[Plugin] Gradientator v1.21
Re: [Plugin] Gradientator v1.21
Postby steve r » Tue Jul 24, 2012 5:38 pm
stuartmitch wrote:Thanks Thom Thom, is there anything you don't know about???
I have tried it with adjoining and separate faces and it still doesn't seem to provide a Gradient of colors. Rather, it simply adds color 1 to the first face, color 2 to the second face and so on. Do I need to stipulate the degree of gradient somewhere?
Cheers....Scotty
It seems like the issue you might be having is with the number of faces. This plugin only applies one color to one face at a time, and doesn't sub-divide them. In the picture you've provided, it looks like you've got two different applications of the plugin, but each time it's to only three faces. So, Gradientator sees that you've got three faces selected, and just applies the three colors; no gradient needed. However, with more than three faces, it will begin to gradient to greater degrees. So, trying to replicate your image with more faces:
As you can see, it's still applying those three colors, but the "in-between" faces are getting the gradient colors, or colors that are in-between those main colors. So, the amount of gradientating you'll get is dependent on the number of faces you select at one time. Does that help?
steve r
Postby stuartmitch » Mon Jul 30, 2012 4:12 am
Steve,
many thanks for clarifying that for me. I had missed the point that I needed more than three faces. From the initial illustrations it had looked like only 1 face was having colours gradiented (no such word??) across it.
I've got it now. Just needed to be belted on the head a couple of times!
Cheers...>Scotty
stuartmitch
Postby chuzhuo » Mon Aug 19, 2013 3:47 pm
its so cool!
chuzhuo
Gradientator v1.21 -> shows error on skp 2014
Postby leefordjudes » Sun Oct 19, 2014 7:26 am
It shows an error on sketchup 2014
Error Loading File gradientator.rb
Error: #<SyntaxError: C:/Users/admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/gradientator.rb:79: formal argument cannot be an instance variable
...ck("get_data") do |@grad_dialog,action_name|
how to
leefordjudes
Re: Gradientator v1.21 -> shows error on skp 2014
Postby sdmitch » Sun Oct 19, 2014 3:54 pm
leefordjudes wrote:It shows an error on sketchup 2014
how to
Using Notepad or similar text editor, simply remove the '@' in |@grad_dialog,action_name| in line 79 to this
Code: Select all
@grad_dialog.add_action_callback("get_data") do |grad_dialog,action_name|
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby Box » Sun Oct 19, 2014 5:35 pm
That works, Cheers Sd. :thumb:
Postby dtrarch » Sat Nov 01, 2014 3:16 am
Thx a bunch Mitch.
Just plain fun to mess with. :thumbd: :thumbd:
Works too :enlight:
dtr
dtrarch
Premium Member
Premium Member
Postby bomastudio » Mon Aug 17, 2015 11:08 am
In SketchUp 2015 I get the following error after the install:
Error: #<SyntaxError: C:/Users/nessuno/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/gradientator.rb:79: formal argument cannot be an instance variable
...ck("get_data") do |@grad_dialog, action_name|
C:/Users/nessuno/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubytoolbar/rubytoolbar.rb:144:in `load'
C:/Users/nessuno/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubytoolbar/rubytoolbar.rb:144:in `rt_load'
C:/Users/nessuno/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/rubytoolbar/rubytoolbar.rb:190:in `block in <module:RubyToolbar>'
SketchUp:1:in `call'
I solved changing row 79 to the end of the do block in this way
Code: Select all
@grad_dialog.add_action_callback("get_data") do |grad_dialog, action_name|
         if action_name == "begin_gradientating"
            @grad_dialog = grad_dialog
            @coloronename = @grad_dialog.get_element_value("color_one_name")
            @colortwoname = @grad_dialog.get_element_value("color_two_name")
            @colorthreename = @grad_dialog.get_element_value("color_three_name")
            @grad_dialog.close
            gradientate(@coloronename,@colortwoname,@colorthreename,@faces,@model)
         if action_name == "close_this_window"
            @grad_dialog.close
bomastudio
PluginStore Author
PluginStore Author
Postby utiler » Fri Nov 13, 2015 4:34 am
So do I. Would love to try this plugin....
utiler
Top SketchUcator
Postby Dave R » Fri Nov 13, 2015 11:46 am
utiler wrote:So do I. Would love to try this plugin....
Andrew, did you try the solution offered by sdmitch? I just tried it and that makes it work in SU2015.
Global Moderator
Postby TIG » Fri Nov 13, 2015 12:40 pm
The post just before yours offers a solution viewtopic.php?p=575140#p575140, and @sdmitch gave an even simpler version a few posts earlier viewtopic.php?p=541222#p541222
Just edit the RB using a plain-text editor like Notepad++, then find the do |@grad_dialog, text around line #79, and remove the @ so it's do |grad_dialog,.
Save the RB and restart SketchUp...
Since the @grad_dialog is defined earlier it is not necessary to redefine it in the do block, so using ANY name which doesn't start with a @ will work !
Global Moderator
Postby utiler » Sun Nov 15, 2015 9:42 am
Thanks Dave / TIG. Trust me to jump into a new plugin without reading through recent posts.... Cheers, I'll give it a crack tonight!
utiler
Top SketchUcator
Postby utiler » Mon Nov 16, 2015 1:28 am
;) Worked a treat, guys. Thanks!!!
I'll post in a few days what I needed it for. Glad to share.... ;)
utiler
Top SketchUcator
Postby pilou » Mon Nov 16, 2015 12:24 pm
Works fine! :)
Speedy Galerie
Top SketchUcator
Postby GianfrancoGalli » Sat Aug 06, 2016 10:53 am
hi, just landed on this post. the plugin is not working in make 15/16. i can select it in both Make 15 as 16, but it's not doing anything.
i've used v1.21. downloaded it to C:\Users\YOUR USERNAME\AppData\Roaming\SketchUp\SketchUp 201X\SketchUp\Plugins
thanks for your thoughts!
GianfrancoGalli
Postby sdmitch » Mon Aug 08, 2016 5:27 pm
GianfrancoGalli wrote:hi, just landed on this post. the plugin is not working in make 15/16. i can select it in both Make 15 as 16, but it's not doing anything.
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=45951%26amp;p=601292#p541222
sdmitch
PluginStore Author
PluginStore Author
Postby JaysonBata » Sun May 03, 2020 10:02 am
why is it not functioning to my sketchup 2017? :(
JaysonBata
Postby Dave R » Sun May 03, 2020 3:22 pm
The script needs some editing to work. Scroll up a few posts and read what sdmitch wrote. Edit the .rb file to make that change and it'll work. this is in SU2020 after editing the script and installing it.
Global Moderator
Postby dlightsey » Sat Sep 12, 2020 12:03 am
Does anybody have the repaired file. When I open the RBZ file using note pad, I get a bunch of garbage. I have tried all the standards when opening.
Thanks,
dlightsey
Postby Dave R » Sat Sep 12, 2020 1:53 am
Download the .rb file from the first post of the thread and make the edit according to the this post.
Global Moderator
Previous
Return to Plugins
Users browsing this forum: ArDiego, Bing [Bot], Laod94 and 17 guests
