[Plugin] FullScreen v5.0.0 (14 Feb 2021)
Re: [Plugin] SU FullScreen 3.6.0 (Jan 29, 2014)
Postby Anton_S » Thu Jan 30, 2014 4:25 am
3.6.0 Jan 29, 2014
  • Figured out a way to keep all shortcuts working while the menu bar is removed. The fancy shortcuts sections and the show/hide menu bar option were removed. They are no longer required! :)
  • Fixed the get screen resolution function in AMS library. Now, it will return the size of all monitors combined. This fixes an issue where the dialog could not be moved to another screen.
  • Simplified and improved stuff.
Anton_S
PluginStore Author
PluginStore Author
Postby CadFather » Thu Jan 30, 2014 11:22 am
Master Anton strikes again - thanks!
CadFather
PluginStore Author
PluginStore Author
Postby unearthed » Fri Jan 31, 2014 3:13 am
Thanks for this plugin Anton, it's arguably the number 1 plugin for me as it enables me to quickly clear my screen for online client presentations. The only thing is could the floating black dialog be made smaller?
Growplan - People ∩ Plants ∩ Place
windows 7 64b, 4GB RAM, SU 8.0.16846
Gimp, QGIS, Vectorworks 12, Bricscad 11
unearthed
Postby Anton_S » Fri Jan 31, 2014 7:10 am
CadFather wrote:Master Anton strikes again - thanks!
Thank you, CadFather!
unearthed wrote:Thanks for this plugin Anton, it's arguably the number 1 plugin for me as it enables me to quickly clear my screen for online client presentations. The only thing is could the floating black dialog be made smaller?
I'm glad you like it. :D I've been thinking about making another collapsible on top, that would collapse/uncollapse all other collapsibles. Perhaps this feature could be available in the next release. Thanks for suggestion!
Anton_S
PluginStore Author
PluginStore Author
Re: [plugin] (updated February 1, 2012) Window Style
Postby vicxp0518 » Tue Feb 18, 2014 1:33 pm
unclex wrote:and i can not dare try the Menu Option, if i close it, how reopen it ??
Yes i'm encountering with the problem :( It's bad to me, 'cos I've already hidden everything in the window include the menu bar, then, how can I bring it back again?? I've got nothing to do with my Sketchup now even if I reinstalled both SU and this plugin. Please tell me.
vicxp0518
Postby Anton_S » Tue Feb 18, 2014 5:36 pm
Didn't you download the latest version? Use F12 to toggle the menubar and it would be a good idea to assign more shortcuts, as well. For example, SHIFT-S could be used to toggle statusbar, SHIFT-D could be used to toggle toolbar containers, and F11 could be assigned to toggle fullscreen. The latest version automatically assigns F12 shortctut at the begging of use.
If you don't have any shortcuts, and made it so all elements hide at start, do the following:
  1. run regedit.exe
  2. If using SU6-SU8, locate to HKEY_CURRENTUSER/Software/Google/Sketchup[n]/, otherwise locate HKEY_CURRENTUSER/Software/SketchUp/SketchUp[n]/
  3. Delete the Plugins_ams folder. This will reset all plugin data.
Next time, have assign shortcut to reset.
Anton_S
PluginStore Author
PluginStore Author
Re: [Plugin] SU FullScreen 3.7.3 - Feb 23, 2014
Postby Anton_S » Sun Feb 23, 2014 9:59 am
@vicxp0518, I updated the plugin so the menubar remains visible on start, under certain conditions. Download the latest version 3.7.3 and your good to go.
Anton_S
PluginStore Author
PluginStore Author
Postby HirokaMatsuiko » Sun Mar 09, 2014 5:04 pm
this is wonderful plugin
my shortcut is almost full
request if can future updates
add Full Screen Button toggle on / off for toolbar
thank you again
HirokaMatsuiko
Re: [Plugin] SU FullScreen 3.8.0 - Mar 13, 2014
Postby Anton_S » Thu Mar 13, 2014 11:53 pm
HirokaMatsuiko wrote:add Full Screen Button toggle on / off for toolbar
Added!. :thumb:
Anton_S
PluginStore Author
PluginStore Author
Postby Jim » Mon Mar 17, 2014 10:31 pm
Really nice plugin, Anton. Thank you.
Jim
Global Moderator
Postby whiteanne » Wed Mar 26, 2014 7:05 am
I have a proble when running this plugin(latest version) on sketchup pro 2014,it shows like the photo below. Can anyone tell me what should I do to fix it??? it would helps,thats really a useful plugin.
whiteanne
Postby Anton_S » Wed Mar 26, 2014 8:34 am
It seems Sketchup.register_extension is undefined. Scroll down to line 33 and add :: in from of the word Sketchup, save, and test.
It should look like this:
::Sketchup.register_extension @extension, true
If it doesn't work then your SU was modified, or some files were deleted. Try re-installing SketchUp and see what happens.
Anton_S
PluginStore Author
PluginStore Author
Postby ArchieA » Thu Apr 24, 2014 1:31 am
Windows 8, SU 2014. There's no Plugins folder to unzip ams_Lib_1.0.8.zip so I extracted the files to the folder Tools.
Fullscreen still doesn't work.
How to I get rid of the annoying popup stating, Download ams_Lib? Or remove the plugin?
Thanks in advance.
ArchieA
Postby Anton_S » Thu Apr 24, 2014 8:48 am
@archieA The plugins folder is located in %appdata%\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
This plugin is not a standalone plugin. It requires AMS Library. Here is the link: http://sketchucation.com/forums/viewtopic.php?t=55067#p499835 Extract AMS Library in the plugins folder as well.
Anton_S
PluginStore Author
PluginStore Author
Postby ArchieA » Sat Apr 26, 2014 4:11 pm
Anton_S wrote:@archieA The plugins folder is located in %appdata%\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
Thank you. I got it working on SU 2014 on Windows 8. Easy enough when it's clear. I've started using it using F12 to toggle. Great plugin!
ArchieA
Re: [Plugin] SU FullScreen 3.8.1 - Apr 26, 2014
Postby chri » Sat Apr 26, 2014 8:17 pm
Hi Anton
You have done a great job :thumb:
Is-it difficult to create a file ( rb for example ) to change the commands language ?
I have done a french example of what i mean on the next pictures .
Bye
Chri
chri
Postby Anton_S » Sat Apr 26, 2014 9:52 pm
ArchieA wrote:Thank you. I got it working on SU 2014 on Windows 8. Easy enough when it's clear. I've started using it using F12 to toggle. Great plugin!
Very well, I'll add the description to first post. :D
chri wrote:Is-it difficult to create a file ( rb for example ) to change the commands language ?
Yeah, its quite difficult to translate webdialogs.
I heard Aerilius created a method, that could translate the Webdialog, so we'll see.
Thanks for request.
Anton_S
PluginStore Author
PluginStore Author
Postby JQL » Wed Nov 12, 2014 5:38 pm
Hi Anton,
I don't think this plugin is 2015 ready or is it?
JQL
Premium Member
Premium Member
Postby Pherim » Wed Nov 12, 2014 6:20 pm
It's not, because AMS library isn't.
Pherim
Re: [Plugin] AMS Window Settings 4.0.0
Postby CadFather » Fri Nov 21, 2014 7:25 pm
Thank you Master Anton!
(can't believe i was even few weeks without WS!)
laptop is smiling again. :D :fro:
CadFather
PluginStore Author
PluginStore Author
Postby Rich O Brien » Fri Nov 21, 2014 7:42 pm
@max
That laptop is unique.
Treasure it
Rich O Brien
Administrator
Postby CadFather » Fri Nov 21, 2014 7:59 pm
true... :lol: and you should see it now!
PS. easy with your psychic powers.... (i sold it today) :o
CadFather
PluginStore Author
PluginStore Author
Postby Rich O Brien » Fri Nov 21, 2014 8:05 pm
They say there's one born every minute.
Rich O Brien
Administrator
Postby CadFather » Fri Nov 21, 2014 8:11 pm
hahaha... not at all mister, this is a beast which should last plenty (unless you jinx it!) :lol:
CadFather
PluginStore Author
PluginStore Author
Postby CadFather » Fri Nov 21, 2014 10:53 pm
only strange thing i found, the green settings window always pops up on start, even if i uncheck the option. not sure it's supposed to be that way.
CadFather
PluginStore Author
PluginStore Author
Postby Anton_S » Fri Nov 21, 2014 11:43 pm
CadFather wrote:only strange thing i found, the green settings window always pops up on start, even if i uncheck the option. not sure it's supposed to be that way.
It shouldn't show up if you uncheck the "Show on Start" option. I tested it on my Windows 7, SU8, 13, 14, and 15 64bit. Can you give give me your system background, such as OS and SU version?
Anton_S
PluginStore Author
PluginStore Author
Postby CadFather » Fri Nov 21, 2014 11:58 pm
ok, so that's strange, it happens on all my versions (8, 2014, 2015-x64).
i guess you may want to wait if anyone else has the same problem while i investigate further for conflicts etc. win7 64bit.
Thanks Anton
CadFather
PluginStore Author
PluginStore Author
Postby Anton_S » Sat Nov 22, 2014 12:22 am
CadFather wrote:ok, so that's strange, it happens on all my versions (8, 2014, 2015-x64).
Thanks Anton
Hmm...
I thinkswo_on_quit observer from the new AMS library doesn't work properly. I will look into it. Just to ensure that other observers work, I would like you to do a simple test:
  1. Open Window Settings dialog, and use the menu bar option (Menu)Window > Settings > Full Screen to switch SU full screen. See if the dialog updates its radio-button mode.
  2. Another test, maximize and restore your SketchUp window using the maximize button on the upper right corner of the window. See if the dialog updates its radio-button mode.
If the dialog doesn't updates, then there is a problem with the whole observing system in my new library; otherwise, it's just this swo_on_quit observer not working for some...
I would appreciate your tests,
Anton_S
PluginStore Author
PluginStore Author
Postby CadFather » Sat Nov 22, 2014 12:51 am
ok, on all tests the radio buttons update properly. this with 2015x64
CadFather
PluginStore Author
PluginStore Author
Postby Anton_S » Sat Nov 22, 2014 1:23 am
Phew! It's just the swo_on_quit observer method that doesn't work on all systems. I will investigate.
Anton_S
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: dpaul, jesus_karatula, MONICAPARENTE_15, vivilima and 10 guests
