[Plugin] Angular Dimension
• Page 2 of 3 • 1, 2, 3
Re: [Plugin] Angular DimensionHi,
test's fine here, I'm not sure what was up with the original icons, they work when I stuck them in a Toolbar button, but not as a cursor, I know when I scaled mine down 50% to 16x16 they stopped working, so maybe there's a minimum file size? john learn from the mistakes of others, you may not live long enough to make them all yourself...
How to switch from inner angle tool, which looks like is defoult, to outside angle tool? /IP
Re: [Plugin] Angular DimensionAfter activating the tool, read the message line at the bottom of the drawing window.
![]() You can also find the usage instruction at the beginning of the rb file if you open it in a text editor.
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] Angular DimensionUhm, please forgive me if this is a 'duh' question, but I can't seem to get the draw_angle_dim.rb tool to work at all... Running WinXP Pro, SketchUp 8 Pro 8.0.11752.
The icons don't show up, I don't see it on the Plugins menu... how do I activate the tool?? Unfortunately, I don't know much about Ruby, but did try typing DrawAngleDimTool::IN_ICON into the Ruby Console and it does return the correct path and icon file name...and the files are there... DrawAngleDimTool::IN_CURSOR returns 50001 Help? Re: [Plugin] Angular DimensionThe most common reason that plugins don't work for people is they aren't installed correctly. Make sure you have both a folder called 'draw_angle_dim' and a file called 'draw_angle_dim.rb' in the Plugins folder of SketchUp. The folder contains two image files; interior.png and exterior.png. When you have all those files in place correctly, open SketchUp and look in the tools menu for 'Angular Dimension.' There you have it. There is no toolbar and it doesn't appear in the Plugins menu.
Re: [Plugin] Angular DimensionThanks Dave R; I had just found it hiding on the Tools menu. [is there a way to make it (and other ruby's) appear in a certain order on the Tools menu - like next to the native Dimensions item?]
Would help new users if the usage doc were posted and mentioned how/where to activate it...like this: # Name: draw_angle_dim # Description: Create an angle dimension with arc and text in a new group # Adds item "Angular Dimension" to the SketchUp Tools menu # Usage: - Click 3 points, going around an angle in sequence from any point # on one leg, to vertex, to any point on the other leg (clockwise or # counterclockwise doesn't matter). Be careful where you click - # this tool lets the inference engine assist you but doesn't # force you to click on existing model entities! # - The tool will draw two edges along the sides of the angle, # an arc across the angle, and a text with leader showing the # value of the angle. The two edges make it easy to realign # the group with the original angle if the entity containing it is # subsequently moved or rotated. # - The primitive elements of each dimension are gathered into a Group # named Angular Dimension (<angle>), where <angle> is the measured # angle. If you draw multiple angle dimensions, the <angle> value # will help you identify which is which (unless, of course, you have # several with the same value!). # - Each Angular Dimension drawing is packaged in an operation, so that # undo and redo treat all of the elements as a single step. # - The default radius for the arc is half the distance between # the first pick point and the vertex. The user can override # the radius by typing in the VCB at any time. If a new radius is entered # before the first point is picked for the next angle, the prior # dimension is redrawn at the new radius. The user-selected # radius remains in effect for additional angles until the # user enters a new value or selects a different tool. # - The TAB key toggles between drawing the interior (<180) angle # and drawing the exterior (>180) angle dimension. If you press tab # after an angle dimension is drawn but before picking the first # point of the next angle, the current angle dimension will be # redrawn in the new mode. # - Unlike the built-in "smart" linear dimensions in SketchUp, the # entities drawn by this tool are just graphics; they have no tie # to the original angle and will not follow it or scale if it is # modified. You can open the Group for edit, but it is not likely # you will like the results - it is easier to delete the dimension # Group and do it again. # Date: December 23, 2011 # Type: Tool Re: [Plugin] Angular DimensionAnd of course, thanks, slbaumgartner for a cool tool! ...was just a bit mysterious for me since the location and doc were not posted...
Re: [Plugin] Angular DimensionMost plugin writers put that information in their plugins so you can read it after you download it.
As to putting the menu entry in a specific location in a menu, I'm not sure it can be done. Etaoin Shrdlu
Re: [Plugin] Angular DimensionI decide to finally try out this plugin with Sketchup v8 on my Mac. I used the Preferences/Extentions/Install Extension... method after renaming the ZIP file extension to RBZ. The files were installed as stated in a previous post here called "The most common reason that plugins don't work..." with a slight variation that doesn't allow the plugin to work.
The version that I downloaded was for the Mac and was called "draw_angle_dim_Mac". The above extensions installer within Sketchup v8 installed the plugin correctly but one folder level too deep. The installation folder was named the same as the ZIP file "draw_angle_dim_Mac". You have to move the Ruby script "draw_angle_dim.rb" and the folder "draw_angle_dim" up one level for the plugin to work in Sketchup. Get rid of the folder "draw_angle_dim_Mac". Re: [Plugin] Angular Dimension
I don't have a Mac, so I can't check the required paths there (the mac archive was assembled by driven), but what you say is consistent with how it works on a PC.
Actually I think I did the plugin assembly and that seem to be one of my mistake. I seem confused by the zipping thing, and to have it one directory too low seems a recurrent issue. I'll see if I can repack it and will send it to the author. Here are the "better packed" files, same one as first post. They will be posted to the first post some time later. There should be no container folder, but if it appears, it is named "Angle Dim Mac" but the items that should be in the plugin folder are its content, or: - draw_angle_dim.rb - draw_angle_dim folder Re: [Plugin] Angular Dimensionplugin works fine on my computer (PC)
thank you i especially like the message at the bottom of the screen, for each point to come; makes it very easy to use Re: [Plugin] Angular Dimension - display precision?Is it/could it be possible to change the precision of the angular dimension displayed?
It defaults to 0.1 degree, which is fine for most practical purposes. But I'm trying to develop a plugin which will draw regular polyhedra, and while developing it, need high precision displays as I'm checking the maths of the geometry. I'm using a 'unit length' of one million inches, with five decimal digits of precision, for lengths, to check some of the mathematical formulae (Wikipedia seems to have at least one just plain wrong for the tetrahedron)!
Re: [Plugin] Angular DimensionThe precision of the angle is driven by the precision you have set in Model Info>Units. For angular units you have up to 3 places right of the decimal.
Dave, you are absolutely correct. I used SketchUp's built-in formatting for the angle, which obeys whatever the user has set in the model info. Steve
Re: [Plugin] Angular DimensionAbout angle precision... indeed, it uses SU precision, but sometimes even with three decimals, it still shows the ~ symbol. Maybe it should be suppressed if the angle precision goes beyond three decimals, because it is really confusing when you see ~30.000 degrees, for example. It would be somewhat understandable to see ~30.00 when the angle is 30.001 degrees, but as the precision cannot go beyond 3 decimals, there is no point to keep the "~" in that case.
DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] Angular DimensionYou are mistaking the display format for a limit on calculation precision. The units settings in the model info affect how many decimal places SketchUp will display. But it is still perfectly possible to calculate or set a value to more places. For example, if the value is 30.0002 degrees, it will display as ~30.000, telling you that the actual value was rounded based on the display units. This is the same as occurs for all SketchUp units.
Actually I am not mistaking it. I know what you want to say. But I also know that programmatically the "~" can be removed by feeding in a "rounded" value to 3 decimals. So, if SU returns 30.0001 degrees and the plugin will round it to 30.000, then it will NOT display the "~". Of course, this will mean losing the fourth decimal precision... but wait: I can't use the fourth decimal, even if it's there. So, technically there is no lose at all, because SU won't even display the fourth decimal in degrees value. Is just for best displaying properties... to lead to less confusion. As an example, I just rotated a guide line with PRECISELY 30 degrees, but this tool shown me ~30 deg. Meaning that SU was not able to make the rotation to 30 degrees sharp (due its implicit precision limitation, which is fine). But again, the value that made for "~" to appear was somewhere far beyond the decimal point (maybe fourth/fifth decimal), which is completely not important. So, if the plugin just rounds-up the value to 3 decimals and dumps everything else, I believe we are in a common sense "territory". DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] Angular DimensionYou are asking me to make a decision for the user about whether the full precision of a value is important or not. I simply conform to the behavior of all the other units in SketchUp. I don't see why consistency should cause confusion.
For example, if you have length units set to 0.0m and an actual length is 0.02m would you expect a linear dimension to display it as 0.0m rather than ~0.0m? By the way, my experience is different from yours. I just rotated a guide by 30 degrees and the angular dimension displays exactly 30.000 without any ~. Did you type 30 to get an exact value, or click after rotating in the view?
unless you typed in '30degrees' there is a strong possibility SU rounded the radians up or down... john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [Plugin] Angular DimensionOr maybe it was too close to some other geometry and it snapped to it... whatever cause it was, it rounded it to some value that was askew from 30.000. And this is precisely why I got this detail into attention: because such approximations can happen. And unless the precise value can be displayed, there is no reason to provide the ~ symbol. Rounding all values to three decimal precision would be the most elegant way to solve this.
Re: [Plugin] Angular DimensionI request that you post this as a feature request for discussion at the general level of SketchUp, as it has far broader implications than here. In effect you are asking that I "mask" (i.e. not show) or perhaps even heal small modeling errors. I don't agree at all. Such errors are the source of numerous "why doesn't pushpull (or whatever tool) work right?" posts. I see the "~" as a feature, not a flaw. It tells you when you have been sloppy. But, more importantly, if such a change is to be made, it should be consistent across all units displays in SketchUp, not just provided by this extension.
Re: [Plugin] Angular DimensionI understand your point... and it makes perfect sense.
What does NOT make sense is that on linear dimensions you can actually see where the flaw is (because user can choose a much greater precision), the issue here is that for angles you can't see it, if the error goes beyond 3 decimals, thus impossible to correct. So, if I see ~30.000 I have no idea how I should correct it. Is it 29.9999, or is it 30.0001 ? Hence the confusion I was talking about. Maybe to add it as option in a simple setting menu? Kind of keypress switch? Select the tool and in the information bar of sketchup to have a quick description "Press Ctrl to enable (or disable) round-up feature". As you say, in many instances this can be really useful, as it will tell the user there is a problem (even if the problem can't be seen with accuracy). But in other cases, if I see three zeroes after decimal point, I may be just happy to see it rounded. Anyway, currently I just edit the text, but when I have to edit several angular dimensions, is a bit frustrating. Just a suggestion. DESIGNER AND ARTIST DEREI.UK
Users browsing this forum: clemente0403, nnwa12 and 9 guests
