[Plugin] FredoTools - v3.8c - 10 Feb 20
Re: [Plugin] FredoTools - v3.8a - 18 Nov 19
Postby fredo6 » Thu Jan 02, 2020 3:55 pm
rv1974 wrote:Take a look at TT's Edge tools (last 5 commands).
https://sketchucation.com/pluginstore?pln=tt_edgetools
But then tt_edgetools does the job.
Do I miss something?
Or do you want to keep the original curve?
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Thu Jan 02, 2020 5:52 pm
CurviShear generates right 'ramp' curve, TT's 'Make colinear' doesn't. That's the main difference (:
The only CurviShear's weak link is UI.
rv1974
Postby fredo6 » Thu Jan 02, 2020 11:01 pm
rv1974 wrote:CurviShear generates right 'ramp' curve, TT's 'Make colinear' doesn't. That's the main difference (:
Ok. Understood. I put it on my list, but this is what I mean by 'interactive'.
fredo6
PluginStore Author
PluginStore Author
Fredo Round Corner - Face with an image poor results
Postby dalenster » Fri Jan 03, 2020 12:14 am
Hello, Not sure if I'm posting in the correct location. I have a shape with an image as the face. I'm trying to round the corners and have a smooth transition. However, I'm getting the following results. Is there a workaround, I'm I doing something wrong. I don't think this was a problem in the previous version.
dalenster
Re: Fredo Round Corner - Face with an image poor results
Postby fredo6 » Fri Jan 03, 2020 9:24 pm
dalenster wrote:I'm trying to round the corners and have a smooth transition. However, I'm getting the following results. Is there a workaround, I'm I doing something wrong. I don't think this was a problem in the previous version.
It would be helpful to say which tool you use (RoundCorner, FredoCorner, or something else).
None of these tools have the objective to ensure texture continuity. In general, texture application should be done after the geometry is generated.
Anyway, posting the model would help.
fredo6
PluginStore Author
PluginStore Author
Postby kubap » Thu Jan 30, 2020 5:22 pm
Hi Fredo,
It's a great plugin, especially ThruPaint. Thank you :)
Is it possible to add an option to paint algong the shortest/lognest sides when painting whole groups/components?
It would be great for example for wood furniture so the texture always goes along the long side of a plank. For example when you have a cupboard made of many planks every plank is textured along the longer sides automatically, as it is in real furniture.
Now it's kind of random and the only way is to correct it manually face after face.
kubap
Postby fredo6 » Thu Jan 30, 2020 8:01 pm
kubap wrote:Is it possible to add an option to paint along the shortest/longest sides when painting whole groups/components?
Unfortunately, Sketchup does not provide any UV control for painting objects (groups or components). The positioning of textures is based on axes and position of the objects.
So, if you want control of orientation, you have to paint at the face level.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v3.8b - 05 Feb 20
Postby fredo6 » Wed Feb 05, 2020 9:52 pm
NEW RELEASE: FredoTools v3.8b - 05 Feb 20
Requirement: LibFredo6 v9.5e or above
FredoTools 3.8b is a minor release for ReportLabelArea, allowing to count the material coming from object containers, when faces are painted with the dedfault material.:
See FredoTools plugin home page for Download.
See also main post of this thread for User Discussion.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby bharralure » Sat Feb 08, 2020 11:21 am
Bonjour Fredo,
Je rencontre un problème avec "Volume Solide", aussi bien dans SU19 que SU20.
Je joins un Gif qui, j'espère sera plus explicite que ma mauvaise prose.
bharralure
Postby fredo6 » Sat Feb 08, 2020 4:49 pm
bharralure wrote:Je rencontre un problème avec "Volume Solide", aussi bien dans SU19 que SU20.
Je ne comprends pas trop ce qui se passe dans le Gif. Le modèle me serait plus utile.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby bharralure » Sun Feb 09, 2020 11:27 pm
Bonjour Fredo,
Je viens seulement de prendre connaissance de votre réponse, et je vous en remercie. Je ne comprends pas pourquoi je na'ai pas été automatiquement alerté ?
Je cherche à connaître le volume de A (qui doit être de 0,00096 m³) que l'on peut obtenir en déduisant C (0,08502 m³) de B (0,08502 m³).
"Volume Solides" indique 0,04080 m³ du fait de la présence de "96 faces orientées incorrectement", même après avoir utilisé "AutoReverseFaces", et alors que "Solid Inspector²" ne trouve pas d'erreur.
Si j'inverse les faces sur C, "Volume Solides" trouve 241 Faces orientées incorrectement (ce qui est normal), et indique un volume faux. "AutoReverseFaces" corrige l'erreur parfaitement, et dans ce cas "Volume Solides" indique une valeur correcte.
Ma question est donc : pourquoi cela ne fonctionne pas sur A ?
Je viens de me souvenir qu'une version antérieure avais posé problème pour la volume des pièces crées "en miroir" (je n'ai pas retrouvé le post). Je viens donc de le rajouter à mon modèle que joins, le résultat est également faux.
Test_VolumeSolide.19.skp
bharralure
Re: [Plugin] FredoTools - v3.8c - 10 Feb 20
Postby fredo6 » Mon Feb 10, 2020 10:01 am
NEW RELEASE: FredoTools v3.8c - 10 Feb 20
FredoTools 3.8c is a minor release for SolidVolume, to fix and issue whereby the volume could be sensititive to the orientation of faces.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby bharralure » Mon Feb 10, 2020 10:29 am
Bonjour Fredo,
Merci pour cette mise à jour rapide et efficace.
Je viens de tester sur SU19 et SU20, et tout est rentré dans l'ordre, parfait.
bharralure
Postby volker72 » Wed Feb 12, 2020 5:37 pm
Hello Fredo,
is it possible to do the same with length as ReportLabelArea does with faces.
Volker
volker72
Postby fredo6 » Thu Feb 13, 2020 7:45 pm
volker72 wrote:is it possible to do the same with length as ReportLabelArea does with faces.
You need to tell which length...length of edges, length of object bounding boxes, ...
fredo6
PluginStore Author
PluginStore Author
Postby volker72 » Tue Feb 18, 2020 2:00 pm
I am interested in the length of edges. The goal is to add up these lengths by layers. That would be wonderful.
volker72
Postby jmdrla » Tue Mar 03, 2020 5:00 pm
I loaded the FredoTools-v3.8c this morning in my SketchUp Pro along with the required library. I have tried to add the tools to the program about ten times now and it is showing up in the extension manager as installed and activated. Unfortunately it is not in my extension menu and I cannot access the tools. When I look at the details for the tools on the extension manager I can see that it is signed but there is no other information in the details. I am assuming that this is not a version that can be used on SU2020 even though it shows as compatible with 2020. What is the issue?
OK I should have used the word tools instead of extensions. However the program is not in the tools menu. I did restart the SU2020 when I did the install and nothing appeared in my tools menu. I am uploading a screen shot so you can see what I have
jmdrla
Premium Member
Premium Member
Postby Dave R » Tue Mar 03, 2020 5:07 pm
jmdrla wrote:Unfortunately it is not in my extension menu and I cannot access the tools... What is the issue?
First things first. FredoTools aren't supposed to show up in the Extension menu. They are supposed to show up in the Tools menu. Did you look there? Also did you restart SketchUp after installing the extensions?
There's also a toolbar that can be made visible via View>Toolbars.
jmdrla wrote:I am assuming that this is not a version that can be used on SU2020 even though it shows as compatible with 2020.
Not so. FredoTools work just fine in SketchUp 2020. Here is a screen shot from SU2020 showing the menu.
Out of curiosity, when you installed SketchUp 2020, did you right click on the downloaded installer file and choose Run as administrator? BTW, maybe you could update your profile. It still shows you are using SU2017.
Global Moderator
Postby edjul04 » Mon Mar 30, 2020 10:10 pm
If I generate area report, it shows all areas on the plugin screen but if I export to CSV it gives me an error and only shows the information of one of the entities.
How can I fix the mistake?
edjul04
Postby fredo6 » Wed Apr 01, 2020 1:14 pm
edjul04 wrote:If I generate area report, it shows all areas on the plugin screen but if I export to CSV it gives me an error and only shows the information of one of the entities.
What is the error?
fredo6
PluginStore Author
PluginStore Author
Postby edjul04 » Wed Apr 01, 2020 2:03 pm
Thanks!
This is an example of what was happening.
I re-installed sketchup and the plugin without success, I was using SketchUp2019. Yesterday I upgraded my license to SketchUp2020 and the problem was fixed.
edjul04
Postby fredo6 » Wed Apr 01, 2020 8:38 pm
Could you post or PM me the model so that I have a closer look.
fredo6
PluginStore Author
PluginStore Author
Previous
Return to Plugins
Users browsing this forum: Bing [Bot], ccastaneda, Google Bot, gulcintuba, JonFar, laforestf and 13 guests
