[Plugin] FredoTools - v4.0b - 06 Dec 20Re: [Plugin] FredoTools - v4.0a - 17 mai 20Bonjour,
Je n'arrive pas à lancer votre plugin, L'erreur ci-dessous s'affiche lors du lancement de sketchup : Auriez vous une solution à me proposer ? Cordialement Erreur de chargement du fichier Fredo6_!LibFredo6.rb Error: #<Errno::EACCES: Permission denied @ rb_sysopen - C:/Users/ST1DCE~1/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles/LibFredo6Trace_17_1590444009629.txt> c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:113:in `initialize' c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:113:in `open' c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:113:in `log' c:/users/sté/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:166:in `startup' C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:65:in `process' C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:72:in `<module:LibFredo6_Loader>' C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>' Erreur de chargement du fichier Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:81:in `-' C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:81:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require' C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in `<module:Fredo6>' C:/Users/sTé/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in `<top (required)>' Re: [Plugin] FredoTools - v4.0a - 17 May 20You have an accented character in your Windows user-name:
c:/users/sté/appdata/... This used to be the kiss-of-death to older Ruby versions, but with the newer 'encode' methods most user's paths can be re-encoded into a 'Ruby-safe' format... Clearly something is going wrong ! I'm sure that Fredo will have ideas, and a solution... Watch this space... Vous avez un caractère accentué dans votre nom d'utilisateur Windows: c:/users/sté/appdata/... Auparavant, c'était le baiser de la mort pour les anciennes versions de Ruby, mais avec les nouvelles méthodes d'encodage, la plupart des chemins de l'utilisateur peuvent être ré-encodés au format 'Ruby-safe' ... De toute évidence, quelque chose ne va pas! Je suis sûr que Fredo aura des idées et une solution ... Surveillez cet endroit... TIG
Ok, I've now installed LibFredo v9.5k from the Sketchucation store which says it's OK for SU versions up to 2016. When Skethcup restarts, I get a dialog saying: "This legacy version of LibFredo6 can ONLY be used for Sketchup version prior to SU2016" This implies: new LibFredo only for SU >=2017 legacy LibFrdeo only for SU <= 2015 No provision for SU2016?!? I look in Fredo6_!LibFredo6.rb and see one of the first the lines is: if Sketchup.version.to_i < 16 Thinking this was a typo I edited it to test for '< 17' and now the result is: "Wrong installation: Folder Fredo6_!LibFredo6 is missing in <my plugins location>" I can confirm the folder is present in the location that it's complaining about. I'm not sure what's going on here - any help appreciated. Re: [Plugin] FredoTools - v4.0a - 17 May 20What is your "plugins location"? What version of SketchUp are you using? Please complete your profile.
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] FredoTools - v4.0a - 17 May 20@CTH1963,
Thanks for signaling this problem. I have updated the Prior2017 - LibFredo6 - Archived version on the Sketchucation Extension Store. Initially, I thought I could exclude SU2016 from legacy, but there are other elements that will be deprecated in Sketchup also in this version. So I ended up to consider Legacy all SU versions <= 2016. Fredo
Fredo, I have 2019 and the problem remains. Re: [Plugin] FredoTools - v4.0a - 17 May 20@Avex
Your problem is related to permission of Sketchup to access the AppData directories.
I guess this is related to setting the proper security parameters. Fredo
As Fredo says it's caused by your computer not having permissions set up correctly. This is usually because the user double-clicked the installer's exe file to 'Run' it. You can do a 'Repair' as follows... While logged into Windows as your normal user-account, ensure that SketchUp is closed. Find the SketchUp installer's exe file - usually in your Downloads folder ? Select the installer's exe file's icon and right-click > context-menu > "Run as administrator" When prompted choose "Repair" [note that for a brand new installation that would be "Install"]. When it completes retry and seem if the permissions are now set right... Sometimes permissions to extension's own Temp files like this can be messed up and you need to delete the folder: C:/Users/ST1DCE~1/AppData/Local/Temp/Fredo6_LibFredo6_TemporaryFiles When SketchUp is next started it'll be recreated with good permissions These folders are hidden, but pasting C:/Users/ST1DCE~1/AppData/Local/Temp/ in a Windows Explorer path-bar should take you there... TIG
Plugin folder: c:\Users\Chris\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins So you can see the Sketchup version is 2016. The permissions on the ../Appdata/.. tree of directories is 'Full Control' for 3 users: SYSTEM Chris (me - member of Users and Administrators) Administrators So I can't imagine that Sketchup should have any problems with accessing the plugins folder - it never has in the past 4 years & it's running on the same PC for all that time. I'll try applying the updated build Fredo mentions below. Thanks for all the suggestions. Re: [Plugin] FredoTools - v4.0a - 17 May 20
Update: Installing the updated plugin (via sketchucation Plugin Store extension) still results in the dialog "Wrong installation..." per my previous reply. I can see the Fredo6_!LibFredo6 folder and associated Fredo6_!LibFredo6.rb file is present in the plugins directory. @Fredo, I have nothing in Appdata/local/temp with "Fredo" in it's name but cleared all anyway with no difference in result. BTW, can you pls explain how to get the error log example quoted in your reply? Thx. Solved - Re: [Plugin] FredoTools - v4.0a - 17 May 20
I think I found the issue: The line below in Fredo6_!LibFredo6.rb
selects the .rbe file which doesn't exist - the .rbs file *does*. Changing the version test to >=17 solved the problem. Thanks everyone for your attention to the issue. Re: [Plugin] FredoTools - v4.0a - 17 May 20FWIW, there's also a version test in Fredo6_RoundCorner.rb (v3.3a):
that should be changed to '<= 16'... @Fredo FYI I tried installing FredoCorner v1.8b which lists the only dependency as LibFredo6 9.1b (archive legacy ver I have installed is 9.5k) but it complains that SU2017 or newer is required. The 'More Info' page says it should work for SU2016 and above... Cheers, Chris. Re: [Plugin] FredoTools - v4.0a - 17 May 20@CTH1963
If you run Sketchup SU2016, then you MUST use the legacy versions of my plugins. There are here. Fredo
Re: [Plugin] FredoTools - v4.0a - 17 May 20Hi!
Is it possible with Report On Areas to auto-refresh calculation when selection is changed? Re: [Plugin] FredoTools - v4.0a - 17 May 20
The calculation of the report may take time, in seconds. So, an automatic recalculation on any change of a selection could be counterproductive, as you may want to select several objects in a row. That's why currently ReportArea just highlight the Refresh button in Red when a change of selection takes place.
Still, I think this could be an option. Not a default one, but an available setting. I personally use this tool for low number of faces and with fast computer. Auto-recalculation would not be counterproductive for me. But it's just a suggestion ![]() Re: [Plugin] FredoTools - v4.0b - 06 Dec 20NEW RELEASE: FredoTools v4.0b - 06 Dec 20
Requirement: LibFredo6 v10.4b or above FredoTools 4.0b is a minor release for ReportLabelArea, offering an option for automatic refresh of the reports. ------------------------------------------- See FredoTools plugin home page for Download. See also main post of this thread for User Discussion. Fredo
Here it is.... The option is in the Default Parameters. Fredo
Re: [Plugin] FredoTools - v4.0a - 17 May 20Thank you reeely much! You are fantastic ![]() |
Users browsing this forum: junior_ek and 12 guests
