[Plugin] SplitUp
Re: [Plugin] SplitUp v1.5 20120219
Postby smicha » Mon Mar 04, 2013 8:57 am
Is it possible to add extra parameters to the plugin to work separately in RGB directions? Let's say I have a cube and I want to divide each of its plane into quads. 5x5x5 works great - simply select a cube and use the plugin with '5' as a value. But now I'd like the cube to be cut into 6x4x3 as depicted on the screenshot.
smicha
Postby TIG » Mon Mar 04, 2013 5:38 pm
I think Thomthom has some tools in his Edges set ?
Have you look at that...
Of course doing the simple splits as you show is easy enough using native copy/array tools and auto-splitting of crossing edges... :?
Global Moderator
Postby pilou » Mon Mar 04, 2013 5:58 pm
is easy enough
Sure :)
Select "face X" Copy move / 3
Select "face Y" Copy move / 4
select "face Z" Copy move / 6
not a big deal :)
Speedy Galerie
Top SketchUcator
Postby Rich O Brien » Mon Mar 04, 2013 6:18 pm
Pilou wrote:
is easy enough
Sure :)
not a big deal :)
Internal faces. Make one more shift+click to subtract face from selection then perfect :fro:
Rich O Brien
Administrator
Postby pilou » Mon Mar 04, 2013 6:22 pm
Internal faces.
If not wanted yes :)
else Remove inner faces ;)
but
Curiously the Remove inner faces seems don't yet works! :o
Maybe icompatibility with another plug ?
Speedy Galerie
Top SketchUcator
Postby smicha » Mon Mar 04, 2013 7:00 pm
TIG, Pilou, Rich,
Thanks for your comments but this was not my question. I just did it manually in even simpler way. This would be great to have 3 parameters in input in the plugin.
smicha
Postby JQL » Mon Sep 23, 2013 10:50 am
Hi Tig and Rich,
Thanks for this addition to SU arsenal.
To improve on what you already have, is it somehow possible to make the plugin work also on holes created by "hole cutting components"?
Best regards,
JQL
JQL
Premium Member
Premium Member
Postby rombout » Fri Feb 20, 2015 7:52 pm
Hi guys, tried this plugin again since quite a while. Im still runnin gold SU 8. For me on mac the plugin 'crashes' a lot. with low numbers it works until i try it from about the 3rd time. The mesh start to flikker and SU stops working.
im running os 10.6.8, its a old lady
rombout
Previous
Return to Plugins
Users browsing this forum: Google Bot, nicmendo, qhsdn1218, SBelli and 10 guests
