'nil'.
Global Moderator
License type: Pro
Postby MattC » Mon Jul 30, 2012 12:34 pm
Yup, second way is exactly how I changed it.
My fault was testing it on set of random points, and combination of 3 colinear points didn't occure.
Matt
MattC
Postby sl!m » Fri Aug 03, 2012 2:09 am
Hi there,
I found this Voronoi so cool... couldn't resist posting this.
Interacting with the mouse moving over the points.
Is that code any useful to ruby Heros ?
http://mbostock.github.com/d3/ex/voronoi.html
Have a great day/night!
Sl!m
sl!m
Premium Member
Premium Member
Postby juanjo » Tue Aug 07, 2012 7:37 pm
Hi Matt
Great plugin mate... lots of potential here
But I have a little problem: you say that for this to run properly this plugin requires "delauney3.rb"
I don't have it... I only have "delaunay2.rb".
I get the Typical plugin error..."Error loading file VoronoiXY.rb no such file to load -- delauney3.rb"
But I can't find the robust version that TIG is refering to here: viewtopic.php?t=8314
I did got the "conic curve" plugin to work and it's awesome.
Also tried to use "qhull.rb" but it's a mess! I just get flashing DOS-screen ans crashes.... It's a shame, since it would also be a super-tool...
Have you heard of any progress on that???
viewtopic.php?t=19040
viewtopic.php?t=8116
I'd really appreciate your help so i can start using this baby!
Thanks!
juanjo
Postby TIG » Tue Aug 07, 2012 10:38 pm
My 'modularized' version of 'delauney' [delauney3.rb] ships as part of my 'Triangulate Points' tool - which is very much like Didier's original... BUT avoids potential clashes with common loose method names like 'triangulate' !
viewtopic.php?p=301274#p301274
It doesn't replace the original, it just makes a 'safer' alternative for any tool that is using it instead...
Global Moderator
License type: Pro
Postby MattC » Wed Aug 08, 2012 7:25 am
juanjo wrote:But I have a little problem: you say that for this to run properly this plugin requires "delauney3.rb"
Hi juanjo, if You download a zip package made by pjt, and not separate files from first post, then You will have "delauney3.rb" as a part of it.
I couldn't get "qhull.rb" to work, and that was one of the reasons why I started to work on this project.
But I have some problems with the code. Some cases generates strange forms. So the work continues.
Greets
Matt
MattC
Postby dtolios » Thu Aug 09, 2012 4:54 pm
MattC wrote:Pilou You 're teasing me :D
Is it Sketchup ??
Or something else?
Well only step that I miss from those, is generation of 3D Voronoi :D
For rest I have plugins already.
@ Joel, indeed there WAS a problem - file in first message is updated.
Matt
Would it be too much to ask for 3D Voronoi?
I would be in...even if not for free... :thumb:
dtolios
Postby MattC » Fri Aug 10, 2012 7:32 am
Well... I think 2D voronoi package (delauney triangulation by TIG + Voronoi on XY plane + Conic Curve + Convex hull on XY plane) is almost ready.
Next step will be: (delauney triangulation in 3D + Voronoi 3D + Conic Curve + Convex hull 3D).
But it is a lot more complicated.
So it is a bit to early to decide free / paid - but I think donationware ( if You like it - gratify creator) is the way to go.
Cheers
Matt
MattC
Postby the.pjt » Tue Aug 21, 2012 8:09 am
hello Matt, did you got the Icons ? ... or a more important question: is this plugin still alive ?
the.pjt
Postby MattC » Tue Aug 21, 2012 9:55 pm
Yes I got it, Thanks a lot, I am a bit busy at my normal work, but plugin is still alive.
I will try to get updated version online this weekend, but I was already focused on Voronoi2D version 2.0
Cheers
Matt
MattC
Postby dekay » Fri Oct 26, 2012 8:19 am
tanks a lot, your script is very easy to use compared to others.it has been very helpful to me.
thank you once again..
dekay
SketchUp version: 6
Level of SketchUp: Beginner
Postby VICTOR HUGO » Sat Dec 15, 2012 7:38 am
Very interesting plugin...
where can I get the CPOINT creator or a CPOINT plugin?
Thanks.
VICTOR HUGO
Postby cotty » Sat Dec 15, 2012 9:54 am
VICTOR HUGO wrote:Very interesting plugin...
Thanks.
Here
A picture is worth a 1000 words. A 3D SketchUp model is worth a (1e3)^2 words?!
my little gallery
cotty
Top SketchUcator
SketchUp version: 8
SketchUp use: education
Postby ivreich » Mon Dec 17, 2012 1:35 am
VoronoiXY Error
Hi MattC
I'm still having problems creating a simple 2D Voronoi. Have attached the file with the cpoints and the error message.
Conic curve seems to work fine...
Cheers
joel
UPDATE: I see what the problem is. It's still the co-linear points. The plugin will not work if any of the points are colinear in either the X or Y axis.
Something that can be fixed?
ivreich
SketchUp version: 8
License type: Pro
Postby Pilou » Mon Dec 17, 2012 3:07 am
With Wings3d and plugin Manifold
www.youtube.com Video from : www.youtube.com
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby Pilou » Mon Dec 17, 2012 3:35 am
Why not put in the first post the link for the Delauney3.rb by Tig ?
It was not so evident to find it! :o
here the link! ;)
Else works fine :)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby Pilou » Wed Feb 27, 2013 10:11 am
Hello
For the Voronoï (with SU V7 tested) images previous post
All works fine except I must click on the Ok Botton for have a voronoï polygon for each new polygon! :shock: :o
Tig triangle works for a selection of points in one pass! :thumb:
And for the conic curve : does it possible to have the same for a selection of faces ?
Click on each polygon is some tiedious when you have thousand of them!
EDIT : About Voronoï xy
Works fine in V8 ! :enlight:
But something must be made for the UNDO !!! ;)
Here you must make each CTRL+ Z for each polygon ! :o
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby Pilou » Wed Feb 27, 2013 10:38 am
And about Conic Curve
Does this possible ?
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby MattC » Thu Feb 28, 2013 8:14 am
Hi Pilou, Hello everybody
Currently I am rewriting the whole Voronoi 2D plug-in.
It is going painfully slow, but I have a lot of other things on my head right now.
Why I am completely redesigning it? Well my understanding of Ruby got a bit better, and also I got some new ideas how to tackle this problem.
What I want to accomplish:
1) prepare a nice flow chart for a process of creating 2D Voronoi diagram
2) based on that define set of standard functions that will be used
3) compose final version of Voronoi 2D plug-in
- do steps 1-3 with 3D Voronoi
- do steps 1-3 with Conic Curve
- do steps 1-3 with random point generator (2D and 3D)
Shall I succeed then next step would be a "fracture tool" similar to one in Blender.
@ Pilou
So to create voronoi diagram You have to iterate through the message boxes i=1, i=2 ... etc?
I think that that was one of the first complains and I have disabled it in one of later versions. If not I can do it one more time. the same applies to UNDO in one step. Conic curve on all faces in selection was also made, but I don't know if it was made an official release.
Your last question is more complicated. Conic curve plug-in was made as a response to the topic in the first post. There You can see that there are multiple curves inside polygons. And all the polygons are convex. So the conic curve , which is a construction based on 3 points (let's say A B and C), is always located inside the smaller angle near the point B. In Your case polygon is Concave and conic curve will go outside. Is it possible to force it inside? Well it is.
See explanation of how the conic curve is made in first post. You have to set an offset that will sit well inside, and also play with a weight value. But in this version You cannot set different weights for every vertex. Maybe I will get to that in one of the future releases.
Stay tuned for more details. I will try to make a nice blog (possibly later an e-book) about it.
Cheers
Matt
MattC
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
PreviousNext
Return to Plugins
Users browsing this forum: Adriano50, Google Bot, Safety Not Guaranteed and 10 guests
