by Pilou » Tue Feb 21, 2012 4:59 pm
Does exist a plugin like this one ? Resolved by sdmitch ! Edit Here the normal thread of the Multiple Offsets by sdmitch
Remus has made a " face offset multiple" but it's not the same sort of result!
Pilou
- Top SketchUcator
- Operating system: Windows
- SketchUp version: 6
- License type: Free
- SketchUp use: hobby
- Level of SketchUp: Advanced
by JClements » Tue Feb 21, 2012 9:38 pm
be kind of neat if this would be combined with an option for multiple scale-and-copy function.
John Illustrator Beaverton, Oregon
JClements
- Premium Member
- Name: JClements
- SketchUp version: 8
- License type: Pro
- SketchUp use: illustration, cartoons
by Pilou » Tue Feb 21, 2012 9:46 pm
SDmitch has made one, I am testing it!
Pilou
- Top SketchUcator
by Pilou » Tue Feb 21, 2012 10:07 pm
Works fine!  I am waiting his authorization for post it here !  multi _Offset.jpg
Pilou
- Top SketchUcator
by dereeei » Tue Feb 21, 2012 10:48 pm
Doesn't seem too "complicated" with that webdialog, when all input data could be inset in VCB? And the direction could be set with a mouse click. Indeed, is fancy that way...but is it really necessary ? Just a thought, thanks.
dereeei
- Name: derei
by Pilou » Tue Feb 21, 2012 10:53 pm
When you have 100 clicks to make with the normal tool yes this can be some useful
Pilou
- Top SketchUcator
by jorge2011 » Tue Feb 21, 2012 11:13 pm
excellent idea, pilou, is possible to test this plugin?
thank you very much
jorge2011
- Name: jorge2011
- SketchUp version: 7
- License type: Pro
- SketchUp use: architecture
by Pilou » Tue Feb 21, 2012 11:38 pm
I have now the authorization of sdmitch So here the plugin!  By sdmitch
Pilou
- Top SketchUcator
by jorge2011 » Wed Feb 22, 2012 12:09 am
Thank you very much. just some suggestions.
Both the funsion does not work. There is an error in the offset circles or polygons. When I select one line, the tool does not work. It only works with faces.
and an order. It is possible that the offset is also a curve. now exploits the geometry? You can add the option to create faces?
thank you very much
jorge2011
- Name: jorge2011
- License type: Pro
by dereeei » Wed Feb 22, 2012 12:11 am
Pilou wrote:but is it really necessary ?
I'm not talking about the tool, that's more than amazing! I always dreamed to a tool like that... but a webdialog just seemed too much in my head.
dereeei
- Name: derei
by EarthMover » Wed Feb 22, 2012 1:58 am
Very useful! Thanks Sam and Pilou!
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller Some of my 3D crap
EarthMover
- Top SketchUcator
- Name: Adam Hails
by sdmitch » Wed Feb 22, 2012 3:52 am
jorge2011 wrote:Thank you very much. just some suggestions.
thank you very much
Yes, the plugin only works with faces. trying to sort out the order and directions of an endless number of line segments was just not worth the effort when Sketchup solves that problem with a face. The plugin erases the original and all faces created with the offset process. This plugin was quick and dirty exercise and has had limited testing and may not be able to work with every shape and offset you may come up with so 'keep it real'. When I have had a chance to throughly test and check it out, I will post it. As for now, please consider this a work in progress.
sdmitch
- Name: Sam
- Level of SketchUp: Beginner
by Didier Bur » Wed Feb 22, 2012 8:37 am
Hi, Just to say there's a typo in 'start_operation, shouldn't be 'Bevel Maker' but 'Multiple offsets'.
Didier Bur
- License type: Pro
by Pilou » Wed Feb 22, 2012 10:06 am
Done  And maybe sdmitch must start a thread with [Plugin] for be int the Data base's plugins!  When it will be not a WIP  Yet very cool!
Pilou
- Top SketchUcator
by sdmitch » Wed Feb 22, 2012 8:33 pm
I wasn't able to solve all the problems but the new posted version is a major improvement over the one posted to this thread. In all but one test cases I devised, the plugin operated as expected. In the one case, the offsets were created in the opposite direction from the selected one. I'm still trying to figure out why.
sdmitch
- Name: Sam
by Pilou » Wed Feb 22, 2012 9:58 pm
Cool Here the normal thread of the Multiple Offsets by sdmitch
Pilou
- Top SketchUcator
Return to Plugins
