[Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
Re: [Plugin] FredoTools::ThruPaint - v1.3a - 20 Oct 16
Postby Bandika » Tue Dec 03, 2019 11:59 am
Me too. Strange, that it did not freeze, it worked, finally it made it - just in one and a half ours. I worked in two files that time, it was exactly the same. I am happy now that it works again:)
Bandika
Postby rv1974 » Wed Dec 18, 2019 10:36 am
Fredo, is it possible to add ability to assign (globally ) front face materials to corresponding back faces AND preserve front faces texture coordinates?
rv1974
Postby fredo6 » Wed Dec 18, 2019 11:11 am
rv1974 wrote:Fredo, is it possible to add ability to assign (globally ) front face materials to corresponding back faces AND preserve front faces texture coordinates?
In principle, the UV are mirrored on the backface.
Can you first try FredoTool:ReverseOrientFace to see if this does the job with the good mirroring on the back face.
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Dec 18, 2019 12:14 pm
In my tests your ReverseOrientFace is completely OK on transferring UV's when flipping.
Does it mean you potentially could add my request to ThruPaint or ReverseOrientFace?
Off-topic Minor issue: In ReverseOrientFace I can't make make tooltips work (they are enabled and SU restarted)
rv1974
Postby fredo6 » Wed Dec 18, 2019 4:59 pm
Just to be sure, you want a very unusual behavior, which is that the UV on the other side of the face are different.
In Sketchup, ThruPaint, etc... the flipping of faces or the painting on both sides of a face keeps the UV identical (so that if the material is transparent, you see only one texture).
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Dec 18, 2019 6:04 pm
In simple words I need singe click solution that'd take everything I see on front and apply in exact manner to the back (no matter what happens currently on the back, it will be replaced with front textures).
Theoretically ThruPaint is good if you'd start from the scratch and use TruPaint exclusively all the way.
rv1974
Postby fredo6 » Wed Dec 18, 2019 10:22 pm
Do you have an example. I am still not sure of what you want.
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Jan 22, 2020 9:45 am
The same components with the same material applied, but with randomized UV's..
Is it theoretically possible in current SU? Maybe some trick thru dynamic components?
rv1974
Postby fredo6 » Wed Jan 22, 2020 12:32 pm
rv1974 wrote:The same components with the same material applied, but with randomized UV's..
Still not clear...
Component instances behave the same when you paint their elements. And there is no control of UV when you paint their instances.
fredo6
PluginStore Author
PluginStore Author
Postby summerson1990 » Sat Feb 22, 2020 3:18 pm
Why is there a limit for only 5000 faces interactively refreshed while manipulating with the texture? Sometimes it's not possible to see interactive results on high poly meshes.
summerson1990
Postby fredo6 » Sat Feb 22, 2020 8:50 pm
I could increase the limit, as apparently machines become more powerful.
Still, what it means that you can preview the 5000 faces around the face where you manipulate the gizmo. So It should be sufficient to see what is going on.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby summerson1990 » Sat Feb 22, 2020 9:24 pm
fredo6 wrote:I could increase the limit, as apparently machines become more powerful.
Fredo
I think my GIF screen record above shows that in some cases it's not so comfortable to see what is going on when we've got a highpoly surface. Did you see it? Of course I can make a position of texture I need in other ways. But I was just interested about why did you do such a limitation and ask if it's ok if you could allow us to increase this value.
summerson1990
Postby fredo6 » Sun Feb 23, 2020 10:31 am
summerson1990 wrote:But I was just interested about why did you do such a limitation and ask if it's ok if you could allow us to increase this value.
As you show in the GIF video, the interactivity of the transformation is slowed down when you use a high number of faces.
It's OK for increasing the number, but you may then suffer from a lag as you play with the gizmo.
fredo6
PluginStore Author
PluginStore Author
Postby goldviper » Tue Apr 14, 2020 6:23 am
Please help
How can i enable nodes for non uniform scale
my Thrupaint only has pink node for uniform scale?
goldviper
Postby fredo6 » Tue Apr 14, 2020 11:28 am
goldviper wrote:Please help
The non uniform scaling is only available when you paint with the Quad Mesh UV or the Project UV modes, not with the Natural mode.
fredo6
PluginStore Author
PluginStore Author
Postby germscb21 » Sat May 16, 2020 4:15 am
Hi guys, i tried to download but it keeps loading forever and it never actually downloads it. I tried also downloading from the extension manager or directly from fredo tools in skp, but it doesnt work.. plzz heeelp
germscb21
Postby kakashi66 » Tue Jun 09, 2020 12:48 am
Is this plugin still available? It doesn't come up with any search.
kakashi66
Premium Member
Premium Member
Postby pbacot » Tue Jun 09, 2020 1:54 am
TruPaint is now installed as part of FredoTools. See first post above, and read down towards the bottom, or go look for FredoTools.
For that matter I don't know if the search is working right on the store, but you can find FreodTools in a full listing of Fredo6 plugins in the search
Top SketchUcator
Postby Dmeat » Wed Jun 17, 2020 9:03 pm
hi everyone, is the downloadlink broken, or is it just me?
Dmeat
Postby TIG » Thu Jun 18, 2020 12:59 pm
What 'downlink' ?
https://sketchucation.com/pluginstore?pln=FredoTools
works fine...
You do need to be logged in to the PluginStore ??
-1
Global Moderator
Postby maxder » Sun Jun 28, 2020 11:48 pm
I have been modeling in SU for years and have gained so much from the plugins and discussions with Fredo, Thom Thom, Tig and many others.
But I have been going in circles figuring out a UV workflow for taking my SU model into UE4 using Datasmith. My architectural forms are not super complex or organic, but a fair amount of curved surfaces and some double curvature. I have been using SubD and Quadface Tools.
I have played with SketchUV, Wrap-r and Thrupaint. Thrupaint is the most intuitive to me, but it says that it is not actually UV Mapping, and I don't know enough about UV to know what that means. Will it get me into trouble in UE4 (which I haven't trained on yet)? Or will it be enough for Datasmith to convert properly?
I haven't been able to get SketchUV to work with SubD quads unless I de-triangulate, which in turn messes with my curved geometry.
I thought Wrap-r was the solution when I unwrapped and textured the control mesh, but then it is distorted when I SubD. Unwrapping the subdivided mesh seems to be a royal pain. I am not trying to add edge wear or anything at least in SU, just want stand-in metal, stone and wood textures, but as seamless as possible.
Again, Thrupaint is the most intuitive tool for me, but is it UV mapping or not? I appreciate any help anyone can give.
maxder
Premium Member
Premium Member
Postby jonorman » Tue Jun 30, 2020 4:30 pm
Are there any known issues with Twinmotion and its sync plugin ??? Each time I reload the models after saving, i have to retexture in Twinmotion.
jonorman
Premium Member
Premium Member
Postby pilou » Tue Jun 30, 2020 6:03 pm
Sorry no problem for me : with ThruPaint or Not!
The Sync works like a charm! :fro:
(Su 2017 Make --> TwinMotion 2019 free )
I believe that we must have the SU Pro for Sync with free TwinMotion 2020 ?
When you say "reload" what is exactly ?
Direct from SU with the Twin Sync plugin or a simple reload inside Twin after saved a SU FIle ?
Speedy Galerie
Top SketchUcator
Postby jonorman » Tue Jun 30, 2020 6:56 pm
Ok, a bit short explanation :-)
Example.
I model a pipe, steel pipe. Create a material in SU and load a albedo image. Then i use Fredo`s Thru paint (latest version) and i texture it using Quadmesh UV mapping.
The texture add`s nicely in SU and I`m all happy to send it to TM using the sync tool (No merging, keeping all objects)
When the model shows up in TM, i load the rest of the textures, roughness, metallic and bump.
The model looks good in TM.
Now I save the model in SU and TM and shut down for the day.
Next day: Open SU model, open Twinmotion model.. Maybe I add somthing in SU, maybe a second pipe, using the same workflow as described above, and syncing with TM The material i added on the first pipe the day before are gone and replaced with the one from SU.
I have to reload all the other maps. Rough, metallic and bump..
This happens every time. I found another comment on this issue in the TM forums, saying it had to do with our favorite mapping tools, Thrupaint.. :? (I don't belivee it :-D)
Hope this makes sense :-)
jonorman
Premium Member
Premium Member
Postby misticalages » Mon Aug 31, 2020 7:11 am
Hello dear Fredo,
I come across a problem regarding ThruPaint, makeing it exporting separate material for each face, which i don't want it to happen. :ugeek: Final model exports and it has for like 238 materials and so...
I encountered and found out when i was changing the material and deleting it, the error it never happens. :|
Using Sketchup 2020 and the last FredoTools on the sketchUcation.
Thank you.
Misticalages
misticalages
Postby suprachs » Tue Oct 13, 2020 2:37 am
I am using sketchup pro 2020, installed ThruPhaint, does not show buttons, images cannot be used.
suprachs
Postby fredo6 » Tue Oct 13, 2020 2:20 pm
suprachs wrote:I am using sketchup pro 2020, installed ThruPaint, does not show buttons, images cannot be used.
Are you on Sketchup 2016?
If so, you need to take the legacy version of LibFredo6 and the legacy version of FredoTools.
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Fri Nov 27, 2020 3:44 pm
Fredo may I ask some childish question?
Is there any fundamental difficulty to implement Natural UV mode that is aligned to longes edges of the tube-like surfaces? Just like QuadMesh UV mode but without distortions?
Legend:
1- QuadMesh UV mode (almost OK except distortions)
2- Current Natural UV mode (messy)
3- The desired one- every segment of the tube gets aligned to direction distortion-free UV mapping. I can achieve it with a current Natural UV mode (clicking segment by segment) but is it possible to get it with single click?
rv1974
Re: [Plugin] FredoTools::ThruPaint - conflict with ENScape
Postby tomaszdrgas » Thu Dec 03, 2020 2:03 am
​It doesn't crush ENScape or something so don't worry..
Enscape is a render plugin for sketchup and few other like Rhino, Vectorworks..
I found that if I set up an ENS material and "Save As" it to some library, Fredo6 ThruPaint (which I use actually instead of native paint bucket) doesn't see ENS specific settings when introducing new material to the model.. It works with no problem when material is already one of the materials.
So if You have created a library of ENS setted up materials and want to use them in Your model, than when You pick the material from that library and paint it in Your model for the first time do it with native sKetchup Paint Tool. ThruPaint will make it a 'flat' sKetchup material loosing any links to bump, roughness etc. and mixing Tint Color and Color settings into texture image..
I don't really know who should fix what in order to make it work so I let know to both. I love ThruPaint and I have to use ENS.
tomaszdrgas
Postby tomaszdrgas » Thu Dec 03, 2020 2:11 am
rv1974 wrote:Fredo may I ask some childish question?
I guess that main problem is that plugin doesn't really know which direction is prefered one,. maybe we could assume the red 'U' direction..
Second problem ThruPaint tries very hard to make texturing continues.. As far as I have seen Your desired result it has breakes on every bend of tube.. So I guess You want some mix of 'quad' abd 'natural uv' modes.. Just select and paint each segment seperatly with 'natural uv'.. As You did I guess..
tomaszdrgas
PreviousNext
Return to Plugins
Users browsing this forum: aldix63, batu_61, csdj86, mranal1168, slkho1, Steini Jons and 13 guests
