[Plugin] FredoTools - v4.0a - 17 May 20
Re: [Plugin] FredoTools - v3.1e - 01 Oct 17
Postby Oxer » Fri Nov 03, 2017 8:18 pm
The FredoTools v3.1e works fine on OS X 10.11.6 & SU2016, the issue is with SU2017.
http://www.oxervision.blogspot.com/
Oxer
Postby fredo6 » Fri Nov 03, 2017 9:21 pm
Oxer wrote:The FredoTools v3.1e works fine on OS X 10.11.6 & SU2016, the issue is with SU2017.
Even more weird.
Did you try with double-click on a textured face?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Oxer » Fri Nov 03, 2017 10:32 pm
Yes, but this doesn't resolve the issue. Don't worry Fredo, it's a little problem but it doesn't interrupt my workflow.
Oxer
Postby fredo6 » Fri Nov 03, 2017 10:44 pm
Just try to understand what can be caused by
- a difference between Mac and Windows
- a difference between SU2016 and SU2017
To you get a stable gizmo when pressing Enter on a textured face ?
What happen if you click down, release without moving the mouse ?
fredo6
PluginStore Author
PluginStore Author
Postby Oxer » Sat Nov 04, 2017 1:34 am
Yes, If I press Enter over a textured face the gizmo is stable. When click down the gizmo appears but it disappear immediately (1 second).
Oxer
Re: [Plugin] FredoTools - v3.1g - 11 Nov 17
Postby fredo6 » Sat Nov 11, 2017 12:50 pm
NEW RELEASE: FredoTools v3.1g - 11 Nov 17
FredoTools 3.1g fixes a bug in FredoTools::ReportLabelArea, for the CSV export in non-English languages.
See FredoTools plugin home page for Download.
See also main post of this thread for User Discussion.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Mousa_SA » Thu Dec 14, 2017 12:42 pm
Hello Fredo,
Is the thrupaint bugsplat fixed in "FredoTools v3.1g - 11 Nov 17" release?
It still occur on some of my machines!
Any suggestion is much appreciated.
Mousa_SA
Re: [Plugin] FredoTools - v3.2a - 24 Feb 18
Postby fredo6 » Sun Feb 25, 2018 12:39 am
NEW RELEASE: FredoTools v3.2a - 24 Feb 18
FredoTools 3.2a is about bug fixing and introduction of FaceTriangulator.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v3.2b - 27 Feb 18
Postby fredo6 » Wed Feb 28, 2018 12:01 am
NEW RELEASE: FredoTools v3.2b - 27 Feb 18
FredoTools 3.2b is about a small adjustment in FaceTriangulator and some bug fixing.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Feb 28, 2018 6:37 am
May I ask, what is the main purpose of triangulator?
rv1974
Postby fredo6 » Wed Feb 28, 2018 8:53 am
rv1974 wrote:May I ask, what is the main purpose of triangulator?
Just to divide a face into triangles, which is useful in some situations. Actually FaceTriangulator is just a byproduct of another plugin to come.
Note that there exists other plugins for face trinagulation (at least one by TIG). FaceTriangulator gives the same result, but you can impose triangulation points as Construction Points on the face.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Mousa_SA » Sat Mar 03, 2018 7:48 pm
fredo6 wrote:NEW RELEASE: FredoTools v3.2b - 27 Feb 18
Fredo
Fredo, I installed this update, but SketchUp still crash when I launch the Thrupaint.
Mousa_SA
Postby fredo6 » Sat Mar 03, 2018 8:58 pm
Mousa_SA wrote:Fredo, I installed this update, but SketchUp still crash when I launch the Thrupaint.
Which version of Sketchup? Your profile says SU2016.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Mousa_SA » Sat Mar 03, 2018 11:14 pm
fredo6 wrote:Which version of Sketchup? Your profile says SU2016.
Fredo
That occur on SketchUp 2018 and SketchUp 2017, I didn't test it on 2016.
Mousa_SA
Postby fredo6 » Mon Mar 05, 2018 12:10 pm
I know there is this random bugsplat, but I am unable to reproduce it in my own environment.
If you have it, could you send a report to Sketchup in the bugsplat window, note the bugsplat record number and post or send this crash number to me.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Mousa_SA » Mon Mar 05, 2018 9:40 pm
Fredo
I thought this update has a fix for these random bugsplat. The Bugsplat record number is #37782
I have sent the bugsplat report to you as a PM.
Mousa_SA
Re: [Plugin] FredoTools - v3.2c - 12 Mar 18
Postby fredo6 » Mon Mar 12, 2018 8:56 am
NEW RELEASE: FredoTools v3.2c - 12 Mar 18
FredoTools 3.2c fixes a major bug in the calculation of volume in SolidVolume
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Sun Mar 25, 2018 8:11 am
Fredo, in this particular model reverse\ orient tool fails to exit with saved result. could you take a look? Thanks!
rv1974
Postby fredo6 » Sun Mar 25, 2018 2:33 pm
rv1974 wrote:Fredo, in this particular model reverse\ orient tool fails to exit with saved result. could you take a look? Thanks!
I tried on your model but AutoOrientFaces does the job and performs correctly the reversing.
The issue with your model is that each of the 12 subgroups have a quite large number of faces. In particular the two wheels which have 3,218 faces. The whole model would probably need a rework, because the number of faces seems oversized for a rather boxy shape.
I would probably need to optimize the algorithm. The white screen is just when processing the two wheels.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby JQL » Fri Mar 30, 2018 1:12 am
Hi Fredo,
I've noticed that your tools don't follow the convention for selecting a surface with a single click.
The selection method is assuming two or more faces connected by a hidden edge to be a surface, while sketchup convention assumes a surface to be at least two faces connected by a soft edge.
Is this by design?
Thanks,
João
JQL
Premium Member
Premium Member
Postby fredo6 » Fri Mar 30, 2018 8:58 am
JQL wrote:Hi Fredo,
Is this by design?
Thanks,
João
In general I assume that if you don't see the edge on the screen, the bounding faces are part of the same click-selection. When Geometry Hidden is turned on, then faces behave as separate.
This may not be what the user wants in some occasions; this is why I also have explicit options with palette buttons.
Which tool of FredoTools are you referring to ?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby JQL » Fri Mar 30, 2018 12:26 pm
I'm referring to every tool I guess. I was convinced it had to do with a global selection method defined by LibFredo.
I often require the use of surfaces and treat them as such in Sketchup. But for JPP, reverse/orient faces, or thrupaint, I often had problems and didn't understand why. So I started selectin the surfaces first, with regular sketchup selection tool. So I only recently found out what was happening...
JQL
Premium Member
Premium Member
Postby fredo6 » Fri Mar 30, 2018 2:56 pm
JQL wrote:I'm referring to every tool I guess. I was convinced it had to do with a global selection method defined by LibFredo.
Is this now as you expect?
fredo6
PluginStore Author
PluginStore Author
Postby Rich O Brien » Fri Mar 30, 2018 3:02 pm
Fredo,
Is it possible to add Cast Shadows On/Off to the Face Triangulator tool?
Rich O Brien
Administrator
Postby JQL » Fri Mar 30, 2018 3:32 pm
Not quite. What I would expect is that only with soft edges, two or more faces would be considered surfaces, as in sketchup.
JQL
Premium Member
Premium Member
Postby fredo6 » Fri Mar 30, 2018 3:55 pm
Never noticed for the Hidden?
Can be done, but this impacts everyone that is used to or prefer the current behavior. Indeed, the strng argument is that this is how Sketchup does the selection.
fredo6
PluginStore Author
PluginStore Author
Postby JQL » Fri Mar 30, 2018 4:05 pm
Well... That's a tough one. Make it coherent with Sketchup or keep it as it is for every user sake?
What if people do what I did and don't use the option as they don't quite understand it?
Or what if, following the hidden preferences you have, you would have an option of surface selection method?
JQL
Premium Member
Premium Member
Postby PAragao » Sun Apr 08, 2018 1:57 pm
Hi all,
I think this tool will be my savior since I keep finding mismatches on the edges of my sketch. However, when I try to tell it to fix the edges it gives the error "Cannot create unit vector from zero length vector"
Anyone has an idea how to solve this?
Thanks.
Date: 08-Apr-18 14:45:11
An error occurred in Edge Inspector
Error during Inspection
body_fredotools__edgeinspector.rbe: 3286 -- axes
body_fredotools__edgeinspector.rbe: 3286 -- zero_edge_disolve_edge
body_fredotools__edgeinspector.rbe: 3269 -- block in zero_edge_absorb_final
body_fredotools__edgeinspector.rbe: 3249 -- each
body_fredotools__edgeinspector.rbe: 3249 -- zero_edge_absorb_final
body_fredotools__edgeinspector.rbe: 3379 -- block in zero_edge_resolve
body_fredotools__edgeinspector.rbe: 3367 -- each
body_fredotools__edgeinspector.rbe: 3367 -- each_with_index
body_fredotools__edgeinspector.rbe: 3367 -- zero_edge_resolve
body_fredotools__edgeinspector.rbe: 2706 -- call
body_fredotools__edgeinspector.rbe: 2706 -- block in execute_fixing
body_fredotools__edgeinspector.rbe: 2703 -- each
body_fredotools__edgeinspector.rbe: 2703 -- each_with_index
body_fredotools__edgeinspector.rbe: 2703 -- execute_fixing
body_fredotools__edgeinspector.rbe: 1713 -- robot_fixing_execute_single
body_fredotools__edgeinspector.rbe: 1703 -- robot_fixing_exec
body_fredotools__edgeinspector.rbe: 1686 -- robot_fixing
body_fredotools__edgeinspector.rbe: 1573 -- block in resolver_fixing
lib6operation.rbe: 332 -- call
lib6operation.rbe: 332 -- step_geometry
lib6operation.rbe: 374 -- start_execution
body_fredotools__edgeinspector.rbe: 1573 -- resolver_fixing
body_fredotools__edgeinspector.rbe: 1924 -- block in palette_floating
body_lib6palette.rbe: 3754 -- call
body_lib6palette.rbe: 3754 -- execute_button
body_lib6palette.rbe: 3559 -- onLButtonUp
lib6palette.rbe: 91 -- onLButtonUp
body_fredotools__edgeinspector.rbe: 786 -- onLButtonUp
PAragao
Postby fredo6 » Mon Apr 09, 2018 1:01 pm
PAragao wrote:Hi all,
This looks like a bug (I fixed it). It does mean that you seem to have zero-length edges in your model.
By the way, if you are lucky to have 'ill-edged' models, I am interested for testing EdgeInspector.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v3.2d - 09 Apr 18
Postby fredo6 » Mon Apr 09, 2018 1:26 pm
NEW RELEASE: FredoTools v3.2d - 09 Apr 18
FredoTools 3.2d is about bug fixing in EdgeInspector.
Fredo
fredo6
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: bharralure, cironaka, Google Bot, gormez, maxberg1, oheneba and 8 guests
