SketchUcation Premium Membership
Window Challenge
Window Challenge
Postby masterpaul » Fri Mar 23, 2012 6:10 am
So this is the solution Im trying to think of... I have a facade of the building (as you can see its uneven, bottem smaller then top etc). And I an window design I want To apply to it. Shape bending tool wont do the job, the fredo scale might but what happens if there will be like 30 floors to do,window will be a pain.
masterpaul
Re: Window Challenge
Postby sdmitch » Sat Mar 24, 2012 4:07 pm
It seems you Window Challenge is more a Mission Impossible. Shape Bender could do the job but only if you create a small gap somewhere in the curve and create a group of windows at least as long as length of the curve.
Otherwise it would seem your only options is un-bent windows placed on the curve.
http://sdmitch.blogspot.com/
sdmitch
Operating system: Windows
SketchUp version: 8
License type: Free/Make
SketchUp use: hobby
Level of SketchUp: Beginner
Postby Hieru » Sat Mar 24, 2012 4:47 pm
Have you tried Component Stringer?
I did something similar with a simple curve here, but it should work for more complex paths.
Hieru
Premium Member
Premium Member
SketchUp version: 8
SketchUp use: architecture
Postby gilles » Sat Mar 24, 2012 5:00 pm
you can use Component stringer and BZ_tools and Recurve( see plugins index )
# 1 Draw your bean
# 2 erase the face
# 3 select the perimeter an recurve
# 4 right-click/ BZ_ convert to / polyline segmentor
# 5 type how many windows you want, enter
# 6 erase one segment of the curve ( Component stringer does not work with closed curves )
# 7 select your window component and your curve then plugin/Component stringer /scaling: stretch
# 8 add the last window. Done
# 9 use the tape tool to rescale if needed.
Note: you may have to play with component axis to find the good orientation of the window.
Have fun
gilles
Top SketchUcator
Operating system: Mac
SketchUp version: 8
SketchUp use: other
Postby masterpaul » Sat Mar 24, 2012 10:44 pm
I tried using the component stringer. It works fine in most cases until you get to unevenly oriented/slanted walls (e.g one wall is facing up, but the angle slowly changes, and then you have a wall that faces down slighty)
Im thinking that the solution to this could be a plugin that would:
Draw/Model a "pattern" on a selected surface or surfaces. The "pattern" would be assigned by selecting a component.
masterpaul
Postby gilles » Sat Mar 24, 2012 11:51 pm
Do you mean your walls are not vertical?
gilles
Top SketchUcator
SketchUp version: 8
SketchUp use: other
Postby masterpaul » Sun Mar 25, 2012 12:41 am
gilles wrote:Do you mean your walls are not vertical?
Yes :P Thanks, I ment the wholes are slanted in different directions. Each floor is different. This is why I think a "paint surfaces with component" could be very useful
masterpaul
Postby gilles » Sun Mar 25, 2012 8:57 am
In this case all your windows or most of them will be different.
Can you imagine the cost of this?
gilles
Top SketchUcator
SketchUp version: 8
SketchUp use: other
Postby masterpaul » Sun Mar 25, 2012 4:39 pm
gilles wrote:In this case all your windows or most of them will be different.
Ye, but atleast all put my monster rig to good use :P
(If you mean cont of production, Im doing this project as an experiment)
masterpaul
Postby gilles » Sun Mar 25, 2012 4:45 pm
Good luck?
Maybe you could find fredoscale useful for this.
gilles
Top SketchUcator
SketchUp version: 8
SketchUp use: other
Postby TIG » Sun Mar 25, 2012 5:12 pm
Perhaps you need to build the mesh and lattice it into windows - EEbyRails then LatticeMaker - one leaving diagonals and the other after manually erasing coplanar diagonals [simple selection tricks...]
I know the windows are not all the same width - but hey, this is a quick 5min demo... you have several hours to sort this perfectly...
Global Moderator
SketchUp version: 2013
License type: Pro
Level of SketchUp: Advanced
Postby broomstick » Mon Mar 26, 2012 11:26 pm
THere is also a plugin called component onto faces wich could help you. You have to correctly position the center of the component though :)
broomstick
Postby DareDevil » Wed Mar 28, 2012 5:03 pm
My solution is not a plugin :( and it's a commercial soft :( again...
It's Paracloud Gem
I dream about a simple free plug for SU doing that ! Waiting for it, I've bought the V4 next year.
DareDevil
Postby jpalm32 » Wed Mar 28, 2012 6:14 pm
daredevil wrote:My solution is not a plugin :( and it's a commercial soft :( again...
It's Paracloud Gem
Price??? Nothing on site I can find. Not much info either
jpalm32
Premium Member
Premium Member
Postby DareDevil » Wed Mar 28, 2012 8:52 pm
It's Paracloud Gem
Sad... there is no info on the new version of the web site :(
I said "I've bought the V4 next year", but's not realy true... "My school bought it" is better ;)
So, I dont realy know the price, but I remember something about 250$ for academic license.
DareDevil
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Return to Plugins
Users browsing this forum: dauria, luc Compère, Majestic-12 Bot, parkmancarter and 14 guests
