[Plugin] FredoTools - v3.8a - 18 Nov 19
Re: [Plugin] FredoTools - v3.4a - 12 Apr 19
Postby fredo6 » Mon Jun 03, 2019 9:14 pm
designerbursa wrote:solid volume command. It would be nice to have a report window that shows the dimensions of the part I selected on the screen.
I think it should be a different plugin, because the request does apply to objects which are non-solid.
By the way, there may exist already some plugins giving the dimension of the bounding box, which I assume is what you want.
Fredo
PS: indeed, there is no problem to adding this feature to Solid Volume, but that would be restrictive.
fredo6
PluginStore Author
PluginStore Author
Postby designerbursa » Tue Jun 04, 2019 12:28 am
Fredo
This is exactly what I'm looking for "element stat" :)
Sorry, now I noticed.
Thanks FREDO! ..
designerbursa
Postby designerbursa » Tue Jun 04, 2019 12:29 am
Fredo
This is exactly what I'm looking for "ElementStats" :)
Thanks FREDO! ..
designerbursa
Postby Loiseau » Thu Jun 06, 2019 9:14 pm
Am intéres to have the extention "VisuHole" from Fredo6. You thing is possible :?:
Loiseau
Postby TIG » Thu Jun 06, 2019 9:48 pm
Loiseau wrote:Hi,
You need to download the appropriate RBZ files for that extension by Fredo, and his support Lib, from the SketchUcation PluginStore.
https://sketchucation.com/pluginstore?pln=VisuHole
https://sketchucation.com/pluginstore?pln=LibFredo6
Then install the two RBZ files - using the SketchUp Extension Manager > Install [red] button...
Then restart SketchUp to sync everything.
Then use the tool as explained in the usage notes...
Vous devez télécharger les fichiers RBZ appropriés pour cette extension de Fredo, et son support Lib, à partir du SketchUcation PluginStore.
Installez ensuite les deux fichiers RBZ - à l'aide du bouton SketchUp Extension Manager> Installer [rouge] ...
Ensuite, redémarrez SketchUp pour tout synchroniser.
Ensuite, utilisez l'outil comme expliqué dans les notes d'utilisation ...
Global Moderator
Re: [Plugin] FredoTools - v3.5a - 12 Sep 19
Postby fredo6 » Thu Sep 12, 2019 9:41 pm
NEW RELEASE: FredoTools v3.5a - 12 Sep 19
Requirement: LibFredo6 v9.1b or above
FredoTools 3.5a introduces the ColorBySlope tool, which create a color mapping for a terrain mesh based on the slope of its faces.
See FredoTools plugin home page for Download.
See also main post of this thread for User Discussion.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Oxer » Thu Sep 19, 2019 5:25 pm
New Spanish Language file (added Color by Slope).
FredoTools_ES.zip
http://www.oxervision.blogspot.com/
Oxer
Postby fredo6 » Thu Sep 19, 2019 11:05 pm
Oxer wrote:New Spanish Language file (added Color by Slope).
Thank you. it will go into the next release soon (along with a new tool).
Fredo
fredo6
PluginStore Author
PluginStore Author
Fredo's ThruPaint and ESC key
Postby dedmin » Sun Sep 29, 2019 3:54 am
dedmin
Re: [Plugin] FredoTools - v3.6a - 16 Oct 19
Postby fredo6 » Wed Oct 16, 2019 11:06 pm
NEW RELEASE: FredoTools v3.6a - 16 Oct 19
Requirement: LibFredo6 v9.2a or above
FredoTools 3.6a is a major release which introduces:
  • ColorByAltitude tool, which create a color mapping for a terrain mesh based on the altitude of its faces.
  • ColorPaint tool, which is a configurable Color Selector.
  • A new view 'Outliner' in ReportLabelArea tool, with a hierarchical, expandable tree of groups and components with their individual areas.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby volker72 » Thu Oct 17, 2019 2:42 pm
i have a question for you.
I calculate thermal bridges (building physics). I place the edges on different layers (edges = thermal bridges).
A report that outputs the length of the edges according to layers, like the ReportLabelArea does with areas, would be great.
Is this easy to do?
I could imagine that other users could also use this ReportLabelLenght.
You are doing a great job, thank you very much and many greetings
Volker
volker72
Re: [Plugin] FredoTools - v3.7a - 02 Nov 19
Postby fredo6 » Sat Nov 02, 2019 10:10 am
NEW RELEASE: FredoTools v3.7a - 02 Nov 19
Requirement: LibFredo6 v9.3a or above
FredoTools 3.6a is a major release which introduces evolutions in:
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v3.8a - 18 Nov 19
Postby fredo6 » Tue Nov 19, 2019 12:00 am
NEW RELEASE: FredoTools v3.8a - 18 Nov 19
Requirement: LibFredo6 v9.4a or above
FredoTools 3.8a is a major release which introduces:
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby pbs1962 » Thu Nov 21, 2019 7:07 pm
Looking for help with curvishear..
Just started working with this awesome plugin, but I must be doing something wrong.
When I run this to build a ramp (two concentric semicircles) the model appears correct but it remains flat...I've tried various views, changing the height in case it was a scale problem...but no luck...I can post a video of my steps if that helps.
Does anyone have a fix or suggestions for where to get more info?
pbs1962
Postby Dave R » Fri Nov 22, 2019 1:35 pm
How about posting your SKP file with the ramp ready to run Curvishear?
Global Moderator
Postby pbs1962 » Fri Nov 22, 2019 3:34 pm
pbs1962 wrote:Looking for help with curvishear..
Here's the skp file.
pbs1962
Postby Dave R » Fri Nov 22, 2019 5:29 pm
This is what I see when I open your file. The geometry sort of looks like you're looking down on the ramp but its oriented in the vertical red/blue plane. The extension is extending up in the blue direction as it's supposed to do.
If you want the ramp shape, lay the C-shape down on the ground plane as I've done on the right.
FWIW, if you are having a difficult time keeping track of which way is up in SketchUp, you can either edit the style to include sky and horizon or choose a different style that already has it.
Global Moderator
Postby dangeruss03 » Sun Dec 01, 2019 7:37 am
I Just download it, i can't use Curvishear properly. i try to make ramp for my basement but it seems like something wrong. i don't know what happen and what to do. please help if anybody knew something
dangeruss03
Postby Dave R » Sun Dec 01, 2019 2:20 pm
dangeruss03 wrote:i try to make ramp for my basement but it seems like something wrong.
Your image doesn't show. Please attach the SKP file so we can see what you are trying to do and exactly how you have it set up.
Global Moderator
Postby dangeruss03 » Sun Dec 01, 2019 2:40 pm
Ramp_Trial.skp
this is the file thanks
dangeruss03
Postby Dave R » Sun Dec 01, 2019 3:13 pm
I'm not sure what you are doing wrong. I do see that all of your curves are exploded to their individual segments. I welded the curves back together and ran Curvishear. It worked fine for me.
Maybe you can review the usage instructions here and try again. It would also be helpful if you outline the exact steps you are using as you are setting up for and running Curvishear.
Global Moderator
Postby dangeruss03 » Sun Dec 01, 2019 5:13 pm
Dave R wrote:I'm not sure what you are doing wrong. I do see that all of your curves are exploded to their individual segments. I welded the curves back together and ran Curvishear. It worked fine for me.
But how to weld all the lines, i tried to use super weld plugin and it work just like that
dangeruss03
Postby Dave R » Sun Dec 01, 2019 5:19 pm
I used TIG-Weld to do it but I only welded the curves. I did not weld the entire perimeter. Why are the curves exploded in the first place? Maybe you should redraw them so they aren't exploded.
Global Moderator
Postby oo7wazzy » Wed Dec 04, 2019 10:50 am
HI Fredo
I downloaded the LibFredo6 package for Sketchup 19 on MAC. It is loaded and installed, but I can't see any of the tools. It is showing in the Window drop down menu but nowhere else that I can see. Have I done something wrong in the installation ? In the extension manager it is Enabled. Any help would be appreciated.
oo7wazzy
Postby Dave R » Wed Dec 04, 2019 1:29 pm
Have you quit and restarted SketchUp after installing?
Fredo Tools shows in the Tools menu. Do you see that?
Global Moderator
Postby rv1974 » Thu Jan 02, 2020 11:05 am
Many years I dream of ability to explicitly move the end vertex, run CurviShear and get desired slope (it means curve as required condition has to be ditched).
rv1974
Postby fredo6 » Thu Jan 02, 2020 12:31 pm
rv1974 wrote:Many years I dream of ability to explicitly move the end vertex, run CurviShear and get desired slope (it means curve as required condition has to be ditched).
Unless I am wrong, you can do it natively
1) Launch the Move tool with no selection
2) Hover an extremity, click and drag vertically.
3) The curve should deform itself
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Thu Jan 02, 2020 12:57 pm
It won't happen (the curve will be deformed in plan view and it won't even remotely resemble a ramp). That's why CurviShear was created.
rv1974
Postby fredo6 » Thu Jan 02, 2020 2:07 pm
rv1974 wrote:It won't happen (the curve will be deformed in plan view and it won't even remotely resemble a ramp). That's why CurviShear was created.
In short, you would like an interactive version of CurviShear....
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Thu Jan 02, 2020 3:45 pm
No (although I wouldn't disagree). Take a look at TT's Edge tools (last 5 commands).
https://sketchucation.com/pluginstore?pln=tt_edgetools
I'm talking of CurviShear to adopt the similar way of input.
I wouldn't call it interactive. I just feed Curvishear real geometry (bunch of connected edges or polyline) and get result without any input in modal window.
rv1974
PreviousNext
Return to Plugins
Users browsing this forum: suzylee37 and 7 guests
