SketchUcation Plugin Store
Plug in WELD- hidden geometry?
Postby ipsketchpi » Wed May 23, 2012 8:31 pm
I have downloaded WELD plug in from SMUSTARD COM. Something close to Auto CAD comand PEDIT (makes poliline). But I have a problem. When I push these surface from these new WELDED perimeter, I have no edges represented in new 3D object- attachement. Why, is there any other plug in to join edges into one poliline and to have these major connecting points retained?
/IP
ipsketchpi
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: engineering and mechanical design
Re: Plug in WELD- hidden geometry?
Postby mitcorb » Wed May 23, 2012 8:39 pm
This is normal behavior for the program. If you have softened edges, use Control+Shift+Eraser tool to harden. Or select the menu command for soften smooth edges and set the slider in the interface to taste. Make your selection first.
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free/Make
SketchUp use: architecture
Postby Jeff Hammond » Wed May 23, 2012 9:35 pm
ipsketchpi wrote: Why, is there any other plug in to join edges into one poliline and to have these major connecting points retained?
recurve won't join any lines with an angle greater than one radian..
viewtopic.php?t=36822
it's way better than weld.rb ;)
dotdotdot
Jeff Hammond
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Level of SketchUp: Advanced
Postby ipsketchpi » Wed May 23, 2012 9:37 pm
thanks
/IP
ipsketchpi
License type: Pro
Postby Dave R » Wed May 23, 2012 11:35 pm
The easy fix is to not select edges that you don't want included in the welded polyline.
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
License type: Pro
SketchUp use: woodworking
Postby Jeff Hammond » Thu May 24, 2012 12:29 am
Dave R wrote:The easy fix is to not select edges that you don't want included in the welded polyline.
that's what's sweet about recurve.. you only have to select one edge then use the 'select curve & recurve' option... it will then select all the other appropriate segments automatically and join them.
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby ipsketchpi » Thu May 24, 2012 5:54 pm
How to do that ? "that's what's sweet about recurve.. you only have to select one edge then use the 'select curve & recurve' option... it will then select all the other appropriate segments automatically and join them." Can you please post printscreen?
/IP
ipsketchpi
License type: Pro
Postby Jeff Hammond » Thu May 24, 2012 11:20 pm
it's in the right-click context menu.. right click on one of the segments then ---
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby ipsketchpi » Fri May 25, 2012 2:06 pm
I do not have such comand. Does it come from some plug in?
/IP
ipsketchpi
License type: Pro
Postby Jeff Hammond » Fri May 25, 2012 4:52 pm
ipsketchpi wrote:I do not have such comand. Does it come from some plug in?
it's a plugin called recurve...
see the third post in this thread. ;)
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Return to Plugins
Users browsing this forum: casa_22, devak69, Google Feedfetcher, loreyp, seasdes, stuartrader and 8 guests
