by Anton_S » Sat Oct 20, 2018 2:08 am
Hi Jorgensen, There are "Save", "Retain", and "Reset" options, which are almost exactly what you're looking for. Here is how to utilize them: - Assign an F11 hotkey to (Menu) Window Settings -> Retain command.
- Assign an F12 hotkey to (Menu) Window Settings -> Reset command.
- Use WindowSettings UI to hide all the elements you would want hidden in fullscreen mode.
- Click on the Save button and close the UI
Use F11 and F12 keys to toggle between fullscreen mode. I know that you are looking for a single hotkey to do both, so that's a good request. Anton
Anton_S
- PluginStore Author
- Name: Anton
- Operating system: Windows
- SketchUp version: 2018
- License type: Pro
- SketchUp use: hobby
- Level of SketchUp: Advanced
by Jorgensen » Sat Oct 20, 2018 9:33 am
Thanks Anton
Just what I was looking for. Not sure what happens, but it works.
And it's not a problem using two keys.
Jorgensen
sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
Jorgensen
- Name: Jorgensen
- SketchUp version: 2016
- License type: Pro
- SketchUp use: architecture
by khaeid » Tue Mar 05, 2019 9:51 am
It stopped working on Sketchup 2019, I get the following error:
Error Loading File ams_WindowSettings.rb Error: #<IOError: The required, staged c extension file, "C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/libraries/stage/win64/2.5/ams_lib.so", is missing!> C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:199:in `block in require_all' C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:196:in `each' C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:196:in `require_all' C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/main.rb:129:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in `require' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in `require' C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_WindowSettings.rb:16:in `<top (required)>'
khaeid
- Name: khaled
- SketchUp version: 2017
- License type: Free/Make
- Level of SketchUp: Beginner
by Anton_S » Wed Mar 06, 2019 12:19 pm
@khaeid Update to the latest version of AMS Library to rid of the error.
Anton_S
- Name: Anton
- License type: Pro
by khaeid » Wed Mar 06, 2019 12:25 pm
I am already using the last version of the library 3.5.2, and I uninstalled both Library and Windows settings now and installed them again, and still have the same error
khaeid
- Name: khaled
by Anton_S » Wed Mar 06, 2019 12:27 pm
Anton_S
- Name: Anton
- License type: Pro
by khaeid » Wed Mar 06, 2019 1:13 pm
Ah ok, Thank you, it works now, the version in Extension Warehouse was still the old one, I was downloading the library from there
khaeid
- Name: khaled
by egomez121 » Tue Apr 16, 2019 6:21 pm
Thanks for this plug in! It works great on my Win7 PC! One request for me would be to have the ability to turn off the header for all the floating toolbars. I have a bunch on my secondary screen and the name headers take up a ton of room that I could utilize to better organize those floaters. Thanks again!
egomez121
- Premium Member
- Name: Enrique Gomez
- SketchUp version: 2015
- License type: Pro
- SketchUp use: landscape architecture
by zooen » Tue Jul 02, 2019 9:38 am
Hello everyone, Well! it's been years that I use SU and I did not know it great plugin. Thank you Anton, Bravo!  It was while researching the procedure to follow to buy a license of Clothworks that I discovered it. Zooen
zooen
- Name: Zooen
- SketchUp version: 2020
- License type: Pro
- SketchUp use: other
by pipinek » Sun Mar 22, 2020 9:24 pm
Anton_S wrote:updated february 10th, 2012Now works on windows 7 too!!! Well, read the 1st post for an info.  Thankyou, for your replies and comments!!! They really improved the plugin plus my English. Somehow, therefore, I don't strugle at the english essays anymore...  :berserk:
Greetings, Any chance to get an update for Su 2020? Thank you
pipinek
- Premium Member
- Name: HansKloss
- License type: Pro
- SketchUp use: urban planning
by Anton_S » Tue Mar 24, 2020 7:31 pm
pipinek wrote:Greetings,
Thank you
Hi! This plugin should work with SU2020 just as fine, provided you have the latest versions of the AMS Library and the Windows Settings plugins installed.
Anton_S
- Name: Anton
- License type: Pro
by pipinek » Wed Mar 25, 2020 3:50 pm
Anton_S wrote:pipinek wrote:Greetings,
Thank you
Oh, splendid. Than you. Alas I have noticed one issue with the plugin. Once active whilst I open/activate a toolbar it is completely frozen. As if it does exist on the screen except its visual presence there. The only way to touch it with the effect is to disable/unable an option Setting-Toolbar Containers. But in that case some docked icon are slightly displaced. Have to replace them. I will appreciate any piece of advice. Thank you in advance.
pipinek
- Premium Member
- Name: HansKloss
- License type: Pro
by Anton_S » Wed Mar 25, 2020 6:30 pm
pipinek wrote:Oh, splendid. Than you.
Could you elaborate what's going on, perhaps with a screenshot? I am not able to quite make out what's going on.
Anton_S
- Name: Anton
- License type: Pro
by pipinek » Wed Mar 25, 2020 6:55 pm
Anton_S wrote:pipinek wrote:Oh, splendid. Than you.
Hello, There is nothing to be illustrated. Just opened toolbar. I cannot move it (a cursor becomes white while moving it on it) no button (tools) can be clicked. When I uncheck the option Toolbar Containers (via menu, as above) docked toolbars disappear and then I can move the previously dead toolbar. After checking the Toolbar Containers (menu) all seems be back to normal. Except the docked toolbars which are displaced slightly, vertically. Hope it is more clear, or less confusing. Thank you. PS The same symptoms are present on different computers with SU 2020 Pro. Also after SU opened there tool tooltips are not available. Switching on/of Toolbar Containetrs (menu-widows-setting) make them appeared back.
pipinek
- Premium Member
- Name: HansKloss
- License type: Pro
by Anton_S » Thu Apr 02, 2020 5:59 am
pipinek wrote:There is nothing to be illustrated. Just opened toolbar. I cannot move it (a cursor becomes white while moving it on it) no button (tools) can be clicked.
When you say, "toolbar", do you the Window Settings UI or any SketchUp toolbar, such as the Principal/Edit? pipinek wrote:Also after SU opened there tool tooltips are not available.
This could be due to the fact that you have the "Retain on Start" option checked, which applies your saved settings when you open SketchUp. And your save settings have the toolbar container marked as hidden. To fix this, either disable the "Retain on Start" option or "Save" the desired layout, which you would want applied when you restart Sketchup. As a side note, I do realize the Window Settings UI is a little old and could use some improvements and reduction in size. I am looking forward to updating this plugin. Thanks.
Anton_S
- Name: Anton
- License type: Pro
by jwhida » Fri Sep 04, 2020 12:14 am
Confirmed it works on SU 2020, though I do note that the Sketchup warehouse version of the required AMS Library is not the most recent (it is currently v3.5.2, whereas Sketchucation version is v3.6.oh) So make sure you use the Sketchucation files until the warehouse is also updated. Great work this is very useful for client presentations Anton_S wrote:pipinek wrote:Greetings,
Thank you
jwhida
- Name: John
- License type: Pro
by shake1 » Sun Nov 22, 2020 2:01 pm
Not work in SU 2021, please check this. I have been using it for a very long time, i need it! Su 21.jpg
shake1
- Name: vladislavpishko
- License type: Pro
- SketchUp use: interior design
by fdreise » Sun Dec 20, 2020 6:44 pm
I recently changed my permanent license (pro 2018) into a subscription license and with the reinstall of the plugins I got the same error as Shake1. It seems to need a file from a directory which isn't created. I hope this can be fixed as it would be a terrible shame not to have this in su21.
Thanks in advance for any help.
fdreise
- Name: fdreise
- License type: Pro
by pipinek » Sat Jan 16, 2021 8:53 pm
shake1 wrote:Not work in SU 2021, please check this. I have been using it for a very long time, i need it! Su 21.jpg
Greetings, I have been using this splendid plugin with SU 2020. Till now - there is a certain interference with the new RPC Archvision AVAIl Browser Utilities. Models from the AVAIL (RPC) browser are not permitted to be placed/dragged onto the SU Window. Once disabling the AMS Window Setting Plugin all works fine. Could it be possible to fix the issue. Sadly had to remove the plugin. Hope for not long time. Regards
pipinek
- Premium Member
- Name: HansKloss
- License type: Pro
by Menzip » Sat Jan 23, 2021 8:15 am
IT doesn't work at 2021ver. could you check it ?
Menzip
- Name: PARK
- SketchUp version: 2019
- License type: Pro
by shake1 » Mon Feb 08, 2021 3:32 pm
Антон, хоть пару слов, - ждать совместимость с 2021?
shake1
- License type: Pro
by Anton_S » Tue Feb 09, 2021 6:25 am
shake1 wrote:Антон, хоть пару слов, - ждать совместимость с 2021?
Yes, sorry, update in progress. You can expect this within this month.
Anton_S
- Name: Anton
- License type: Pro
by pipinek » Tue Feb 09, 2021 6:51 am
Anton_S wrote:shake1 wrote:Антон, хоть пару слов, - ждать совместимость с 2021?
Thank you very much. Splendid. Could you please drop a line here once its done? There is a conflict between your plugin and AVAIL RPC Browser and SU plugin. Once your plugin activated one cannot use the AVAIL Archvision feature. Anything can be done to make them work together?
pipinek
- Premium Member
- Name: HansKloss
- License type: Pro
by Anton_S » Tue Feb 09, 2021 7:11 am
pipinek wrote:Anton_S wrote:shake1 wrote:Антон, хоть пару слов, - ждать совместимость с 2021?
Hey, Could you elaborate on the conflict? What is AVAIL RPC Browser? Edit: I see your message above regarding the AVAIL RPC Brower drag and drop functionality. Let me know if this is fixed once I update this. Thanks, Anton
Anton_S
- Name: Anton
- License type: Pro
by pipinek » Tue Feb 09, 2021 7:45 am
Anton_S wrote:pipinek wrote:Anton_S wrote:shake1 wrote:Антон, хоть пару слов, - ждать совместимость с 2021?
AVAIL Browser and SU AVAIL plugin replace the previous Archvision RPC Dashboard and SU plugin. This is bank of a special kind of 3d models used within several pieces of software, Rhino, 3ds max, Sketchup, Rhino, Autocad. Placing model within the program is made by drop and drag a model/proxy from the AVIL browser into the SU window. Whilst your plugin is active placing a model from the AVAIL browser or SU plugin window is blocked. Once removed the AVAIL works well. There is undoubtedly the serious conflict between them. https://archvision.com/avail/PS Once updated I will check it will check it with both SU 2020 and 2021. I would be marvellous if there is no conflict between them.
pipinek
- Premium Member
- Name: HansKloss
- License type: Pro
by Anton_S » Mon Feb 15, 2021 3:58 am
Hi all, Announcing version 5! Includes new UI based on React and Material UI, no longer requires AMS Library, and should be compatible with SU2021. See viewtopic.php?f=323&t=42926&p=382150#p382150Best, Anton
Anton_S
- Name: Anton
- License type: Pro
by pipinek » Mon Feb 15, 2021 5:27 am
Thank you for your marvellous work. Alas the newest version stops as well AVAIL RPC functionality. Same as before. Within both Su 2020 and 2021.
pipinek
- Premium Member
- Name: HansKloss
- License type: Pro
by Anton_S » Mon Feb 15, 2021 10:33 am
pipinek wrote:Thank you for your marvellous work. Alas the newest version stops as well AVAIL RPC functionality. Same as before. Within both Su 2020 and 2021.
I think I know what's going on. Can you check if the attached version works? Thanks! https://drive.google.com/file/d/1mIXriT ... sp=sharing
Anton_S
- Name: Anton
- License type: Pro
by pipinek » Mon Feb 15, 2021 3:12 pm
Anton_S wrote:pipinek wrote:Thank you for your marvellous work. Alas the newest version stops as well AVAIL RPC functionality. Same as before. Within both Su 2020 and 2021.
Hullo, It DOES work. With the newest version there is no conflict between the plugin and AVAIL RPC browser. Many thanks again. PS As in previous version I have an issue with the toolboxes placed on the SU working space (not docked. Most of the time they are frozen. Cannot activate any icon or move them on the screen. This is very annoying. With the previous version opening and close a Menu-Toolbat dialog windows or deactivate/activate an item of your plugin via the Menu resolved the problem. At present several times I could make alive the toolbar only by restarting SU 2021 (samein 2020 one). Sometimes it works, sometimes not. One more thing - it seems whilst the plugin activated the screen toolbar tips are not showing,
pipinek
- Premium Member
- Name: HansKloss
- License type: Pro
by shake1 » Mon Feb 15, 2021 6:15 pm
Антон, спасибо, все работает!
shake1
- License type: Pro
- Robot
Return to Plugins
