[Plugin] Curvizard - v2.4b - 10 Feb 20
Re: [Plugin] Curvizard - v2.0a - 13 Nov 15
Postby Ahmed0007 » Thu Dec 28, 2017 7:58 pm
Ahmed0007
Postby fredo6 » Thu Dec 28, 2017 10:52 pm
Thanks. Good tutorial video. I noticed that TutorialUp makes very didactic videos, going into some details and some usage that I did not think of myself.
In the case of this video on Curvizard, I think what may be missing is the interactive approach of Curvizard, that is the point-and-click capability to operate transformations (as opposed to pre-selection)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby CassieFlo » Wed Mar 28, 2018 3:43 pm
I've downloaded this plugin using the SCF Plugin Store (and restarted Sketchup right after) and have LibFredo6 8.1. However I keep getting a message that pops up saying that I have to install LibFredo6 v6.9 or higher to run curvizard...any thoughts on what is going on or how I can get this plugin working?
Thanks in advance!
Cassie
CassieFlo
Postby TIG » Wed Mar 28, 2018 3:48 pm
Assuming you have download both the latest LibFredo and installed it, and also the the latest version of Curvizard...
and you have restarted SketchUp completely...
Then that error is indeed strange.
You profile says: you have a MAC using SketchUp Pro - pre-v6 !
Can you correct it and advise us on your current configuration...
Help us to help you...
Global Moderator
Postby CassieFlo » Wed Mar 28, 2018 4:09 pm
TIG wrote:Assuming you have download both the latest LibFredo and installed it, and also the the latest version of Curvizard...
I have indeed installed both latest versions and restarted SU completely multiple times.
And oops! I am not sure why that was listed as such, I am using SU 2018.
CassieFlo
Postby fredo6 » Wed Mar 28, 2018 5:32 pm
Cassie,
I just published an update to Curvizard (v2.1a), as I realized the published version was quite old (2015).
Can you tell me if you still get an error.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] Curvizard - v2.1a - 28 Mar 18
Postby fredo6 » Wed Mar 28, 2018 5:50 pm
NEW RELEASE: Curvizard v2.1a - 28 Mar 18
Curvizard 2.1a is a maintenance release to keep the plugin on par with latest LibFredo6 versions. So upgrade is strongly suggested[/b][/color][/size].
Requirement: LibFredo6 8.1 or above
See main post of this thread for Download of Curvizard.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby CassieFlo » Wed Mar 28, 2018 6:47 pm
Fredo-
Yes! That worked, thank you so much!
CassieFlo
Re: [Plugin] Curvizard - v2.1b - 01 Apr 18
Postby bambutec » Fri Apr 20, 2018 2:13 pm
Hi Fredo,
actually ´m using your palette tools a lot. Not the Curvizard yet, but wonder if it would be possible to draw a real spatial contour.
The tutorial did not refer on a spatial type of editing the vertices.
My desire is related to an intuitive process creating contour lines of a hull, which is not yet defined , means from scratch.
The strategy follows many times to find a resulting spatial contour from two related planar contours.
Do you have an idea in terms of Plugin for this ?
Thank you for your work its really great .
Uli
bambutec
Postby Box » Tue Jul 03, 2018 3:24 pm
Hi Fredo I'm getting a repeatable error when using Curvizard Convert Edges to Guides.
It happens with any edge, even a single straight line.
This is with 2018 pro all plugins up to date, Libfredo6 8.4g
It works correctly in 2017.
I've attached the error text.
Re: [Plugin] Curvizard - v2.1c - 3 Jul 18
Postby fredo6 » Tue Jul 03, 2018 10:26 pm
NEW RELEASE: Curvizard v2.1c - 03 Jul 18
Curvizard 2.1c is a maintenance release fixing a small bug signaled by Box.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] Curvizard - v2.2a - 23 Nov 18
Postby fredo6 » Fri Nov 23, 2018 11:54 pm
NEW RELEASE: Curvizard v2.2a - 23 Nov 18
Requirement: LibFredo6 8.6m or above
Curvizard 2.2a introduces new toolbar icons designed by JClements. They are provided in Vector mode (SVG, PDF) and Raster mode (PNG), and thus should scale for hi-res screens on SketchUp versions >= SU2016 (and all versions on Mac)
See Plugin Page of Curvizard for Download.
See main post of this thread for discussion on Curvizard.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Sat Nov 24, 2018 8:48 am
Since there's a little hope to see this as core function, I wish we had a commercial FredoSplines with following interactive features:
1. handles for shape editing
2. 3 types of control points: smooth\corner\bezier
3. interactive refinement (=segmentation) control
4. Important for arch modelling: total slope (in %%) AND (optionaly) total height input
rv1974
Re: [Plugin] Curvizard - v2.4a - 24 Feb 19
Postby fredo6 » Sun Feb 24, 2019 12:10 pm
NEW RELEASE: Curvizard v2.4a - 24 Feb 19
Curvizard 2.4a offers 2 new tools[/b][/color] in order to reconstruct Polygons, Arc or Circle from a sequence of edges, when this is possible.
Requirement: LibFredo6 8.8a or above
See Home Page of Curvizard for information and Download.
See Main post of this Curvizard thread for discussion, bug reports and suggestions.
fredo6
PluginStore Author
PluginStore Author
Postby pbacot » Sun Feb 24, 2019 8:14 pm
That can be very useful at times. Thanks!
Top SketchUcator
Postby designerbursa » Wed Feb 27, 2019 8:20 am
"Convert Guides to Edges" Are you considering adding ?
designerbursa
Postby designerbursa » Wed Feb 27, 2019 9:11 am
"Convert to Arc / Circle"
thank you fredo6
designerbursa
Postby fredo6 » Wed Feb 27, 2019 9:12 am
designerbursa wrote:"Convert Guides to Edges" Are you considering adding ?
This would be different!
Anyway, there are already several plugins doing that, like TIG xLine2Line.
fredo6
PluginStore Author
PluginStore Author
Postby uwesketch » Thu Feb 28, 2019 10:08 pm
New feature "Convert to Arc/Circle":
Great, thanks a lot Fredo.
  • Is it correct, that when using "Make curves", that now the curve is converted automatically to an arc as well?
  • Now I can finally convert the corner edges generated by FredoCorner (using circle rounding) back to arcs, if desired. This then allows adding radius measurements in Sketchup and Layout! :-)
  • Any chance that this feature is added as an option to FredoCorner for the generation of the corner edges when rounding using circles?
uwesketch
Postby fredo6 » Thu Feb 28, 2019 10:14 pm
uwesketch wrote:Is it correct, that when using "Make curves", that now the curve is converted automatically to an arc as well?
Correct. I may introduce an option to disable this behavior however.
uwesketch wrote:Any chance that this feature is added as an option to FredoCorner for the generation of the corner edges when rounding using circles?
I understand that you ask for creating curves, possibly arcs when applicable.
I assume that only the rounding edges on rounded borders are to be converted to curves.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby bharralure » Fri Mar 01, 2019 12:25 am
Merci beaucoup Fredo
Un outil qui va remplacer avantageusement (parce que beaucoup plus complet) "niline2arc" de Nobnob qui, malgré tout et sans mise à jour depuis 6 ans, fonctionne toujours.
Les améliorations que j'apprécie:
- sélection multiple, y compris avec les faces
- ne pas être obligé d'entrer à l'intérieur des groupes et composants
- l'outil reconnait les cercle ou arc même si l'option "convertir en courbe" à été choisie
peut être est t'il possible de découvrir d'autres astuces ...
bharralure
Postby uwesketch » Fri Mar 01, 2019 10:13 am
Since an arc or n-gon (polygon) is as well a curve, it is not wrong to always convert to an arc or polygon, if it is an arc or polygon. I do not see any disadvantage for this.
Yes, only the corner edges, not as well the inner edges or borders.
To clarify I marked in below picture the edges.
uwesketch
Postby fredo6 » Fri Mar 01, 2019 11:21 am
uwesketch wrote:Yes, only the corner edges, not as well the inner edges or borders.
Conversion to curve is probably possible.
But be aware that in most cases, this won't be an arc of circle, even if you chose a Circular profile, except in the special cases where the corner is purely made of orthogonal faces.
fredo6
PluginStore Author
PluginStore Author
Postby uwesketch » Fri Mar 01, 2019 2:23 pm
Looking already forward to it.
Agree, it will not be in all cases an arc. But it is enough, if the edge to be rounded is perpendicular to the face at the end of the edge.
uwesketch
Postby pilou » Fri Mar 15, 2019 12:21 am
Trivial question but...when something is Converted to guides lines with Curvizard
How to make the inverse ? :o
TIG xLine2line makes that but you must edit the Group generated above and the little black crosses are always living ! :shock:
So Curvizard don't make this trivial thing ? (i miss maybe something too :)
Speedy Galerie
Top SketchUcator
Postby fredo6 » Fri Mar 15, 2019 10:46 am
pilou wrote:Trivial question but...when something is Converted to guides lines with Curvizard
Curvizard could do it, but it is supposed to work on true edges.
So that's why the function 'convert Construction Lines to Edges' should live in another plugin. I did not do it because there was some existing, but it is not too complex.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby pilou » Fri Mar 15, 2019 11:01 am
Will be fine and more speedy than research the good plugin, enter the Group, click the lines, kill the cross points, explode the group etc... :)
Speedy Galerie
Top SketchUcator
Postby Box » Mon Feb 03, 2020 6:38 am
Hi Fredo,
I think this has happened since the latest update to libfredo.
If I remember correctly Smooth, Simplify etc previously left the edges welded but now explode the curve. Unless I'm missing an autoweld setting.
Postby fredo6 » Mon Feb 03, 2020 8:38 am
I can reproduce it. Strange. I am looking into the issue and will come back.
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Mon Feb 03, 2020 5:04 pm
Problem of Sketchup curves not constructed fixed with LibFredo6 v9.5d.
Fredo
fredo6
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: guigoncalves96, sketchseda and 14 guests
