Please help
[Plugin] Angular Dimension
• Page 3 of 3 • 1, 2, 3
Re: [Plugin] Angular DimensionHi! I don`t know if someone else has issues when launching sketchup after installing the pluging. It is freezing the program
![]() Please help Re: [Plugin] Angular DimensionUse Angular Dimension 2 instead.
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
That's a new issue that hasn't been reported previously. I haven't been able to reproduce it. The code hasn't been modified since 2015, so this isn't due to any recent changes by me. Have you tried uninstalling the plugin to see if that makes the problem go away? It doesn't do anything during SketchUp startup that would explain freezing the program, so I unless some other plugin is interacting with it, I am at a loss as to what may be going on. As @DaveR mentioned, Angular Dimension 2 is the successor plugin to this one. It uses 3D text in the plane of the angle instead of leader text floating on the screen. That avoids issues where the leader text punches through or hides behind objects in the view. It also provides a lot of format customization options that the original Angular Dimension did not have.
