[Plugin] Simple Plugin Installer
Re: [Plugin] Simple Plugin Installer (1.0.1) — 02 January 20
Postby thomthom » Thu Jan 26, 2012 9:25 am
Tomasz wrote:It can be done through a C/C++ extension. I have it in mind to create such a 'library', but I am currently too busy to invest my time in it.
Ditto.
I tried to make Google add such helper methods.
It is only an issue under Windows though. So only a Windows C Extension is required. OSX works fine.
PluginStore Author
PluginStore Author
Postby newrui » Tue Jan 31, 2012 11:19 pm
Hello. Any chance for something for us mac users?
newrui
Re: [Plugin] Simple Plugin Installer (1.0.2) — 09 February 2
Postby thomthom » Thu Feb 09, 2012 1:37 pm
Version 1.0.2
  • Fixed: Installed RB files are now loaded after installation - avoiding restart.
PluginStore Author
PluginStore Author
Postby thomthom » Thu Feb 09, 2012 1:38 pm
newrui wrote:Hello. Any chance for something for us mac users?
? This plugin should be usable for OSX users... Are you getting errors?
PluginStore Author
PluginStore Author
Postby Dave R » Thu Feb 09, 2012 1:44 pm
Thomas, it works fine on Mac for me.
Global Moderator
Postby thomthom » Thu Feb 09, 2012 1:50 pm
Thanks Dave. I'd be surprised if it didn't. Now we can only ponder what the question was related to...
PluginStore Author
PluginStore Author
Re: [Plugin] Simple Plugin Installer (1.0.3) — 15 February 2
Postby thomthom » Wed Feb 15, 2012 1:19 pm
Version 1.0.3
  • Added: RBS support.
PluginStore Author
PluginStore Author
Postby guanjin » Mon Feb 20, 2012 12:46 pm
thomthom wrote:Version 1.0.3
Load error version SU8M2
I come from China, is to learn
guanjin
Postby thomthom » Mon Feb 20, 2012 12:49 pm
That doesn't seem to be related to this plugin. It refer to a "window style.rb" plugin that tries to load "windows/api.rb".
PluginStore Author
PluginStore Author
Postby Dave R » Mon Feb 20, 2012 1:28 pm
Probably the plugin by dukejazz.
Global Moderator
Postby guanjin » Mon Feb 20, 2012 1:37 pm
Dave R wrote:Probably the plugin by dukejazz.
Thank you, problem solved! Windows plug-in is not clean, delete
guanjin
Postby Iceonfire » Thu Mar 01, 2012 2:37 am
I keep getting the message windows cannot open this file. When I try to have it select from a list of programs, it takes me to a bunch of PC cleaner sites. Any further direction?
Iceonfire
Postby Gaieus » Thu Mar 01, 2012 4:19 am
Hi Katie,
You do not need to open or run these rb files (but if you are interested, open them with notepad as they are simple text files).
Simply copy the file into your plugins folder:
C:\Program Files\Google\Google SketchUp 8\Plugins
or
C:\Program Files (x86)\Google\Google SketchUp 8\Plugins
on a 64 bit Windows, restart SketchUp and you are done.
Some more complex plugins consist of several files so they are usually distributed zipped in an archive. See this topic how to deal with them:
viewtopic.php?f=323&t=35746
Cheers and welcome!
Postby thomthom » Thu Sep 06, 2012 5:27 pm
Changed the download to be a RBZ file only - and with screenshot description of how to install from within SketchUp.
PluginStore Author
PluginStore Author
Postby BlueAngel4 » Thu Nov 15, 2012 8:46 am
Thanks man! :D
BlueAngel4
Re: [Plugin] Simple Plugin Installer (1.1.0) — 03 December 2
Postby thomthom » Mon Dec 03, 2012 2:06 pm
Version 1.1.0
Added guard against VirtualStore under Windows.
PluginStore Author
PluginStore Author
Postby FortGreene » Mon Dec 24, 2012 1:21 pm
Hi Thomas,
I am brand new to SketchUp, so forgive me for having no idea what I am doing! I have been reading through the forums with all the amazing plugins available, so I am anxious to get started. First plugin in I want to load is this one for sure. I followed your step by step install instructions, easy enough, but SketchUp is not accepting the plugin. It says:
"SketchUp was unable to install the Extension you have chosen for some unknown reason.
Consult your Extension's documentation for additional help."
I am using Mac SketchUp Pro 8. Any ideas? Am I missing something?
Thanks!
Chris
FortGreene
Postby TIG » Mon Dec 24, 2012 1:45 pm
@Chris
Do you have full read/write permissions to your 'plugins' folder?
If not you will need to fix them.
Here’s how I believe you modify permissions on MAC OSX, using the 'Info' window...
[I'm on a PC !]
  • While using an 'administrator account'...
  • Click the folder's icon to select it.
  • From the 'File' menu, select 'Get Info'.
  • A dialog appears.
  • Click the 'disclosure triangle' next to 'Sharing & Permissions' to display permissions for the selected folder.
  • Click the 'lock' and 'authenticate' buttons as needed.
  • Use the menus next to 'users and groups' to change the permissions to 'read+write' for you [and
  • everyone else depending on your setup].
  • Use the 'cog' button to apply the changes to all contained files and subfolders/files as well...
  • When you’re finished, close the 'Info' window.
  • The changes are now current.
On a MAC the correct folder path should be:
macintosh HD//Library/Application Support/Google SketchUp 8/SketchUp/plugins
Note this is NOT the similar 'user' one...
Global Moderator
Postby FortGreene » Mon Dec 24, 2012 2:26 pm
Thank you TIG for a prompt response. I will try this today and it sounds like it should work.
While I have your attention, looking through your posts about the plugin you created for work planes, I don't see the actual download for version 2.3 or any previous version? Are the actual plugins you create in a different part of the forum/ site? Hen I clock on the corresponding link to the updated version, it just goes back to the same thread.
Tks
C
FortGreene
Postby TIG » Mon Dec 24, 2012 2:55 pm
Most plugins have their download link in their thread's first post, usually it's at the end of that post.
'WorkPlane' is no exception.
See viewtopic.php?p=274345#p274345
Look at the end of that post and there's the archive WorkPlane23.zip to download and install... It's been successfully downloaded 3,088 times !
A ZIP archive set of files etc is easily installed using the appropriate 'Simple Installer' option...
Global Moderator
Postby FortGreene » Mon Dec 24, 2012 3:18 pm
Awesome. Thanks again TIG! I'll make sure to look for the .zip file.
FortGreene
Postby thomthom » Mon Dec 24, 2012 6:00 pm
What version of SketchUp do you have installed? Do you have the latest maintainense release - released last week? It mentioned it fixed from faulty permission issues.
PluginStore Author
PluginStore Author
Postby JGA » Sun Dec 30, 2012 12:44 pm
Thanks very much for the update. I found the original version worked very well.
Regards,
JGA
JGA
Postby archxcalibur1992 » Fri Mar 29, 2013 5:27 pm
Hey guys,
For some reason, the "Install Extension" option is not available to me.
Any fix for this? otherwise how do i go around installing the plugin?
Im using Windows 7 64-bit, Google Sketchup 8 Pro.
Attached a screenshot of the problem
archxcalibur1992
Postby Gaieus » Fri Mar 29, 2013 9:35 pm
Please, make sure you update your SU installation to the latest build. This was introduced during one of the SU 8 maintenance releases. You apparently have an older version.
Postby Dave R » Fri Mar 29, 2013 9:52 pm
I believe the option was introduced with the second maintenance release. There have been three more since.
Didn't you get at least one notification that there is a new version of SU8?
Global Moderator
Postby thomthom » Fri Mar 29, 2013 10:31 pm
It was added in M2 - hence the requirement listing SU8M2.
Firewalls might block the update notifications. Our office does this. All though, when the firewall was more relaxed, I noticed that most uses just clicked away the notification. Messagebox-blindness.
PluginStore Author
PluginStore Author
Postby archxcalibur1992 » Sat Mar 30, 2013 12:18 am
Thank you guys. Apparently my "check for updates" option in preferences was unchecked.
And till now i have been using sketchup without ever facing issues so never realized updates have come.
Thank you ThomThom, I finally managed to get your shell plugin working, it's been really useful.
I'm glad to have joined this community, has already helped me a lot with my modelling work.
Looking forward to give some input from my side too :)
On a side note, I'm experiencing issues with sketchup becoming a little slower, i mean its lagging a little after the update, any input on this guys?
archxcalibur1992
Postby thomthom » Sat Mar 30, 2013 8:55 am
Could be that you have run into issues with messed up toolbar registry items. Are you comfortable navigating the registry?
PluginStore Author
PluginStore Author
Postby archxcalibur1992 » Sun Mar 31, 2013 5:19 am
Actually, I have no idea how to edit anything regarding the registry. But then I'm a fast learner.
Anyways the issue seems to have gone now after i restarted my laptop.
archxcalibur1992
PreviousNext
Return to Plugins
Users browsing this forum: Davidjr and 14 guests
