[Plugin] FullScreen v5.0.0 (14 Feb 2021)
Re: [plugin] SU Window Settings - Update June 18, 2012
Postby pilou » Mon Nov 05, 2012 10:20 pm
Not sure about earlier versions, nor windows 8
Seems no problem with SU 8 with Windows 8 (Integral x64) :enlight:
(not tested by me but by an another French user ;)
Speedy Galerie
Top SketchUcator
Postby Anton_S » Tue Nov 06, 2012 12:33 am
Pilou wrote:Seems no problem with SU 8 with Windows 8 (Integral x64)
Good!!! Good!!! :mrgreen:
Anton_S
PluginStore Author
PluginStore Author
Re: [Plugin] SU Window Settings 2.0.0 - Update November 11,
Postby Anton_S » Mon Nov 12, 2012 8:32 am
New Release!!!
See 1st post ;)
Anton_S
PluginStore Author
PluginStore Author
Postby Burkhard » Mon Nov 12, 2012 11:47 am
Great work here.
Something I noticed. When setting the menubar invisible, the Dialog settings pop up.
When closing, the menubar is visible again. No chance to hide the menubar like the statusbar?
You got a pm
Burkhard
Premium Member
Premium Member
Postby Anton_S » Mon Nov 12, 2012 8:13 pm
Burkhard wrote:Something I noticed. When setting the menubar invisible, the Dialog settings pop up.
Well, it shows up to give a way back to set-up the menubar again. If want to remove menubar, without dialog showing up then use commands, write in ruby console:
AMS::Sketchup::MenuBar.maintain(true or false)
For more commands, see first post :mrgreen:
Anton_S
PluginStore Author
PluginStore Author
Postby jorge2011 » Mon Nov 12, 2012 8:47 pm
thanks for this update.
A small error.
In option: Owned Popups - "Show / Hide" does not work correctly.
When you hide and show, the windows can not be uncoupled and refitted.
jorge2011
Postby Anton_S » Mon Nov 12, 2012 8:52 pm
jorge2011 wrote:thanks for this update.
A small error.
The issue was already reported, and I don't seem to have success in fixing it :roll:
Working on it.. :geek:
Anton_S
PluginStore Author
PluginStore Author
Postby jorge2011 » Mon Nov 12, 2012 9:27 pm
sorry, but that option is the same option of the menu: Window> hide dialog boxes?
in your plugin is just adding an access to this function. no?
jorge2011
Postby renderiza » Tue Nov 13, 2012 2:35 am
This is awesome! I am soon to be finishing another of my plugins called "Key Scene" and this will greatly enhance it...Thank you so much!
Renderiza
renderiza
Premium Member
Premium Member
Postby matt.gordon320 » Thu Dec 06, 2012 8:02 pm
Anton, this is amazingly helpful! I teach Sketchup as well as being a heavy user in Architecture, and I do a lot of screencasts for my students. I got really tired of turning all my plugins off and moving my toolbars all over whenever I had to record. Now, I don't ever have to again!
Just wanted to say a VERY sincere thanks, you've saved me hours and hours of tedious work that goes completely unnoticed to everyone but me :D
matt.gordon320
Premium Member
Premium Member
[Plugin] SU Window Settings 2.0.0 - Feature Request
Postby Pete » Fri Apr 26, 2013 1:51 am
I am really benefiting from using this plugin!! I really appreciate the work you are doing!! Thank you for sharing.
Here is an idea for a feature: can the dialog height for the component options window be overridden to use the entire height of the screen above the windows task bar?
Demonstration:
Pete
Postby Anton_S » Fri Apr 26, 2013 8:38 am
Hello Pete,
Component Options is a tool, written by Google SketchUp. I honestly have no rights modifying the way its dialog interacts. Change it would probably end me in the SketchUp jail, well, unless I already violated enough dialogs. :roll: It would be great if you post your suggestion to the SU Wishes or somewhere in that category, they'd probably be convinced with it ;)
:mrgreen:
Anton_S
PluginStore Author
PluginStore Author
Postby CadFather » Fri Apr 26, 2013 9:49 am
on the other hand, i guess you could use winsize (it's a must for windows users anyway)
http://winsize2.sourceforge.net/en/index.html
the drawback is that it resizes a window by its name, so if you have the palette called 'components',
and you set it to 900x500 pixels, that will also resize the window's folder by the same name when you are browsing in explorer.
CadFather
PluginStore Author
PluginStore Author
Postby Pete » Fri Apr 26, 2013 4:16 pm
CadFather, winsize is doing just what I want!! Thank you.
In case someone has a native SketchUp way to do this I have moved this discussion to http://sketchucation.com/forums/viewtopic.php?f=289&t=52060
Pete
Re: [Plugin] SketchUp Full Screen 2.0.1 (May 8, 2013)
Postby Anton_S » Thu May 09, 2013 10:14 am
Version 2.0.1 ( May 8, 2013 )
  • Added show/hide/close dialogs and floating toolbars
  • Added set menubar on close checkbox option
  • ~Fixed the corrupted window bug, after show hidden popups; now windows can be connected, uncoupled and refitted.
  • Stabilized the css file.
  • Extended title text features, added onCaptionChanged observer.
  • Optimized script
See first post ;)
Anton_S
PluginStore Author
PluginStore Author
Postby JuanV.Soler » Thu May 09, 2013 5:25 pm
Hi Anton_S ,
I am not able anymore to keep retain or save the settings with this new upgrade :(
thanks for this fantastic plugin
_,_)))_,_
JuanV.Soler
Re: [Plugin] SketchUp Full Screen 2.0.2 (May 9, 2013)
Postby Anton_S » Thu May 09, 2013 6:59 pm
Version 2.0.2 ( May 9, 2013 )
  • Fixed retain button and save_settings function
Anton_S
PluginStore Author
PluginStore Author
Postby JuanV.Soler » Thu May 09, 2013 7:53 pm
yes ¡ :thumb: :thumb: :thumb:
thanks :D
_,_)))_,_
JuanV.Soler
Postby CadFather » Thu May 09, 2013 8:01 pm
Thank You! this is one of those i can't do without... makes all my mac friends just a bit sad.. :mrgreen:
CadFather
PluginStore Author
PluginStore Author
Postby Gus R » Thu May 09, 2013 8:35 pm
Anton_S wrote:Version 2.0.1 ( May 8, 2013 )
  • Optimized script
See first post ;)
Just discovered this plugin thanks to the update. This is really nice Anton. :thumb:
Gus R
Postby Anton_S » Sat May 11, 2013 9:06 pm
Gus R wrote:Just discovered this plugin thanks to the update. This is really nice Anton. :thumb:
Yep, I just changed the subject plugin from SU Window Settings to Sketchup FullScreen so that it describes the right way.
Anton_S
PluginStore Author
PluginStore Author
Postby Rich O Brien » Sat May 11, 2013 10:16 pm
This is one of those essentials for SketchUp
Anton deserves some PayPal karma for this plugin.
The latest version is a winner. Well done
Rich O Brien
Administrator
Postby wsxqaz » Mon May 13, 2013 2:14 pm
How do you do! This how do localization into Chinese, I can't find the related file that is the correct file
wsxqaz
Postby cmeed » Mon May 13, 2013 5:22 pm
This looks like a great help - An idea struck me - there is only so much screen space, Su is very plugin dependent and su is so versatile, it got me thinking - does su let you extend this plugin so you could customise your work area by displaying certain tool pallettes/windows for certain jobs....much like photoshop does
example
custom arrangement1 - Job:organic modelling - vertex tools, artisan- are open
custom arrangement 2 - Job:working in 2d - 2d tools- are open
just a thought...
c
cmeed
Premium Member
Premium Member
Postby Anton_S » Mon May 13, 2013 6:26 pm
wsxqaz wrote:How do you do! This how do localization into Chinese, I can't find the related file that is the correct file
I guess you want the Chinese translation, right?
I will add it in the newer version :D :!:
Anton_S
PluginStore Author
PluginStore Author
Postby Anton_S » Mon May 13, 2013 6:42 pm
cmeed wrote:customise your work area by displaying certain tool pallettes/windows for certain jobs....much like photoshop does
example
just a thought...
Hmm, so you want to have different project panels? Great Idea!!! :thumb: I will have to think about that...
Maybe this idea may be incorporated into SketchUcation Plugin Store by Rich O Brien. His plugins manager allows you to enable/disable certain plugins. Maybe Rich could add custom arrangement templates. :bounce:
Anton_S
PluginStore Author
PluginStore Author
Postby cmeed » Mon May 13, 2013 6:48 pm
I didn't know about richs' I'll take a look.
cheers
c
cmeed
Premium Member
Premium Member
Postby unearthed » Fri May 17, 2013 5:20 am
Hi Anton,
Seconding the profiles idea: I'd use a stripped-to-nothing profile for online live-model presentations, and a normal modelling profile.
Growplan - People ∩ Plants ∩ Place
windows 7 64b, 4GB RAM, SU 8.0.16846
Gimp, QGIS, Vectorworks 12, Bricscad 11
unearthed
Postby unearthed » Fri May 17, 2013 5:37 am
Thank again - that's a very time-saving plugin, and it doesn't seem to mess up my normal toolbar/menu settings.
unearthed
Postby Anton_S » Sat May 18, 2013 1:01 am
unearthed wrote:Thank again - that's a very time-saving plugin, and it doesn't seem to mess up my normal toolbar/menu settings.
Great :thumb: :mrgreen:
Anton_S
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: farhad604, kenaibear, kocaahmet43, kosmakosmakosma, luisviverojr and 12 guests
